BlueScreen wie jetzt weiter
Und was hast du verändert? Bzw. läuft es nun fehlerfrei?
Edit: Die Frage hat sich erledigt...hab´s gesehen (PN) ;).
Hallo!
Ich habe in letzter Zeit viele BlueScreens mit Memory_Management. Hier mal eine Minidump-Datei:
BUGCHECK_STR: 0x1a_5100
CUSTOMER_CRASH_COUNT: 1
DEFAULT_BUCKET_ID: VISTA_DRIVER_FAULT
PROCESS_NAME: ICQ.exe
CURRENT_IRQL: 0
LAST_CONTROL_TRANSFER: from fffff8000312f827 to fffff800030d7740
STACK_TEXT:
fffff880`02a54418 fffff800`0312f827 : 00000000`0000001a 00000000`00005100 fffff6fc`5004bb80 00000000`00000001 : nt!KeBugCheckEx
fffff880`02a54420 fffff800`0310293b : 00000000`00000001 fffff880`02a54580 fffff8a0`09770000 00000000`00000001 : nt! ?? ::FNODOBFM::`string'+0xae27
fffff880`02a54530 fffff800`03208ceb : fffffa80`0395c280 00000000`00001000 00000000`00000011 fffff980`12dc16a8 : nt!MiAllocatePagedPoolPages+0x4bb
fffff880`02a54650 fffff800`0320b6eb : fffffa80`0395c280 00000000`00001000 00000000`00000011 fffff800`030f6237 : nt!MiAllocatePoolPages+0x8e2
fffff880`02a547a0 fffff880`01504881 : 00010000`00000001 00010000`000114e3 fffff8a0`00000000 fffff980`00000000 : nt!ExAllocatePoolWithTag+0x31b
fffff880`02a54890 fffff880`014d0cf6 : fffffa80`06311240 fffffa80`04b5d180 fffffa80`06311240 00010000`000114e3 : Ntfs!NtfsCreateFcb+0x2c9
fffff880`02a54970 fffff880`014f4b04 : fffff880`08d0fac0 fffffa80`03b70790 fffffa80`06311240 00000000`00000000 : Ntfs!NtfsOpenFile+0x1ca
fffff880`02a54b50 fffff880`0145dc0d : fffffa80`06311240 fffffa80`03b70790 fffff880`08d0fac0 fffffa80`06382b00 : Ntfs!NtfsCommonCreate+0xc54
fffff880`02a54d30 fffff800`030cf5c7 : fffff880`08d0fa30 00000000`00000000 00000000`00000000 00000000`00000000 : Ntfs!NtfsCommonCreateCallout+0x1d
fffff880`02a54d60 fffff800`030cf581 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KxSwitchKernelStackCallout+0x27
fffff880`08d0f900 00000000`00000000 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiSwitchKernelStackContinue
STACK_COMMAND: kb
FOLLOWUP_IP:
nt! ?? ::FNODOBFM::`string'+ae27
fffff800`0312f827 cc int 3
SYMBOL_STACK_INDEX: 1
SYMBOL_NAME: nt! ?? ::FNODOBFM::`string'+ae27
FOLLOWUP_NAME: MachineOwner
MODULE_NAME: nt
IMAGE_NAME: ntkrnlmp.exe
DEBUG_FLR_IMAGE_TIMESTAMP: 4cc791bd
FAILURE_BUCKET_ID: X64_0x1a_5100_nt!_??_::FNODOBFM::_string_+ae27
Followup: MachineOwner
0: kd> !analyze -v
* Bugcheck Analysis *
MEMORY_MANAGEMENT (1a)
# Any other values for parameter 1 must be individually examined.
Arguments:
Arg1: 0000000000005100, The subtype of the bugcheck.
Arg2: fffff6fc5004bb80
Arg3: 0000000000000001
Arg4: 0a00000000020070
Debugging Details:
CURRENT_IRQL: 0
STACK_TEXT:
STACK_COMMAND: kb
FOLLOWUP_IP:
MODULE_NAME: nt
Kann mir jemand Helfen? Liegt es an ICQ?
Hmmm, ja das "neue" also nicht die DOS MemTest86+. Ich habe ihn bei 200% mit 0 Errors beendet.
Vielleicht kann es ja sein dass es mit folgendem zusammenhängt:
Denn mein DVD-Brenner wird in Windows nicht mehr erkannt (BIOS noch nicht geschaut) obwohl es noch auf und zu geht.
Also nicht gänzlich kaputt zu sein scheint. Und in der Windows Verwaltung wird ein Datenträger 3 angezeigt der nicht
Initialisiert werden kann.
Jo, das könnte auch sein. Hier war mal ein ähnliches Problem, und die Lösung war ein Wackelkontakt beim SATA-DVD-Kabel ;) Prüf das mal, und dann alle anderen Steckverbindungen gleich mit. Evtl. auch mal das Kabel tauschen.
Softy
Die Stopfehlercodes sind immer die Gleichen (0x1A)? Bei welchen Aktionen treten die Bluescreens auf?
Ist dein System übertaktet?
Mache bitte noch ein paar Screenshots von CPU-Z (Reiter CPU, Mainboard, Memory und SPD).
habe auch so einen Bluescreen.
Habe mal dieses Debugging Tool drüberlaufen lassen.
Code:
1: kd> !analyze -v
SYSTEM_SERVICE_EXCEPTION (3b)
An exception happened while executing a system service routine.
Arguments:
Arg1: 00000000c0000005, Exception code that caused the bugcheck
Arg2: fffff88004aaa817, Address of the instruction which caused the bugcheck
Arg3: fffff88006a248f0, Address of the context record for the exception that caused the bugcheck
Arg4: 0000000000000000, zero.
Debugging Details:
EXCEPTION_CODE: (NTSTATUS) 0xc0000005 - Die Anweisung in 0x%08lx verweist auf Speicher 0x%08lx. Der Vorgang %s konnte nicht im Speicher durchgef hrt werden.
FAULTING_IP:
atikmdag+90817
fffff880`04aaa817 8b4820          mov     ecx,dword ptr [rax+20h]
CONTEXT:  fffff88006a248f0 -- (.cxr 0xfffff88006a248f0)
rax=0000000000000000 rbx=fffffa8003aea840 rcx=fffffa80039f51f0
rdx=0000000000000000 rsi=0000000000000015 rdi=fffffa8003a05010
rip=fffff88004aaa817 rsp=fffff88006a252d0 rbp=fffffa80039f51f0
 r8=0000000000000015  r9=fffff88004e6c970 r10=0000000000000000
r11=fffff88006a25420 r12=0000000000000000 r13=fffffa8002a20480
r14=0000000000000001 r15=0000000000000000
iopl=0         nv up ei pl zr na po nc
cs=0010  ss=0018  ds=002b  es=002b  fs=0053  gs=002b             efl=00010246
atikmdag+0x90817:
fffff880`04aaa817 8b4820          mov     ecx,dword ptr [rax+20h] ds:002b:00000000`00000020=????????
Resetting default scope
BUGCHECK_STR:  0x3B
PROCESS_NAME:  dwm.exe
CURRENT_IRQL:  0
LAST_CONTROL_TRANSFER:  from 0000000000000000 to fffff88004aaa817
STACK_TEXT:
fffff880`06a252d0 00000000`00000000 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : atikmdag+0x90817
FOLLOWUP_IP:
atikmdag+90817
SYMBOL_STACK_INDEX:  0
SYMBOL_NAME:  atikmdag+90817
MODULE_NAME: atikmdag
IMAGE_NAME:  atikmdag.sys
DEBUG_FLR_IMAGE_TIMESTAMP:  4cef1f94
STACK_COMMAND:  .cxr 0xfffff88006a248f0 ; kb
FAILURE_BUCKET_ID:  X64_0x3B_atikmdag+90817
1: kd> !analyze –v
Use !analyze -v to get detailed debugging information.
BugCheck 3B, {c0000005, fffff88004aaa817, fffff88006a248f0, 0}
Probably caused by : atikmdag.sys ( atikmdag+90817 )
@gOOm-xEON: Bei dir trat eine Speicherzugriffsverletzung durch den Grafikkartentreiber auf.
Ist es immer der gleiche Stopfehlercode? Bzw. wird bei den Stopfehlern immer die "atikmdag.sys" angegeben?
Mögliche Lösung: anderen Grafikkartentreiber ausprobieren. Welche Version ist denn bei dir installiert?
hi habe seit ca 3 wochen das problem das der pc immer wieder einfreiert. grade wenn ich spiele spiele, aber auch wenn ich in ff bin oder garnichts mache. meist ist es so das das bild einfriert und die musik im hintergrund dan stottert, manchmal läuft sie aber auch weiter und manchmal erscheint der bildschirm dann nurnoch in schwarz grün. heut hab ich das erste mal nen bluescreen bekommen, warscheinlich weil er bei dem freeze dann noch ne ganze weile gelaufen ist (war nicht daheim) und ich sonst wenn ich den freeze hatte immer gleich neu gestartet habe.
habe mal nach deiner anleitung das ausgewertet und das bei rausbekommen. ich hoffe mal du kannst mir helfen und sagen woran das liegt. danke =)
IRQL_NOT_LESS_OR_EQUAL (a)
An attempt was made to access a pageable (or completely invalid) address at an
interrupt request level (IRQL) that is too high. This is usually
caused by drivers using improper addresses.
If a kernel debugger is available get the stack backtrace.
Arguments:
Arg1: fffffac005204468, memory referenced
Arg2: 0000000000000002, IRQL
Arg3: 0000000000000001, bitfield :
bit 0 : value 0 = read operation, 1 = write operation
bit 3 : value 0 = not an execute operation, 1 = execute operation (only on chips which support this level of status)
Arg4: fffff80002a6b3f6, address which referenced memory
Debugging Details:
WRITE_ADDRESS: fffffac005204468
CURRENT_IRQL: 2
FAULTING_IP:
nt!MiClearFilePointer+a2
fffff800`02a6b3f6 48832000 and qword ptr [rax],0
BUGCHECK_STR: 0xA
PROCESS_NAME: svchost.exe
TRAP_FRAME: fffff88009a46640 -- (.trap 0xfffff88009a46640)
NOTE: The trap frame does not contain all registers.
Some register values may be zeroed or incorrect.
rax=fffffac005204468 rbx=0000000000000000 rcx=0000000080000000
rdx=0000000000000001 rsi=0000000000000000 rdi=0000000000000000
rip=fffff80002a6b3f6 rsp=fffff88009a467d0 rbp=fffffa80052041f0
r8=0000000000000001 r9=0000000000000001 r10=0000000000000002
r11=0000000000000001 r12=0000000000000000 r13=0000000000000000
r14=0000000000000000 r15=0000000000000000
nt!MiClearFilePointer+0xa2:
fffff800`02a6b3f6 48832000 and qword ptr [rax],0 ds:fffffac0`05204468=????????????????
LAST_CONTROL_TRANSFER: from fffff80002a81ca9 to fffff80002a82740
STACK_TEXT:
fffff880`09a464f8 fffff800`02a81ca9 : 00000000`0000000a fffffac0`05204468 00000000`00000002 00000000`00000001 : nt!KeBugCheckEx
fffff880`09a46500 fffff800`02a80920 : fffff880`09a468f0 00000000`00000000 00000000`00000000 fffff880`01288160 : nt!KiBugCheckDispatch+0x69
fffff880`09a46640 fffff800`02a6b3f6 : 00000000`00000002 00000000`00000000 fffff880`009e8180 00000000`00000000 : nt!KiPageFault+0x260
fffff880`09a467d0 fffff800`02b42361 : fffffa80`052041f0 00000000`00000000 fffffa80`052041f0 000fffff`ffffff00 : nt!MiClearFilePointer+0xa2
fffff880`09a46830 fffff800`02ade6cc : fffffa80`052041f0 00000000`00000000 00000000`00000001 00000000`0011cc0a : nt!MiCheckForControlAreaDeletion+0x31
fffff880`09a46880 fffff800`02a45cc8 : 00000000`00000002 00000000`00000000 fffffa80`035850f0 00000001`00000080 : nt! ?? ::FNODOBFM::`string'+0x10c6c
fffff880`09a468f0 fffff800`02b432ad : fffffa80`035850f0 fffff880`09a46a40 00000000`00000080 00000000`0008881f : nt!MiRestoreTransitionPte+0xcc
fffff880`09a46950 fffff800`02af1ade : 00000000`00000002 fffff880`09a46a40 fffffa80`03bd8ec8 00000000`00000002 : nt!MiRemoveLowestPriorityStandbyPage+0x2ad
fffff880`09a469d0 fffff800`02a9c9c6 : 00000000`00000001 00000000`0189f5da fffff880`09a46c20 fffff680`0000c4f8 : nt! ?? ::FNODOBFM::`string'+0x29bb7
fffff880`09a46ac0 fffff800`02a8082e : 00000000`00000001 00000000`00014000 00000000`0040fe01 00000000`06a50080 : nt!MmAccessFault+0x5c6
fffff880`09a46c20 00000000`776f9d5b : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiPageFault+0x16e
00000000`019fea00 00000000`00000000 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : 0x776f9d5b
STACK_COMMAND: kb
FOLLOWUP_IP:
SYMBOL_STACK_INDEX: 3
SYMBOL_NAME: nt!MiClearFilePointer+a2
MODULE_NAME: nt
IMAGE_NAME: memory_corruption
FAILURE_BUCKET_ID: X64_0xA_nt!MiClearFilePointer+a2
Bei dir ist die Sache leider alles andere als eindeutig. "Memory Corruption" wird als Ursache ausgegeben und auch die Stacks verzeichnen einen Speicherfehler "PageFault, MmAccessFault".
Nun kann aber Speicher i.d.S. insbes. der RAM, VRAM, CPU-Cache oder die Festplatte sein. Selbst das Motherboard könnte als Ursache in Betracht kommen.
Was für Hardware hast du den im PC drin? Mache bitte ein paar Screenshots von CPU-Z (Reiter Mainboard, CPU, Memory, SPD und Graphics) und einen von CrystalDiskInfo.
Überprüfe als erstes auch noch deinen RAM mit Memtest86+ auf Fehler.
danke schonmal für die antwort. die screenshots kommen gleich.
nen memtest hab ich vor 3 tagen über nacht mal durchlaufen lassen und es wurden keine fehler gefunden, werde heute nacht aber nochmal einen durchlaufen lassen.
hardware:
motherboard: asus p5n-e sli
cpu: intel core 2 quad q6600 (2,4ghz)
ram: 4x corsair cm2x1024-6400 ddr2-800
grafikkarte: 2x nvidia gforce 8800 gts 640mb
netzteil: thermaltake toughpower 850w
festplatte: 2x seagate st3500630as 500gb
os: windows 7 ultimate x64
treiber sind alle aktuell laut driver genius
Da haben wir auch noch ein potentielle Fehlerursache, insbes. da die 88er Reihe in letzter Zeit vermehrt mit Schäden (VRAM) auffällt. Deine Probleme sind ja auch erst seit drei Wochen aufgetreten. Vorher lief ja vermutlich alles Problemfrei.
Folgende Tests würde ich vorschlagen:
- System mit nur zwei RAM Riegeln laufen lassen (beide Kits 2x1 GB einzeln testen). Bleibt dies ohne Verbesserung...
- SLI auflösen und die Grafikkarten einzeln testen (auch hier beide Einzeln laufen lassen).
...die Screenshots bitte trotzdem machen.
Hi,
ich kenne mich mit dem Sockel 775 nicht so gut aus, aber was mir auffällt, ist dass Deine Graka nur mit 8 lanes angebunden ist. Sollten eigentlich 16 sein. Hast Du die Graka schon mal ausgebaut, ggf. entstaubt und wieder eingebaut?
Grüße --- Softy
ja, entstauben tu ich eig alle 2-3 monate mal und habs auch komplett gereinigt als die probleme auftraten. allerdings hör ich das mit 8 lanes grade zum ersten mal ^^ kp was das heisen soll =D
Beim unteren linken CPU-Z Screen steht, dass die Grafikkarte mit 8 lanes angebunden ist, aber max. 16 lanes unterstützt werden. Das ist die Speicherbandbreite. Hast Du sonst noch PCIe-Karten im PC (Soundkarte o.ä.)?
EDIT: Hat sich erledigt, hab gerade gesehen, dass Du 2 Grafikkarten drin hast^^. Dann passt das schon mit den 8 lanes.
