* Bugcheck Analysis *
PAGE_FAULT_IN_NONPAGED_AREA (50)
Invalid system memory was referenced. This cannot be protected by try-except,
it must be protected by a Probe. Typically the address is just plain bad or it
is pointing at freed memory.
Arguments:
Arg1: fffff8a00ab87000, memory referenced.
Arg2: 0000000000000000, value 0 = read operation, 1 = write operation.
Arg3: fffff800030877fb, If non-zero, the instruction address which referenced the bad memory
address.
Arg4: 0000000000000000, (reserved)
Debugging Details:
Could not read faulting driver name
READ_ADDRESS: fffff8a00ab87000
FAULTING_IP:
nt!memcpy+14b
fffff800`030877fb 4c8b540a28 mov r10,qword ptr [rdx+rcx+28h]
MM_INTERNAL_CODE: 0
CUSTOMER_CRASH_COUNT: 1
DEFAULT_BUCKET_ID: VISTA_DRIVER_FAULT
BUGCHECK_STR: 0x50
PROCESS_NAME: SDMonSvc.exe
CURRENT_IRQL: 0
TRAP_FRAME: fffff880092b05f0 -- (.trap 0xfffff880092b05f0)
NOTE: The trap frame does not contain all registers.
Some register values may be zeroed or incorrect.
rax=0000000000000011 rbx=0000000000000000 rcx=00000000085bbc00
rdx=fffff8a0025cb3d6 rsi=0000000000000000 rdi=0000000000000000
rip=fffff800030877fb rsp=fffff880092b0788 rbp=fffff880092b0b60
r8=0000000026d15000 r9=0000000000000000 r10=0000000000000000
r11=0000000002ed0040 r12=0000000000000000 r13=0000000000000000
r14=0000000000000000 r15=0000000000000000
iopl=0 nv up ei pl nz na po nc
nt!memcpy+0x14b:
fffff800`030877fb 4c8b540a28 mov r10,qword ptr [rdx+rcx+28h] ds:1000:fffff8a0`0ab86ffe=????????????????
Resetting default scope
LAST_CONTROL_TRANSFER: from fffff8000303ca0c to fffff80003090d00
STACK_TEXT:
STACK_COMMAND: kb
FOLLOWUP_IP:
nt! ?? ::FNODOBFM::`string'+4621f
fffff800`0303ca0c cc int 3
SYMBOL_STACK_INDEX: 1
SYMBOL_NAME: nt! ?? ::FNODOBFM::`string'+4621f
FOLLOWUP_NAME: MachineOwner
MODULE_NAME: nt
IMAGE_NAME: ntkrnlmp.exe
DEBUG_FLR_IMAGE_TIMESTAMP: 4d9fdd5b
FAILURE_BUCKET_ID: X64_0x50_nt!_??_::FNODOBFM::_string_+4621f
Followup: MachineOwner
so was soll mir das jetzt sagen??
ps: ich trootel hab vergessen die anführungszeichen weg zu machen.. oh man.. -.-
pps: stimmt denn bei cpu-z und gpu-z alles??
ppps: also mein pc fährt hoch und es ist wieder einmal der aero effektm (durchsichtigkeit) einfach weg und nicht einstellbar.. mir wird bei der rpoblemdiagnose gesagt, das mein grafikkartentreiber aero nicht unterstützt.. wenn ich den treiber sauber neu installiere, dann geht es bis zum nächsten neustart.. DAS NERVT!!
pppps: muss nochmal nerven, habe gemerkt, dass bei dem asus treiber alles noch auf 5.1 eingestellt war und als ich es geändert hatte und dann nochmal neustartete, ging plötzlich alles wieder (auch mein tv programm zeigte mir an, dass es nicht geht, aber nach diesem neustart ging es dann auch wieder).. liegt es also am xonar treiber??
erst nach einbau der karte kamen die probleme..
