Njghtmare
AW: Allgemeiner Ryzen Laberthread
Hier mal etwas zu den Voltage Werten was Jemand aus zwei Reviews extrahiert hat, ist ja vielleicht für den Einen oder Anderen interessant
Maximum safe vcore voltages for Ryzen : Amd
From Tom's Review:
"AMD predicts that most customers should see somewhere between 3.9 and 4.1 GHz across all cores, and suggests you stick with a 1.35V ceiling if you want your chip to last. Although core voltages in excess of 1.45V are considered sustainable, they'll have a more pronounced effect on longevity."
Tom's hardware indicates that that drop-off point is 1.45 volt
From Kitguru:
"Default voltage for manual tuning should start at around 1.3625V, according to AMD. Users should be fine pushing to 1.40V with a decent CPU cooler and up to 1.45V with a high-end dual-tower heatsink or dual-fan AIO radiator. At 1.45V, however, AMD suggests that processor longevity could be affected according to their models."
I take that to mean 1.35-1.45V is probably safe depending on your cooling solution.
From Tom's Review:
From Kitguru:
