AMD RX VEGA Laberthread
Also ich hab mal mit Afterburner gegengtestet und da ist alles normal. Sonst müsste ich ja auch Lags bekommen ohne HBCC an..
Denke mal der Treiber und GPU-Z verstehen sich nicht :P
Witzig, vor kurzem ist ne neue GPU-Z Version rausgekommen: TechPowerUp GPU-Z v2.8.0 Released | TechPowerUp
- Fixed crashes and other issues on AMD Ryzen Raven Ridge APU
- Added DXVA 2.0 hardware decoder info to Advanced Tab
- "Disable sensor" menu item now properly called "Hide"
- Improved VRAM usage monitoring on AMD
- Improved rendering performance of NVIDIA PerfCap sensor
- Improved AMD power limit reporting in Advanced Panel
- "MemVendor" is now included in XML dump output
- Fixed NVIDIA PerfCap sensor drawing outside its area
- Fixed "BIOS reading not supported" error on NVIDIA, on some motherboards
- Fixed HBM memory type detection in Advanced Tab on Fury X
- Fixed temperature misreadings on Vega
- Fixed "Digital Signature" label getting truncated on some hidpi screens
- Added support for RX 460 Mobile, RX 560 Mobile, RX 570 Mobile, RX 580 Mobile, RX 550 based on Baffin LE
Mal was ganz anderes: AMD GPU Market Share Increase Big Time in Q4 as NVIDIA / Intel Decline
AMD was the main benefactor of the total mining hardware sales of $776 million as reported in the article. When comparing the graphics chip market segments, almost the entire industry saw a downward trend in Q4 2017 which includes discrete graphics for desktop, notebook integrated and embedded for mobility systems. The discrete notebook market and desktop integrated and embedded platforms saw an increase in growth rate of 3.6% and 3.0% respectively.
Da werden nicht wenige VEGAs drunter sein. Der Umsatz ist im Vergleich zur Stückzahl ziemlich hoch.
- AMD’s overall unit shipments increased 8.08% quarter-to-quarter, Intel’s total shipments decreased -1.98% from last quarter, and NVIDIA’s decreased -6.00%.
- The attach rate of GPUs (includes integrated and discrete GPUs) to PCs for the quarter was 134% which was down -10.06% from last quarter.
- Discrete GPUs were in 36.88% of PCs, which is down -2.67%.
- The overall PC market increased 5.93% quarter-to-quarter, and decreased -0.15% year-to-year.
- Desktop graphics add-in boards (AIBs) that use discrete GPUs decreased -4.62% from last quarter.
- Q4’17 saw no change in tablet shipments from last quarter
Ich konnte kein überlaufen des Vram entdecken bei meinen Games.
das ende vom log, gemerkt habe ich nichts beim spielen -.-
Code:
           Date            , GPU Core Clock [MHz] , GPU Memory Clock [MHz] , SOC Clock [MHz] , GPU Temperature [°C] , GPU Temperature (Hot Spot) [°C] , HBM Temperature [°C] , Fan Speed (RPM) [RPM] , Fan Speed (%) [%] , GPU Load [%] , GPU only Power Draw [W] , Memory Used [MB] , VDDC [V] ,
2018-02-25 22:12:07.180 ,             1728.0   ,               1100.0   ,        1107.0   ,               35.0   ,                          49.0   ,               39.0   ,                 864   ,              59   ,         85   ,                 241.0   ,          12258   , 1.1438   ,
2018-02-25 22:12:07.495 ,             1695.0   ,               1100.0   ,        1107.0   ,               35.0   ,                          48.0   ,               40.0   ,                 864   ,              59   ,         81   ,                 224.0   ,          12259   , 1.1438   ,
2018-02-25 22:12:07.805 ,             1709.0   ,               1100.0   ,        1107.0   ,               35.0   ,                          50.0   ,               40.0   ,                 865   ,              59   ,         96   ,                 251.0   ,          12259   , 1.1313   ,
2018-02-25 22:12:08.120 ,             1713.0   ,               1100.0   ,        1107.0   ,               35.0   ,                          49.0   ,               39.0   ,                 864   ,              59   ,         91   ,                 236.0   ,          12259   , 1.1313   ,
2018-02-25 22:12:08.430 ,             1720.0   ,               1100.0   ,        1107.0   ,               35.0   ,                          49.0   ,               39.0   ,                 864   ,              59   ,         86   ,                 228.0   ,          12260   , 1.1375   ,
2018-02-25 22:12:08.745 ,             1727.0   ,               1100.0   ,        1107.0   ,               35.0   ,                          49.0   ,               39.0   ,                 864   ,              59   ,         95   ,                 240.0   ,          12260   , 1.1375   ,
2018-02-25 22:12:09.058 ,             1726.0   ,               1100.0   ,        1107.0   ,               35.0   ,                          51.0   ,               40.0   ,                 864   ,              59   ,         96   ,                 254.0   ,          12267   , 1.1438   ,
2018-02-25 22:12:09.367 ,             1728.0   ,               1100.0   ,        1107.0   ,               35.0   ,                          50.0   ,               41.0   ,                 864   ,              59   ,         95   ,                 256.0   ,          12263   , 1.1438   ,
2018-02-25 22:12:09.682 ,             1730.0   ,               1100.0   ,        1107.0   ,               35.0   ,                          49.0   ,               40.0   ,                 864   ,              59   ,         85   ,                 242.0   ,          12289   , 1.1313   ,
2018-02-25 22:12:09.995 ,             1728.0   ,               1100.0   ,        1107.0   ,               36.0   ,                          50.0   ,               40.0   ,                 863   ,              59   ,         86   ,                 245.0   ,          12284   , 1.1438   ,
2018-02-25 22:12:10.305 ,             1727.0   ,               1100.0   ,        1107.0   ,               35.0   ,                          50.0   ,               40.0   ,                 863   ,              59   ,         93   ,                 258.0   ,          12267   , 1.1438   ,
2018-02-25 22:12:10.617 ,             1727.0   ,               1100.0   ,        1107.0   ,               35.0   ,                          50.0   ,               40.0   ,                 863   ,              59   ,         87   ,                 254.0   ,          12261   , 1.1313   ,
2018-02-25 22:12:10.932 ,             1728.0   ,               1100.0   ,        1107.0   ,               35.0   ,                          51.0   ,               40.0   ,                 862   ,              59   ,         88   ,                 257.0   ,          12270   , 1.1438   ,
2018-02-25 22:12:11.245 ,             1726.0   ,               1100.0   ,        1107.0   ,               35.0   ,                          51.0   ,               40.0   ,                 862   ,              59   ,         97   ,                 261.0   ,          12253   , 1.1375   ,
2018-02-25 22:12:11.558 ,             1726.0   ,               1100.0   ,        1107.0   ,               35.0   ,                          50.0   ,               40.0   ,                 862   ,              59   ,         99   ,                 250.0   ,          12256   , 1.1438   ,
2018-02-25 22:12:11.868 ,             1730.0   ,               1100.0   ,        1107.0   ,               35.0   ,                          49.0   ,               39.0   ,                 863   ,              59   ,         98   ,                 239.0   ,          12255   , 1.1500   ,
2018-02-25 22:12:12.182 ,             1734.0   ,               1100.0   ,        1107.0   ,               35.0   ,                          49.0   ,               38.0   ,                 864   ,              59   ,         99   ,                 235.0   ,          12254   , 1.1313   ,
2018-02-25 22:12:12.495 ,             1737.0   ,               1100.0   ,        1107.0   ,               35.0   ,                          50.0   ,               38.0   ,                 861   ,              59   ,         98   ,                 237.0   ,          12236   , 1.1375   ,
2018-02-25 22:12:12.804 ,             1577.0   ,               1100.0   ,        1104.0   ,               34.0   ,                          44.0   ,               38.0   ,                 861   ,              59   ,         99   ,                 137.0   ,          12240   , 1.1500   ,
2018-02-25 22:12:13.120 ,             1654.0   ,               1100.0   ,        1107.0   ,               35.0   ,                          48.0   ,               38.0   ,                 864   ,              59   ,         99   ,                 233.0   ,          12240   , 1.1500   ,
2018-02-25 22:12:13.430 ,             1695.0   ,               1100.0   ,        1107.0   ,               35.0   ,                          48.0   ,               38.0   ,                 862   ,              59   ,         99   ,                 234.0   ,          12240   , 1.1438   ,
2018-02-25 22:12:13.742 ,             1717.0   ,               1100.0   ,        1107.0   ,               35.0   ,                          48.0   ,               38.0   ,                 865   ,              59   ,         98   ,                 231.0   ,          12240   , 1.1500   ,
2018-02-25 22:12:14.054 ,             1728.0   ,               1100.0   ,        1107.0   ,               35.0   ,                          49.0   ,               38.0   ,                 864   ,              59   ,         99   ,                 236.0   ,          12240   , 1.1438   ,
2018-02-25 22:12:14.370 ,             1734.0   ,               1100.0   ,        1107.0   ,               35.0   ,                          48.0   ,               38.0   ,                 865   ,              58   ,         99   ,                 233.0   ,          12240   , 1.1438   ,
2018-02-25 22:12:14.682 ,             1737.0   ,               1100.0   ,        1107.0   ,               35.0   ,                          48.0   ,               38.0   ,                 864   ,              58   ,         99   ,                 232.0   ,          12240   , 1.1438   ,
2018-02-25 22:12:14.993 ,             1739.0   ,               1100.0   ,        1107.0   ,               35.0   ,                          48.0   ,               39.0   ,                 863   ,              58   ,         99   ,                 235.0   ,          12240   , 1.1438   ,
2018-02-25 22:12:15.308 ,             1740.0   ,               1100.0   ,        1107.0   ,               35.0   ,                          49.0   ,               39.0   ,                 860   ,              58   ,         99   ,                 239.0   ,          12240   , 1.1438   ,
2018-02-25 22:12:15.617 ,             1740.0   ,               1100.0   ,        1107.0   ,               35.0   ,                          49.0   ,               38.0   ,                 860   ,              58   ,         99   ,                 239.0   ,          12240   , 1.1438   ,
2018-02-25 22:12:15.930 ,             1729.0   ,               1100.0   ,        1107.0   ,               35.0   ,                          49.0   ,               38.0   ,                 858   ,              58   ,         98   ,                 230.0   ,          12240   , 1.1500   ,
2018-02-25 22:12:16.242 ,             1734.0   ,               1100.0   ,        1107.0   ,               35.0   ,                          49.0   ,               38.0   ,                 857   ,              58   ,         99   ,                 238.0   ,          12240   , 1.1438   ,
2018-02-25 22:12:16.557 ,             1738.0   ,               1100.0   ,        1107.0   ,               35.0   ,                          48.0   ,               38.0   ,                 856   ,              58   ,         99   ,                 235.0   ,          12240   , 1.1375   ,
2018-02-25 22:12:16.867 ,             1739.0   ,               1100.0   ,        1107.0   ,               35.0   ,                          49.0   ,               38.0   ,                 857   ,              58   ,         98   ,                 236.0   ,          12240   , 1.1375   ,
Der HBCC Test zu FF wird interessant.
Wenn es auf PCGH überhaupt einen HBCC Test geben wird, CB liefert da schon zuverlässiger/regelmäßiger HBCC-Tests.
AFAIK das erste mal, daß der VRAM nicht ausreicht.
Nicht ganz, vielleicht erinnerst du dich noch: Need for Speed Payback: Techniktest des Frostbite-Racers [Grosses Update]
Während unserer Ausflüge in Ultra HD wurden stets rund 9 GiByte belegt. Ein paar Messungen später stellte sich bereits heraus, dass NFS Payback auf 8-GiByte-Grafikkarten unter Ultra HD tatsächlich an Nachladerucklern krankt, sobald alle Details maximiert werden.
Gab auch Nachfragen und Versprechen dazu (allerdings weiß ich nicht ob der Artikel bereits erschienen ist oder nicht):
http://extreme.pcgameshardware.de/n...-frostbite-racers-liveticker.html#post9115797
http://extreme.pcgameshardware.de/n...rostbite-racers-liveticker-5.html#post9117870
Wie ich sagte, GPU-Z meldet 9GB+ Afterburner gleichzeitig nur 4.
Sonst könnte der VRAM ja auch nicht auf 9GB steigen wenn nur 8 verbaut sind. :)
Hmm, ist ja alles ganz toll, ändert aber am Grundproblem der Verfügbarkeit für "normale Preise" nix.
AMD Discrete GPU Share Rises To Highest Point In Nearly 4 Years - Global GPU Shortage Crisis Continues
According to the latest discrete GPU market share report from Jon Peddie research via Anandtech, AMD grew its share from 27.2% in Q3 of 2017, to 33.7% in Q4 2017. Which represents nearly a 24% increase in the company’s GPU unit shipments, one of the largest jumps recorded in the company’s recent history.
Wird sich auch nix, wenn die Miner die Dinger von der Fabrik in Flugzeugen wegkaufen.
Da wär man ja auch markttechnisch selten dämlich, wenn man welche zu Normalpreisen an Gamern verkauft.
Muss man schon verstehen, in der Marktwirtschaft regeln nun mal Angebot und Nachfrage den Preis.
Bin mir noch nicht 100% sicher, aber ich glaube mein Netzteil kommt mit der voll ausgefahrenen Vega FE@Default nicht klar, obwohl die Leistungsaufnahme des Gesamtsystems bisher bei max. 350 Watt (Gaming; zudem nur Peaks) lag. Das System schaltet sich ab, höre das Relais meines Netzteils klicken und danach kann ich das System nicht mehr einschalten, bis ich nicht den ON/OFF-Schalter am Netzteil betätige (also Netzteil aus und wieder an). Mit der Vega 56@OCing (>300W) gabs keine Probleme.
Empfehlungen der Hersteller lauten ja:
- RX Vega 56 -> 650W NT
- RX Vega 64 -> 750W NT
- Vega FE -> 850W NT
Ich schätze die doppelte Menge an HBM2 macht den Unterschied bei der Belastung des Netzteils. Auf ein 750W Titanium würde ich mich gerade noch einlassen (wenns sicher mit der Vega FE läuft), aber auf 850W habe ich eigentlich keinen Bock mehr... was meint ihr, kann es wirklich sein, dass die Vega FE für das 650W Titanium zu viel ist oder hat die Graka oder das NT einen Hau weg?
Edit: CPU läuft auch nur @Default und zieht unter Prime95 ca. 125W (Gesamtsystem). Also keine große Belastung fürs Netzteil, zumal die CPU im Spielebetrieb idR kaum ausgelastet ist und dort nur ca. 30-40 Watt ziehen dürfte.
FF15 (Demo) macht selbst @UHD(200%) keine Probleme, aber Kingdom Come: Deliverance haut rein.
Hatte mit meiner vega64 auch diverse Probleme gerade mit oc und such mit dem lc bios , das wollte garnicht problemlos laufen. Hatte sich verschiedene Netzteile durchprobiert bq straight 10 400/500/600w Dark pro 11 1000w, System power 400w, seasonic 850w Prime Titan. Beim letzteren bin ich hängen geblieben. Oc/lc bios hab ich dann nicht mehr versucht.
