Nope.Ich schau mal, ob eine Neuinstallation des Treibers Abhilfe schafft
Had the same issue. Fast startup was off both in windows and bios. Turns out I just had MSI Afterburner loading up stock speeds and volts with my windows boot. So if the startup changes don't fix it, make sure you don't have any other overclocking software loading up their own settings with your boot.
Das habe ich noch gar nicht getestet.Treiberreset (sagt die Adrenalin-Benachrichtigungsanzeige) sogar bei Stock-Settings.
