Xen und 3D
so hab mal weitergetestet,
Intel onboard grafik, AMD 4670 PCIe und Nvidia GT430 PCIe laufen nicht unter windows, gfx_passthru = 0, über VNC Win7x64 Installiert, Treiber intsalliert, dann ein reboot durchgeführt, jeder bootvorgang wird abgebrochen, einzigster unterschied ist die Intel GPU bei gfx_passthru = 1 ein Bild ausgibt(sozusagen den qemu POST screen) dann will er wind starten und bricht auch mit der selben fehlermeldung ab.ImageShack® - Online Photo and Video Hosting
hier mal die log file:
Code:
domid: 38
config qemu network with xen bridge for  tap38.0 xenbr0
Using file /srv/MePo/sz.img in read-write mode
Watching /local/domain/0/device-model/38/logdirty/cmd
Watching /local/domain/0/device-model/38/command
Watching /local/domain/38/cpu
qemu_map_cache_init nr_buckets = 10000 size 4194304
shared page at pfn feffd
buffered io page at pfn feffb
Guest uuid = 68ffda00-8703-9ad8-5084-5b6fda91898b
Time offset set 0
Register xen platform.
Done register platform.
platform_fixed_ioport: changed ro/rw state of ROM memory area. now is rw state.
xs_read(/local/domain/0/device-model/38/xen_extended_power_mgmt): read error
Log-dirty: no command yet.
I/O request not ready: 0, ptr: 0, port: 0, data: 0, count: 0, size: 0
vcpu-set: watch node error.
xs_read(/local/domain/38/log-throttling): read error
qemu: ignoring not-understood drive `/local/domain/38/log-throttling'
medium change watch on `/local/domain/38/log-throttling' - unknown device, ignored
dm-command: hot insert pass-through pci dev
register_real_device: Assigning real physical device 01:00.0 ...
register_real_device: Enable MSI translation via per device option
register_real_device: Enable power management
pt_iomul_init: Error: pt_iomul_init can't open file /dev/xen/pci_iomul: No such file or directory: 0x1:0x0.0x0
pt_register_regions: IO region registered (size=0x10000000 base_addr=0xd000000c)
pt_register_regions: IO region registered (size=0x00010000 base_addr=0xe0020004)
pt_register_regions: IO region registered (size=0x00000100 base_addr=0x0000e001)
pt_register_regions: Expansion ROM registered (size=0x00020000 base_addr=0xe0000002)
pcilib: Cannot open /sys/bus/pci/devices/0000:00:02.0/config
pt_msi_setup: msi mapped with pirq 37
pci_intx: intx=1
register_real_device: Real physical device 01:00.0 registered successfuly!
IRQ type = MSI-INTx
char device redirected to /dev/pts/2
xen be: console-0: xen be: console-0: initialise() failed
initialise() failed
initialise() failed
initialise() failed
initialise() failed
initialise() failed
initialise() failed
initialise() failed
initialise() failed
initialise() failed
initialise() failed
initialise() failed
initialise() failed
pt_iomem_map: e_phys=e0000000 maddr=d0000000 type=8 len=268435456 index=0 first_map=1
pt_iomem_map: e_phys=f1040000 maddr=e0020000 type=0 len=65536 index=2 first_map=1
pt_ioport_map: e_phys=c100 pio_base=e000 len=256 index=4 first_map=1
mfg Marco
a%3E
a%3E
@ Marco: Kannst du mal die Config der Win-VM Posten und, was dein lsusb ausgibt wenn du keine devices hidest (also ganz normal ohne xen bootest)
@ Hardware_fanatiker: Joa, das machen wir hier in dem Threat schon seit Monaten.. Unter anderem laufen auf meinem Rechner ne Win7 VM zum Zocken / Arbeiten / Bildbearbeitung, und ne Debian Mediacenter-VM für Filme und Musik parallel..
Hi Dragon
also hab hier mal mein lsusb:
Code:
Bus 016 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 015 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 014 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 013 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 012 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 011 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 010 Device 002: ID 045e:0745 Microsoft Corp.
Bus 010 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 009 Device 002: ID 0d8c:000c C-Media Electronics, Inc. Audio Adapter
Bus 009 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 008 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 007 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 006 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 005 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 004 Device 003: ID 0403:6001 Future Technology Devices International, Ltd FT232 USB-Serial (UART) IC
Bus 004 Device 002: ID 1a40:0201 TERMINUS TECHNOLOGY INC.
Bus 004 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
und hier meine Win-VM .cfg :
Code:
builder     = 'hvm'
memory      = '2048'
name        = 'xbmc'
boot        ='c'
disk        = ['file:/srv/MePo/sz.img,ioemu:hda,w']
device_model = 'qemu-dm'
vcpus=4
pci_msitranslate=1
pci_power_mgmt=1
sdl=0
#pci=['00:1a.0', '00:1a.1', '00:1a.2', '00:1a.7', '00:1b.0', '00:1d.0', '00:1d.1', '00:1d.2', '00:1d.7']
pci=['01:00.0']
gfx_passthru = 0
#dhcp        = 'dhcp'
vif = [ 'bridge=xenbr0, model=e1000' ]
viridian=1
usbdevice='tablet'
vnc=0
vncpasswd=''
vnclisten='0.0.0.0'
on_poweroff = 'destroy'
on_reboot   = 'restart'
on_crash    = 'restart'
bin schon leicht am verzweifeln.
mfg Marco
Ach, verdammt, ich meinte nich lsusb, ich meinte lspci.. -.- sorry, hab parallel an meinem server mit ner externen platte rumgewerkelt.. ich bin dumm ^^ kannst du dein lspci noch mal posten? ich guck solang mal durch deine config..
Ah, okay, sry.. Hatte ich falsch verstanden.. und nein, können wir leider nicht.. die tun das gleiche was wir machen.. Aber auf jedenfall vielen vielen Dank für den Hinweis! Der Link war echt interessant..
:) hätte ich mir eig. denken können das du die lspci meinst ;)
Code:
00:00.0 Host bridge: Intel Corporation 4 Series Chipset DRAM Controller (rev 03)
00:01.0 PCI bridge: Intel Corporation 4 Series Chipset PCI Express Root Port (rev 03)
00:03.0 Communication controller: Intel Corporation 4 Series Chipset HECI Controller (rev 03)
00:03.2 IDE interface: Intel Corporation 4 Series Chipset PT IDER Controller (rev 03)
00:03.3 Serial controller: Intel Corporation 4 Series Chipset Serial KT Controller (rev 03)
00:19.0 Ethernet controller: Intel Corporation 82567LM-3 Gigabit Network Connection (rev 02)
00:1a.0 USB Controller: Intel Corporation 82801JD/DO (ICH10 Family) USB UHCI Controller #4 (rev 02)
00:1a.1 USB Controller: Intel Corporation 82801JD/DO (ICH10 Family) USB UHCI Controller #5 (rev 02)
00:1a.2 USB Controller: Intel Corporation 82801JD/DO (ICH10 Family) USB UHCI Controller #6 (rev 02)
00:1a.7 USB Controller: Intel Corporation 82801JD/DO (ICH10 Family) USB2 EHCI Controller #2 (rev 02)
00:1b.0 Audio device: Intel Corporation 82801JD/DO (ICH10 Family) HD Audio Controller (rev 02)
00:1c.0 PCI bridge: Intel Corporation 82801JD/DO (ICH10 Family) PCI Express Port 1 (rev 02)
00:1c.3 PCI bridge: Intel Corporation 82801JD/DO (ICH10 Family) PCI Express Port 4 (rev 02)
00:1d.0 USB Controller: Intel Corporation 82801JD/DO (ICH10 Family) USB UHCI Controller #1 (rev 02)
00:1d.1 USB Controller: Intel Corporation 82801JD/DO (ICH10 Family) USB UHCI Controller #2 (rev 02)
00:1d.2 USB Controller: Intel Corporation 82801JD/DO (ICH10 Family) USB UHCI Controller #3 (rev 02)
00:1d.7 USB Controller: Intel Corporation 82801JD/DO (ICH10 Family) USB2 EHCI Controller #1 (rev 02)
00:1e.0 PCI bridge: Intel Corporation 82801 PCI Bridge (rev a2)
00:1f.0 ISA bridge: Intel Corporation 82801JDO (ICH10DO) LPC Interface Controller (rev 02)
00:1f.2 IDE interface: Intel Corporation 82801JD/DO (ICH10 Family) 4-port SATA IDE Controller (rev 02)
00:1f.3 SMBus: Intel Corporation 82801JD/DO (ICH10 Family) SMBus Controller (rev 02)
00:1f.5 IDE interface: Intel Corporation 82801JD/DO (ICH10 Family) 2-port SATA IDE Controller (rev 02)
01:00.0 VGA compatible controller: nVidia Corporation Device 0de1 (rev a1)
01:00.1 Audio device: nVidia Corporation Device 0bea (rev a1)
03:00.0 USB Controller: NetMos Technology MCS9990 PCIe to 4‐Port USB 2.0 Host Controller
03:00.1 USB Controller: NetMos Technology MCS9990 PCIe to 4‐Port USB 2.0 Host Controller
03:00.2 USB Controller: NetMos Technology MCS9990 PCIe to 4‐Port USB 2.0 Host Controller
03:00.3 USB Controller: NetMos Technology MCS9990 PCIe to 4‐Port USB 2.0 Host Controller
03:00.4 USB Controller: NetMos Technology MCS9990 PCIe to 4‐Port USB 2.0 Host Controller
03:00.5 USB Controller: NetMos Technology MCS9990 PCIe to 4‐Port USB 2.0 Host Controller
03:00.6 USB Controller: NetMos Technology MCS9990 PCIe to 4‐Port USB 2.0 Host Controller
03:00.7 USB Controller: NetMos Technology MCS9990 PCIe to 4‐Port USB 2.0 Host Controller
04:00.0 Multimedia controller: Twinhan Technology Co. Ltd Mantis DTV PCI Bridge Controller [Ver 1.0] (rev 01)
mfg Marco
habe ich mich leider noch nie mit beschäftigt, und mein lpic1 fange ich erst im Oktober an :(
edit: naja werde nochmal versuchen xen 4.1.1 mit meinem vgabios zu bauen.. daumen drücken ;)
Hallo Community
Da ja bekannterweise bei mir VGA Passthru nie so richtig laufen wollte, habe ich jetzt meine Server Hardware komplett ausgetauscht, und jetzt läufts auch mit dem VGA Passthru bei Win HVMs.
Leider noch nicht mit Linux HVMs, habe XBMC Live getestet, bild kommt, aber irgendwie hat er keine netzwerk verbindung, wenn ich das Aktuelle ubuntu nehme bekomm ich leider kein bild :( habt ihr vllt ein paar tips für mich ?
mfg marco
Hallo Community
mfg marco
Sehr cool! was hast du jetzt für ne hardware? Ich führ hier nebenbei ne Liste.. (vorallem mobo, graka und cpu sind interessant)
Ubuntu is n bissel nervig.. ich musste da erst den fglrx installieren (den neueren treiber, nich den vom packaging system) und neu starten, danach gings..
So mal ne kleine Auflistung:
MB: Gigabyte GA-890FXA-UD7 (F5 beta bios)
CPU: Phenom 2 X6 1090T
GPU: 1. 5770
2. 5450
das mit dem fglrx werde ich gleich mal probieren, danke :)
hattest du schonmal versucht 3 grakas 3 verschiedenen HVMs zuzuweisen ?
mfg Marco
Hallo erstmal, ich habe mich extra hier angemeldet weil ich auch euren Thread gestoßen bin.Das was ihr hier super schon durchgekaut habt ist wo ich hin will.
Ich würde gerne:
xen haben als Dom0 empfehlt ihr ja wie ich das sehe Debian
1x Windows 7 zum zocken als mit Vga Passthrough
1x Gentoo oder Ubuntu zum arbeiten
Habt ihr jetzt schon ein How to erstellt, hab mir zwar alle Seiten durchgelsen aber nicht das mir etwas untergegangen ist.
Mein system:
Amd x4 Phenom
1x ati 4850.
Möchte dann die 4850 zur win7 durchschleifen damit man zocken kann.
Wie ist das bei 1 Bildschirm Betrieb, ist es da möglich das ich zb meine linux Vm dann starte, die dann runterfahren kann um dann die Win 7 VM zu starten um zu zocken?
empfehlt ihr eine 2 Grafik karte oder ist sie dringen voraussetzung.
Mit Linux kenne ich mich aus, bin aber nicht so Profi wie ihr.
chris
