Microsoft (R) Windows Debugger Version 6.12.0002.633 AMD64
Copyright (c) Microsoft Corporation. All rights reserved.
Loading Dump File [C:\Users\SibstLP\Desktop\090810-19188-01.dmp]
Mini Kernel Dump File: Only registers and stack trace are available
Symbol search path is: SRV*C:\symbols*
http://msdl.microsoft.com/download/symbols
Executable search path is:
Windows 7 Kernel Version 7600 MP (4 procs) Free x64
Product: WinNt, suite: TerminalServer SingleUserTS Personal
Built by: 7600.16617.amd64fre.win7_gdr.100618-1621
Machine Name:
Kernel base = 0xfffff800`02e11000 PsLoadedModuleList = 0xfffff800`0304ee50
Debug session time: Wed Sep 8 12:55:35.403 2010 (UTC + 2:00)
System Uptime: 0 days 1:25:37.698
Loading Kernel Symbols
Loading User Symbols
Loading unloaded module list
* Bugcheck Analysis *
Use !analyze -v to get detailed debugging information.
BugCheck 1, {7394056a, 0, ffff0000, fffff88006b73ca0}
Probably caused by : ntkrnlmp.exe ( nt!KiSystemServiceExit+245 )
Followup: MachineOwner
3: kd> !analyze -v
APC_INDEX_MISMATCH (1)
This is a kernel internal error. The most common reason to see this
bugcheck is when a filesystem or a driver has a mismatched number of
calls to disable and re-enable APCs. The key data item is the
Thread->KernelApcDisable field. A negative value indicates that a driver
has disabled APC calls without re-enabling them. A positive value indicates
that the reverse is true. This check is made on exit from a system call.
Arguments:
Arg1: 000000007394056a, address of system function (system call)
Arg2: 0000000000000000, Thread->ApcStateIndex << 8 | Previous ApcStateIndex
Arg3: 00000000ffff0000, Thread->KernelApcDisable
Arg4: fffff88006b73ca0, Previous KernelApcDisable
Debugging Details:
FAULTING_IP:
+3537386465373062
00000000`7394056a ?? ???
CUSTOMER_CRASH_COUNT: 1
DEFAULT_BUCKET_ID: VISTA_DRIVER_FAULT
BUGCHECK_STR: 0x1
PROCESS_NAME: iexplore.exe
CURRENT_IRQL: 0
LAST_CONTROL_TRANSFER: from fffff80002e80ca9 to fffff80002e81740
STACK_TEXT:
fffff880`06b73a68 fffff800`02e80ca9 : 00000000`00000001 00000000`7394056a 00000000`00000000 00000000`ffff0000 : nt!KeBugCheckEx
fffff880`06b73a70 fffff800`02e80be0 : ffffffff`fb010942 00000000`00000000 ffffffff`00000000 00000000`00000000 : nt!KiBugCheckDispatch+0x69
fffff880`06b73bb0 00000000`7394056a : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiSystemServiceExit+0x245
00000000`044ce4d8 00000000`00000000 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : 0x7394056a
STACK_COMMAND: kb
FOLLOWUP_IP:
fffff800`02e80be0 4883ec50 sub rsp,50h
SYMBOL_STACK_INDEX: 2
SYMBOL_NAME: nt!KiSystemServiceExit+245
FOLLOWUP_NAME: MachineOwner
MODULE_NAME: nt
IMAGE_NAME: ntkrnlmp.exe
DEBUG_FLR_IMAGE_TIMESTAMP: 4c1c44a9
FAILURE_BUCKET_ID: X64_0x1_SysCallNum_109a_nt!KiSystemServiceExit+245
3: kd> !analyze -v
Arguments:
Debugging Details:
FAULTING_IP:
+3537386465373062
BUGCHECK_STR: 0x1
CURRENT_IRQL: 0
STACK_TEXT:
STACK_COMMAND: kb
FOLLOWUP_IP:
MODULE_NAME: nt
