Microsoft (R) Windows Debugger Version 6.12.0002.633 AMD64
Copyright (c) Microsoft Corporation. All rights reserved.
Loading Dump File [C:\Windows\Minidump\092910-19578-01.dmp]
Mini Kernel Dump File: Only registers and stack trace are available
Symbol search path is: *** Invalid ***
* Symbol loading may be unreliable without a symbol search path. *
* Use .symfix to have the debugger choose a symbol path. *
* After setting your symbol path, use .reload to refresh symbol locations. *
Executable search path is:
* Symbols can not be loaded because symbol path is not initialized. *
* The Symbol Path can be set by: *
* using the _NT_SYMBOL_PATH environment variable. *
* using the -y <symbol_path> argument when starting the debugger. *
* using .sympath and .sympath+ *
Unable to load image ntoskrnl.exe, Win32 error 0n2
*** ERROR: Module load completed but symbols could not be loaded for ntoskrnl.exe
Windows 7 Kernel Version 7600 MP (4 procs) Free x64
Product: WinNt, suite: TerminalServer SingleUserTS
Machine Name:
Kernel base = 0xfffff800`0320e000 PsLoadedModuleList = 0xfffff800`0344be50
Debug session time: Wed Sep 29 17:14:01.301 2010 (UTC + 2:00)
System Uptime: 0 days 0:11:44.175
Loading Kernel Symbols
Loading User Symbols
Loading unloaded module list
* Bugcheck Analysis *
Use !analyze -v to get detailed debugging information.
BugCheck 3B, {c0000005, fffff80003564465, fffff8800b51f770, 0}
***** Kernel symbols are WRONG. Please fix symbols to do analysis.
*** Your debugger is not using the correct symbols ***
*** In order for this command to work properly, your symbol path ***
*** must point to .pdb files that have full type information. ***
*** Certain .pdb files (such as the public OS symbols) do not ***
*** contain the required information. Contact the group that ***
*** provided you with these symbols if you need this command to ***
*** work. ***
*** Type referenced: nt!_KPRCB ***
*** work. ***
*** Type referenced: nt!KPRCB ***
*** work. ***
*** work. ***
*** work. ***
*** work. ***
*** work. ***
*** work. ***
Probably caused by : ntoskrnl.exe ( nt+356465 )
Followup: MachineOwner
----- 64 bit Kernel Mini Dump Analysis
DUMP_HEADER64:
MajorVersion 0000000f
MinorVersion 00001db0
KdSecondaryVersion 00000000
DirectoryTableBase 00000001`eb9a1000
PfnDataBase fffffa80`00000000
PsLoadedModuleList fffff800`0344be50
PsActiveProcessHead fffff800`0342db30
MachineImageType 00008664
NumberProcessors 00000004
BugCheckCode 0000003b
BugCheckParameter1 00000000`c0000005
BugCheckParameter2 fffff800`03564465
BugCheckParameter3 fffff880`0b51f770
BugCheckParameter4 00000000`00000000
KdDebuggerDataBlock fffff800`033f7070
SecondaryDataState 00000000
ProductType 00000001
SuiteMask 00000110
MiniDumpFields 00000dff
TRIAGE_DUMP64:
ServicePackBuild 00000000
SizeOfDump 00040000
ValidOffset 0003fffc
ContextOffset 00000348
ExceptionOffset 00000f00
MmOffset 00002080
UnloadedDriversOffset 00009bd0
PrcbOffset 000020d0
ProcessOffset 00006dd0
ThreadOffset 000072a0
CallStackOffset 00007738
SizeOfCallStack 00002158
DriverListOffset 0000a6c8
DriverCount 000000c3
StringPoolOffset 00011478
StringPoolSize 00001b80
BrokenDriverOffset 00000000
TriageOptions 00000041
TopOfStack fffff880`0b51eea8
BStoreOffset 00000000
SizeOfBStore 00000000
LimitOfBStore 00000000`00000000
DebuggerDataOffset 00009890
DebuggerDataSize 00000340
DataBlocksOffset 00012ff8
DataBlocksCount 0000000b
fffff800`034b6074 - fffff800`034b6077 at offset 000130a8
fffff800`034b6068 - fffff800`034b606b at offset 000130ac
fffffa80`06ee5000 - fffffa80`06ee5517 at offset 000130b0
fffff800`0341f5a8 - fffff800`0341f5af at offset 000135c8
fffff800`0341f5b0 - fffff800`0341f5b7 at offset 000135d0
fffff800`03564000 - fffff800`03564fff at offset 000135d8
fffff880`0b51f000 - fffff880`0b51ffff at offset 000145d8
fffff800`0327e640 - fffff800`0327e83f at offset 000155d8
fffff800`033ce000 - fffff800`033cefff at offset 000157d8
fffff800`0320e000 - fffff800`0320efff at offset 000167d8
fffff800`0327e000 - fffff800`0327efff at offset 000177d8
Max offset 187d8, 316a1 from end of file
Machine Name:*** WARNING: Unable to verify timestamp for srv.sys
*** ERROR: Module load completed but symbols could not be loaded for srv.sys
start end module name
fffff800`03171000 fffff800`0317b000 kdcom Tue Jul 14 03:31:07 2009 (4A5BDFDB)
fffff800`0320e000 fffff800`037ea000 nt Sat Jun 19 06:16:41 2010 (4C1C44A9)
fffff800`037ea000 fffff800`03833000 hal Tue Jul 14 03:27:36 2009 (4A5BDF08)
fffff880`00c00000 fffff880`00c0e000 SscRdCls Fri Nov 16 20:59:09 2007 (473DF68D)
fffff880`00c0e000 fffff880`00c5a000 fltmgr Tue Jul 14 01:19:59 2009 (4A5BC11F)
fffff880`00c5a000 fffff880`00c6e000 fileinfo Tue Jul 14 01:34:25 2009 (4A5BC481)
fffff880`00c6e000 fffff880`00c79700 PxHlpa64 Thu Jun 21 00:27:08 2007 (4679A9BC)
fffff880`00c89000 fffff880`00ccd000 mcupdate Tue Jul 14 03:29:10 2009 (4A5BDF66)
fffff880`00ccd000 fffff880`00ce1000 PSHED Tue Jul 14 03:32:23 2009 (4A5BE027)
fffff880`00ce1000 fffff880`00d3f000 CLFS Tue Jul 14 01:19:57 2009 (4A5BC11D)
fffff880`00d3f000 fffff880`00dff000 CI Tue Jul 14 03:32:13 2009 (4A5BE01D)
fffff880`00e00000 fffff880`00e5c000 volmgrx Tue Jul 14 01:20:33 2009 (4A5BC141)
fffff880`00e5c000 fffff880`00e64000 intelide Tue Jul 14 01:19:48 2009 (4A5BC114)
fffff880`00e64000 fffff880`00e74000 PCIIDEX Tue Jul 14 01:19:48 2009 (4A5BC114)
fffff880`00e74000 fffff880`00e8e000 mountmgr Tue Jul 14 01:19:54 2009 (4A5BC11A)
fffff880`00e8e000 fffff880`00e97000 atapi Tue Jul 14 01:19:47 2009 (4A5BC113)
fffff880`00e97000 fffff880`00ea2000 amdxata Tue May 19 19:56:59 2009 (4A12F2EB)
fffff880`00ea5000 fffff880`00f49000 Wdf01000 Tue Jul 14 01:22:07 2009 (4A5BC19F)
fffff880`00f49000 fffff880`00f58000 WDFLDR Tue Jul 14 01:19:54 2009 (4A5BC11A)
fffff880`00f58000 fffff880`00f8b000 pci Tue Jul 14 01:19:51 2009 (4A5BC117)
fffff880`00f8b000 fffff880`00f97000 BATTC Tue Jul 14 01:31:01 2009 (4A5BC3B5)
fffff880`00f97000 fffff880`00fac000 volmgr Tue Jul 14 01:19:57 2009 (4A5BC11D)
fffff880`00fac000 fffff880`00fd6000 ataport Tue Jul 14 01:19:52 2009 (4A5BC118)
fffff880`00fd6000 fffff880`00fe1000 msahci Tue Jul 14 02:01:01 2009 (4A5BCABD)
fffff880`00fe1000 fffff880`00ff6000 SscRdBus Thu Jun 18 14:12:35 2009 (4A3A2F33)
fffff880`01000000 fffff880`01015000 partmgr Tue Jul 14 01:19:58 2009 (4A5BC11E)
fffff880`01015000 fffff880`0101c000 pciide Tue Jul 14 01:19:49 2009 (4A5BC115)
fffff880`0101c000 fffff880`01150000 spql Sun Mar 22 13:35:35 2009 (49C63097)
fffff880`01150000 fffff880`01159000 WMILIB Tue Jul 14 01:19:51 2009 (4A5BC117)
fffff880`01159000 fffff880`01188000 SCSIPORT Tue Jul 14 02:01:04 2009 (4A5BCAC0)
fffff880`01188000 fffff880`011df000 ACPI Tue Jul 14 01:19:34 2009 (4A5BC106)
fffff880`011df000 fffff880`011e9000 msisadrv Tue Jul 14 01:19:26 2009 (4A5BC0FE)
fffff880`011e9000 fffff880`011f6000 vdrvroot Tue Jul 14 02:01:31 2009 (4A5BCADB)
fffff880`011f6000 fffff880`011ff000 compbatt Tue Jul 14 01:31:02 2009 (4A5BC3B6)
fffff880`0121d000 fffff880`013c0000 Ntfs Tue Jul 14 01:20:47 2009 (4A5BC14F)
fffff880`013c0000 fffff880`013fe000 1394ohci Tue Jul 14 02:07:12 2009 (4A5BCC30)
fffff880`01400000 fffff880`0140d000 TDI Tue Jul 14 01:21:18 2009 (4A5BC16E)
fffff880`0140f000 fffff880`0146d000 msrpc Tue Jul 14 01:21:32 2009 (4A5BC17C)
fffff880`0146d000 fffff880`01487000 ksecdd Tue Jul 14 01:20:54 2009 (4A5BC156)
fffff880`01487000 fffff880`014fa000 cng Tue Jul 14 01:49:40 2009 (4A5BC814)
fffff880`014fa000 fffff880`0150b000 pcw Tue Jul 14 01:19:27 2009 (4A5BC0FF)
fffff880`0150b000 fffff880`01515000 Fs_Rec Tue Jul 14 01:19:45 2009 (4A5BC111)
fffff880`01515000 fffff880`015fa000 timntr Mon Aug 17 09:16:13 2009 (4A8903BD)
fffff880`01600000 fffff880`0164a000 fwpkclnt Tue Jul 14 01:21:08 2009 (4A5BC164)
fffff880`0164a000 fffff880`0165a000 vmstorfl Tue Jul 14 01:42:54 2009 (4A5BC67E)
fffff880`01664000 fffff880`01756000 ndis Tue Jul 14 01:21:40 2009 (4A5BC184)
fffff880`01756000 fffff880`017b6000 NETIO Tue Jul 14 01:21:46 2009 (4A5BC18A)
fffff880`017b6000 fffff880`017e1000 ksecpkg Fri Dec 11 07:03:32 2009 (4B21E0B4)
fffff880`017e1000 fffff880`017ff000 tdx Tue Jul 14 01:21:15 2009 (4A5BC16B)
fffff880`01801000 fffff880`019fe000 tcpip Mon Jun 14 05:39:04 2010 (4C15A458)
fffff880`01a00000 fffff880`01a25000 VIDEOPRT Tue Jul 14 01:38:51 2009 (4A5BC58B)
fffff880`01a25000 fffff880`01a35000 watchdog Tue Jul 14 01:37:35 2009 (4A5BC53F)
fffff880`01a35000 fffff880`01a3e000 RDPCDD Tue Jul 14 02:16:34 2009 (4A5BCE62)
fffff880`01a3e000 fffff880`01a47000 rdpencdd Tue Jul 14 02:16:34 2009 (4A5BCE62)
fffff880`01a47000 fffff880`01a50000 rdprefmp Tue Jul 14 02:16:35 2009 (4A5BCE63)
fffff880`01a50000 fffff880`01a5b000 Msfs Tue Jul 14 01:19:47 2009 (4A5BC113)
fffff880`01a5f000 fffff880`01aab000 volsnap Tue Jul 14 01:20:08 2009 (4A5BC128)
fffff880`01aab000 fffff880`01abd000 mup Tue Jul 14 01:23:45 2009 (4A5BC201)
fffff880`01abd000 fffff880`01af7000 fvevol Sat Sep 26 04:34:26 2009 (4ABD7DB2)
fffff880`01af7000 fffff880`01b0d000 disk Tue Jul 14 01:19:57 2009 (4A5BC11D)
fffff880`01b0d000 fffff880`01b3d000 CLASSPNP Tue Jul 14 01:19:58 2009 (4A5BC11E)
fffff880`01b3d000 fffff880`01b6e000 WUDFRd Tue Jul 14 02:06:06 2009 (4A5BCBEE)
fffff880`01b73000 fffff880`01b9d000 cdrom Tue Jul 14 01:19:54 2009 (4A5BC11A)
fffff880`01b9d000 fffff880`01bca000 MpFilter Sat Mar 20 06:58:08 2010 (4BA463F0)
fffff880`01bca000 fffff880`01bd3000 Null Tue Jul 14 01:19:37 2009 (4A5BC109)
fffff880`01bd3000 fffff880`01bda000 Beep Tue Jul 14 02:00:13 2009 (4A5BCA8D)
fffff880`01bda000 fffff880`01be8000 vga Tue Jul 14 01:38:47 2009 (4A5BC587)
fffff880`01be8000 fffff880`01bf9000 Npfs Tue Jul 14 01:19:48 2009 (4A5BC114)
fffff880`01c00000 fffff880`01c3f000 snapman Tue Sep 08 09:57:04 2009 (4AA60E50)
fffff880`01c3f000 fffff880`01c79000 rdyboost Tue Jul 14 01:34:34 2009 (4A5BC48A)
fffff880`01c79000 fffff880`01c82000 hwpolicy Tue Jul 14 01:19:22 2009 (4A5BC0FA)
fffff880`01c84000 fffff880`01dea000 tdrpm251 Fri Jul 31 15:59:53 2009 (4A72F8D9)
fffff880`01dea000 fffff880`01df2000 spldr Mon May 11 18:56:27 2009 (4A0858BB)
fffff880`01df2000 fffff880`01dfe000 hotcore3 Fri Mar 20 11:35:11 2009 (49C3715F)
fffff880`03000000 fffff880`03056180 vpcvmm Wed Sep 23 03:32:38 2009 (4AB97AB6)
fffff880`03057000 fffff880`03062600 VBoxUSBMon Thu Dec 17 14:58:01 2009 (4B2A38E9)
fffff880`03063000 fffff880`030908c0 VBoxDrv Thu Dec 17 14:58:01 2009 (4B2A38E9)
fffff880`03091000 fffff880`030a5000 termdd Tue Jul 14 02:16:36 2009 (4A5BCE64)
fffff880`030af000 fffff880`03139000 afd Tue Jul 14 01:21:40 2009 (4A5BC184)
fffff880`03139000 fffff880`0317e000 netbt Tue Jul 14 01:21:28 2009 (4A5BC178)
fffff880`0317e000 fffff880`03189000 ws2ifsl Tue Jul 14 02:10:33 2009 (4A5BCCF9)
fffff880`03189000 fffff880`03192000 wfplwf Tue Jul 14 02:09:26 2009 (4A5BCCB6)
fffff880`03192000 fffff880`031b8000 pacer Tue Jul 14 02:09:41 2009 (4A5BCCC5)
fffff880`031b8000 fffff880`031cc000 vpcnfltr Wed Sep 23 03:32:30 2009 (4AB97AAE)
fffff880`031cc000 fffff880`031db000 netbios Tue Jul 14 02:09:26 2009 (4A5BCCB6)
fffff880`031db000 fffff880`031f6000 wanarp Tue Jul 14 02:10:21 2009 (4A5BCCED)
fffff880`03200000 fffff880`0321e000 dfsc Tue Jul 14 01:23:44 2009 (4A5BC200)
fffff880`0321e000 fffff880`0322f000 blbdrive Tue Jul 14 01:35:59 2009 (4A5BC4DF)
fffff880`0322f000 fffff880`03255000 tunnel Tue Jul 14 02:09:37 2009 (4A5BCCC1)
fffff880`03255000 fffff880`0326b000 intelppm Tue Jul 14 01:19:25 2009 (4A5BC0FD)
fffff880`0326b000 fffff880`032c2000 Rt64win7 Thu Mar 04 14:42:52 2010 (4B8FB8DC)
fffff880`032c2000 fffff880`032e3000 WudfPf Tue Jul 14 02:05:37 2009 (4A5BCBD1)
fffff880`032f9000 fffff880`0334a000 rdbss Tue Jul 14 01:24:09 2009 (4A5BC219)
fffff880`0334a000 fffff880`03356000 nsiproxy Tue Jul 14 01:21:02 2009 (4A5BC15E)
fffff880`03356000 fffff880`03361000 mssmbios Tue Jul 14 01:31:10 2009 (4A5BC3BE)
fffff880`03361000 fffff880`03370000 discache Tue Jul 14 01:37:18 2009 (4A5BC52E)
fffff880`03370000 fffff880`033f3000 csc Tue Jul 14 01:24:26 2009 (4A5BC22A)
fffff880`03412000 fffff880`03fe2f00 nvlddmkm Sat Sep 11 06:24:42 2010 (4C8B048A)
fffff880`03fe3000 fffff880`03fe4180 nvBridge Sat Sep 11 06:21:30 2010 (4C8B03CA)
fffff880`03fe5000 fffff880`03ffa000 lltdio Tue Jul 14 02:08:50 2009 (4A5BCC92)
fffff880`04200000 fffff880`04256000 USBPORT Tue Jul 14 02:06:31 2009 (4A5BCC07)
fffff880`04256000 fffff880`0427a000 HDAudBus Tue Jul 14 02:06:13 2009 (4A5BCBF5)
fffff880`0427a000 fffff880`0429d000 luafv Tue Jul 14 01:26:13 2009 (4A5BC295)
fffff880`042b0000 fffff880`043a4000 dxgkrnl Fri Oct 02 03:00:14 2009 (4AC5509E)
fffff880`043a4000 fffff880`043ea000 dxgmms1 Tue Jul 14 01:38:32 2009 (4A5BC578)
fffff880`043ea000 fffff880`043fb000 usbehci Sat Oct 24 06:27:33 2009 (4AE28235)
fffff880`0460f000 fffff880`04651000 a9cv8vyh Tue Apr 07 18:07:00 2009 (49DB7A24)
fffff880`04651000 fffff880`0465a000 wmiacpi Tue Jul 14 01:31:02 2009 (4A5BC3B6)
fffff880`0465a000 fffff880`04772000 cfosspeed Tue Feb 10 11:45:55 2009 (49915AE3)
fffff880`04772000 fffff880`04782000 CompositeBus Tue Jul 14 02:00:33 2009 (4A5BCAA1)
fffff880`04782000 fffff880`04788a00 ManyCam_x64 Thu Mar 13 08:46:01 2008 (47D8DBB9)
fffff880`04789000 fffff880`04799d00 STREAM Tue Jul 14 02:06:18 2009 (4A5BCBFA)
fffff880`0479a000 fffff880`047dd000 ks Tue Jul 14 02:00:31 2009 (4A5BCA9F)
fffff880`047dd000 fffff880`047e2200 ksthunk Tue Jul 14 02:00:19 2009 (4A5BCA93)
fffff880`047e3000 fffff880`047ef000 SndTAudio Fri Jan 15 10:39:22 2010 (4B5037CA)
fffff880`047ef000 fffff880`047f9000 VMNET Mon Aug 10 14:04:50 2009 (4A800CE2)
fffff880`04800000 fffff880`04808000 LHidEqd Wed Jun 17 18:49:56 2009 (4A391EB4)
fffff880`04808000 fffff880`0481b000 LHidFilt Wed Jun 17 18:49:39 2009 (4A391EA3)
fffff880`0481b000 fffff880`04829000 monitor Tue Jul 14 01:38:52 2009 (4A5BC58C)
fffff880`0482d000 fffff880`04869000 vpchbus Wed Sep 23 03:32:32 2009 (4AB97AB0)
fffff880`04869000 fffff880`048c3000 usbhub Sat Oct 24 06:28:24 2009 (4AE28268)
fffff880`048c3000 fffff880`048d8000 NDProxy Tue Jul 14 02:10:05 2009 (4A5BCCDD)
fffff880`048d8000 fffff880`0495ef00 fwlanusbn Mon Feb 09 10:41:22 2009 (498FFA42)
fffff880`0495f000 fffff880`0497c000 usbccgp Tue Jul 14 02:06:45 2009 (4A5BCC15)
fffff880`0497c000 fffff880`04997000 USBSTOR Tue Jul 14 02:06:34 2009 (4A5BCC0A)
fffff880`04997000 fffff880`049b0000 HIDCLASS Tue Jul 14 02:06:21 2009 (4A5BCBFD)
fffff880`049b0000 fffff880`049c7000 LEqdUsb Wed Jun 17 18:49:54 2009 (4A391EB2)
fffff880`049c7000 fffff880`049d3000 Dxapi Tue Jul 14 01:38:28 2009 (4A5BC574)
fffff880`049d3000 fffff880`049e1000 kbdhid Tue Jul 14 02:00:20 2009 (4A5BCA94)
fffff880`049e1000 fffff880`049ec000 VMkbd Fri May 21 08:43:49 2010 (4BF62BA5)
fffff880`049ec000 fffff880`049f9000 mouhid Tue Jul 14 02:00:20 2009 (4A5BCA94)
fffff880`04a00000 fffff880`04a26b40 VBoxNetFlt Thu Dec 17 14:58:01 2009 (4B2A38E9)
fffff880`04a27000 fffff880`04a28480 swenum Tue Jul 14 02:00:18 2009 (4A5BCA92)
fffff880`04a29000 fffff880`04a3b000 circlass Tue Jul 14 02:06:34 2009 (4A5BCC0A)
fffff880`04a3b000 fffff880`04a4d000 umbus Tue Jul 14 02:06:56 2009 (4A5BCC20)
fffff880`04a4d000 fffff880`04a5d000 vmnetbridge Mon Aug 10 14:05:58 2009 (4A800D26)
fffff880`04a63000 fffff880`04aa0000 portcls Tue Jul 14 02:06:27 2009 (4A5BCC03)
fffff880`04aa0000 fffff880`04ac2000 drmk Tue Jul 14 03:01:25 2009 (4A5BD8E5)
fffff880`04ac2000 fffff880`04ad8000 AgileVpn Tue Jul 14 02:10:24 2009 (4A5BCCF0)
fffff880`04ad8000 fffff880`04afc000 rasl2tp Tue Jul 14 02:10:11 2009 (4A5BCCE3)
fffff880`04afc000 fffff880`04b08000 ndistapi Tue Jul 14 02:10:00 2009 (4A5BCCD8)
fffff880`04b08000 fffff880`04b37000 ndiswan Tue Jul 14 02:10:11 2009 (4A5BCCE3)
fffff880`04b37000 fffff880`04b52000 raspppoe Tue Jul 14 02:10:17 2009 (4A5BCCE9)
fffff880`04b52000 fffff880`04b73000 raspptp Tue Jul 14 02:10:18 2009 (4A5BCCEA)
fffff880`04b73000 fffff880`04b8d000 rassstp Tue Jul 14 02:10:25 2009 (4A5BCCF1)
fffff880`04b8d000 fffff880`04baa000 vpcusb Wed Sep 23 03:32:39 2009 (4AB97AB7)
fffff880`04baa000 fffff880`04bb9000 usbrpm Tue Jul 14 02:35:14 2009 (4A5BD2C2)
fffff880`04bb9000 fffff880`04bbaf00 USBD Tue Jul 14 02:06:23 2009 (4A5BCBFF)
fffff880`04bbe000 fffff880`04bc9000 rdpbus Tue Jul 14 02:17:46 2009 (4A5BCEAA)
fffff880`04bc9000 fffff880`04bd8000 kbdclass Tue Jul 14 01:19:50 2009 (4A5BC116)
fffff880`04bd8000 fffff880`04be7000 mouclass Tue Jul 14 01:19:50 2009 (4A5BC116)
fffff880`04be7000 fffff880`04bfb000 LMouFilt Wed Jun 17 18:49:43 2009 (4A391EA7)
fffff880`06000000 fffff880`0600e000 crashdmp Tue Jul 14 02:01:01 2009 (4A5BCABD)
fffff880`0600e000 fffff880`0601a000 dump_ataport Tue Jul 14 01:19:47 2009 (4A5BC113)
fffff880`0601a000 fffff880`06023000 dump_atapi Tue Jul 14 01:19:47 2009 (4A5BC113)
fffff880`06023000 fffff880`06036000 dump_dumpfve Tue Jul 14 01:21:51 2009 (4A5BC18F)
fffff880`06036000 fffff880`06044000 hidusb Tue Jul 14 02:06:22 2009 (4A5BCBFE)
fffff880`06049000 fffff880`061f4600 RTKVHD64 Tue Apr 14 10:18:07 2009 (49E446BF)
fffff880`061f5000 fffff880`061fd080 HIDPARSE Tue Jul 14 02:06:17 2009 (4A5BCBF9)
fffff880`09a00000 fffff880`09a18000 mpsdrv Tue Jul 14 02:08:25 2009 (4A5BCC79)
fffff880`09a18000 fffff880`09a45000 mrxsmb Sat Feb 27 08:52:19 2010 (4B88CF33)
fffff880`09a51000 fffff880`09aa4000 nwifi Tue Jul 14 02:07:23 2009 (4A5BCC3B)
fffff880`09aa4000 fffff880`09ab7000 ndisuio Tue Jul 14 02:09:25 2009 (4A5BCCB5)
fffff880`09ab7000 fffff880`09acf000 rspndr Tue Jul 14 02:08:50 2009 (4A5BCC92)
fffff880`09acf000 fffff880`09ad6000 TurboB Mon Nov 02 21:47:34 2009 (4AEF4566)
fffff880`09ad6000 fffff880`09b0c000 fastfat Tue Jul 14 01:23:28 2009 (4A5BC1F0)
fffff880`09b0c000 fffff880`09bd4000 HTTP Tue Jul 14 01:22:16 2009 (4A5BC1A8)
fffff880`09bd4000 fffff880`09bf2000 bowser Tue Jul 14 01:23:50 2009 (4A5BC206)
fffff880`0b000000 fffff880`0b0d6000 vmx86 Fri May 21 09:31:12 2010 (4BF636C0)
fffff880`0b0eb000 fffff880`0b139000 mrxsmb10 Sat Feb 27 08:52:28 2010 (4B88CF3C)
fffff880`0b139000 fffff880`0b15c000 mrxsmb20 Sat Feb 27 08:52:26 2010 (4B88CF3A)
fffff880`0b15c000 fffff880`0b168000 hcmon Fri May 21 07:54:08 2010 (4BF62000)
fffff880`0b168000 fffff880`0b180000 vmci Fri May 21 07:22:24 2010 (4BF61890)
fffff880`0b180000 fffff880`0b1cf000 atksgt Sun May 17 15:36:34 2009 (4A1012E2)
fffff880`0b1cf000 fffff880`0b1d7000 cpuz132_x64 Fri Mar 27 00:17:23 2009 (49CC0D03)
fffff880`0b1d7000 fffff880`0b1e4000 lirsgt Sun May 17 15:06:57 2009 (4A100BF1)
fffff880`0bc00000 fffff880`0bc2d000 srvnet Tue Jun 22 05:20:32 2010 (4C202C00)
fffff880`0bc2d000 fffff880`0bc3f000 tcpipreg Tue Jul 14 02:09:49 2009 (4A5BCCCD)
fffff880`0bc3f000 fffff880`0bc49000 vmnetuserif Fri May 21 08:08:24 2010 (4BF62358)
fffff880`0bc49000 fffff880`0bc55000 vstor2_ws60 Wed Apr 28 01:16:25 2010 (4BD77049)
fffff880`0bc55000 fffff880`0bcbd000 srv2 Tue Jun 22 05:20:47 2010 (4C202C0F)
fffff880`0bcde000 fffff880`0bd84000 peauth Tue Jul 14 03:01:19 2009 (4A5BD8DF)
fffff880`0bddb000 fffff880`0bde6000 secdrv Wed Sep 13 15:18:38 2006 (4508052E)
fffff880`0c26d000 fffff880`0c303000 srv Tue Jun 22 05:21:11 2010 (4C202C27)
fffff880`0c303000 fffff880`0c332000 ipnat Tue Jul 14 02:10:03 2009 (4A5BCCDB)
fffff880`0c332000 fffff880`0c342000 MpNWMon Sat Mar 20 06:58:00 2010 (4BA463E8)
fffff880`0c342000 fffff880`0c348000 RTCore64 Wed May 25 08:39:12 2005 (42941D90)
fffff880`0c348000 fffff880`0c352000 kerneld Sat Sep 05 19:27:16 2009 (4AA29F74)
fffff880`0c352000 fffff880`0c35d000 tdtcp Tue Jul 14 02:16:32 2009 (4A5BCE60)
fffff880`0c35d000 fffff880`0c36c000 tssecsrv Tue Jul 14 02:16:41 2009 (4A5BCE69)
fffff880`0c36c000 fffff880`0c3a4000 RDPWD Tue Jul 14 02:16:47 2009 (4A5BCE6F)
fffff960`000e0000 fffff960`003ef000 win32k Sat Jun 19 06:31:59 2010 (4C1C483F)
fffff960`00450000 fffff960`0045a000 TSDDD Tue Jul 14 02:16:34 2009 (4A5BCE62)
fffff960`00780000 fffff960`007a7000 cdd Wed May 19 21:48:26 2010 (4BF4408A)
fffff960`00910000 fffff960`00971000 ATMFD Thu May 27 06:11:31 2010 (4BFDF0F3)
Unloaded modules:
fffff880`0bd84000 fffff880`0bddb000 rixdpx64.sys
Timestamp: unavailable (00000000)
Checksum: 00000000
ImageSize: 00057000
fffff880`01b3d000 fffff880`01b4b000 crashdmp.sys
Checksum: 00000000
ImageSize: 0000E000
fffff880`01b4b000 fffff880`01b57000 dump_ataport
Checksum: 00000000
ImageSize: 0000C000
fffff880`01b57000 fffff880`01b60000 dump_atapi.s
Checksum: 00000000
ImageSize: 00009000
fffff880`01b60000 fffff880`01b73000 dump_dumpfve
Checksum: 00000000
ImageSize: 00013000
fffff880`04b8d000 fffff880`04bbe000 WUDFRd.sys
Checksum: 00000000
ImageSize: 00031000
*** work. ***
*** work. ***
*** work. ***
*** work. ***
*** work. ***
*** work. ***
*** work. ***
*** work. ***
Finished dump check
