Stirbt diese HDD?
airXgamer
Moin,
ich habe heute nach langer Zeit mal wieder ein sehr altes Notebook angeworfen, ein Asus EEE 1000HE. Während Linux seine Updates installierte, konnte ich deutliche Geräusche der HDD hören. Daraufhin habe ich dann mal schnell die Smartwerte ausgelesen:
smartctl 6.4 2014-10-07 r4002 [i686-linux-3.16.0-4-686-pae] (local build)
Copyright (C) 2002-14, Bruce Allen, Christian Franke, smartmontools
=== START OF INFORMATION SECTION ===
Model Family: Seagate Momentus 5400.5
Device Model: ST9160310AS
Serial Number: 5SV5AC1K
LU WWN Device Id: 5 000c50 01464e85e
Firmware Version: 0303
User Capacity: 160.041.885.696 bytes [160 GB]
Sector Size: 512 bytes logical/physical
Device is: In smartctl database [for details use: -P show]
ATA Version is: ATA8-ACS T13/1699-D revision 4
SATA Version is: SATA 2.6, 3.0 Gb/s
Local Time is: Sun Jun 23 14:11:26 2019 CEST
SMART support is: Available - device has SMART capability.
SMART support is: Enabled
=== START OF READ SMART DATA SECTION ===
SMART overall-health self-assessment test result: PASSED
See vendor-specific Attribute list for marginal Attributes.
General SMART Values:
Offline data collection status: (0x00) Offline data collection activity
was never started.
Auto Offline Data Collection: Disabled.
Self-test execution status: ( 0) The previous self-test routine completed
without error or no self-test has ever
been run.
Total time to complete Offline
data collection: ( 723) seconds.
capabilities: (0x73) SMART execute Offline immediate.
Auto Offline data collection on/off support.
Suspend Offline collection upon new
command.
No Offline surface scan supported.
Self-test supported.
Conveyance Self-test supported.
Selective Self-test supported.
SMART capabilities: (0x0003) Saves SMART data before entering
power-saving mode.
Supports SMART auto save timer.
Error logging capability: (0x01) Error logging supported.
General Purpose Logging supported.
Short self-test routine
recommended polling time: ( 1) minutes.
Extended self-test routine
recommended polling time: ( 63) minutes.
Conveyance self-test routine
recommended polling time: ( 2) minutes.
SCT capabilities: (0x103f) SCT Status supported.
SCT Error Recovery Control supported.
SCT Feature Control supported.
SCT Data Table supported.
SMART Attributes Data Structure revision number: 10
Vendor Specific SMART Attributes with Thresholds:
ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE
1 Raw_Read_Error_Rate 0x000f 117 099 006 Pre-fail Always - 156026916
3 Spin_Up_Time 0x0003 099 099 000 Pre-fail Always - 0
4 Start_Stop_Count 0x0032 099 099 020 Old_age Always - 1478
5 Reallocated_Sector_Ct 0x0033 100 100 036 Pre-fail Always - 0
7 Seek_Error_Rate 0x000f 072 060 030 Pre-fail Always - 17978830
9 Power_On_Hours 0x0032 099 099 000 Old_age Always - 878
10 Spin_Retry_Count 0x0013 100 100 097 Pre-fail Always - 0
12 Power_Cycle_Count 0x0032 099 099 020 Old_age Always - 1437
184 End-to-End_Error 0x0032 100 100 099 Old_age Always - 0
187 Reported_Uncorrect 0x0032 100 100 000 Old_age Always - 0
188 Command_Timeout 0x0032 100 099 000 Old_age Always - 396
189 High_Fly_Writes 0x003a 100 100 000 Old_age Always - 0
190 Airflow_Temperature_Cel 0x0022 057 042 045 Old_age Always In_the_past 43 (Min/Max 26/45 #10)
191 G-Sense_Error_Rate 0x0032 100 100 000 Old_age Always - 113
192 Power-Off_Retract_Count 0x0032 100 100 000 Old_age Always - 33
193 Load_Cycle_Count 0x0032 088 088 000 Old_age Always - 24887
194 Temperature_Celsius 0x0022 043 058 000 Old_age Always - 43 (0 13 0 0 0)
195 Hardware_ECC_Recovered 0x001a 063 058 000 Old_age Always - 156026916
197 Current_Pending_Sector 0x0012 100 100 000 Old_age Always - 0
198 Offline_Uncorrectable 0x0010 100 100 000 Old_age Offline - 0
199 UDMA_CRC_Error_Count 0x003e 200 200 000 Old_age Always - 0
SMART Error Log Version: 1
No Errors Logged
SMART Self-test log structure revision number 1
Num Test_Description Status Remaining LifeTime(hours) LBA_of_first_error
# 1 Short offline Completed without error 00% 640 -
# 2 Short offline Completed without error 00% 639 -
# 3 Short offline Completed without error 00% 639 -
# 4 Short offline Completed without error 00% 639 -
# 5 Short offline Completed without error 00% 639 -
SMART Selective self-test log data structure revision number 1
SPAN MIN_LBA MAX_LBA CURRENT_TEST_STATUS
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
Selective self-test flags (0x0):
After scanning selected spans, do NOT read-scan remainder of disk.
If Selective self-test is pending on power-up, resume after 0 minute delay.
Meine bescheidenen SMART Kenntnisse analysieren daraus: Platte hat einen weg, ist aber noch nicht ganz kaputt. Würdet ihr euch dieser Einordnung anschließen?
(Falls die Frage aufkommt: Ja, keine wichtigen Daten drauf und alles gesichert)
Mit freundlichen Grüßen,
AirX
Inzersdorfer
Die Festplatte ist bis auf die wohl älteren Command Timeouts ohne Fehler, keine Lesefehler oder Suchfehler, da bei diesen beiden Attributen von Seagate-HDDs der Hexadezimale Rohwert geteilt auszuwerten ist, leider berücksichtigt das smartctl nicht.
Die Geräusche könnten auch von Plattenselbsttests oder von Schreiboperationen der Updates kommen.
Nichtsdestotrotz kann jeder Massenspeicher, egal wie alt oder neu, egal wie gut oder schlecht sein Zustand sei, jederzeit ohne Vorwarnung vollständig ausfallen. Gegen Datenverlust hilft nur Datensicherung und gegebenenfalls Backups derselben.
