FreshlyChicken
Moin,
hier erstmal der Code
//Die 5 ausgewählten Zahlen
int[] randomZahl = {3,6,8,9,4};
void setup(){
size(500,500);
void draw(){
line(100,0,100,500);
line(200,0,200,500);
line(300,0,300,500);
line(400,0,400,500);
line(500,100,0,100);
line(500,200,0,200);
line(500,300,0,300);
line(500,400,0,400);
void mouseClicked(){
int a = 0;
//Zeile 1
if(mouseX<=100 && mouseY<=100){
rect(0,0,100,100);
a = 1;
else if(mouseX<=200 && mouseX>=100 && mouseY<=100 && mouseY>=0){
rect(100,0,100,100);
a = 2;
else if(mouseX<=300 && mouseX>=200 && mouseY<=100 && mouseY>=0){
rect(200,0,100,100);
a = 3;
else if(mouseX<=400 && mouseX>=300 && mouseY<=100 && mouseY>=0){
rect(300,0,100,100);
a = 4;
else if(mouseX<=500 && mouseX>=400 && mouseY<=100 && mouseY>=0){
rect(400,0,100,100);
a = 5;
//Zeile 2
else if(mouseX<=100 && mouseX>=0 && mouseY<=200 && mouseY>=100){
rect(0,100,100,100);
a = 6;
else if(mouseX<=200 && mouseX>=100 && mouseY<=200 && mouseY>=100){
rect(100,100,100,100);
a = 7;
else if(mouseX<=300 && mouseX>=200 && mouseY<=200 && mouseY>=100){
rect(200,100,100,100);
a = 8;
else if(mouseX<=400 && mouseX>=300 && mouseY<=200 && mouseY>=100){
rect(300,100,100,100);
a = 9;
else if(mouseX<=500 && mouseX>=400 && mouseY<=200 && mouseY>=100){
rect(400,100,100,100);
a = 10;
//Zeile 3
else if(mouseX<=100 && mouseX>=0 && mouseY<=300 && mouseY>=200){
rect(0,200,100,100);
a = 11;
else if(mouseX<=200 && mouseX>=100 && mouseY<=300 && mouseY>=200){
rect(100,200,100,100);
a = 12;
else if(mouseX<=300 && mouseX>=200 && mouseY<=300 && mouseY>=200){
rect(200,200,100,100);
a = 13;
else if(mouseX<=400 && mouseX>=300 && mouseY<=300 && mouseY>=200){
fill(0);
rect(300,200,100,100);
a = 14;
else if(mouseX<=500 && mouseX>=400 && mouseY<=300 && mouseY>=200){
rect(400,200,100,100);
a = 15;
//Zeile 4
else if(mouseX<=100 && mouseX>=0 && mouseY<=400 && mouseY>=300){
rect(0,300,100,100);
a = 16;
else if(mouseX<=200 && mouseX>=100 && mouseY<=400 && mouseY>=300){
rect(100,300,100,100);
a = 17;
else if(mouseX<=300 && mouseX>=200 && mouseY<=400 && mouseY>=300){
rect(200,300,100,100);
a = 18;
else if(mouseX<=400 && mouseX>=300 && mouseY<=400 && mouseY>=300){
rect(300,300,100,100);
a = 19;
else if(mouseX<=500 && mouseX>=400 && mouseY<=400 && mouseY>=300){
rect(400,300,100,100);
a = 20;
//Zeile 5
else if(mouseX<=100 && mouseX>=0 && mouseY<=500 && mouseY>=400){
rect(0,400,100,100);
a = 21;
else if(mouseX<=200 && mouseX>=100 && mouseY<=500 && mouseY>=400){
rect(100,400,100,100);
a = 22;
else if(mouseX<=300 && mouseX>=200 && mouseY<=500 && mouseY>=400){
rect(200,400,100,100);
a = 23;
else if(mouseX<=400 && mouseX>=300 && mouseY<=500 && mouseY>=400){
rect(300,400,100,100);
a = 24;
else if(mouseX<=500 && mouseX>=400 && mouseY<=500 && mouseY>=400){
rect(400,400,100,100);
a = 25;
for(int i = 0; i <= 25;++i){
if(randomZahl == a){
fill(0);
else{
fill(255);
void setup(){
size(500,500);
void draw(){
int a = 0;
//Zeile 1
rect(0,0,100,100);
a = 1;
a = 2;
a = 3;
a = 4;
a = 5;
//Zeile 2
a = 6;
a = 7;
a = 8;
a = 9;
a = 10;
//Zeile 3
a = 11;
a = 12;
a = 13;
fill(0);
a = 14;
a = 15;
//Zeile 4
a = 16;
a = 17;
a = 18;
a = 19;
a = 20;
//Zeile 5
a = 21;
a = 22;
a = 23;
a = 24;
a = 25;
fill(0);
else{
fill(255);
. Die Aufgabe war es ein einfaches Schiffe versenken zu programmieren, 25 Quadrate zu haben, vorher festzulegen welches Quadrat ein "Schiff" sogesagt ist und wenn man auf das richtige Feld klickt soll es eingefärbt werden. Wenn es falsch ist eine andere Farbe wo man erkennt das es falsch ist. Der Spieler hat dabei nur 5 Versuche danach wird in der Konsole ausgegeben das er verloren hat und es fängt von vorne an.
