Es gibt ein neues Bios für das P55 FTW / 200:
EVGA P55 FTW (E657) Updates:
* Improves USB Compatibility
* New CPU Support
* Improves Memory Compatibility
* ClockGen Switch Mode Disable Option to not power up twice
Download:
KLICK
EVGA P55 FTW 200 (E658) Updates:
* New CPU Support
Download:
KLICK
How-To Bios-Flash:
This flash is designed for Windows 32Bit/64Bit or DOS mode.
* Download the following .zip file: E658_A51.zip
* First go into your BIOS and load defaults, save and exit
* Go into the folder where you unzipped this package and run the appropriate batch file.
o For Windows XP, Vista or 7
32Bit: AFUWIN32.BAT
64Bit: AFUWIN64.BAT
o If in DOS Mode: AFUDOS.BAT
* Press Y in
CAPITAL LETTERS to start the flash process
DO NOT TURN OFF POWER OR RESET DURING THE FLASH PROCESS
* After the flashing is finished, shut down the computer. Then power on again and go into BIOS, Load Defaults, Save and Exit.
Warning:
**Do not restart or interrupt your PC while the flash is ongoing
**Do not Flash BIOS on overclocked settings
**It is always recommended to power-down after flash
