PyON 1 options
"checkpoint": "3",
"core-priority": "low",
"extra-core-args": "-forceasm",
"passkey": "********************************",
"pause-on-start": "true",
"power": "full",
"proxy": ":8080",
"team": "70335",
"user": "mattifolder"
> options -a -d
PyON 1 options
"allow": "127.0.0.1",
"auto-conf": "true",
"capture-directory": "capture",
"capture-on-error": "false",
"capture-packets": "false",
"capture-requests": "false",
"capture-responses": "false",
"capture-sockets": "false",
"cause": "ANY",
"certificate-file": None,
"checkpoint": "3",
"child": "false",
"client-subtype": "STDCLI",
"client-threads": "6",
"client-type": "normal",
"command-address": "0.0.0.0",
"command-allow-no-pass": "127.0.0.1",
"deny": "0/0",
"command-deny-no-pass": "0/0",
"command-enable": "true",
"command-port": "36330",
"config-rotate": "true",
"config-rotate-dir": "configs",
"config-rotate-max": "16",
"connection-timeout": "60",
"cpu-species": "X86_PENTIUM_II",
"cpu-type": "AMD64",
"cpu-usage": "100",
"cpus": "-1",
"crl-file": None,
"cuda-index": None,
"cycle-rate": "4",
"cycles": "-1",
"daemon": "false",
"debug-sockets": "false",
"disable-sleep-when-active": "true",
"disable-viz": "false",
"dump-after-deadline": "true",
"exception-locations": "true",
"exit-when-done": "false",
"fold-anon": "false",
"gpu": "true",
"gpu-beta": "false",
"gpu-index": None,
"gpu-usage": "100",
"gui-enabled": "true",
"http-addresses": "0:7396",
"https-addresses": "",
"idle": "false",
"log": "log.txt",
"log-color": "false",
"log-crlf": "true",
"log-date": "false",
"log-date-periodically": "21600",
"log-domain": "false",
"log-domain-levels": None,
"log-header": "true",
"log-level": "true",
"log-no-info-header": "true",
"log-redirect": "false",
"log-rotate": "true",
"log-rotate-dir": "logs",
"log-rotate-max": "16",
"log-short-level": "false",
"log-simple-domains": "true",
"log-thread-id": "false",
"log-thread-prefix": "true",
"log-time": "true",
"log-to-screen": "true",
"log-truncate": "false",
"machine-id": "0",
"max-connect-time": "900",
"max-connections": "800",
"max-packet-size": "normal",
"max-queue": "16",
"max-request-length": "52428800",
"max-shutdown-wait": "60",
"max-slot-errors": "10",
"max-unit-errors": "5",
"max-units": "0",
"memory": None,
"min-connect-time": "300",
"next-unit-percentage": "99",
"priority": None,
"no-assembly": "false",
"open-web-control": "false",
"opencl-index": None,
"os-species": "WIN_8",
"os-type": "WIN32",
"passkey": "16acbacf7513245daefbed952f8fd788",
"password": None,
"pause-on-battery": "true",
"paused": "false",
"pci-bus": None,
"pci-slot": None,
"pid": "false",
"pid-file": "FAHClient.pid",
"power": "full",
"private-key-file": None,
"project-key": "0",
"proxy": ":8080",
"proxy-enable": "false",
"proxy-pass": "",
"proxy-user": "",
"respawn": "false",
"service": "false",
"service-description": "FAHClient",
"service-restart": "true",
"service-restart-delay": "5000",
"session-cookie": "sid",
"session-lifetime": "86400",
"session-timeout": "3600",
"smp": "true",
"stack-traces": "false",
"stall-detection-enabled": "false",
"stall-percent": "5",
"stall-timeout": "1800",
"team": "70335",
"user": "mattifolder",
"verbosity": "3",
"web-allow": "127.0.0.1",
"web-deny": "0/0",
"web-enable": "true"
> slot-options 01 -d
PyON 1 slot-options
"client-type": "advanced",
"cpus": "6",
"machine-id": "1",
"max-packet-size": "big",
"next-unit-percentage": "100"
> quit
