20:47:20:INFO(1):Read GPUs.txt
20:47:20:************************* Folding@home Client *************************
20:47:20: Website:
Folding@home – Fighting disease with a world wide distributed super computer.
20:47:20: Copyright: (c) 2009-2018 foldingathome.org
20:47:20: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
20:47:20: Args:
20:47:20: Config: C:\Program Files (x86)\FAHClient\config.xml
20:47:20:******************************** Build ********************************
20:47:20: Version: 7.5.1
20:47:20: Date: May 11 2018
20:47:20: Time: 13:06:32
20:47:20: Repository: Git
20:47:20: Revision: 4705bf53c635f88b8fe85af7675557e15d491ff0
20:47:20: Branch: master
20:47:20: Compiler: Visual C++ 2008
20:47:20: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
20:47:20: Platform: win32 10
20:47:20: Bits: 32
20:47:20: Mode: Release
20:47:20:******************************* System ********************************
20:47:20: CPU: AMD Ryzen 9 3950X 16-Core Processor
20:47:20: CPU ID: AuthenticAMD Family 23 Model 113 Stepping 0
20:47:20: CPUs: 32
20:47:20: Memory: 31.95GiB
20:47:20: Free Memory: 20.51GiB
20:47:20: Threads: WINDOWS_THREADS
20:47:20: OS Version: 6.2
20:47:20: Has Battery: false
20:47:20: On Battery: false
20:47:20: UTC Offset: 1
20:47:20: PID: 17284
20:47:20: CWD: C:\Program Files (x86)\FAHClient
20:47:20: OS: Windows 10 Enterprise
20:47:20: OS Arch: AMD64
20:47:20: GPUs: 1
20:47:20: GPU 0: Bus:11 Slot:0 Func:0 NVIDIA:8 GP102 [GeForce GTX 1080 Ti] 11380
20:47:20: CUDA Device 0: Platform:0 Device:0 Bus:11 Slot:0 Compute:6.1 Driver:10.2
20:47:20:OpenCL Device 0: Platform:0 Device:0 Bus:11 Slot:0 Compute:1.2 Driver:442.59
20:47:20: Win32 Service: false
20:47:20:***********************************************************************
20:47:20:<config>
20:47:20: <service-description v='Folding@home Client'/>
20:47:20: <service-restart v='true'/>
20:47:20: <service-restart-delay v='5000'/>
20:47:20:
20:47:20: <!-- Client Control -->
20:47:20: <client-threads v='6'/>
20:47:20: <cycle-rate v='4'/>
20:47:20: <cycles v='-1'/>
20:47:20: <data-directory v='.'/>
20:47:20: <disable-sleep-when-active v='true'/>
20:47:20: <exec-directory v='C:\Program Files (x86)\FAHClient'/>
20:47:20: <exit-when-done v='false'/>
20:47:20: <fold-anon v='false'/>
20:47:20: <open-web-control v='false'/>
20:47:20:
20:47:20: <!-- Configuration -->
20:47:20: <config-rotate v='true'/>
20:47:20: <config-rotate-dir v='configs'/>
20:47:20: <config-rotate-max v='16'/>
20:47:20:
20:47:20: <!-- Debugging -->
20:47:20: <assignment-servers>
20:47:20: assign1.foldingathome.org:8080 assign2.foldingathome.org:80
20:47:20: </assignment-servers>
20:47:20: <auth-as v='true'/>
20:47:20: <capture-directory v='capture'/>
20:47:20: <capture-on-error v='false'/>
20:47:20: <capture-packets v='false'/>
20:47:20: <capture-requests v='false'/>
20:47:20: <capture-responses v='false'/>
20:47:20: <capture-sockets v='false'/>
20:47:20: <core-exec v='FahCore_$type'/>
20:47:20: <core-wrapper-exec v='FAHCoreWrapper'/>
20:47:20: <debug-sockets v='false'/>
20:47:20: <exception-locations v='true'/>
20:47:20: <stack-traces v='false'/>
20:47:20:
20:47:20: <!-- Error Handling -->
20:47:20: <max-slot-errors v='10'/>
20:47:20: <max-unit-errors v='5'/>
20:47:20:
20:47:20: <!-- Folding Core -->
20:47:20: <checkpoint v='15'/>
20:47:20: <core-dir v='cores'/>
20:47:20: <core-priority v='idle'/>
20:47:20: <cpu-affinity v='false'/>
20:47:20: <cpu-usage v='100'/>
20:47:20: <gpu-usage v='100'/>
20:47:20: <no-assembly v='false'/>
20:47:20:
20:47:20: <!-- Folding Slot Configuration -->
20:47:20: <cause v='ANY'/>
20:47:20: <client-subtype v='STDCLI'/>
20:47:20: <client-type v='normal'/>
20:47:20: <cpu-species v='X86_AMD'/>
20:47:20: <cpu-type v='AMD64'/>
20:47:20: <cpus v='-1'/>
20:47:20: <disable-viz v='false'/>
20:47:20: <gpu v='true'/>
20:47:20: <max-packet-size v='normal'/>
20:47:20: <os-species v='WIN_8'/>
20:47:20: <os-type v='WIN32'/>
20:47:20: <project-key v='0'/>
20:47:20: <smp v='true'/>
20:47:20:
20:47:20: <!-- GUI -->
20:47:20: <gui-enabled v='true'/>
20:47:20:
20:47:20: <!-- HTTP Server -->
20:47:20: <allow v='127.0.0.1'/>
20:47:20: <connection-timeout v='60'/>
20:47:20: <deny v='0/0'/>
20:47:20: <http-addresses v='0:7396'/>
20:47:20: <https-addresses v=''/>
20:47:20: <max-connect-time v='900'/>
20:47:20: <max-connections v='800'/>
20:47:20: <max-request-length v='52428800'/>
20:47:20: <min-connect-time v='300'/>
20:47:20:
20:47:20: <!-- Logging -->
20:47:20: <log v='log.txt'/>
20:47:20: <log-color v='false'/>
20:47:20: <log-crlf v='true'/>
20:47:20: <log-date v='false'/>
20:47:20: <log-date-periodically v='21600'/>
20:47:20: <log-domain v='false'/>
20:47:20: <log-header v='true'/>
20:47:20: <log-level v='true'/>
20:47:20: <log-no-info-header v='true'/>
20:47:20: <log-redirect v='false'/>
20:47:20: <log-rotate v='true'/>
20:47:20: <log-rotate-dir v='logs'/>
20:47:20: <log-rotate-max v='16'/>
20:47:20: <log-short-level v='false'/>
20:47:20: <log-simple-domains v='true'/>
20:47:20: <log-thread-id v='false'/>
20:47:20: <log-thread-prefix v='true'/>
20:47:20: <log-time v='true'/>
20:47:20: <log-to-screen v='true'/>
20:47:20: <log-truncate v='false'/>
20:47:20: <verbosity v='5'/>
20:47:20:
20:47:20: <!-- Network -->
20:47:20: <proxy v=':8080'/>
20:47:20: <proxy-enable v='false'/>
20:47:20: <proxy-pass v=''/>
20:47:20: <proxy-user v=''/>
20:47:20:
20:47:20: <!-- Process Control -->
20:47:20: <child v='false'/>
20:47:20: <daemon v='false'/>
20:47:20: <pid v='false'/>
20:47:20: <pid-file v='Folding@home Client.pid'/>
20:47:20: <respawn v='false'/>
20:47:20: <service v='false'/>
20:47:20:
20:47:20: <!-- Remote Command Server -->
20:47:20: <command-address v='0.0.0.0'/>
20:47:20: <command-allow-no-pass v='127.0.0.1'/>
20:47:20: <command-deny-no-pass v='0/0'/>
20:47:20: <command-enable v='true'/>
20:47:20: <command-port v='36330'/>
20:47:20:
20:47:20: <!-- Slot Control -->
20:47:20: <idle v='false'/>
20:47:20: <max-shutdown-wait v='60'/>
20:47:20: <pause-on-battery v='true'/>
20:47:20: <pause-on-start v='false'/>
20:47:20: <paused v='false'/>
20:47:20: <power v='full'/>
20:47:20:
20:47:20: <!-- User Information -->
20:47:20: <machine-id v='0'/>
20:47:20: <passkey v='********************************'/>
20:47:20: <team v='70335'/>
20:47:20: <user v='Valdiralita'/>
20:47:20:
20:47:20: <!-- Web Server -->
20:47:20: <web-allow v='127.0.0.1'/>
20:47:20: <web-deny v='0/0'/>
20:47:20: <web-enable v='true'/>
20:47:20:
20:47:20: <!-- Web Server Sessions -->
20:47:20: <session-cookie v='sid'/>
20:47:20: <session-lifetime v='86400'/>
20:47:20: <session-timeout v='3600'/>
20:47:20:
20:47:20: <!-- Work Unit Control -->
20:47:20: <dump-after-deadline v='true'/>
20:47:20: <max-queue v='16'/>
20:47:20: <max-units v='0'/>
20:47:20: <next-unit-percentage v='99'/>
20:47:20: <stall-detection-enabled v='false'/>
20:47:20: <stall-percent v='5'/>
20:47:20: <stall-timeout v='1800'/>
20:47:20:
20:47:20: <!-- Folding Slots -->
20:47:20: <slot id='0' type='GPU'>
20:47:20: <client-type v='advanced'/>
20:47:20: </slot>
20:47:20: <slot id='2' type='CPU'>
20:47:20: </slot>
20:47:20:</config>
20:47:21:Trying to access database...
20:47:21:Successfully acquired database lock
20:47:21:Enabled folding slot 00: READY gpu:0:GP102 [GeForce GTX 1080 Ti] 11380
20:47:21:Enabled folding slot 02: READY cpu:31
20:47:21:ERROR:Exception: Failed to register systray icon: Unbekannter Fehler
20:47:21:Started thread 4 on PID 17284
20:47:21:Started thread 5 on PID 17284
20:47:21:Started thread 7 on PID 17284
20:47:21:Started thread 6 on PID 17284
20:47:21:Started thread 8 on PID 17284
20:47:21:Started thread 9 on PID 17284
20:47:21:WU02:FS02:Starting
20:47:21:WARNING:WU02:FS02:Changed SMP threads from 16 to 31 this can cause some work units to fail
20:47:21:WU02:FS02:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" "C:\Program Files (x86)\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe" -dir 02 -suffix 01 -version 705 -lifeline 17284 -checkpoint 15 -np 31
20:47:21:WU02:FS02:Started FahCore on PID 10980
20:47:21:Started thread 10 on PID 17284
20:47:21:WU02:FS02:Core PID:1564
20:47:21:WU02:FS02:FahCore 0xa7 started
20:47:21:Started thread 11 on PID 17284
20:47:21:WU00:FS00:Connecting to 65.254.110.245:8080
20:47:21:WU01:FS02:Connecting to 65.254.110.245:8080
20:47:21:WU02:FS02:0xa7:*********************** Log Started 2020-03-17T20:47:21Z ***********************
20:47:21:WU02:FS02:0xa7:************************** Gromacs Folding@home Core ***************************
20:47:21:WU02:FS02:0xa7: Type: 0xa7
20:47:21:WU02:FS02:0xa7: Core: Gromacs
20:47:21:WU02:FS02:0xa7: Args: -dir 02 -suffix 01 -version 705 -lifeline 10980 -checkpoint 15 -np
20:47:21:WU02:FS02:0xa7: 31
20:47:21:WU02:FS02:0xa7:************************************ CBang *************************************
20:47:21:WU02:FS02:0xa7: Date: Oct 26 2019
20:47:21:WU02:FS02:0xa7: Time: 01:38:25
20:47:21:WU02:FS02:0xa7: Revision: c46a1a011a24143739ac7218c5a435f66777f62f
20:47:21:WU02:FS02:0xa7: Branch: master
20:47:21:WU02:FS02:0xa7: Compiler: Visual C++ 2008
20:47:21:WU02:FS02:0xa7: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
20:47:21:WU02:FS02:0xa7: Platform: win32 10
20:47:21:WU02:FS02:0xa7: Bits: 64
20:47:21:WU02:FS02:0xa7: Mode: Release
20:47:21:WU02:FS02:0xa7:************************************ System ************************************
20:47:21:WU02:FS02:0xa7: CPU: AMD Ryzen 9 3950X 16-Core Processor
20:47:21:WU02:FS02:0xa7: CPU ID: AuthenticAMD Family 23 Model 113 Stepping 0
20:47:21:WU02:FS02:0xa7: CPUs: 32
20:47:21:WU02:FS02:0xa7: Memory: 31.95GiB
20:47:21:WU02:FS02:0xa7:Free Memory: 20.50GiB
20:47:21:WU02:FS02:0xa7: Threads: WINDOWS_THREADS
20:47:21:WU02:FS02:0xa7: OS Version: 6.2
20:47:21:WU02:FS02:0xa7:Has Battery: false
20:47:21:WU02:FS02:0xa7: On Battery: false
20:47:21:WU02:FS02:0xa7: UTC Offset: 1
20:47:21:WU02:FS02:0xa7: PID: 1564
20:47:21:WU02:FS02:0xa7: CWD: C:\Program Files (x86)\FAHClient\work
20:47:21:WU02:FS02:0xa7:******************************** Build - libFAH ********************************
20:47:21:WU02:FS02:0xa7: Version: 0.0.18
20:47:21:WU02:FS02:0xa7: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
20:47:21:WU02:FS02:0xa7: Copyright: 2019 foldingathome.org
20:47:21:WU02:FS02:0xa7: Homepage:
20:47:21:WU02:FS02:0xa7: Time: 01:52:30
20:47:21:WU02:FS02:0xa7: Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
20:47:21:WU02:FS02:0xa7:************************************ Build *************************************
20:47:21:WU02:FS02:0xa7: SIMD: avx_256
20:47:21:WU02:FS02:0xa7:********************************************************************************
roject: 14328 (Run 7, Clone 4247, Gen 7)
20:47:22:WU02:FS02:0xa7:Unit: 0x000000089bf7a4d65e6d0d09bebef229
igital signatures verified
20:47:22:WU02:FS02:0xa7:Reducing thread count from 31 to 30 to avoid domain decomposition by a prime number > 3
20:47:22:WU02:FS02:0xa7:Calling: mdrun -s frame7.tpr -o frame7.trr -cpi state.cpt -cpt 15 -nt 30
20:47:22:WU02:FS02:0xa7:Steps: first=1750000 total=250000
20:47:23:WU02:FS02:0xa7:Completed 145762 out of 250000 steps (58%)
20:47:24:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
20:47:24:WU00:FS00:Connecting to 18.218.241.186:80
20:47:24:WARNING:WU01:FS02:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
20:47:24:WU01:FS02:Connecting to 18.218.241.186:80
20:47:25:WARNING:WU01:FS02:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
20:47:25:ERROR:WU01:FS02:Exception: Could not get an assignment
20:47:25:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
20:47:25:ERROR:WU00:FS00:Exception: Could not get an assignment
20:47:25:WU01:FS02:Connecting to 65.254.110.245:8080
20:47:25:WU00:FS00:Connecting to 65.254.110.245:8080
20:47:26:WARNING:WU01:FS02:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
20:47:26:WU01:FS02:Connecting to 18.218.241.186:80
20:47:26:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
20:47:26:WU00:FS00:Connecting to 18.218.241.186:80
20:47:26:WARNING:WU01:FS02:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
20:47:26:ERROR:WU01:FS02:Exception: Could not get an assignment
20:47:26:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
