[ 0.000000] Initializing cgroup subsys cpuset
[ 0.000000] Initializing cgroup subsys cpuacct
[ 0.000000] Linux version 4.4.0-13-generic (buildd@lgw01-23) (gcc version 4.8.2 (Ubuntu 4.8.2-19ubuntu1) ) #29~14.04.1-Ubuntu SMP Fri Mar 11 20:25:40 UTC 2016 (Ubuntu 4.4.0-13.29~14.04.1-generic 4.4.5)
[ 0.000000] Command line: BOOT_IMAGE=/boot/vmlinuz-4.4.0-13-generic root=UUID=7666fef3-5f9e-496c-9cb2-b44f25375f48 ro quiet splash vt.handoff=7
[ 0.000000] KERNEL supported cpus:
[ 0.000000] Intel GenuineIntel
[ 0.000000] AMD AuthenticAMD
[ 0.000000] Centaur CentaurHauls
[ 0.000000] x86/fpu: xstate_offset[2]: 576, xstate_sizes[2]: 256
[ 0.000000] x86/fpu: Supporting XSAVE feature 0x01: 'x87 floating point registers'
[ 0.000000] x86/fpu: Supporting XSAVE feature 0x02: 'SSE registers'
[ 0.000000] x86/fpu: Supporting XSAVE feature 0x04: 'AVX registers'
[ 0.000000] x86/fpu: Enabled xstate features 0x7, context size is 832 bytes, using 'standard' format.
[ 0.000000] x86/fpu: Using 'eager' FPU context switches.
[ 0.000000] e820: BIOS-provided physical RAM map:
[ 0.000000] BIOS-e820: [mem 0x0000000000000000-0x0000000000057fff] usable
[ 0.000000] BIOS-e820: [mem 0x0000000000058000-0x0000000000058fff] reserved
[ 0.000000] BIOS-e820: [mem 0x0000000000059000-0x000000000009efff] usable
[ 0.000000] BIOS-e820: [mem 0x000000000009f000-0x000000000009ffff] reserved
[ 0.000000] BIOS-e820: [mem 0x0000000000100000-0x00000000ca953fff] usable
[ 0.000000] BIOS-e820: [mem 0x00000000ca954000-0x00000000ca95afff] ACPI NVS
[ 0.000000] BIOS-e820: [mem 0x00000000ca95b000-0x00000000cb2aefff] usable
[ 0.000000] BIOS-e820: [mem 0x00000000cb2af000-0x00000000cb55dfff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000cb55e000-0x00000000dddb9fff] usable
[ 0.000000] BIOS-e820: [mem 0x00000000dddba000-0x00000000dde4afff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000dde4b000-0x00000000ddeaefff] usable
[ 0.000000] BIOS-e820: [mem 0x00000000ddeaf000-0x00000000ddff2fff] ACPI NVS
[ 0.000000] BIOS-e820: [mem 0x00000000ddff3000-0x00000000def89fff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000def8a000-0x00000000deffefff] type 20
[ 0.000000] BIOS-e820: [mem 0x00000000defff000-0x00000000deffffff] usable
[ 0.000000] BIOS-e820: [mem 0x00000000f8000000-0x00000000fbffffff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fec00000-0x00000000fec00fff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fed00000-0x00000000fed03fff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fed1c000-0x00000000fed1ffff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fee00000-0x00000000fee00fff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000ff000000-0x00000000ffffffff] reserved
[ 0.000000] BIOS-e820: [mem 0x0000000100000000-0x000000021dffffff] usable
[ 0.000000] NX (Execute Disable) protection: active
[ 0.000000] efi: EFI v2.31 by American Megatrends
[ 0.000000] efi: ACPI 2.0=0xddfb7000 ACPI=0xddfb7000 SMBIOS=0xf04c0 MPS=0xfd450
[ 0.000000] SMBIOS 2.7 present.
[ 0.000000] DMI: Gigabyte Technology Co., Ltd. H97M-D3H/H97M-D3H, BIOS F4 06/28/2014
[ 0.000000] e820: update [mem 0x00000000-0x00000fff] usable ==> reserved
[ 0.000000] e820: remove [mem 0x000a0000-0x000fffff] usable
[ 0.000000] e820: last_pfn = 0x21e000 max_arch_pfn = 0x400000000
[ 0.000000] MTRR default type: uncachable
[ 0.000000] MTRR fixed ranges enabled:
[ 0.000000] 00000-9FFFF write-back
[ 0.000000] A0000-BFFFF uncachable
[ 0.000000] C0000-CFFFF write-protect
[ 0.000000] D0000-DFFFF uncachable
[ 0.000000] E0000-FFFFF write-protect
[ 0.000000] MTRR variable ranges enabled:
[ 0.000000] 0 base 0000000000 mask 7E00000000 write-back
[ 0.000000] 1 base 0200000000 mask 7FF0000000 write-back
[ 0.000000] 2 base 0210000000 mask 7FF8000000 write-back
[ 0.000000] 3 base 0218000000 mask 7FFC000000 write-back
[ 0.000000] 4 base 021C000000 mask 7FFE000000 write-back
[ 0.000000] 5 base 00E0000000 mask 7FE0000000 uncachable
[ 0.000000] 6 disabled
[ 0.000000] 7 disabled
[ 0.000000] 8 disabled
[ 0.000000] 9 disabled
[ 0.000000] x86/PAT: Configuration [0-7]: WB WC UC- UC WB WC UC- WT
[ 0.000000] original variable MTRRs
[ 0.000000] reg 0, base: 0GB, range: 8GB, type WB
[ 0.000000] reg 1, base: 8GB, range: 256MB, type WB
[ 0.000000] reg 2, base: 8448MB, range: 128MB, type WB
[ 0.000000] reg 3, base: 8576MB, range: 64MB, type WB
[ 0.000000] reg 4, base: 8640MB, range: 32MB, type WB
[ 0.000000] reg 5, base: 3584MB, range: 512MB, type UC
[ 0.000000] total RAM covered: 8160M
[ 0.000000] Found optimal setting for mtrr clean up
[ 0.000000] gran_size: 64K chunk_size: 64M num_reg: 6 lose cover RAM: 0G
[ 0.000000] New variable MTRRs
[ 0.000000] reg 0, base: 0GB, range: 2GB, type WB
[ 0.000000] reg 1, base: 2GB, range: 1GB, type WB
[ 0.000000] reg 2, base: 3GB, range: 512MB, type WB
[ 0.000000] reg 3, base: 4GB, range: 4GB, type WB
[ 0.000000] reg 4, base: 8GB, range: 512MB, type WB
[ 0.000000] reg 5, base: 8672MB, range: 32MB, type UC
[ 0.000000] e820: update [mem 0xe0000000-0xffffffff] usable ==> reserved
[ 0.000000] e820: last_pfn = 0xdf000 max_arch_pfn = 0x400000000
[ 0.000000] found SMP MP-table at [mem 0x000fd740-0x000fd74f] mapped at [ffff8800000fd740]
[ 0.000000] Scanning 1 areas for low memory corruption
[ 0.000000] Base memory trampoline at [ffff880000097000] 97000 size 24576
[ 0.000000] Using GB pages for direct mapping
[ 0.000000] BRK [0x03001000, 0x03001fff] PGTABLE
[ 0.000000] BRK [0x03002000, 0x03002fff] PGTABLE
[ 0.000000] BRK [0x03003000, 0x03003fff] PGTABLE
[ 0.000000] BRK [0x03004000, 0x03004fff] PGTABLE
[ 0.000000] BRK [0x03005000, 0x03005fff] PGTABLE
[ 0.000000] BRK [0x03006000, 0x03006fff] PGTABLE
[ 0.000000] RAMDISK: [mem 0x34304000-0x36179fff]
[ 0.000000] ACPI: Early table checksum verification disabled
[ 0.000000] ACPI: RSDP 0x00000000DDFB7000 000024 (v02 ALASKA)
[ 0.000000] ACPI: XSDT 0x00000000DDFB7080 000084 (v01 ALASKA A M I 01072009 AMI 00010013)
[ 0.000000] ACPI: FACP 0x00000000DDFC7FA0 00010C (v05 ALASKA A M I 01072009 AMI 00010013)
[ 0.000000] ACPI: DSDT 0x00000000DDFB71A0 010DFE (v02 ALASKA A M I 00000088 INTL 20120711)
[ 0.000000] ACPI: FACS 0x00000000DDFF1080 000040
[ 0.000000] ACPI: APIC 0x00000000DDFC80B0 000092 (v03 ALASKA A M I 01072009 AMI 00010013)
[ 0.000000] ACPI: FPDT 0x00000000DDFC8148 000044 (v01 ALASKA A M I 01072009 AMI 00010013)
[ 0.000000] ACPI: SSDT 0x00000000DDFC8190 000BEE (v01 Ther_R Ther_Rvp 00001000 INTL 20120711)
[ 0.000000] ACPI: SSDT 0x00000000DDFC8D80 000539 (v01 PmRef Cpu0Ist 00003000 INTL 20051117)
[ 0.000000] ACPI: SSDT 0x00000000DDFC92C0 000B74 (v01 CpuRef CpuSsdt 00003000 INTL 20051117)
[ 0.000000] ACPI: MCFG 0x00000000DDFC9E38 00003C (v01 ALASKA A M I 01072009 MSFT 00000097)
[ 0.000000] ACPI: HPET 0x00000000DDFC9E78 000038 (v01 ALASKA A M I 01072009 AMI. 00000005)
[ 0.000000] ACPI: SSDT 0x00000000DDFC9EB0 00036D (v01 SataRe SataTabl 00001000 INTL 20120711)
[ 0.000000] ACPI: SSDT 0x00000000DDFCA220 005B5E (v01 SaSsdt SaSsdt 00003000 INTL 20120711)
[ 0.000000] ACPI: BGRT 0x00000000DDFCFD80 000038 (v00 ALASKA A M I 01072009 AMI 00010013)
[ 0.000000] ACPI: DMAR 0x00000000DDFCFDB8 000080 (v01 INTEL BDW 00000001 INTL 00000001)
[ 0.000000] ACPI: Local APIC address 0xfee00000
[ 0.000000] No NUMA configuration found
[ 0.000000] Faking a node at [mem 0x0000000000000000-0x000000021dffffff]
[ 0.000000] NODE_DATA(0) allocated [mem 0x21dff6000-0x21dffafff]
[ 0.000000] Zone ranges:
[ 0.000000] DMA [mem 0x0000000000001000-0x0000000000ffffff]
[ 0.000000] DMA32 [mem 0x0000000001000000-0x00000000ffffffff]
[ 0.000000] Normal [mem 0x0000000100000000-0x000000021dffffff]
[ 0.000000] Device empty
[ 0.000000] Movable zone start for each node
[ 0.000000] Early memory node ranges
[ 0.000000] node 0: [mem 0x0000000000001000-0x0000000000057fff]
[ 0.000000] node 0: [mem 0x0000000000059000-0x000000000009efff]
[ 0.000000] node 0: [mem 0x0000000000100000-0x00000000ca953fff]
[ 0.000000] node 0: [mem 0x00000000ca95b000-0x00000000cb2aefff]
[ 0.000000] node 0: [mem 0x00000000cb55e000-0x00000000dddb9fff]
[ 0.000000] node 0: [mem 0x00000000dde4b000-0x00000000ddeaefff]
[ 0.000000] node 0: [mem 0x00000000defff000-0x00000000deffffff]
[ 0.000000] node 0: [mem 0x0000000100000000-0x000000021dffffff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000000001000-0x000000021dffffff]
[ 0.000000] On node 0 totalpages: 2079494
[ 0.000000] DMA zone: 64 pages used for memmap
[ 0.000000] DMA zone: 25 pages reserved
[ 0.000000] DMA zone: 3997 pages, LIFO batch:0
[ 0.000000] DMA32 zone: 14126 pages used for memmap
[ 0.000000] DMA32 zone: 904041 pages, LIFO batch:31
[ 0.000000] Normal zone: 18304 pages used for memmap
[ 0.000000] Normal zone: 1171456 pages, LIFO batch:31
[ 0.000000] ACPI: PM-Timer IO Port: 0x1808
[ 0.000000] ACPI: LAPIC_NMI (acpi_id[0xff] high edge lint[0x1])
[ 0.000000] IOAPIC[0]: apic_id 8, version 32, address 0xfec00000, GSI 0-23
[ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
[ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level)
[ 0.000000] ACPI: IRQ0 used by override.
[ 0.000000] ACPI: IRQ9 used by override.
[ 0.000000] Using ACPI (MADT) for SMP configuration information
[ 0.000000] ACPI: HPET id: 0x8086a701 base: 0xfed00000
[ 0.000000] smpboot: Allowing 8 CPUs, 0 hotplug CPUs
[ 0.000000] PM: Registered nosave memory: [mem 0x00000000-0x00000fff]
[ 0.000000] PM: Registered nosave memory: [mem 0x00058000-0x00058fff]
[ 0.000000] PM: Registered nosave memory: [mem 0x0009f000-0x0009ffff]
[ 0.000000] PM: Registered nosave memory: [mem 0x000a0000-0x000fffff]
[ 0.000000] PM: Registered nosave memory: [mem 0xca954000-0xca95afff]
[ 0.000000] PM: Registered nosave memory: [mem 0xcb2af000-0xcb55dfff]
[ 0.000000] PM: Registered nosave memory: [mem 0xdddba000-0xdde4afff]
[ 0.000000] PM: Registered nosave memory: [mem 0xddeaf000-0xddff2fff]
[ 0.000000] PM: Registered nosave memory: [mem 0xddff3000-0xdef89fff]
[ 0.000000] PM: Registered nosave memory: [mem 0xdef8a000-0xdeffefff]
[ 0.000000] PM: Registered nosave memory: [mem 0xdf000000-0xf7ffffff]
[ 0.000000] PM: Registered nosave memory: [mem 0xf8000000-0xfbffffff]
[ 0.000000] PM: Registered nosave memory: [mem 0xfc000000-0xfebfffff]
[ 0.000000] PM: Registered nosave memory: [mem 0xfec00000-0xfec00fff]
[ 0.000000] PM: Registered nosave memory: [mem 0xfec01000-0xfecfffff]
[ 0.000000] PM: Registered nosave memory: [mem 0xfed00000-0xfed03fff]
[ 0.000000] PM: Registered nosave memory: [mem 0xfed04000-0xfed1bfff]
[ 0.000000] PM: Registered nosave memory: [mem 0xfed1c000-0xfed1ffff]
[ 0.000000] PM: Registered nosave memory: [mem 0xfed20000-0xfedfffff]
[ 0.000000] PM: Registered nosave memory: [mem 0xfee00000-0xfee00fff]
[ 0.000000] PM: Registered nosave memory: [mem 0xfee01000-0xfeffffff]
[ 0.000000] PM: Registered nosave memory: [mem 0xff000000-0xffffffff]
[ 0.000000] e820: [mem 0xdf000000-0xf7ffffff] available for PCI devices
[ 0.000000] Booting paravirtualized kernel on bare hardware
[ 0.000000] clocksource: refined-jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645519600211568 ns
[ 0.000000] setup_percpu: NR_CPUS:256 nr_cpumask_bits:256 nr_cpu_ids:8 nr_node_ids:1
[ 0.000000] PERCPU: Embedded 33 pages/cpu @ffff88021dc00000 s98072 r8192 d28904 u262144
[ 0.000000] pcpu-alloc: s98072 r8192 d28904 u262144 alloc=1*2097152
[ 0.000000] pcpu-alloc: [0] 0 1 2 3 4 5 6 7
[ 0.000000] Built 1 zonelists in Node order, mobility grouping on. Total pages: 2046975
[ 0.000000] Policy zone: Normal
[ 0.000000] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-4.4.0-13-generic root=UUID=7666fef3-5f9e-496c-9cb2-b44f25375f48 ro quiet splash vt.handoff=7
[ 0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.000000] Calgary: detecting Calgary via BIOS EBDA area
[ 0.000000] Calgary: Unable to locate Rio Grande table in EBDA - bailing!
[ 0.000000] Memory: 7868476K/8317976K available (8116K kernel code, 1284K rwdata, 3936K rodata, 1480K init, 1292K bss, 449500K reserved, 0K cma-reserved)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=8, Nodes=1
[ 0.000000] Hierarchical RCU implementation.
[ 0.000000] Build-time adjustment of leaf fanout to 64.
[ 0.000000] RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=8.
[ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=64, nr_cpu_ids=8
[ 0.000000] NR_IRQS:16640 nr_irqs:488 16
[ 0.000000] vt handoff: transparent VT on vt#7
[ 0.000000] Console: colour dummy device 80x25
[ 0.000000] console [tty0] enabled
[ 0.000000] clocksource: hpet: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 133484882848 ns
[ 0.000000] hpet clockevent registered
[ 0.000000] tsc: Fast TSC calibration using PIT
[ 0.000000] spurious 8259A interrupt: IRQ7.
[ 0.000000] tsc: Detected 3399.850 MHz processor
[ 0.000019] Calibrating delay loop (skipped), value calculated using timer frequency.. 6799.70 BogoMIPS (lpj=13599400)
[ 0.000021] pid_max: default: 32768 minimum: 301
[ 0.000024] ACPI: Core revision 20150930
[ 0.009960] ACPI: 6 ACPI AML tables successfully acquired and loaded
[ 0.010653] Security Framework initialized
[ 0.010654] Yama: becoming mindful.
[ 0.010663] AppArmor: AppArmor initialized
[ 0.011006] Dentry cache hash table entries: 1048576 (order: 11, 8388608 bytes)
[ 0.012529] Inode-cache hash table entries: 524288 (order: 10, 4194304 bytes)
[ 0.013214] Mount-cache hash table entries: 16384 (order: 5, 131072 bytes)
[ 0.013221] Mountpoint-cache hash table entries: 16384 (order: 5, 131072 bytes)
[ 0.013385] Initializing cgroup subsys io
[ 0.013388] Initializing cgroup subsys memory
[ 0.013392] Initializing cgroup subsys devices
[ 0.013393] Initializing cgroup subsys freezer
[ 0.013394] Initializing cgroup subsys net_cls
[ 0.013396] Initializing cgroup subsys perf_event
[ 0.013397] Initializing cgroup subsys net_prio
[ 0.013399] Initializing cgroup subsys hugetlb
[ 0.013401] Initializing cgroup subsys pids
[ 0.013417] CPU: Physical Processor ID: 0
[ 0.013417] CPU: Processor Core ID: 0
[ 0.014129] mce: CPU supports 9 MCE banks
[ 0.014139] CPU0: Thermal monitoring enabled (TM1)
[ 0.014146] process: using mwait in idle threads
[ 0.014148] Last level iTLB entries: 4KB 1024, 2MB 1024, 4MB 1024
[ 0.014148] Last level dTLB entries: 4KB 1024, 2MB 1024, 4MB 1024, 1GB 4
[ 0.014370] Freeing SMP alternatives memory: 28K (ffffffff81eb5000 - ffffffff81ebc000)
[ 0.019723] ftrace: allocating 31825 entries in 125 pages
[ 0.028369] DMAR: Host address width 39
[ 0.028371] DMAR: DRHD base: 0x000000fed90000 flags: 0x1
[ 0.028376] DMAR: dmar0: reg_base_addr fed90000 ver 1:0 cap d2008c20660462 ecap f010da
[ 0.028377] DMAR: RMRR base: 0x000000deece000 end: 0x000000deedcfff
[ 0.028379] DMAR-IR: IOAPIC id 8 under DRHD base 0xfed90000 IOMMU 0
[ 0.028379] DMAR-IR: HPET id 0 under DRHD base 0xfed90000
[ 0.028380] DMAR-IR: x2apic is disabled because BIOS sets x2apic opt out bit.
[ 0.028381] DMAR-IR: Use 'intremap=no_x2apic_optout' to override the BIOS setting.
[ 0.028535] DMAR-IR: Enabled IRQ remapping in xapic mode
[ 0.028536] x2apic: IRQ remapping doesn't support X2APIC mode
[ 0.028918] ..TIMER: vector=0x30 apic1=0 pin1=2 apic2=-1 pin2=-1
[ 0.068603] TSC deadline timer enabled
[ 0.068605] smpboot: CPU0: Intel(R) Xeon(R) CPU E3-1231 v3 @ 3.40GHz (family: 0x6, model: 0x3c, stepping: 0x3)
[ 0.068623] Performance Events: PEBS fmt2+, 16-deep LBR, Haswell events, full-width counters, Intel PMU driver.
[ 0.068636] ... version: 3
[ 0.068636] ... bit width: 48
[ 0.068637] ... generic registers: 4
[ 0.068637] ... value mask: 0000ffffffffffff
[ 0.068638] ... max period: 0000ffffffffffff
[ 0.068638] ... fixed-purpose events: 3
[ 0.068639] ... event mask: 000000070000000f
[ 0.069171] x86: Booting SMP configuration:
[ 0.069172] .... node #0, CPUs: #1
[ 0.072688] NMI watchdog: enabled on all CPUs, permanently consumes one hw-PMU counter.
[ 0.072732] #2 #3 #4 #5 #6 #7
[ 0.091562] x86: Booted up 1 node, 8 CPUs
[ 0.091566] smpboot: Total of 8 processors activated (54397.60 BogoMIPS)
[ 0.097844] devtmpfs: initialized
[ 0.099401] evm: security.selinux
[ 0.099402] evm: security.SMACK64
[ 0.099402] evm: security.SMACK64EXEC
[ 0.099403] evm: security.SMACK64TRANSMUTE
[ 0.099403] evm: security.SMACK64MMAP
[ 0.099404] evm: security.ima
[ 0.099404] evm: security.capability
[ 0.099441] PM: Registering ACPI NVS region [mem 0xca954000-0xca95afff] (28672 bytes)
[ 0.099442] PM: Registering ACPI NVS region [mem 0xddeaf000-0xddff2fff] (1327104 bytes)
[ 0.099509] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.099563] pinctrl core: initialized pinctrl subsystem
[ 0.099635] RTC time: 16:06:03, date: 05/24/16
[ 0.099709] NET: Registered protocol family 16
[ 0.109739] cpuidle: using governor ladder
[ 0.121745] cpuidle: using governor menu
[ 0.121748] PCCT header not found.
[ 0.121796] ACPI FADT declares the system doesn't support PCIe ASPM, so disable it
[ 0.121797] ACPI: bus type PCI registered
[ 0.121798] acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
[ 0.121846] PCI: MMCONFIG for domain 0000 [bus 00-3f] at [mem 0xf8000000-0xfbffffff] (base 0xf8000000)
[ 0.121848] PCI: MMCONFIG at [mem 0xf8000000-0xfbffffff] reserved in E820
[ 0.121853] PCI: Using configuration type 1 for base access
[ 0.122054] perf_event_intel: PMU erratum BJ122, BV98, HSD29 worked around, HT is on
[ 0.137971] ACPI: Added _OSI(Module Device)
[ 0.137972] ACPI: Added _OSI(Processor Device)
[ 0.137973] ACPI: Added _OSI(3.0 _SCP Extensions)
[ 0.137973] ACPI: Added _OSI(Processor Aggregator Device)
[ 0.141190] ACPI: Executed 15 blocks of module-level executable AML code
[ 0.143632] ACPI: Dynamic OEM Table Load:
[ 0.143636] ACPI: SSDT 0xFFFF880213954000 0003D3 (v01 PmRef Cpu0Cst 00003001 INTL 20051117)
[ 0.144103] ACPI: Dynamic OEM Table Load:
[ 0.144106] ACPI: SSDT 0xFFFF880213D01800 0005AA (v01 PmRef ApIst 00003000 INTL 20051117)
[ 0.144596] ACPI: Dynamic OEM Table Load:
[ 0.144598] ACPI: SSDT 0xFFFF880213943400 000119 (v01 PmRef ApCst 00003000 INTL 20051117)
[ 0.145998] ACPI: Interpreter enabled
[ 0.146003] ACPI Exception: AE_NOT_FOUND, While evaluating Sleep State [\_S1_] (20150930/hwxface-580)
[ 0.146007] ACPI Exception: AE_NOT_FOUND, While evaluating Sleep State [\_S2_] (20150930/hwxface-580)
[ 0.146018] ACPI: (supports S0 S3 S4 S5)
[ 0.146019] ACPI: Using IOAPIC for interrupt routing
[ 0.146036] PCI: Using host bridge windows from ACPI; if necessary, use "pci=nocrs" and report a bug
[ 0.146308] ACPI: Power Resource [PG00] (on)
[ 0.146551] ACPI: Power Resource [PG01] (on)
[ 0.146765] ACPI: Power Resource [PG02] (on)
[ 0.153146] ACPI: Power Resource [FN00] (off)
[ 0.153189] ACPI: Power Resource [FN01] (off)
[ 0.153231] ACPI: Power Resource [FN02] (off)
[ 0.153271] ACPI: Power Resource [FN03] (off)
[ 0.153313] ACPI: Power Resource [FN04] (off)
[ 0.153851] ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-3e])
[ 0.153855] acpi PNP0A08:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI]
[ 0.154172] acpi PNP0A08:00: _OSC: OS now controls [PCIeHotplug PME AER PCIeCapability]
[ 0.154173] acpi PNP0A08:00: FADT indicates ASPM is unsupported, using BIOS configuration
[ 0.154468] PCI host bridge to bus 0000:00
[ 0.154470] pci_bus 0000:00: root bus resource [io 0x0000-0x0cf7 window]
[ 0.154471] pci_bus 0000:00: root bus resource [io 0x0d00-0xffff window]
[ 0.154472] pci_bus 0000:00: root bus resource [mem 0x000a0000-0x000bffff window]
[ 0.154473] pci_bus 0000:00: root bus resource [mem 0x000d0000-0x000d3fff window]
[ 0.154474] pci_bus 0000:00: root bus resource [mem 0x000d4000-0x000d7fff window]
[ 0.154475] pci_bus 0000:00: root bus resource [mem 0x000d8000-0x000dbfff window]
[ 0.154476] pci_bus 0000:00: root bus resource [mem 0x000dc000-0x000dffff window]
[ 0.154477] pci_bus 0000:00: root bus resource [mem 0xe0000000-0xfeafffff window]
[ 0.154478] pci_bus 0000:00: root bus resource [bus 00-3e]
[ 0.154483] pci 0000:00:00.0: [8086:0c08] type 00 class 0x060000
[ 0.154539] pci 0000:00:01.0: [8086:0c01] type 01 class 0x060400
[ 0.154562] pci 0000:00:01.0: PME# supported from D0 D3hot D3cold
[ 0.154615] pci 0000:00:01.0: System wakeup disabled by ACPI
[ 0.154659] pci 0000:00:14.0: [8086:8cb1] type 00 class 0x0c0330
[ 0.154680] pci 0000:00:14.0: reg 0x10: [mem 0xf7200000-0xf720ffff 64bit]
[ 0.154721] pci 0000:00:14.0: PME# supported from D3hot D3cold
[ 0.154755] pci 0000:00:14.0: System wakeup disabled by ACPI
[ 0.154778] pci 0000:00:16.0: [8086:8cba] type 00 class 0x078000
[ 0.154800] pci 0000:00:16.0: reg 0x10: [mem 0xf7218000-0xf721800f 64bit]
[ 0.154844] pci 0000:00:16.0: PME# supported from D0 D3hot D3cold
[ 0.154904] pci 0000:00:1a.0: [8086:8cad] type 00 class 0x0c0320
[ 0.154927] pci 0000:00:1a.0: reg 0x10: [mem 0xf7217000-0xf72173ff]
[ 0.154988] pci 0000:00:1a.0: PME# supported from D0 D3hot D3cold
[ 0.155020] pci 0000:00:1a.0: System wakeup disabled by ACPI
[ 0.155044] pci 0000:00:1b.0: [8086:8ca0] type 00 class 0x040300
[ 0.155062] pci 0000:00:1b.0: reg 0x10: [mem 0xf7210000-0xf7213fff 64bit]
[ 0.155102] pci 0000:00:1b.0: PME# supported from D0 D3hot D3cold
[ 0.155134] pci 0000:00:1b.0: System wakeup disabled by ACPI
[ 0.155155] pci 0000:00:1c.0: [8086:8c90] type 01 class 0x060400
[ 0.155206] pci 0000:00:1c.0: PME# supported from D0 D3hot D3cold
[ 0.155251] pci 0000:00:1c.0: System wakeup disabled by ACPI
[ 0.155273] pci 0000:00:1c.2: [8086:8c94] type 01 class 0x060400
[ 0.155325] pci 0000:00:1c.2: PME# supported from D0 D3hot D3cold
[ 0.155368] pci 0000:00:1c.2: System wakeup disabled by ACPI
[ 0.155391] pci 0000:00:1c.3: [8086:8c96] type 01 class 0x060400
[ 0.155442] pci 0000:00:1c.3: PME# supported from D0 D3hot D3cold
[ 0.155485] pci 0000:00:1c.3: System wakeup disabled by ACPI
[ 0.155511] pci 0000:00:1d.0: [8086:8ca6] type 00 class 0x0c0320
[ 0.155534] pci 0000:00:1d.0: reg 0x10: [mem 0xf7216000-0xf72163ff]
[ 0.155594] pci 0000:00:1d.0: PME# supported from D0 D3hot D3cold
[ 0.155627] pci 0000:00:1d.0: System wakeup disabled by ACPI
[ 0.155650] pci 0000:00:1f.0: [8086:8cc6] type 00 class 0x060100
[ 0.155777] pci 0000:00:1f.2: [8086:8c82] type 00 class 0x010601
[ 0.155793] pci 0000:00:1f.2: reg 0x10: [io 0xf070-0xf077]
[ 0.155799] pci 0000:00:1f.2: reg 0x14: [io 0xf060-0xf063]
[ 0.155804] pci 0000:00:1f.2: reg 0x18: [io 0xf050-0xf057]
[ 0.155810] pci 0000:00:1f.2: reg 0x1c: [io 0xf040-0xf043]
[ 0.155815] pci 0000:00:1f.2: reg 0x20: [io 0xf020-0xf03f]
[ 0.155820] pci 0000:00:1f.2: reg 0x24: [mem 0xf7215000-0xf72157ff]
[ 0.155841] pci 0000:00:1f.2: PME# supported from D3hot
[ 0.155883] pci 0000:00:1f.3: [8086:8ca2] type 00 class 0x0c0500
[ 0.155896] pci 0000:00:1f.3: reg 0x10: [mem 0xf7214000-0xf72140ff 64bit]
[ 0.155912] pci 0000:00:1f.3: reg 0x20: [io 0xf000-0xf01f]
[ 0.155990] pci 0000:01:00.0: [10de:17c8] type 00 class 0x030000
[ 0.156006] pci 0000:01:00.0: reg 0x10: [mem 0xf6000000-0xf6ffffff]
[ 0.156014] pci 0000:01:00.0: reg 0x14: [mem 0xe0000000-0xefffffff 64bit pref]
[ 0.156023] pci 0000:01:00.0: reg 0x1c: [mem 0xf0000000-0xf1ffffff 64bit pref]
[ 0.156029] pci 0000:01:00.0: reg 0x24: [io 0xe000-0xe07f]
[ 0.156034] pci 0000:01:00.0: reg 0x30: [mem 0xf7000000-0xf707ffff pref]
[ 0.156080] pci 0000:01:00.0: System wakeup disabled by ACPI
[ 0.156103] pci 0000:01:00.1: [10de:0fb0] type 00 class 0x040300
[ 0.156119] pci 0000:01:00.1: reg 0x10: [mem 0xf7080000-0xf7083fff]
[ 0.161772] pci 0000:00:01.0: PCI bridge to [bus 01]
[ 0.161774] pci 0000:00:01.0: bridge window [io 0xe000-0xefff]
[ 0.161775] pci 0000:00:01.0: bridge window [mem 0xf6000000-0xf70fffff]
[ 0.161777] pci 0000:00:01.0: bridge window [mem 0xe0000000-0xf1ffffff 64bit pref]
[ 0.161819] acpiphp: Slot [1] registered
[ 0.161822] pci 0000:00:1c.0: PCI bridge to [bus 02]
[ 0.161876] pci 0000:03:00.0: [10ec:8168] type 00 class 0x020000
[ 0.161911] pci 0000:03:00.0: reg 0x10: [io 0xd000-0xd0ff]
[ 0.161937] pci 0000:03:00.0: reg 0x18: [mem 0xf7100000-0xf7100fff 64bit]
[ 0.161953] pci 0000:03:00.0: reg 0x20: [mem 0xf2100000-0xf2103fff 64bit pref]
[ 0.162016] pci 0000:03:00.0: supports D1 D2
[ 0.162017] pci 0000:03:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.162058] pci 0000:03:00.0: System wakeup disabled by ACPI
[ 0.169779] pci 0000:00:1c.2: PCI bridge to [bus 03]
[ 0.169781] pci 0000:00:1c.2: bridge window [io 0xd000-0xdfff]
[ 0.169783] pci 0000:00:1c.2: bridge window [mem 0xf7100000-0xf71fffff]
[ 0.169787] pci 0000:00:1c.2: bridge window [mem 0xf2100000-0xf21fffff 64bit pref]
[ 0.169838] pci 0000:04:00.0: [8086:244e] type 01 class 0x060401
[ 0.169951] pci 0000:04:00.0: supports D1 D2
[ 0.169952] pci 0000:04:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.169978] pci 0000:04:00.0: System wakeup disabled by ACPI
[ 0.169995] pci 0000:00:1c.3: PCI bridge to [bus 04-05]
[ 0.170105] pci 0000:04:00.0: PCI bridge to [bus 05] (subtractive decode)
[ 0.170686] ACPI: PCI Interrupt Link [LNKA] (IRQs 4 6 10 *11 12 14 15)
[ 0.170716] ACPI: PCI Interrupt Link [LNKB] (IRQs 4 6 *10 11 12 14 15)
[ 0.170743] ACPI: PCI Interrupt Link [LNKC] (IRQs 4 6 *10 11 12 14 15)
[ 0.170771] ACPI: PCI Interrupt Link [LNKD] (IRQs 4 6 10 *11 12 14 15)
[ 0.170797] ACPI: PCI Interrupt Link [LNKE] (IRQs 4 6 10 11 12 14 15) *0, disabled.
[ 0.170824] ACPI: PCI Interrupt Link [LNKF] (IRQs 4 6 10 11 12 14 15) *0, disabled.
[ 0.170852] ACPI: PCI Interrupt Link [LNKG] (IRQs 4 6 10 *11 12 14 15)
[ 0.170879] ACPI: PCI Interrupt Link [LNKH] (IRQs 4 6 *10 11 12 14 15)
[ 0.171045] ACPI: Enabled 5 GPEs in block 00 to 3F
[ 0.171111] vgaarb: setting as boot device: PCI:0000:01:00.0
[ 0.171113] vgaarb: device added: PCI:0000:01:00.0,decodes=io+mem,owns=io+mem,locks=none
[ 0.171114] vgaarb: loaded
[ 0.171114] vgaarb: bridge control possible 0000:01:00.0
[ 0.171246] SCSI subsystem initialized
[ 0.171266] libata version 3.00 loaded.
[ 0.171280] ACPI: bus type USB registered
[ 0.171289] usbcore: registered new interface driver usbfs
[ 0.171293] usbcore: registered new interface driver hub
[ 0.171305] usbcore: registered new device driver usb
[ 0.171404] PCI: Using ACPI for IRQ routing
[ 0.172545] PCI: pci_cache_line_size set to 64 bytes
[ 0.172585] e820: reserve RAM buffer [mem 0x00058000-0x0005ffff]
[ 0.172586] e820: reserve RAM buffer [mem 0x0009f000-0x0009ffff]
[ 0.172587] e820: reserve RAM buffer [mem 0xca954000-0xcbffffff]
[ 0.172588] e820: reserve RAM buffer [mem 0xcb2af000-0xcbffffff]
[ 0.172588] e820: reserve RAM buffer [mem 0xdddba000-0xdfffffff]
[ 0.172589] e820: reserve RAM buffer [mem 0xddeaf000-0xdfffffff]
[ 0.172590] e820: reserve RAM buffer [mem 0xdf000000-0xdfffffff]
[ 0.172591] e820: reserve RAM buffer [mem 0x21e000000-0x21fffffff]
[ 0.172656] NetLabel: Initializing
[ 0.172657] NetLabel: domain hash size = 128
[ 0.172657] NetLabel: protocols = UNLABELED CIPSOv4
[ 0.172664] NetLabel: unlabeled traffic allowed by default
[ 0.172700] hpet0: at MMIO 0xfed00000, IRQs 2, 8, 0, 0, 0, 0, 0, 0
[ 0.172703] hpet0: 8 comparators, 64-bit 14.318180 MHz counter
[ 0.174720] clocksource: Switched to clocksource hpet
[ 0.178265] AppArmor: AppArmor Filesystem Enabled
[ 0.178296] pnp: PnP ACPI init
[ 0.178359] system 00:00: [mem 0xfed40000-0xfed44fff] has been reserved
[ 0.178361] system 00:00: Plug and Play ACPI device, IDs PNP0c01 (active)
[ 0.178409] system 00:01: [io 0x0800-0x087f] has been reserved
[ 0.178410] system 00:01: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.178422] pnp 00:02: Plug and Play ACPI device, IDs PNP0b00 (active)
[ 0.178443] system 00:03: [io 0x1854-0x1857] has been reserved
[ 0.178445] system 00:03: Plug and Play ACPI device, IDs INT3f0d PNP0c02 (active)
[ 0.178522] system 00:04: [io 0x0a00-0x0a0f] has been reserved
[ 0.178523] system 00:04: [io 0x0a30-0x0a3f] has been reserved
[ 0.178524] system 00:04: [io 0x0a20-0x0a2f] has been reserved
[ 0.178525] system 00:04: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.178660] pnp 00:05: [dma 0 disabled]
[ 0.178685] pnp 00:05: Plug and Play ACPI device, IDs PNP0501 (active)
[ 0.178861] pnp 00:06: [dma 0 disabled]
[ 0.178924] pnp 00:06: Plug and Play ACPI device, IDs PNP0400 (active)
[ 0.178949] system 00:07: [io 0x04d0-0x04d1] has been reserved
[ 0.178951] system 00:07: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.179209] system 00:08: [mem 0xfed1c000-0xfed1ffff] has been reserved
[ 0.179210] system 00:08: [mem 0xfed10000-0xfed17fff] has been reserved
[ 0.179211] system 00:08: [mem 0xfed18000-0xfed18fff] has been reserved
[ 0.179212] system 00:08: [mem 0xfed19000-0xfed19fff] has been reserved
[ 0.179213] system 00:08: [mem 0xf8000000-0xfbffffff] has been reserved
[ 0.179214] system 00:08: [mem 0xfed20000-0xfed3ffff] has been reserved
[ 0.179215] system 00:08: [mem 0xfed90000-0xfed93fff] could not be reserved
[ 0.179216] system 00:08: [mem 0xfed45000-0xfed8ffff] has been reserved
[ 0.179217] system 00:08: [mem 0xff000000-0xffffffff] has been reserved
[ 0.179218] system 00:08: [mem 0xfee00000-0xfeefffff] could not be reserved
[ 0.179219] system 00:08: [mem 0xf7fe0000-0xf7feffff] has been reserved
[ 0.179221] system 00:08: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.179320] pnp: PnP ACPI: found 9 devices
[ 0.184852] clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
[ 0.184886] pci 0000:00:01.0: PCI bridge to [bus 01]
[ 0.184887] pci 0000:00:01.0: bridge window [io 0xe000-0xefff]
[ 0.184889] pci 0000:00:01.0: bridge window [mem 0xf6000000-0xf70fffff]
[ 0.184891] pci 0000:00:01.0: bridge window [mem 0xe0000000-0xf1ffffff 64bit pref]
[ 0.184894] pci 0000:00:1c.0: PCI bridge to [bus 02]
[ 0.184901] pci 0000:00:1c.2: PCI bridge to [bus 03]
[ 0.184903] pci 0000:00:1c.2: bridge window [io 0xd000-0xdfff]
[ 0.184906] pci 0000:00:1c.2: bridge window [mem 0xf7100000-0xf71fffff]
[ 0.184908] pci 0000:00:1c.2: bridge window [mem 0xf2100000-0xf21fffff 64bit pref]
[ 0.184912] pci 0000:04:00.0: PCI bridge to [bus 05]
[ 0.184930] pci 0000:00:1c.3: PCI bridge to [bus 04-05]
[ 0.184938] pci_bus 0000:00: resource 4 [io 0x0000-0x0cf7 window]
[ 0.184939] pci_bus 0000:00: resource 5 [io 0x0d00-0xffff window]
[ 0.184940] pci_bus 0000:00: resource 6 [mem 0x000a0000-0x000bffff window]
[ 0.184941] pci_bus 0000:00: resource 7 [mem 0x000d0000-0x000d3fff window]
[ 0.184942] pci_bus 0000:00: resource 8 [mem 0x000d4000-0x000d7fff window]
[ 0.184943] pci_bus 0000:00: resource 9 [mem 0x000d8000-0x000dbfff window]
[ 0.184944] pci_bus 0000:00: resource 10 [mem 0x000dc000-0x000dffff window]
[ 0.184945] pci_bus 0000:00: resource 11 [mem 0xe0000000-0xfeafffff window]
[ 0.184945] pci_bus 0000:01: resource 0 [io 0xe000-0xefff]
[ 0.184946] pci_bus 0000:01: resource 1 [mem 0xf6000000-0xf70fffff]
[ 0.184947] pci_bus 0000:01: resource 2 [mem 0xe0000000-0xf1ffffff 64bit pref]
[ 0.184948] pci_bus 0000:03: resource 0 [io 0xd000-0xdfff]
[ 0.184949] pci_bus 0000:03: resource 1 [mem 0xf7100000-0xf71fffff]
[ 0.184950] pci_bus 0000:03: resource 2 [mem 0xf2100000-0xf21fffff 64bit pref]
[ 0.184969] NET: Registered protocol family 2
[ 0.185070] TCP established hash table entries: 65536 (order: 7, 524288 bytes)
[ 0.185188] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes)
[ 0.185354] TCP: Hash tables configured (established 65536 bind 65536)
[ 0.185373] UDP hash table entries: 4096 (order: 5, 131072 bytes)
[ 0.185399] UDP-Lite hash table entries: 4096 (order: 5, 131072 bytes)
[ 0.185448] NET: Registered protocol family 1
[ 0.218755] pci 0000:01:00.0: Video device with shadowed ROM
[ 0.218765] PCI: CLS 64 bytes, default 64
[ 0.218792] Trying to unpack rootfs image as initramfs...
[ 0.518395] Freeing initrd memory: 31192K (ffff880034304000 - ffff88003617a000)
[ 0.518414] PCI-DMA: Using software bounce buffering for IO (SWIOTLB)
[ 0.518416] software IO TLB [mem 0xcd4ee000-0xd14ee000] (64MB) mapped at [ffff8800cd4ee000-ffff8800d14edfff]
[ 0.518462] RAPL PMU detected, API unit is 2^-32 Joules, 4 fixed counters 655360 ms ovfl timer
[ 0.518463] hw unit of domain pp0-core 2^-14 Joules
[ 0.518463] hw unit of domain package 2^-14 Joules
[ 0.518464] hw unit of domain dram 2^-14 Joules
[ 0.518464] hw unit of domain pp1-gpu 2^-14 Joules
[ 0.518529] Scanning for low memory corruption every 60 seconds
[ 0.518778] futex hash table entries: 2048 (order: 5, 131072 bytes)
[ 0.518801] audit: initializing netlink subsys (disabled)
[ 0.518810] audit: type=2000 audit(1464105963.516:1): initialized
[ 0.519000] Initialise system trusted keyring
[ 0.519079] HugeTLB registered 1 GB page size, pre-allocated 0 pages
[ 0.519080] HugeTLB registered 2 MB page size, pre-allocated 0 pages
[ 0.519945] zbud: loaded
[ 0.520068] VFS: Disk quotas dquot_6.6.0
[ 0.520086] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.520359] fuse init (API version 7.23)
[ 0.520436] Key type big_key registered
[ 0.520656] Key type asymmetric registered
[ 0.520658] Asymmetric key parser 'x509' registered
[ 0.520679] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 249)
[ 0.520705] io scheduler noop registered
[ 0.520707] io scheduler deadline registered (default)
[ 0.520725] io scheduler cfq registered
[ 0.521263] pcieport 0000:00:01.0: Signaling PME through PCIe PME interrupt
[ 0.521265] pci 0000:01:00.0: Signaling PME through PCIe PME interrupt
[ 0.521266] pci 0000:01:00.1: Signaling PME through PCIe PME interrupt
[ 0.521267] pcie_pme 0000:00:01.0:pcie01: service driver pcie_pme loaded
[ 0.521279] pcieport 0000:00:1c.0: Signaling PME through PCIe PME interrupt
[ 0.521281] pcie_pme 0000:00:1c.0:pcie01: service driver pcie_pme loaded
[ 0.521294] pcieport 0000:00:1c.2: Signaling PME through PCIe PME interrupt
[ 0.521294] pci 0000:03:00.0: Signaling PME through PCIe PME interrupt
[ 0.521297] pcie_pme 0000:00:1c.2:pcie01: service driver pcie_pme loaded
[ 0.521308] pcieport 0000:00:1c.3: Signaling PME through PCIe PME interrupt
[ 0.521309] pci 0000:04:00.0: Signaling PME through PCIe PME interrupt
[ 0.521311] pcie_pme 0000:00:1c.3:pcie01: service driver pcie_pme loaded
[ 0.521315] pci_hotplug: PCI Hot Plug PCI Core version: 0.5
[ 0.521319] pciehp: PCI Express Hot Plug Controller Driver version: 0.4
[ 0.521338] efifb: probing for efifb
[ 0.521347] efifb: framebuffer at 0xf1000000, mapped to 0xffffc90001000000, using 3072k, total 3072k
[ 0.521348] efifb: mode is 1024x768x32, linelength=4096, pages=1
[ 0.521349] efifb: scrolling: redraw
[ 0.521349] efifb: Truecolor: size=8:8:8:8, shift=24:16:8:0
[ 0.521396] Console: switching to colour frame buffer device 128x48
[ 0.521404] fb0: EFI VGA frame buffer device
[ 0.521409] intel_idle: MWAIT substates: 0x42120
[ 0.521410] intel_idle: v0.4 model 0x3C
[ 0.521410] intel_idle: lapic_timer_reliable_states 0xffffffff
[ 0.521638] input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input0
[ 0.521640] ACPI: Power Button [PWRB]
[ 0.521660] input: Sleep Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0E:00/input/input1
[ 0.521662] ACPI: Sleep Button [SLPB]
[ 0.521682] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input2
[ 0.521683] ACPI: Power Button [PWRF]
[ 0.522170] thermal LNXTHERM:00: registered as thermal_zone0
[ 0.522171] ACPI: Thermal Zone [TZ00] (28 C)
[ 0.522300] thermal LNXTHERM:01: registered as thermal_zone1
[ 0.522301] ACPI: Thermal Zone [TZ01] (30 C)
[ 0.522342] GHES: HEST is not enabled!
[ 0.522401] Serial: 8250/16550 driver, 32 ports, IRQ sharing enabled
[ 0.542803] 00:05: ttyS0 at I/O 0x3f8 (irq = 4, base_baud = 115200) is a 16550A
[ 0.543752] Linux agpgart interface v0.103
[ 0.545738] brd: module loaded
[ 0.546705] loop: module loaded
[ 0.546854] libphy: Fixed MDIO Bus: probed
[ 0.546857] tun: Universal TUN/TAP device driver, 1.6
[ 0.546857] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[ 0.546881] PPP generic driver version 2.4.2
[ 0.546916] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 0.546919] ehci-pci: EHCI PCI platform driver
[ 0.546981] ehci-pci 0000:00:1a.0: EHCI Host Controller
[ 0.546984] ehci-pci 0000:00:1a.0: new USB bus registered, assigned bus number 1
[ 0.546992] ehci-pci 0000:00:1a.0: debug port 2
[ 0.550878] ehci-pci 0000:00:1a.0: cache line size of 64 is not supported
[ 0.550885] ehci-pci 0000:00:1a.0: irq 16, io mem 0xf7217000
[ 0.562763] ehci-pci 0000:00:1a.0: USB 2.0 started, EHCI 1.00
[ 0.562793] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 0.562794] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.562795] usb usb1: Product: EHCI Host Controller
[ 0.562795] usb usb1: Manufacturer: Linux 4.4.0-13-generic ehci_hcd
[ 0.562796] usb usb1: SerialNumber: 0000:00:1a.0
[ 0.562886] hub 1-0:1.0: USB hub found
[ 0.562889] hub 1-0:1.0: 2 ports detected
[ 0.563002] ehci-pci 0000:00:1d.0: EHCI Host Controller
[ 0.563005] ehci-pci 0000:00:1d.0: new USB bus registered, assigned bus number 2
[ 0.563012] ehci-pci 0000:00:1d.0: debug port 2
[ 0.566902] ehci-pci 0000:00:1d.0: cache line size of 64 is not supported
[ 0.566909] ehci-pci 0000:00:1d.0: irq 23, io mem 0xf7216000
[ 0.578775] ehci-pci 0000:00:1d.0: USB 2.0 started, EHCI 1.00
[ 0.578790] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
[ 0.578791] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.578792] usb usb2: Product: EHCI Host Controller
[ 0.578793] usb usb2: Manufacturer: Linux 4.4.0-13-generic ehci_hcd
[ 0.578794] usb usb2: SerialNumber: 0000:00:1d.0
[ 0.578887] hub 2-0:1.0: USB hub found
[ 0.578889] hub 2-0:1.0: 2 ports detected
[ 0.578952] ehci-platform: EHCI generic platform driver
[ 0.578958] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 0.578961] ohci-pci: OHCI PCI platform driver
[ 0.578967] ohci-platform: OHCI generic platform driver
[ 0.578972] uhci_hcd: USB Universal Host Controller Interface driver
[ 0.579032] xhci_hcd 0000:00:14.0: xHCI Host Controller
[ 0.579034] xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 3
[ 0.580095] xhci_hcd 0000:00:14.0: hcc params 0x200077c1 hci version 0x100 quirks 0x00009810
[ 0.580098] xhci_hcd 0000:00:14.0: cache line size of 64 is not supported
[ 0.580174] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002
[ 0.580175] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.580175] usb usb3: Product: xHCI Host Controller
[ 0.580176] usb usb3: Manufacturer: Linux 4.4.0-13-generic xhci-hcd
[ 0.580177] usb usb3: SerialNumber: 0000:00:14.0
[ 0.580262] hub 3-0:1.0: USB hub found
[ 0.580276] hub 3-0:1.0: 14 ports detected
[ 0.582392] xhci_hcd 0000:00:14.0: xHCI Host Controller
[ 0.582394] xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 4
[ 0.582415] usb usb4: New USB device found, idVendor=1d6b, idProduct=0003
[ 0.582415] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.582416] usb usb4: Product: xHCI Host Controller
[ 0.582417] usb usb4: Manufacturer: Linux 4.4.0-13-generic xhci-hcd
[ 0.582418] usb usb4: SerialNumber: 0000:00:14.0
[ 0.582494] hub 4-0:1.0: USB hub found
[ 0.582503] hub 4-0:1.0: 6 ports detected
[ 0.583708] i8042: PNP: No PS/2 controller found. Probing ports directly.
[ 0.584054] serio: i8042 KBD port at 0x60,0x64 irq 1
[ 0.584057] serio: i8042 AUX port at 0x60,0x64 irq 12
[ 0.584167] mousedev: PS/2 mouse device common for all mice
[ 0.584395] rtc_cmos 00:02: RTC can wake from S4
[ 0.584513] rtc_cmos 00:02: rtc core: registered rtc_cmos as rtc0
[ 0.584544] rtc_cmos 00:02: alarms up to one month, y3k, 242 bytes nvram, hpet irqs
[ 0.584548] i2c /dev entries driver
[ 0.584577] device-mapper: uevent: version 1.0.3
[ 0.584655] device-mapper: ioctl: 4.34.0-ioctl (2015-10-28) initialised:
dm-devel@redhat.com
[ 0.584663] Intel P-state driver initializing.
[ 0.584862] ledtrig-cpu: registered to indicate activity on CPUs
[ 0.584875] EFI Variables Facility v0.08 2004-May-17
[ 0.610493] NET: Registered protocol family 10
[ 0.610627] NET: Registered protocol family 17
[ 0.610634] Key type dns_resolver registered
[ 0.610786] microcode: CPU0 sig=0x306c3, pf=0x2, revision=0x12
[ 0.610799] microcode: CPU1 sig=0x306c3, pf=0x2, revision=0x12
[ 0.610804] microcode: CPU2 sig=0x306c3, pf=0x2, revision=0x12
[ 0.610823] microcode: CPU3 sig=0x306c3, pf=0x2, revision=0x12
[ 0.610842] microcode: CPU4 sig=0x306c3, pf=0x2, revision=0x12
[ 0.610856] microcode: CPU5 sig=0x306c3, pf=0x2, revision=0x12
[ 0.610861] microcode: CPU6 sig=0x306c3, pf=0x2, revision=0x12
[ 0.610879] microcode: CPU7 sig=0x306c3, pf=0x2, revision=0x12
[ 0.610911] microcode: Microcode Update Driver: v2.01 <tigran@aivazian.fsnet.co.uk>, Peter Oruba
[ 0.611029] registered taskstats version 1
[ 0.611042] Loading compiled-in X.509 certificates
[ 0.611531] Loaded X.509 cert 'Build time autogenerated kernel key: c461202e0e8271c9f18dea07428000e954e004b7'
[ 0.611542] zswap: loaded using pool lzo/zbud
[ 0.612610] Key type trusted registered
[ 0.614348] Key type encrypted registered
[ 0.614351] AppArmor: AppArmor sha1 policy hashing enabled
[ 0.614353] ima: No TPM chip found, activating TPM-bypass!
[ 0.614365] evm: HMAC attrs: 0x1
[ 0.614675] Magic number: 0:559:136
[ 0.614678] usb usb4-port1: hash matches
[ 0.614682] block ram1: hash matches
[ 0.614813] rtc_cmos 00:02: setting system clock to 2016-05-24 16:06:04 UTC (1464105964)
[ 0.614854] BIOS EDD facility v0.16 2004-Jun-25, 0 devices found
[ 0.614855] EDD information not available.
[ 0.614900] PM: Hibernation image not present or could not be loaded.
[ 0.615474] Freeing unused kernel memory: 1480K (ffffffff81d43000 - ffffffff81eb5000)
[ 0.615475] Write protecting the kernel read-only data: 12288k
[ 0.615691] Freeing unused kernel memory: 64K (ffff8800027f0000 - ffff880002800000)
[ 0.615967] Freeing unused kernel memory: 160K (ffff880002bd8000 - ffff880002c00000)
[ 0.622804] systemd-udevd[154]: starting version 204
[ 0.629230] FUJITSU Extended Socket Network Device Driver - version 1.0 - Copyright (c) 2015 FUJITSU LIMITED
[ 0.630760] sdhci: Secure Digital Host Controller Interface driver
[ 0.630762] sdhci: Copyright(c) Pierre Ossman
[ 0.636850] ahci 0000:00:1f.2: version 3.0
[ 0.636965] ahci 0000:00:1f.2: AHCI 0001.0300 32 slots 6 ports 6 Gbps 0x4 impl SATA mode
[ 0.636968] ahci 0000:00:1f.2: flags: 64bit ncq led clo pio slum part ems apst
[ 0.637195] r8169 Gigabit Ethernet driver 2.3LK-NAPI loaded
[ 0.637200] r8169 0000:03:00.0: can't disable ASPM; OS doesn't have ASPM control
[ 0.637726] scsi host0: ahci
[ 0.637758] r8169 0000:03:00.0 eth0: RTL8168evl/8111evl at 0xffffc90000e7e000, 74:d4:35:ff:15:27, XID 0c900800 IRQ 31
[ 0.637761] r8169 0000:03:00.0 eth0: jumbo features [frames: 9200 bytes, tx checksumming: ko]
[ 0.637822] scsi host1: ahci
[ 0.637894] scsi host2: ahci
[ 0.637966] scsi host3: ahci
[ 0.638033] scsi host4: ahci
[ 0.638105] scsi host5: ahci
[ 0.638158] ata1: DUMMY
[ 0.638159] ata2: DUMMY
[ 0.638160] ata3: SATA max UDMA/133 abar m2048@0xf7215000 port 0xf7215200 irq 30
[ 0.638161] ata4: DUMMY
[ 0.638162] ata5: DUMMY
[ 0.638162] ata6: DUMMY
[ 0.874787] usb 1-1: new high-speed USB device number 2 using ehci-pci
[ 0.890787] usb 3-3: new low-speed USB device number 2 using xhci_hcd
[ 0.890793] usb 2-1: new high-speed USB device number 2 using ehci-pci
[ 0.954798] ata3: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[ 0.955799] ata3.00: ATA-9: TS32GSSD370, N1114H, max UDMA/133
[ 0.955801] ata3.00: 62533296 sectors, multi 2: LBA48 NCQ (depth 31/32), AA
[ 0.956530] ata3.00: configured for UDMA/133
[ 0.956679] scsi 2:0:0:0: Direct-Access ATA TS32GSSD370 4H PQ: 0 ANSI: 5
[ 0.956904] sd 2:0:0:0: Attached scsi generic sg0 type 0
[ 0.956952] sd 2:0:0:0: [sda] 62533296 512-byte logical blocks: (32.0 GB/29.8 GiB)
[ 0.957196] sd 2:0:0:0: [sda] Write Protect is off
[ 0.957198] sd 2:0:0:0: [sda] Mode Sense: 00 3a 00 00
[ 0.957269] sd 2:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 0.960093] sda: sda1 sda2 sda3
[ 0.960588] sd 2:0:0:0: [sda] Attached SCSI disk
[ 1.007248] usb 1-1: New USB device found, idVendor=8087, idProduct=8009
[ 1.007250] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 1.007504] hub 1-1:1.0: USB hub found
[ 1.007611] hub 1-1:1.0: 6 ports detected
[ 1.022699] usb 3-3: New USB device found, idVendor=046d, idProduct=c016
[ 1.022701] usb 3-3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 1.022702] usb 3-3: Product: Optical USB Mouse
[ 1.022702] usb 3-3: Manufacturer: Logitech
[ 1.022789] usb 3-3: ep 0x81 - rounding interval to 64 microframes, ep desc says 80 microframes
[ 1.023266] usb 2-1: New USB device found, idVendor=8087, idProduct=8001
[ 1.023268] usb 2-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 1.023493] hub 2-1:1.0: USB hub found
[ 1.023582] hub 2-1:1.0: 8 ports detected
[ 1.025115] hidraw: raw HID events driver (C) Jiri Kosina
[ 1.027545] usbcore: registered new interface driver usbhid
[ 1.027547] usbhid: USB HID core driver
[ 1.028397] input: Logitech Optical USB Mouse as /devices/pci0000:00/0000:00:14.0/usb3/3-3/3-3:1.0/0003:046D:C016.0001/input/input6
[ 1.028465] hid-generic 0003:046D:C016.0001: input,hidraw0: USB HID v1.10 Mouse [Logitech Optical USB Mouse] on usb-0000:00:14.0-3/input0
[ 1.134788] usb 3-4: new high-speed USB device number 3 using xhci_hcd
[ 1.264119] usb 3-4: New USB device found, idVendor=0bda, idProduct=8178
[ 1.264121] usb 3-4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 1.264122] usb 3-4: Product: USB WLAN
[ 1.264123] usb 3-4: Manufacturer: 802.11n
[ 1.264124] usb 3-4: SerialNumber: 00e04c000001
[ 1.430799] usb 3-8: new low-speed USB device number 4 using xhci_hcd
[ 1.514804] tsc: Refined TSC clocksource calibration: 3399.997 MHz
[ 1.514806] clocksource: tsc: mask: 0xffffffffffffffff max_cycles: 0x31024bd20a6, max_idle_ns: 440795346804 ns
[ 1.634153] usb 3-8: New USB device found, idVendor=1241, idProduct=1503
[ 1.634154] usb 3-8: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 1.634155] usb 3-8: Product: USB Keyboard
[ 1.634156] usb 3-8: Manufacturer:
[ 1.634219] usb 3-8: ep 0x81 - rounding interval to 64 microframes, ep desc says 80 microframes
[ 1.634222] usb 3-8: ep 0x82 - rounding interval to 64 microframes, ep desc says 80 microframes
[ 1.644187] input: USB Keyboard as /devices/pci0000:00/0000:00:14.0/usb3/3-8/3-8:1.0/0003:1241:1503.0002/input/input7
[ 1.698961] hid-generic 0003:1241:1503.0002: input,hidraw1: USB HID v1.10 Keyboard [ USB Keyboard] on usb-0000:00:14.0-8/input0
[ 1.715226] input: USB Keyboard as /devices/pci0000:00/0000:00:14.0/usb3/3-8/3-8:1.1/0003:1241:1503.0003/input/input8
[ 1.770967] hid-generic 0003:1241:1503.0003: input,hidraw2: USB HID v1.10 Device [ USB Keyboard] on usb-0000:00:14.0-8/input1
[ 2.060749] EXT4-fs (sda2): mounted filesystem with ordered data mode. Opts: (null)
[ 2.168634] random: init urandom read with 22 bits of entropy available
[ 2.315585] Adding 8316924k swap on /dev/sda3. Priority:-1 extents:1 across:8316924k SSFS
[ 2.355824] EXT4-fs (sda2): re-mounted. Opts: errors=remount-ro
[ 2.359647] systemd-udevd[444]: starting version 204
[ 2.392736] lp: driver loaded but no devices found
[ 2.398119] ppdev: user-space parallel port driver
[ 2.399803] parport_pc 00:06: reported by Plug and Play ACPI
[ 2.399866] parport0: PC-style at 0x378, irq 5 [PCSPP,TRISTATE]
[ 2.466997] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
[ 2.467315] EDAC MC: Ver: 3.0.0
[ 2.469852] EDAC ie31200: No ECC support
[ 2.494955] lp0: using parport0 (interrupt-driven).
[ 2.501087] AVX2 version of gcm_enc/dec engaged.
[ 2.501089] AES CTR mode by8 optimization enabled
[ 2.515152] clocksource: Switched to clocksource tsc
[ 2.515678] snd_hda_intel 0000:00:1b.0: enabling device (0000 -> 0002)
[ 2.515877] snd_hda_intel 0000:01:00.1: Disabling MSI
[ 2.515882] snd_hda_intel 0000:01:00.1: Handle vga_switcheroo audio client
[ 2.518965] device-mapper: multipath: version 1.10.0 loaded
[ 2.554721] snd_hda_codec_realtek hdaudioC0D2: autoconfig for ALC892: line_outs=4 (0x14/0x15/0x16/0x17/0x0) type:line
[ 2.554724] snd_hda_codec_realtek hdaudioC0D2: speaker_outs=0 (0x0/0x0/0x0/0x0/0x0)
[ 2.554726] snd_hda_codec_realtek hdaudioC0D2: hp_outs=1 (0x1b/0x0/0x0/0x0/0x0)
[ 2.554728] snd_hda_codec_realtek hdaudioC0D2: mono: mono_out=0x0
[ 2.554729] snd_hda_codec_realtek hdaudioC0D2: dig-out=0x11/0x0
[ 2.554730] snd_hda_codec_realtek hdaudioC0D2: inputs:
[ 2.554732] snd_hda_codec_realtek hdaudioC0D2: Front Mic=0x19
[ 2.554734] snd_hda_codec_realtek hdaudioC0D2: Rear Mic=0x18
[ 2.554736] snd_hda_codec_realtek hdaudioC0D2: Line=0x1a
[ 2.556756] [drm] Initialized drm 1.1.0 20060810
[ 2.558651] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 2.565156] intel_rapl: Found RAPL domain package
[ 2.565159] intel_rapl: Found RAPL domain core
[ 2.565162] intel_rapl: Found RAPL domain dram
[ 2.569525] input: HDA Intel PCH Front Mic as /devices/pci0000:00/0000:00:1b.0/sound/card0/input9
[ 2.569571] input: HDA Intel PCH Rear Mic as /devices/pci0000:00/0000:00:1b.0/sound/card0/input10
[ 2.569617] input: HDA Intel PCH Line as /devices/pci0000:00/0000:00:1b.0/sound/card0/input11
[ 2.569668] input: HDA Intel PCH Line Out Front as /devices/pci0000:00/0000:00:1b.0/sound/card0/input12
[ 2.569715] input: HDA Intel PCH Line Out Surround as /devices/pci0000:00/0000:00:1b.0/sound/card0/input13
[ 2.569756] input: HDA Intel PCH Line Out CLFE as /devices/pci0000:00/0000:00:1b.0/sound/card0/input14
[ 2.569789] input: HDA Intel PCH Line Out Side as /devices/pci0000:00/0000:00:1b.0/sound/card0/input15
[ 2.569836] input: HDA Intel PCH Front Headphone as /devices/pci0000:00/0000:00:1b.0/sound/card0/input16
[ 2.572058] nf_conntrack version 0.5.0 (65536 buckets, 262144 max)
[ 2.580658] ip6_tables: (C) 2000-2006 Netfilter Core Team
[ 2.649056] rtl8192cu: Chip version 0x11
[ 2.677719] rtl8192cu: MAC address: f4:f2:6d:10:8c:97
[ 2.677721] rtl8192cu: Board Type 0
[ 2.677796] rtl_usb: rx_max_size 15360, rx_urb_num 8, in_ep 1
[ 2.677813] rtl8192cu: Loading firmware rtlwifi/rtl8192cufw_TMSC.bin
[ 2.679657] ieee80211 phy0: Selected rate control algorithm 'rtl_rc'
[ 2.679822] usbcore: registered new interface driver rtl8192cu
[ 2.680926] usbcore: registered new interface driver rtl8xxxu
[ 2.708536] cfg80211: World regulatory domain updated:
[ 2.708538] cfg80211: DFS Master region: unset
[ 2.708538] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp), (dfs_cac_time)
[ 2.708540] cfg80211: (2402000 KHz - 2472000 KHz @ 40000 KHz), (300 mBi, 2000 mBm), (N/A)
[ 2.708541] cfg80211: (2457000 KHz - 2482000 KHz @ 40000 KHz), (300 mBi, 2000 mBm), (N/A)
[ 2.708542] cfg80211: (2474000 KHz - 2494000 KHz @ 20000 KHz), (300 mBi, 2000 mBm), (N/A)
[ 2.708542] cfg80211: (5170000 KHz - 5250000 KHz @ 40000 KHz), (300 mBi, 2000 mBm), (N/A)
[ 2.708543] cfg80211: (5735000 KHz - 5835000 KHz @ 40000 KHz), (300 mBi, 2000 mBm), (N/A)
[ 2.720350] init: failsafe main process (825) killed by TERM signal
[ 2.847218] nvidia: module license 'NVIDIA' taints kernel.
[ 2.847221] Disabling lock debugging due to kernel taint
[ 2.853231] nvidia: module verification failed: signature and/or required key missing - tainting kernel
[ 2.859790] vgaarb: device changed decodes: PCI:0000:01:00.0,olddecodes=io+mem,decodes=none:owns=io+mem
[ 2.859865] nvidia-nvlink: Nvlink Core is being initialized, major device number 246
[ 2.859881] NVRM: loading NVIDIA UNIX x86_64 Kernel Module 364.12 Wed Mar 16 21:11:26 PDT 2016
[ 2.883342] nvidia-modeset: Loading NVIDIA Kernel Mode Setting Driver for UNIX platforms 364.12 Wed Mar 16 20:44:12 PDT 2016
[ 2.884478] [drm] [nvidia-drm] [GPU ID 0x00000100] Loading driver
[ 2.938214] Bluetooth: Core ver 2.21
[ 2.938225] NET: Registered protocol family 31
[ 2.938225] Bluetooth: HCI device and connection manager initialized
[ 2.938228] Bluetooth: HCI socket layer initialized
[ 2.938230] Bluetooth: L2CAP socket layer initialized
[ 2.938233] Bluetooth: SCO socket layer initialized
[ 2.944341] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 2.944343] Bluetooth: BNEP filters: protocol multicast
[ 2.944346] Bluetooth: BNEP socket layer initialized
[ 2.946998] Bluetooth: RFCOMM TTY layer initialized
[ 2.947003] Bluetooth: RFCOMM socket layer initialized
[ 2.947007] Bluetooth: RFCOMM ver 1.11
[ 2.974099] init: cups main process (1218) killed by HUP signal
[ 2.974105] init: cups main process ended, respawning
[ 3.011451] input: HDA NVidia HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1/input17
[ 3.011521] input: HDA NVidia HDMI/DP,pcm=7 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1/input18
[ 3.011578] input: HDA NVidia HDMI/DP,pcm=8 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1/input19
[ 3.011645] input: HDA NVidia HDMI/DP,pcm=9 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1/input20
[ 3.038441] random: nonblocking pool is initialized
[ 3.071817] init: samba-ad-dc main process (1230) terminated with status 1
[ 3.105066] rtl8192cu: MAC auto ON okay!
[ 3.115917] rtl8192cu: Tx queue select: 0x05
[ 3.148252] nvidia-uvm: Loaded the UVM driver in lite mode, major device number 245
[ 3.442823] init: plymouth-upstart-bridge main process ended, respawning
[ 3.445230] init: plymouth-upstart-bridge main process (1307) terminated with status 1
[ 3.445235] init: plymouth-upstart-bridge main process ended, respawning
[ 3.500329] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 3.629042] r8169 0000:03:00.0 eth0: link down
[ 3.629057] r8169 0000:03:00.0 eth0: link down
[ 3.629092] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 3.758727] NVRM: Your system is not currently configured to drive a VGA console
[ 3.758729] NVRM: on the primary VGA device. The NVIDIA Linux graphics driver
[ 3.758730] NVRM: requires the use of a text-mode VGA console. Use of other console
[ 3.758731] NVRM: drivers including, but not limited to, vesafb, may result in
[ 3.758732] NVRM: corruption and stability problems, and is not supported.
[ 3.880026] nvidia-modeset: Allocated GPU:0 (GPU-efe41b85-b240-ea6a-86ac-2a81e4d54619) @ PCI:0000:01:00.0
[ 4.635604] init: plymouth-stop pre-start process (1831) terminated with status 1
[ 5.819900] r8169 0000:03:00.0 eth0: link up
[ 5.819911] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 11.635379] nf_conntrack: automatic helper assignment is deprecated and it will be removed soon. Use the iptables CT target to attach helpers instead.
[ 103.855070] wlan0: authenticate with 30:b5:c2:63:a9:a6
[ 103.865688] wlan0: send auth to 30:b5:c2:63:a9:a6 (try 1/3)
[ 103.967210] wlan0: send auth to 30:b5:c2:63:a9:a6 (try 2/3)
[ 104.071239] wlan0: send auth to 30:b5:c2:63:a9:a6 (try 3/3)
[ 104.175236] wlan0: authentication with 30:b5:c2:63:a9:a6 timed out
[ 110.971829] wlan0: authenticate with 30:b5:c2:63:a9:a6
[ 110.993155] wlan0: send auth to 30:b5:c2:63:a9:a6 (try 1/3)
[ 111.095524] wlan0: send auth to 30:b5:c2:63:a9:a6 (try 2/3)
[ 111.199537] wlan0: send auth to 30:b5:c2:63:a9:a6 (try 3/3)
[ 111.303539] wlan0: authentication with 30:b5:c2:63:a9:a6 timed out
[ 112.675880] wlan0: authenticate with 30:b5:c2:63:a9:a6
[ 112.696946] wlan0: send auth to 30:b5:c2:63:a9:a6 (try 1/3)
[ 112.799588] wlan0: send auth to 30:b5:c2:63:a9:a6 (try 2/3)
[ 112.903611] wlan0: send auth to 30:b5:c2:63:a9:a6 (try 3/3)
[ 113.007617] wlan0: authentication with 30:b5:c2:63:a9:a6 timed out
[ 114.872035] wlan0: authenticate with 30:b5:c2:63:a9:a6
[ 114.893278] wlan0: send auth to 30:b5:c2:63:a9:a6 (try 1/3)
[ 114.995696] wlan0: send auth to 30:b5:c2:63:a9:a6 (try 2/3)
[ 115.099706] wlan0: send auth to 30:b5:c2:63:a9:a6 (try 3/3)
[ 115.203711] wlan0: authentication with 30:b5:c2:63:a9:a6 timed out
[ 126.908537] wlan0: authenticate with 30:b5:c2:63:a9:a6
[ 126.929818] wlan0: send auth to 30:b5:c2:63:a9:a6 (try 1/3)
[ 127.032202] wlan0: send auth to 30:b5:c2:63:a9:a6 (try 2/3)
[ 127.136228] wlan0: send auth to 30:b5:c2:63:a9:a6 (try 3/3)
[ 127.240228] wlan0: authentication with 30:b5:c2:63:a9:a6 timed out
[ 138.689018] wlan0: authenticate with 30:b5:c2:63:a9:a6
[ 138.710306] wlan0: send auth to 30:b5:c2:63:a9:a6 (try 1/3)
[ 138.812726] wlan0: send auth to 30:b5:c2:63:a9:a6 (try 2/3)
[ 138.916739] wlan0: send auth to 30:b5:c2:63:a9:a6 (try 3/3)
[ 139.020740] wlan0: authentication with 30:b5:c2:63:a9:a6 timed out
[ 149.893426] wlan0: authenticate with 30:b5:c2:63:a9:a6
[ 149.914544] wlan0: send auth to 30:b5:c2:63:a9:a6 (try 1/3)
[ 150.017200] wlan0: send auth to 30:b5:c2:63:a9:a6 (try 2/3)
[ 150.121218] wlan0: send auth to 30:b5:c2:63:a9:a6 (try 3/3)
[ 150.225222] wlan0: authentication with 30:b5:c2:63:a9:a6 timed out
[ 172.526463] wlan0: authenticate with 30:b5:c2:63:a9:a6
[ 172.547647] wlan0: send auth to 30:b5:c2:63:a9:a6 (try 1/3)
[ 172.650204] wlan0: send auth to 30:b5:c2:63:a9:a6 (try 2/3)
[ 172.754176] wlan0: send auth to 30:b5:c2:63:a9:a6 (try 3/3)
[ 172.858194] wlan0: authentication with 30:b5:c2:63:a9:a6 timed out
[ 188.851190] wlan0: authenticate with 30:b5:c2:63:a9:a6
[ 188.872550] wlan0: send auth to 30:b5:c2:63:a9:a6 (try 1/3)
[ 188.974881] wlan0: send auth to 30:b5:c2:63:a9:a6 (try 2/3)
[ 189.078900] wlan0: send auth to 30:b5:c2:63:a9:a6 (try 3/3)
[ 189.182897] wlan0: authentication with 30:b5:c2:63:a9:a6 timed out
[ 200.047663] wlan0: authenticate with 30:b5:c2:63:a9:a6
[ 200.068921] wlan0: send auth to 30:b5:c2:63:a9:a6 (try 1/3)
[ 200.171398] wlan0: send auth to 30:b5:c2:63:a9:a6 (try 2/3)
[ 200.275377] wlan0: send auth to 30:b5:c2:63:a9:a6 (try 3/3)
[ 200.379370] wlan0: authentication with 30:b5:c2:63:a9:a6 timed out
[ 513.869127] wlan0: authenticate with 30:b5:c2:63:a9:a6
[ 513.890412] wlan0: send auth to 30:b5:c2:63:a9:a6 (try 1/3)
[ 513.992924] wlan0: send auth to 30:b5:c2:63:a9:a6 (try 2/3)
[ 514.096912] wlan0: send auth to 30:b5:c2:63:a9:a6 (try 3/3)
[ 514.200914] wlan0: authentication with 30:b5:c2:63:a9:a6 timed out
[ 541.036630] wlan0: authenticate with 30:b5:c2:63:a9:a6
[ 541.047205] wlan0: send auth to 30:b5:c2:63:a9:a6 (try 1/3)
[ 541.150092] wlan0: send auth to 30:b5:c2:63:a9:a6 (try 2/3)
[ 541.254082] wlan0: send auth to 30:b5:c2:63:a9:a6 (try 3/3)
[ 541.358084] wlan0: authentication with 30:b5:c2:63:a9:a6 timed out
[ 558.075064] wlan0: authenticate with 30:b5:c2:63:a9:a6
[ 558.096367] wlan0: send auth to 30:b5:c2:63:a9:a6 (try 1/3)
[ 558.198831] wlan0: send auth to 30:b5:c2:63:a9:a6 (try 2/3)
[ 558.302830] wlan0: send auth to 30:b5:c2:63:a9:a6 (try 3/3)
[ 558.406834] wlan0: authentication with 30:b5:c2:63:a9:a6 timed out
[ 575.715850] wlan0: authenticate with 30:b5:c2:63:a9:a6
[ 575.737109] wlan0: send auth to 30:b5:c2:63:a9:a6 (try 1/3)
[ 575.839580] wlan0: send auth to 30:b5:c2:63:a9:a6 (try 2/3)
[ 575.943587] wlan0: send auth to 30:b5:c2:63:a9:a6 (try 3/3)
[ 576.047585] wlan0: authentication with 30:b5:c2:63:a9:a6 timed out
[ 586.920319] wlan0: authenticate with 30:b5:c2:63:a9:a6
[ 586.941621] wlan0: send auth to 30:b5:c2:63:a9:a6 (try 1/3)
[ 587.044074] wlan0: send auth to 30:b5:c2:63:a9:a6 (try 2/3)
[ 587.148075] wlan0: send auth to 30:b5:c2:63:a9:a6 (try 3/3)
[ 587.252079] wlan0: authentication with 30:b5:c2:63:a9:a6 timed out
[ 603.729077] wlan0: authenticate with 30:b5:c2:63:a9:a6
[ 603.750368] wlan0: send auth to 30:b5:c2:63:a9:a6 (try 1/3)
[ 603.852802] wlan0: send auth to 30:b5:c2:63:a9:a6 (try 2/3)
[ 603.956799] wlan0: send auth to 30:b5:c2:63:a9:a6 (try 3/3)
[ 604.060794] wlan0: authentication with 30:b5:c2:63:a9:a6 timed out
[ 614.929518] wlan0: authenticate with 30:b5:c2:63:a9:a6
[ 614.950798] wlan0: send auth to 30:b5:c2:63:a9:a6 (try 1/3)
[ 615.053281] wlan0: send auth to 30:b5:c2:63:a9:a6 (try 2/3)
[ 615.157272] wlan0: send auth to 30:b5:c2:63:a9:a6 (try 3/3)
[ 615.261276] wlan0: authentication with 30:b5:c2:63:a9:a6 timed out
[ 922.890864] wlan0: authenticate with 30:b5:c2:63:a9:a6
[ 922.912015] wlan0: send auth to 30:b5:c2:63:a9:a6 (try 1/3)
[ 923.014577] wlan0: send auth to 30:b5:c2:63:a9:a6 (try 2/3)
[ 923.118565] wlan0: send auth to 30:b5:c2:63:a9:a6 (try 3/3)
[ 923.222569] wlan0: authentication with 30:b5:c2:63:a9:a6 timed out
[ 945.755877] wlan0: authenticate with 30:b5:c2:63:a9:a6
[ 945.777311] wlan0: send auth to 30:b5:c2:63:a9:a6 (try 1/3)
[ 945.879569] wlan0: send auth to 30:b5:c2:63:a9:a6 (try 2/3)
[ 945.983561] wlan0: send auth to 30:b5:c2:63:a9:a6 (try 3/3)
[ 946.087555] wlan0: authentication with 30:b5:c2:63:a9:a6 timed out
[ 950.892012] wlan0: authenticate with 30:b5:c2:63:a9:a6
[ 950.913080] wlan0: send auth to 30:b5:c2:63:a9:a6 (try 1/3)
[ 951.015781] wlan0: send auth to 30:b5:c2:63:a9:a6 (try 2/3)
[ 951.119785] wlan0: send auth to 30:b5:c2:63:a9:a6 (try 3/3)
[ 951.223790] wlan0: authentication with 30:b5:c2:63:a9:a6 timed out
[ 978.055606] wlan0: authenticate with 30:b5:c2:63:a9:a6
[ 978.066249] wlan0: send auth to 30:b5:c2:63:a9:a6 (try 1/3)
[ 978.168960] wlan0: send auth to 30:b5:c2:63:a9:a6 (try 2/3)
[ 978.272948] wlan0: send auth to 30:b5:c2:63:a9:a6 (try 3/3)
[ 978.376979] wlan0: authentication with 30:b5:c2:63:a9:a6 timed out
[ 989.249677] wlan0: authenticate with 30:b5:c2:63:a9:a6
[ 989.270877] wlan0: send auth to 30:b5:c2:63:a9:a6 (try 1/3)
[ 989.373441] wlan0: send auth to 30:b5:c2:63:a9:a6 (try 2/3)
[ 989.477429] wlan0: send auth to 30:b5:c2:63:a9:a6 (try 3/3)
[ 989.581432] wlan0: authentication with 30:b5:c2:63:a9:a6 timed out
[ 1006.894479] wlan0: authenticate with 30:b5:c2:63:a9:a6
[ 1006.915747] wlan0: send auth to 30:b5:c2:63:a9:a6 (try 1/3)
[ 1007.018200] wlan0: send auth to 30:b5:c2:63:a9:a6 (try 2/3)
[ 1007.122203] wlan0: send auth to 30:b5:c2:63:a9:a6 (try 3/3)
[ 1007.226195] wlan0: authentication with 30:b5:c2:63:a9:a6 timed out
[ 1023.927198] wlan0: authenticate with 30:b5:c2:63:a9:a6
[ 1023.948426] wlan0: send auth to 30:b5:c2:63:a9:a6 (try 1/3)
[ 1024.050943] wlan0: send auth to 30:b5:c2:63:a9:a6 (try 2/3)
[ 1024.154938] wlan0: send auth to 30:b5:c2:63:a9:a6 (try 3/3)
[ 1024.258928] wlan0: authentication with 30:b5:c2:63:a9:a6 timed out
[ 1349.409232] wlan0: authenticate with 30:b5:c2:63:a9:a6
[ 1349.430468] wlan0: send auth to 30:b5:c2:63:a9:a6 (try 1/3)
[ 1349.532979] wlan0: send auth to 30:b5:c2:63:a9:a6 (try 2/3)
[ 1349.636991] wlan0: send auth to 30:b5:c2:63:a9:a6 (try 3/3)
[ 1349.740999] wlan0: authentication with 30:b5:c2:63:a9:a6 timed out
[ 1405.411659] wlan0: authenticate with 30:b5:c2:63:a9:a6
[ 1405.432822] wlan0: send auth to 30:b5:c2:63:a9:a6 (try 1/3)
[ 1405.535400] wlan0: send auth to 30:b5:c2:63:a9:a6 (try 2/3)
[ 1405.639405] wlan0: send auth to 30:b5:c2:63:a9:a6 (try 3/3)
[ 1405.743417] wlan0: authentication with 30:b5:c2:63:a9:a6 timed out
[ 1421.744356] wlan0: authenticate with 30:b5:c2:63:a9:a6
[ 1421.765642] wlan0: send auth to 30:b5:c2:63:a9:a6 (try 1/3)
[ 1421.868153] wlan0: send auth to 30:b5:c2:63:a9:a6 (try 2/3)
[ 1421.972125] wlan0: send auth to 30:b5:c2:63:a9:a6 (try 3/3)
[ 1422.076115] wlan0: authentication with 30:b5:c2:63:a9:a6 timed out
[ 1432.940940] wlan0: authenticate with 30:b5:c2:63:a9:a6
[ 1432.962174] wlan0: send auth to 30:b5:c2:63:a9:a6 (try 1/3)
[ 1433.064605] wlan0: send auth to 30:b5:c2:63:a9:a6 (try 2/3)
[ 1433.168608] wlan0: send auth to 30:b5:c2:63:a9:a6 (try 3/3)
[ 1433.272612] wlan0: authentication with 30:b5:c2:63:a9:a6 timed out
[ 2193.946624] wlan0: authenticate with 30:b5:c2:63:a9:a6
[ 2193.958725] wlan0: send auth to 30:b5:c2:63:a9:a6 (try 1/3)
[ 2194.061442] wlan0: send auth to 30:b5:c2:63:a9:a6 (try 2/3)
[ 2194.165426] wlan0: send auth to 30:b5:c2:63:a9:a6 (try 3/3)
[ 2194.269429] wlan0: authentication with 30:b5:c2:63:a9:a6 timed out
[ 2216.814700] wlan0: authenticate with 30:b5:c2:63:a9:a6
[ 2216.836041] wlan0: send auth to 30:b5:c2:63:a9:a6 (try 1/3)
[ 2216.938431] wlan0: send auth to 30:b5:c2:63:a9:a6 (try 2/3)
[ 2217.042415] wlan0: send auth to 30:b5:c2:63:a9:a6 (try 3/3)
[ 2217.146417] wlan0: authentication with 30:b5:c2:63:a9:a6 timed out
[ 2228.787199] wlan0: authenticate with 30:b5:c2:63:a9:a6
[ 2228.808380] wlan0: send auth to 30:b5:c2:63:a9:a6 (try 1/3)
[ 2228.910946] wlan0: send auth to 30:b5:c2:63:a9:a6 (try 2/3)
[ 2229.014930] wlan0: send auth to 30:b5:c2:63:a9:a6 (try 3/3)
[ 2229.118933] wlan0: authentication with 30:b5:c2:63:a9:a6 timed out
[ 2637.800923] wlan0: authenticate with 30:b5:c2:63:a9:a6
[ 2637.822057] wlan0: send auth to 30:b5:c2:63:a9:a6 (try 1/3)
[ 2637.924595] wlan0: send auth to 30:b5:c2:63:a9:a6 (try 2/3)
[ 2638.028603] wlan0: send auth to 30:b5:c2:63:a9:a6 (try 3/3)
[ 2638.132608] wlan0: authentication with 30:b5:c2:63:a9:a6 timed out
[ 2648.993293] wlan0: authenticate with 30:b5:c2:63:a9:a6
[ 2649.014512] wlan0: send auth to 30:b5:c2:63:a9:a6 (try 1/3)
[ 2649.117086] wlan0: send auth to 30:b5:c2:63:a9:a6 (try 2/3)
[ 2649.221089] wlan0: send auth to 30:b5:c2:63:a9:a6 (try 3/3)
[ 2649.325091] wlan0: authentication with 30:b5:c2:63:a9:a6 timed out
[ 2677.478645] wlan0: authenticate with 30:b5:c2:63:a9:a6
[ 2677.499789] wlan0: send auth to 30:b5:c2:63:a9:a6 (try 1/3)
[ 2677.602291] wlan0: send auth to 30:b5:c2:63:a9:a6 (try 2/3)
[ 2677.706316] wlan0: send auth to 30:b5:c2:63:a9:a6 (try 3/3)
[ 2677.810320] wlan0: authentication with 30:b5:c2:63:a9:a6 timed out
[ 2687.128520] wlan0: authenticate with 30:b5:c2:63:a9:a6
[ 2687.139141] wlan0: send auth to 30:b5:c2:63:a9:a6 (try 1/3)
[ 2687.242728] wlan0: send auth to 30:b5:c2:63:a9:a6 (try 2/3)
[ 2687.346724] wlan0: send auth to 30:b5:c2:63:a9:a6 (try 3/3)
[ 2687.450731] wlan0: authentication with 30:b5:c2:63:a9:a6 timed out
[ 2704.159790] wlan0: authenticate with 30:b5:c2:63:a9:a6
[ 2704.181178] wlan0: send auth to 30:b5:c2:63:a9:a6 (try 1/3)
[ 2704.283466] wlan0: send auth to 30:b5:c2:63:a9:a6 (try 2/3)
[ 2704.387474] wlan0: send auth to 30:b5:c2:63:a9:a6 (try 3/3)
[ 2704.491469] wlan0: authentication with 30:b5:c2:63:a9:a6 timed out
[ 3030.489760] wlan0: authenticate with 30:b5:c2:63:a9:a6
[ 3030.511021] wlan0: send auth to 30:b5:c2:63:a9:a6 (try 1/3)
[ 3030.613543] wlan0: send auth to 30:b5:c2:63:a9:a6 (try 2/3)
[ 3030.717556] wlan0: send auth to 30:b5:c2:63:a9:a6 (try 3/3)
[ 3030.821559] wlan0: authentication with 30:b5:c2:63:a9:a6 timed out
[ 3040.144974] wlan0: authenticate with 30:b5:c2:63:a9:a6
[ 3040.155634] wlan0: send auth to 30:b5:c2:63:a9:a6 (try 1/3)
[ 3040.257952] wlan0: send auth to 30:b5:c2:63:a9:a6 (try 2/3)
[ 3040.361973] wlan0: send auth to 30:b5:c2:63:a9:a6 (try 3/3)
[ 3040.465975] wlan0: authentication with 30:b5:c2:63:a9:a6 timed out
[ 3068.979542] wlan0: authenticate with 30:b5:c2:63:a9:a6
[ 3069.000684] wlan0: send auth to 30:b5:c2:63:a9:a6 (try 1/3)
[ 3069.103203] wlan0: send auth to 30:b5:c2:63:a9:a6 (try 2/3)
[ 3069.207210] wlan0: send auth to 30:b5:c2:63:a9:a6 (try 3/3)
[ 3069.311221] wlan0: authentication with 30:b5:c2:63:a9:a6 timed out
[ 3080.183935] wlan0: authenticate with 30:b5:c2:63:a9:a6
[ 3080.205241] wlan0: send auth to 30:b5:c2:63:a9:a6 (try 1/3)
[ 3080.307697] wlan0: send auth to 30:b5:c2:63:a9:a6 (try 2/3)
[ 3080.411700] wlan0: send auth to 30:b5:c2:63:a9:a6 (try 3/3)
[ 3080.515703] wlan0: authentication with 30:b5:c2:63:a9:a6 timed out
[ 3421.994746] wlan0: authenticate with 30:b5:c2:63:a9:a6
[ 3422.016075] wlan0: send auth to 30:b5:c2:63:a9:a6 (try 1/3)
[ 3422.118448] wlan0: send auth to 30:b5:c2:63:a9:a6 (try 2/3)
[ 3422.222448] wlan0: send auth to 30:b5:c2:63:a9:a6 (try 3/3)
[ 3422.326460] wlan0: authentication with 30:b5:c2:63:a9:a6 timed out
[ 3439.031524] wlan0: authenticate with 30:b5:c2:63:a9:a6
[ 3439.053109] wlan0: send auth to 30:b5:c2:63:a9:a6 (try 1/3)
[ 3439.155196] wlan0: send auth to 30:b5:c2:63:a9:a6 (try 2/3)
[ 3439.259188] wlan0: send auth to 30:b5:c2:63:a9:a6 (try 3/3)
[ 3439.363187] wlan0: authentication with 30:b5:c2:63:a9:a6 timed out
[ 3473.336974] wlan0: authenticate with 30:b5:c2:63:a9:a6
[ 3473.358186] wlan0: send auth to 30:b5:c2:63:a9:a6 (try 1/3)
[ 3473.460666] wlan0: send auth to 30:b5:c2:63:a9:a6 (try 2/3)
[ 3473.564660] wlan0: send auth to 30:b5:c2:63:a9:a6 (try 3/3)
[ 3473.668675] wlan0: authentication with 30:b5:c2:63:a9:a6 timed out
[ 3477.997125] wlan0: authenticate with 30:b5:c2:63:a9:a6
[ 3478.018684] wlan0: send auth to 30:b5:c2:63:a9:a6 (try 1/3)
[ 3478.120854] wlan0: send auth to 30:b5:c2:63:a9:a6 (try 2/3)
[ 3478.224872] wlan0: send auth to 30:b5:c2:63:a9:a6 (try 3/3)
[ 3478.328877] wlan0: authentication with 30:b5:c2:63:a9:a6 timed out
[ 3500.866141] wlan0: authenticate with 30:b5:c2:63:a9:a6
[ 3500.887412] wlan0: send auth to 30:b5:c2:63:a9:a6 (try 1/3)
[ 3500.989854] wlan0: send auth to 30:b5:c2:63:a9:a6 (try 2/3)
[ 3501.093841] wlan0: send auth to 30:b5:c2:63:a9:a6 (try 3/3)
[ 3501.197843] wlan0: authentication with 30:b5:c2:63:a9:a6 timed out
[ 3517.678892] wlan0: authenticate with 30:b5:c2:63:a9:a6
[ 3517.700206] wlan0: send auth to 30:b5:c2:63:a9:a6 (try 1/3)
[ 3517.802582] wlan0: send auth to 30:b5:c2:63:a9:a6 (try 2/3)
[ 3517.906585] wlan0: send auth to 30:b5:c2:63:a9:a6 (try 3/3)
[ 3518.010588] wlan0: authentication with 30:b5:c2:63:a9:a6 timed out
[ 3528.883427] wlan0: authenticate with 30:b5:c2:63:a9:a6
[ 3528.904647] wlan0: send auth to 30:b5:c2:63:a9:a6 (try 1/3)
[ 3529.007057] wlan0: send auth to 30:b5:c2:63:a9:a6 (try 2/3)
[ 3529.111065] wlan0: send auth to 30:b5:c2:63:a9:a6 (try 3/3)
[ 3529.215066] wlan0: authentication with 30:b5:c2:63:a9:a6 timed out
[ 3831.016385] wlan0: authenticate with 30:b5:c2:63:a9:a6
[ 3831.037548] wlan0: send auth to 30:b5:c2:63:a9:a6 (try 1/3)
[ 3831.140107] wlan0: send auth to 30:b5:c2:63:a9:a6 (try 2/3)
[ 3831.244109] wlan0: send auth to 30:b5:c2:63:a9:a6 (try 3/3)
[ 3831.348108] wlan0: authentication with 30:b5:c2:63:a9:a6 timed out
[ 3858.177696] wlan0: authenticate with 30:b5:c2:63:a9:a6
[ 3858.188305] wlan0: send auth to 30:b5:c2:63:a9:a6 (try 1/3)
[ 3858.289278] wlan0: send auth to 30:b5:c2:63:a9:a6 (try 2/3)
[ 3858.393275] wlan0: send auth to 30:b5:c2:63:a9:a6 (try 3/3)
[ 3858.497265] wlan0: authentication with 30:b5:c2:63:a9:a6 timed out
[ 3869.361994] wlan0: authenticate with 30:b5:c2:63:a9:a6
[ 3869.383254] wlan0: send auth to 30:b5:c2:63:a9:a6 (try 1/3)
[ 3869.485761] wlan0: send auth to 30:b5:c2:63:a9:a6 (try 2/3)
[ 3869.589765] wlan0: send auth to 30:b5:c2:63:a9:a6 (try 3/3)
[ 3869.693760] wlan0: authentication with 30:b5:c2:63:a9:a6 timed out
[ 3886.179799] wlan0: authenticate with 30:b5:c2:63:a9:a6
[ 3886.190433] wlan0: send auth to 30:b5:c2:63:a9:a6 (try 1/3)
[ 3886.294486] wlan0: send auth to 30:b5:c2:63:a9:a6 (try 2/3)
[ 3886.398486] wlan0: send auth to 30:b5:c2:63:a9:a6 (try 3/3)
[ 3886.502503] wlan0: authentication with 30:b5:c2:63:a9:a6 timed out
[ 3897.367363] wlan0: authenticate with 30:b5:c2:63:a9:a6
[ 3897.388537] wlan0: send auth to 30:b5:c2:63:a9:a6 (try 1/3)
[ 3897.490961] wlan0: send auth to 30:b5:c2:63:a9:a6 (try 2/3)
[ 3897.594973] wlan0: send auth to 30:b5:c2:63:a9:a6 (try 3/3)
[ 3897.698960] wlan0: authentication with 30:b5:c2:63:a9:a6 timed out
[ 3914.182124] wlan0: authenticate with 30:b5:c2:63:a9:a6
[ 3914.192933] wlan0: send auth to 30:b5:c2:63:a9:a6 (try 1/3)
[ 3914.295687] wlan0: send auth to 30:b5:c2:63:a9:a6 (try 2/3)
[ 3914.399693] wlan0: send auth to 30:b5:c2:63:a9:a6 (try 3/3)
[ 3914.503702] wlan0: authentication with 30:b5:c2:63:a9:a6 timed out
[ 3925.380453] wlan0: authenticate with 30:b5:c2:63:a9:a6
[ 3925.401805] wlan0: send auth to 30:b5:c2:63:a9:a6 (try 1/3)
[ 3925.504178] wlan0: send auth to 30:b5:c2:63:a9:a6 (try 2/3)
[ 3925.608192] wlan0: send auth to 30:b5:c2:63:a9:a6 (try 3/3)
[ 3925.712186] wlan0: authentication with 30:b5:c2:63:a9:a6 timed out
[ 4599.054320] wlan0: authenticate with 30:b5:c2:63:a9:a6
[ 4599.066762] wlan0: send auth to 30:b5:c2:63:a9:a6 (try 1/3)
[ 4599.169271] wlan0: send auth to 30:b5:c2:63:a9:a6 (try 2/3)
[ 4599.273260] wlan0: send auth to 30:b5:c2:63:a9:a6 (try 3/3)
[ 4599.377266] wlan0: authentication with 30:b5:c2:63:a9:a6 timed out
[ 4616.086214] wlan0: authenticate with 30:b5:c2:63:a9:a6
[ 4616.107460] wlan0: send auth to 30:b5:c2:63:a9:a6 (try 1/3)
[ 4616.124984] wlan0: authenticated
[ 4616.125990] wlan0: associate with 30:b5:c2:63:a9:a6 (try 1/3)
[ 4616.229978] wlan0: associate with 30:b5:c2:63:a9:a6 (try 2/3)
[ 4616.333988] wlan0: associate with 30:b5:c2:63:a9:a6 (try 3/3)
[ 4616.437982] wlan0: association with 30:b5:c2:63:a9:a6 timed out
[ 4625.046639] wlan0: authenticate with 30:b5:c2:63:a9:a6
[ 4625.067868] wlan0: send auth to 30:b5:c2:63:a9:a6 (try 1/3)
[ 4625.170378] wlan0: send auth to 30:b5:c2:63:a9:a6 (try 2/3)
[ 4625.178174] wlan0: authenticated
[ 4625.178375] wlan0: associate with 30:b5:c2:63:a9:a6 (try 1/3)
[ 4625.282388] wlan0: associate with 30:b5:c2:63:a9:a6 (try 2/3)
[ 4625.386379] wlan0: associate with 30:b5:c2:63:a9:a6 (try 3/3)
[ 4625.490385] wlan0: association with 30:b5:c2:63:a9:a6 timed out
[ 4642.207300] wlan0: authenticate with 30:b5:c2:63:a9:a6
[ 4642.228610] wlan0: send auth to 30:b5:c2:63:a9:a6 (try 1/3)
[ 4642.331118] wlan0: send auth to 30:b5:c2:63:a9:a6 (try 2/3)
[ 4642.435115] wlan0: send auth to 30:b5:c2:63:a9:a6 (try 3/3)
[ 4642.539127] wlan0: authentication with 30:b5:c2:63:a9:a6 timed out
[ 4650.051681] wlan0: authenticate with 30:b5:c2:63:a9:a6
[ 4650.072992] wlan0: send auth to 30:b5:c2:63:a9:a6 (try 1/3)
[ 4650.089812] wlan0: authenticated
[ 4650.091457] wlan0: associate with 30:b5:c2:63:a9:a6 (try 1/3)
[ 4650.195469] wlan0: associate with 30:b5:c2:63:a9:a6 (try 2/3)
[ 4650.299460] wlan0: associate with 30:b5:c2:63:a9:a6 (try 3/3)
[ 4650.403457] wlan0: association with 30:b5:c2:63:a9:a6 timed out
[ 4661.280198] wlan0: authenticate with 30:b5:c2:63:a9:a6
[ 4661.301516] wlan0: send auth to 30:b5:c2:63:a9:a6 (try 1/3)
[ 4661.403985] wlan0: send auth to 30:b5:c2:63:a9:a6 (try 2/3)
[ 4661.507941] wlan0: send auth to 30:b5:c2:63:a9:a6 (try 3/3)
[ 4661.611946] wlan0: authentication with 30:b5:c2:63:a9:a6 timed out
[ 4674.213934] wlan0: authenticate with 30:b5:c2:63:a9:a6
[ 4674.224587] wlan0: send auth to 30:b5:c2:63:a9:a6 (try 1/3)
[ 4674.328486] wlan0: send auth to 30:b5:c2:63:a9:a6 (try 2/3)
[ 4674.432505] wlan0: send auth to 30:b5:c2:63:a9:a6 (try 3/3)
[ 4674.536491] wlan0: authentication with 30:b5:c2:63:a9:a6 timed out
[ 4685.413195] wlan0: authenticate with 30:b5:c2:63:a9:a6
[ 4685.434395] wlan0: send auth to 30:b5:c2:63:a9:a6 (try 1/3)
[ 4685.536985] wlan0: send auth to 30:b5:c2:63:a9:a6 (try 2/3)
[ 4685.640981] wlan0: send auth to 30:b5:c2:63:a9:a6 (try 3/3)
[ 4685.744975] wlan0: authentication with 30:b5:c2:63:a9:a6 timed out
[ 4702.216568] wlan0: authenticate with 30:b5:c2:63:a9:a6
[ 4702.227233] wlan0: send auth to 30:b5:c2:63:a9:a6 (try 1/3)
[ 4702.329690] wlan0: send auth to 30:b5:c2:63:a9:a6 (try 2/3)
[ 4702.433706] wlan0: send auth to 30:b5:c2:63:a9:a6 (try 3/3)
[ 4702.537698] wlan0: authentication with 30:b5:c2:63:a9:a6 timed out
[ 4713.410482] wlan0: authenticate with 30:b5:c2:63:a9:a6
[ 4713.431766] wlan0: send auth to 30:b5:c2:63:a9:a6 (try 1/3)
[ 4713.534189] wlan0: send auth to 30:b5:c2:63:a9:a6 (try 2/3)
[ 4713.638190] wlan0: send auth to 30:b5:c2:63:a9:a6 (try 3/3)
[ 4713.742190] wlan0: authentication with 30:b5:c2:63:a9:a6 timed out
[ 4730.218668] wlan0: authenticate with 30:b5:c2:63:a9:a6
[ 4730.229249] wlan0: send auth to 30:b5:c2:63:a9:a6 (try 1/3)
[ 4730.233346] wlan0: authenticated
[ 4730.234926] wlan0: associate with 30:b5:c2:63:a9:a6 (try 1/3)
[ 4730.338932] wlan0: associate with 30:b5:c2:63:a9:a6 (try 2/3)
[ 4730.442913] wlan0: associate with 30:b5:c2:63:a9:a6 (try 3/3)
[ 4730.546919] wlan0: association with 30:b5:c2:63:a9:a6 timed out
[ 4741.419675] wlan0: authenticate with 30:b5:c2:63:a9:a6
[ 4741.440903] wlan0: send auth to 30:b5:c2:63:a9:a6 (try 1/3)
[ 4741.543403] wlan0: send auth to 30:b5:c2:63:a9:a6 (try 2/3)
[ 4741.647406] wlan0: send auth to 30:b5:c2:63:a9:a6 (try 3/3)
[ 4741.751438] wlan0: authentication with 30:b5:c2:63:a9:a6 timed out
[ 4755.217801] wlan0: authenticate with 30:b5:c2:63:a9:a6
[ 4755.228544] wlan0: send auth to 30:b5:c2:63:a9:a6 (try 1/3)
[ 4755.331993] wlan0: send auth to 30:b5:c2:63:a9:a6 (try 2/3)
[ 4755.338640] wlan0: authenticated
[ 4755.339997] wlan0: associate with 30:b5:c2:63:a9:a6 (try 1/3)
[ 4755.443995] wlan0: associate with 30:b5:c2:63:a9:a6 (try 2/3)
[ 4755.547991] wlan0: associate with 30:b5:c2:63:a9:a6 (try 3/3)
[ 4755.652014] wlan0: association with 30:b5:c2:63:a9:a6 timed out
[ 4766.528800] wlan0: authenticate with 30:b5:c2:63:a9:a6
[ 4766.550012] wlan0: send auth to 30:b5:c2:63:a9:a6 (try 1/3)
[ 4766.652502] wlan0: send auth to 30:b5:c2:63:a9:a6 (try 2/3)
[ 4766.756495] wlan0: send auth to 30:b5:c2:63:a9:a6 (try 3/3)
[ 4766.860516] wlan0: authentication with 30:b5:c2:63:a9:a6 timed out
[ 4780.221469] wlan0: authenticate with 30:b5:c2:63:a9:a6
[ 4780.232187] wlan0: send auth to 30:b5:c2:63:a9:a6 (try 1/3)
[ 4780.333069] wlan0: send auth to 30:b5:c2:63:a9:a6 (try 2/3)
[ 4780.437064] wlan0: send auth to 30:b5:c2:63:a9:a6 (try 3/3)
[ 4780.541081] wlan0: authentication with 30:b5:c2:63:a9:a6 timed out
[ 4791.417857] wlan0: authenticate with 30:b5:c2:63:a9:a6
[ 4791.439207] wlan0: send auth to 30:b5:c2:63:a9:a6 (try 1/3)
[ 4791.541579] wlan0: send auth to 30:b5:c2:63:a9:a6 (try 2/3)
[ 4791.645562] wlan0: send auth to 30:b5:c2:63:a9:a6 (try 3/3)
[ 4791.749571] wlan0: authentication with 30:b5:c2:63:a9:a6 timed out
[ 4808.221432] wlan0: authenticate with 30:b5:c2:63:a9:a6
[ 4808.232269] wlan0: send auth to 30:b5:c2:63:a9:a6 (try 1/3)
[ 4808.334274] wlan0: send auth to 30:b5:c2:63:a9:a6 (try 2/3)
[ 4808.438290] wlan0: send auth to 30:b5:c2:63:a9:a6 (try 3/3)
[ 4808.542297] wlan0: authentication with 30:b5:c2:63:a9:a6 timed out
[ 4819.403030] wlan0: authenticate with 30:b5:c2:63:a9:a6
[ 4819.424500] wlan0: send auth to 30:b5:c2:63:a9:a6 (try 1/3)
[ 4819.526773] wlan0: send auth to 30:b5:c2:63:a9:a6 (try 2/3)
[ 4819.630767] wlan0: send auth to 30:b5:c2:63:a9:a6 (try 3/3)
[ 4819.734778] wlan0: authentication with 30:b5:c2:63:a9:a6 timed out
[ 5134.068577] wlan0: authenticate with 30:b5:c2:63:a9:a6
[ 5134.089917] wlan0: send auth to 30:b5:c2:63:a9:a6 (try 1/3)
[ 5134.192333] wlan0: send auth to 30:b5:c2:63:a9:a6 (try 2/3)
[ 5134.296338] wlan0: send auth to 30:b5:c2:63:a9:a6 (try 3/3)
[ 5134.321513] wlan0: authenticated
[ 5134.324343] wlan0: associate with 30:b5:c2:63:a9:a6 (try 1/3)
[ 5134.371857] wlan0: RX AssocResp from 30:b5:c2:63:a9:a6 (capab=0x31 status=0 aid=1)
[ 5134.372567] wlan0: associated
[ 5134.372594] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
[ 5143.988711] wlan0: Connection to AP 30:b5:c2:63:a9:a6 lost
[ 5144.013604] cfg80211: World regulatory domain updated:
[ 5144.013606] cfg80211: DFS Master region: unset
[ 5144.013607] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp), (dfs_cac_time)
[ 5144.013608] cfg80211: (2402000 KHz - 2472000 KHz @ 40000 KHz), (300 mBi, 2000 mBm), (N/A)
[ 5144.013609] cfg80211: (2457000 KHz - 2482000 KHz @ 40000 KHz), (300 mBi, 2000 mBm), (N/A)
[ 5144.013610] cfg80211: (2474000 KHz - 2494000 KHz @ 20000 KHz), (300 mBi, 2000 mBm), (N/A)
[ 5144.013611] cfg80211: (5170000 KHz - 5250000 KHz @ 40000 KHz), (300 mBi, 2000 mBm), (N/A)
[ 5144.013612] cfg80211: (5735000 KHz - 5835000 KHz @ 40000 KHz), (300 mBi, 2000 mBm), (N/A)
[ 5144.945108] wlan0: authenticate with 30:b5:c2:63:a9:a6
[ 5144.966485] wlan0: send auth to 30:b5:c2:63:a9:a6 (try 1/3)
[ 5145.068821] wlan0: send auth to 30:b5:c2:63:a9:a6 (try 2/3)
[ 5145.172825] wlan0: send auth to 30:b5:c2:63:a9:a6 (try 3/3)
[ 5145.276823] wlan0: authentication with 30:b5:c2:63:a9:a6 timed out
[ 5146.637208] wlan0: authenticate with 30:b5:c2:63:a9:a6
[ 5146.658718] wlan0: send auth to 30:b5:c2:63:a9:a6 (try 1/3)
[ 5146.760875] wlan0: send auth to 30:b5:c2:63:a9:a6 (try 2/3)
[ 5146.864901] wlan0: send auth to 30:b5:c2:63:a9:a6 (try 3/3)
[ 5146.968884] wlan0: authentication with 30:b5:c2:63:a9:a6 timed out
[ 5148.829292] wlan0: authenticate with 30:b5:c2:63:a9:a6
[ 5148.850383] wlan0: send auth to 30:b5:c2:63:a9:a6 (try 1/3)
[ 5148.952979] wlan0: send auth to 30:b5:c2:63:a9:a6 (try 2/3)
[ 5148.958590] wlan0: authenticated
[ 5148.960989] wlan0: associate with 30:b5:c2:63:a9:a6 (try 1/3)
[ 5149.000625] wlan0: RX AssocResp from 30:b5:c2:63:a9:a6 (capab=0x31 status=0 aid=1)
[ 5149.100822] wlan0: associated
[ 5180.428006] wlan0: deauthenticating from 30:b5:c2:63:a9:a6 by local choice (Reason: 3=DEAUTH_LEAVING)
[ 5180.441876] cfg80211: World regulatory domain updated:
[ 5180.441879] cfg80211: DFS Master region: unset
[ 5180.441880] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp), (dfs_cac_time)
[ 5180.441882] cfg80211: (2402000 KHz - 2472000 KHz @ 40000 KHz), (300 mBi, 2000 mBm), (N/A)
[ 5180.441883] cfg80211: (2457000 KHz - 2482000 KHz @ 40000 KHz), (300 mBi, 2000 mBm), (N/A)
[ 5180.441884] cfg80211: (2474000 KHz - 2494000 KHz @ 20000 KHz), (300 mBi, 2000 mBm), (N/A)
[ 5180.441884] cfg80211: (5170000 KHz - 5250000 KHz @ 40000 KHz), (300 mBi, 2000 mBm), (N/A)
[ 5180.441885] cfg80211: (5735000 KHz - 5835000 KHz @ 40000 KHz), (300 mBi, 2000 mBm), (N/A)
[ 5195.743276] wlan0: authenticate with 30:b5:c2:63:a9:a6
[ 5195.764616] wlan0: send auth to 30:b5:c2:63:a9:a6 (try 1/3)
[ 5195.867013] wlan0: send auth to 30:b5:c2:63:a9:a6 (try 2/3)
[ 5195.971018] wlan0: send auth to 30:b5:c2:63:a9:a6 (try 3/3)
[ 5196.075022] wlan0: authentication with 30:b5:c2:63:a9:a6 timed out
[ 5197.055388] wlan0: authenticate with 30:b5:c2:63:a9:a6
[ 5197.076536] wlan0: send auth to 30:b5:c2:63:a9:a6 (try 1/3)
[ 5197.179064] wlan0: send auth to 30:b5:c2:63:a9:a6 (try 2/3)
[ 5197.283075] wlan0: send auth to 30:b5:c2:63:a9:a6 (try 3/3)
[ 5197.387078] wlan0: authentication with 30:b5:c2:63:a9:a6 timed out
[ 5198.763456] wlan0: authenticate with 30:b5:c2:63:a9:a6
[ 5198.784739] wlan0: send auth to 30:b5:c2:63:a9:a6 (try 1/3)
[ 5198.887146] wlan0: send auth to 30:b5:c2:63:a9:a6 (try 2/3)
[ 5198.991146] wlan0: send auth to 30:b5:c2:63:a9:a6 (try 3/3)
[ 5199.095145] wlan0: authentication with 30:b5:c2:63:a9:a6 timed out
[ 5206.795635] wlan0: authenticate with 30:b5:c2:63:a9:a6
[ 5206.816850] wlan0: send auth to 30:b5:c2:63:a9:a6 (try 1/3)
[ 5206.919488] wlan0: send auth to 30:b5:c2:63:a9:a6 (try 2/3)
[ 5206.923661] wlan0: authenticated
[ 5206.927488] wlan0: associate with 30:b5:c2:63:a9:a6 (try 1/3)
[ 5207.031475] wlan0: associate with 30:b5:c2:63:a9:a6 (try 2/3)
[ 5207.135495] wlan0: associate with 30:b5:c2:63:a9:a6 (try 3/3)
[ 5207.239499] wlan0: association with 30:b5:c2:63:a9:a6 timed out
[ 6065.138676] perf interrupt took too long (2503 > 2500), lowering kernel.perf_event_max_sample_rate to 50000
