Radeon Pro v1.1.1.0!
NiCo-pc
Radeon Pro 1.1.1.0 ist draußen!
Radeon Pro ist ein "Must-have" Tweak-Programm um die Grafik in vielen Spielen aufzuwerten.
Jeder der eine AMD Grafikkarte ab HD4000 hat sollte sich das Programm mal anschauen.
12/19/2012 - New build 1.1.1.0
- New: Added support for 64-bit applications
- New: Improved hardware detection
- New: Improved Windows 8 compatibility
- New: Movie capture feature with real-time Motion JPEG compression (DirectX 9/10/10.1/11) and OpenDML (AVI 2.0) support
- New: FXAA support (DirectX 9/10/10.1/11 and OpenGL)
- New: FXAA can be activated/deactivated during the game (configure the hotkey on RadeonPro's Settings screen)
- New: SMAA support (DirectX 9/10/10.1/11)
- New: SMAA can be activated/deactivated during the game (configure the hotkey on RadeonPro's Settings screen)
- New: Dynamic Vsync Control (DVC) support. This feature controls how vertical synchronization is applied at rendering time, automatically turning it off when frame rate is below monitor's refresh rate to reduce stuttering and turning it on when framerate is above or equal to monitor's refresh rate, improving smoothness.
- New: DVC can be activated/deactivated during the game with SHIFT+HOME key
- New: Dynamic Framerate Control (DFC) support. This feature acts like a frame rate limiter with smoothness control, just set a frame rate target and RadeonPro will try to keep it as close as possible while maintaining frame rendering times close to each other to avoid stuttering.
- New: DFC can be activated/deactivated during the game with SHIFT+END key
- New: DFC feature's frame rate target is adjustable in real time, press SHIFT+INSERT to increase the limit and SHIFT+DELETE to decrease it
- New: Lock frame rate up to monitor's refresh rate. This feature limits internal frame rendering times accordingly to refresh rate (i.e. 60 Hz = 16.67 ms) instead of waiting vertical retrace.
- New: On-Screen Display panel, showing current status of some RadeonPro features on top of game screen. Press PAGEDOWN key to toggle between full panel/reduced panel/hidden.
- New: OSD panel can be made visible since game start either globally or at profile level, just configure it on OSD tab
- New: OSD panel versions can be disabled either globally or at profile level, just configure it on OSD tab
- New: Real time GPU monitoring with On-Screen Display support. GPU monitoring displays your video cards temperatures, utilization, FAN speed and VRAM utilization
- New: Current date/time/FPS and actual playing time can be displayed at OSD
- New: Ambient Occlusion support (DirectX 9/10/10.1/11). Please bear in mind that not all games can be forced to use Ambient Occlusion. RadeonPro currently supports Horizon Based Ambient Occlusion (HBAO) and Volumetric Ambient Occlusion, different algorithms might be added in future. A list of supported games can be seen at end of changelog (see complete listing at Program Settings/Ambient Occlusion), the list will be updated based on author's tests and also based on feedback from users that have access to Ambient Occlusion debugging tool (TBD).
- New: Better keyboard handling (i.e. fixes some games that don't allow OSD control or change of FPS corner)
- New: Improved hook handling with better Steam overlay compatibility
- New: OverDrive controls allow basic overclocking, manual cooler fan speed and PowerTune adjustments (available only at profile level)
- New: Added option to display new CrossfireX logo on OSD when a CrossfireX capable system is detected
- New: Added proper support for Direct3D9Ex games (i.e. Blades of Time, Fallout New Vegas, World of Tanks etc.)
- New: Improved OpenGL support and bug fixes
- New: Built-in SweetFX integration, allowing global and per game SweetFX effect shaders configuration. SweetFX can be used on any DirectX 9/10/10.1/11 games running on 32-bit or 64-bit. Configure SweetFX at RadeonPro settings and remove all 3rd party injector's DLLs from game directories if you want to use RadeonPro's SweetFX integration. Obs: SweetFX shaders are disabled on Battle.net games and Planetside 2. Also, one additional module (PPContainer.dll for 32-bit/PPContainer64.dll for 64-bit) is used when SweetFX shaders are loaded in memory, making easier to detect when a game is employing custom shaders to modify games' appearance through RadeonPro
- New: Improved compatibility with Uplay and Origin overlay modules
- New: The program now warns the user when RadeonPro process is executing with elevated privileges on an UAC enabled system. Running RadeonPro with elevated privileges might break application detection, it's recommended executing RadeonPro with normal privileges (either non-admin or admin account, but not with elevated rights - i.e. don't use Run as Administrator)
- Fixed: Some games that used to hang at startup when API monitoring was active are now playable (i.e. STALKER Call of Pripyat)
- Fixed: screenshots now works in DirectX 10/11 with R10G10B10A2/B8G8R8A8 formats used by some games (Dirt 3/Showdown, F3AR). Performance is not so good as in other games, but it will be optimized soon.
- Changed: German translation update (thanks to Lennart Brüggemann)
- Changed: improved OSD rendering performance on DirectX 10/11 games
- Removed: SVG file creation at benchmark finish
- Removed: CrossfireX bar; to monitor GPU utilization, use OSD options instead
- Removed: alternate AMD Radeon logo
- Removed: skins (all). They will be replaced by new Web skins feature. Anyone with HTML and Javascript skills will be able to create skins for RadeonPro.
- Removed: Aggressive API detection (useless with new hook handler)
- Known issues:
-- Vsync is a bit broken in DirectX 9 for 64-bit apps
-- DFC/DVC may not work as expected in OpenGL apps
-- Movie's audio may go out of sync when target framerate is too high compared to sustained framerate
- Ambient Occlusion support list (DirectX 9 only when API omitted)
-- 2K Sports NBA 2K11
-- 2K Sports NBA 2K13
-- Alan Wake
-- Aliens vs Predator (DX9/DX11)
-- Assassin's Creed Brotherhood
-- Batman Arkham Asylum
-- Batman Arkham City (DX9/DX11)
-- Bioshock (DX9/DX10)
-- Bioshock 2 (DX9/DX10)
-- Blades of Time
-- BLUR
-- Brothers in Arms - Highway to Hell (have issues with out of position shadows during cut scenes when non 16:9 resolution is used)
-- Bulletstorm
-- James Bond 007 - Blood Stone
-- Call of Duty 2
-- Call of Duty: BlackOps
-- Colin McRae DiRT
-- Darksiders
-- Darksiders II
-- Dead Space
-- Dead Space 2
-- Devil May Cry 4
-- Diablo III
-- DiRT 2 (DX9/DX11 - only works with AA 0x)
-- Dishonored
-- Dragon Age II (DX11)
-- F.3.A.R. (DX11)
-- F.E.A.R.
-- Formula One 2012 (DX11)
-- FIFA 2012
-- FIFA 2013
-- Grand Theft Auto IV
-- Hard Reset
-- Ice Age 4
-- Mass Effect 3
-- Need for Speed Hot Pursuit
-- Need for Speed Most Wanted (DX10)
-- Of Orcs and Men
-- Racedriver GRID
-- rFactor
-- S.T.A.L.K.E.R. Shadow of Chernobyl
-- Sonic Adventure 2
-- Sonic Generations
-- Street Fighter IV
-- Street Fighter X Tekken
-- The Amazing Spider-Man
-- The Elder Scrolls V: Skyrim
-- Tomb Raider Anniversary
-- Tomb Raider Underworld
-- Trine
minimale Systemvoraussetzung
- Microsoft Windows Vista SP1 (Windows XP is not supported)
- Microsoft .NET Framework 2.0
- Microsoft DirectX Runtime June 2010 or newer
- ATI Radeon HD 4000 series graphics card or newer
optimale Systemvoraussetzung
- Microsoft Windows Vista Service Pack 2, Windows 7 or 8 (x86/x64)
- Microsoft .NET Framework 3.5
Hier der Link http://www.radeonpro.info/en-US/Downloads/Preview.aspx!
Ich musste erstmal Google bemühen was das ist.
Changelog Copy&Paste ohne eigene Meinung oder Angabe worum es sich überhaupt handelt..
Entweder bin ich total der Hinterwäldler oder man muss das nicht kennen..
Das Programm entwickelt sich seit "kurzem" sehr stark als Gegenpart von Nvidia Inspector.
Das Ding bringt Fähigkeiten mit, die AMD in ihrem Treiber gar nicht anbietet.
Dachte ich mir dann auch, aber das dieses Tool ne eigene News verdient hat und jeder anscheinend von alleine wissen sollte was das ist
und was es macht ist mir etwas Schleierhaft.
Ich verfasse dann jetzt auch User-News und poste Changelogs.:ugly:
WoooW
Zwar kann der NVIDIA Inspector schon recht viel aber SMAA und HABO kann er leider nicht.
Und die Spiele wo NV AO anbiete naja sind auch weniger.
Hättest du die Pcgh Zeitung gelesen sowie die Pcgh-DVD(Anleitung) gesehen hättest du es auch gewust :D:D
Echt? Ich dachte das geht da "immer"?
Ich hab jedenfalls gespendet an japamd. AMD braucht eindeutig so engagierte "Hobby"entwickler, um im Bereich der absoluten Grafikenthusiasten seinen Ruf aufzupolieren, und um das Image der Marke Radeon insgesamt aufzupolieren... denn bald macht AMD wohl nur noch damit Gewinn :ugly:
Soweit ich weiß kann man im NV-Treiber für einige Spiele die eigentlich kein AO bieten ( z.B. Skyrim ) AO erzwingen.
Guggst du >hier<. :)
Einstellen kannst du natürlich im Inspector, was du willst. Nur muss das Spiel sich nicht unbedingt dafür interessieren.
Wenn ein Spiel nicht als tauglich aufgeführt ist, gibt es auch nix, außer in ganz wenigen Einzelfällen (die mir aber noch nicht untergekommen sind). Ob sich was tut, kann man im Allgemeinen sehen - auch an der Framerate. :)
So, gerade getestet, mal hier ein schöner Vergleich, in welchem die Lichtstimmung im direkten Nebeneinander etwas dunkler akzentuiert ist. Wie üblich Nuancen, macht aber einen guten Eindruck, passt zum Bioshock-Feeling.:daumen:
Angesichts des grausligen Aliasings sollte ich wohl mal wieder die DS-Keule auspacken...oder SMAA testen. Hmmm, ich hab' mit dem Programm noch definitiv viel Spaß.:D
Edit: Sorry für die großen Bilder; ich hoffe, ich beanspruche eure Leitungen nicht zu sehr. Hier nochmal zwei kleinere Detailausschnitte mit AO, die gut darstellen, was SMAA (unten) bringt.
Echt ein feines Tool; Hut ab vor dem Entwickler!:hail:
Ja gut, aber trotzdem muss das Spiel nicht von sich aus AO anbieten, wenn der Inspector bits dafür hat, dann gehts. So hatte ich das auch gemeint.
