Kannst deine Spielstände auch aufm Stick sichern.
Leider nicht so "plug&play"-mäßig wie auf der PS4, aber immerhin gibts ne Möglichkeit auch ohne PS+.
Werde ich mich wohl ab diesem Monat dran gewöhnen müssen^^
- Connect a USB drive to your PS5 console.
- USB drives formatted with FAT or exFAT are supported.
- Go to the Home screen and select Settings > System.
- Select System Software > Backup and Restore > Create PS5 backup data.
- If multiple USB drives are connected, select the USB drive where you want to save your backup data.
- Select the individual data you want to backup, and then select Next.
- The file name and size will be displayed. If necessary, enter a description of the backup data.
- Select Backup.
- The console restarts and the backup begins.
- You will see a screen with the message Backup Completed. Your PS5 console will restart. Select OK.
- The console will restart again and you will return to the Home screen.
