Microsoft (R) Windows Debugger Version 6.2.9200.16384 AMD64
Copyright (c) Microsoft Corporation. All rights reserved.
Loading Dump File [C:\Windows\Minidump\102412-10140-01.dmp]
Mini Kernel Dump File: Only registers and stack trace are available
Symbol search path is: SRV*c:\symbols*http://msdl.microsoft.com/download/symbols
Executable search path is: C:\Windows\System32
Windows 7 Kernel Version 7601 (Service Pack 1) MP (4 procs) Free x64
Product: WinNt, suite: TerminalServer SingleUserTS
Built by: 7601.17944.amd64fre.win7sp1_gdr.120830-0333
Machine Name:
Kernel base = 0xfffff800`0384a000 PsLoadedModuleList = 0xfffff800`03a8e670
Debug session time: Wed Oct 24 23:04:37.111 2012 (UTC + 2:00)
System Uptime: 0 days 3:08:56.313
Loading Kernel Symbols
Loading User Symbols
Loading unloaded module list
* Bugcheck Analysis *
Use !analyze -v to get detailed debugging information.
BugCheck D1, {fffff88203049890, 2, 8, fffff88203049890}
Probably caused by : tcpip.sys ( tcpip!TcpSatisfyReceiveRequests+4a7 )
Followup: MachineOwner
1: kd> !analyze -v
DRIVER_IRQL_NOT_LESS_OR_EQUAL (d1)
An attempt was made to access a pageable (or completely invalid) address at an
interrupt request level (IRQL) that is too high. This is usually
caused by drivers using improper addresses.
If kernel debugger is available get stack backtrace.
Arguments:
Arg1: fffff88203049890, memory referenced
Arg2: 0000000000000002, IRQL
Arg3: 0000000000000008, value 0 = read operation, 1 = write operation
Arg4: fffff88203049890, address which referenced memory
Debugging Details:
READ_ADDRESS: GetPointerFromAddress: unable to read from fffff80003af8100
GetUlongFromAddress: unable to read from fffff80003af81c0
fffff88203049890 Nonpaged pool
CURRENT_IRQL: 2
FAULTING_IP:
+0
fffff882`03049890 ?? ???
CUSTOMER_CRASH_COUNT: 1
DEFAULT_BUCKET_ID: WIN7_DRIVER_FAULT
BUGCHECK_STR: 0xD1
PROCESS_NAME: AvastSvc.exe
TRAP_FRAME: fffff880073fde00 -- (.trap 0xfffff880073fde00)
NOTE: The trap frame does not contain all registers.
Some register values may be zeroed or incorrect.
rax=0000000000000d90 rbx=0000000000000000 rcx=fffffa8007791e68
rdx=0000000000000000 rsi=0000000000000000 rdi=0000000000000000
rip=fffff88203049890 rsp=fffff880073fdf98 rbp=fffff880073fe080
r8=0000000000000d90 r9=0000000000000000 r10=9205000000000001
r11=0000000000000000 r12=0000000000000000 r13=0000000000000000
r14=0000000000000000 r15=0000000000000000
iopl=0 nv up ei pl zr na po nc
Resetting default scope
LAST_CONTROL_TRANSFER: from fffff800038c8569 to fffff800038c8fc0
FAILED_INSTRUCTION_ADDRESS:
+0
STACK_TEXT:
fffff880`073fdcb8 fffff800`038c8569 : 00000000`0000000a fffff882`03049890 00000000`00000002 00000000`00000008 : nt!KeBugCheckEx
fffff880`073fdcc0 fffff800`038c71e0 : 00000000`00000000 00000000`00000000 fffff880`073fde10 fffffa80`0726e470 : nt!KiBugCheckDispatch+0x69
fffff880`073fde00 fffff882`03049890 : fffff880`01a4bd97 fffff880`073fe0f8 fffff880`073fe0c8 fffff880`073fe0e8 : nt!KiPageFault+0x260
fffff880`073fdf98 fffff880`01a4bd97 : fffff880`073fe0f8 fffff880`073fe0c8 fffff880`073fe0e8 fffff880`073fe0b0 : 0xfffff882`03049890
fffff880`073fdfa0 fffff880`01a62395 : 00000000`00000000 fffffa80`0f2dd5e0 00000000`00000000 00000000`00000000 : tcpip!TcpSatisfyReceiveRequests+0x4a7
fffff880`073fe280 fffff880`01a61189 : fffffa80`078fd680 fffff880`0195ff4b 00000000`00000228 00000000`00000000 : tcpip!TcpDeliverDataToClient+0x105
fffff880`073fe400 fffff880`01b34843 : fffffa80`0f2dd5e0 00000000`00000228 fffffa80`0f2dd740 00000000`397b163f : tcpip!TcpDeliverReceive+0xa9
fffff880`073fe500 fffff880`01a5f732 : fffffa80`0f2dd5e0 00000000`397b163f fffffa80`0ee0b220 fffffa80`0ee0b220 : tcpip!TcpInspectReceive+0xd3
fffff880`073fe570 fffff880`01a5ed25 : fffff880`073fe908 fffffa80`00000000 fffffa80`0f2dd5e0 fffff880`073fe9e0 : tcpip!TcpTcbFastDatagram+0x382
fffff880`073fe600 fffff880`01a5e65a : fffffa80`0792c910 fffffa80`073eec80 fffffa80`07904010 00000000`00000000 : tcpip!TcpTcbReceive+0x1f5
fffff880`073fe7b0 fffff880`01a5fbfb : fffffa80`06eba850 fffffa80`0ca89080 00000000`00000000 fffffa80`078fb700 : tcpip!TcpMatchReceive+0x1fa
fffff880`073fe900 fffff880`01a3b36a : fffffa80`0792c910 00000001`0000302f fffff880`0000d5c5 fffff880`073fd5c5 : tcpip!TcpPreValidatedReceive+0x36b
fffff880`073fe9d0 fffff800`038d4c48 : fffff880`01b6e9a0 fffff880`073feb06 fffff880`073febb8 fffff880`00000000 : tcpip!IppLoopbackTransmit+0x11a
fffff880`073fea80 fffff880`01a3bc7f : fffff880`01a89830 fffffa80`07973ca0 fffff880`073fec02 00000000`00000000 : nt!KeExpandKernelStackAndCalloutEx+0xd8
fffff880`073feb60 fffff880`01a5915a : fffffa80`0ee1b4b0 00000000`00000000 00000000`00000010 fffffa80`06eba700 : tcpip!IppLoopbackEnqueue+0x22f
fffff880`073fec10 00000000`00000000 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : tcpip!IppDispatchSendPacketHelper+0x38a
STACK_COMMAND: kb
FOLLOWUP_IP:
fffff880`01a4bd97 4c8b25da351400 mov r12,qword ptr [tcpip!TcpInetTransport+0x318 (fffff880`01b8f378)]
SYMBOL_STACK_INDEX: 4
SYMBOL_NAME: tcpip!TcpSatisfyReceiveRequests+4a7
FOLLOWUP_NAME: MachineOwner
MODULE_NAME: tcpip
IMAGE_NAME: tcpip.sys
DEBUG_FLR_IMAGE_TIMESTAMP: 5034f727
FAILURE_BUCKET_ID: X64_0xD1_CODE_AV_BAD_IP_tcpip!TcpSatisfyReceiveRequests+4a7
1: kd> lmv
start end module name
fffff800`03801000 fffff800`0384a000 hal (deferred)
Mapped memory image file: c:\windows\system32\hal.dll
Image path: hal.dll
Image name: hal.dll
Timestamp: Sat Nov 20 14:00:25 2010 (4CE7C669)
CheckSum: 000404C3
ImageSize: 00049000
File version: 6.1.7601.17514
Product version: 6.1.7601.17514
File flags: 0 (Mask 3F)
File OS: 40004 NT Win32
File type: 2.0 Dll
File date: 00000000.00000000
Translations: 0409.04b0
CompanyName: Microsoft Corporation
ProductName: Microsoft® Windows® Operating System
InternalName: hal.dll
OriginalFilename: hal.dll
ProductVersion: 6.1.7601.17514
FileVersion: 6.1.7601.17514 (win7sp1_rtm.101119-1850)
FileDescription: Hardware Abstraction Layer DLL
LegalCopyright: © Microsoft Corporation. All rights reserved.
fffff800`0384a000 fffff800`03e32000 nt (pdb symbols) c:\symbols\ntkrnlmp.pdb\B2DA40502FA744C18B9022FD187ADB592\ntkrnlmp.pdb
Loaded symbol image file: ntkrnlmp.exe
Mapped memory image file: c:\windows\system32\ntoskrnl.exe
Image path: ntkrnlmp.exe
Image name: ntkrnlmp.exe
Timestamp: Thu Aug 30 17:11:58 2012 (503F82BE)
CheckSum: 00554126
ImageSize: 005E8000
File version: 6.1.7601.17944
Product version: 6.1.7601.17944
File type: 1.0 App
InternalName: ntkrnlmp.exe
OriginalFilename: ntkrnlmp.exe
ProductVersion: 6.1.7601.17944
FileVersion: 6.1.7601.17944 (win7sp1_gdr.120830-0333)
FileDescription: NT Kernel & System
fffff800`0402e000 fffff800`04038000 kdcom (deferred)
Mapped memory image file: c:\windows\system32\kdcom.dll
Image path: kdcom.dll
Image name: kdcom.dll
Timestamp: Sat Feb 05 17:52:49 2011 (4D4D8061)
CheckSum: 0000F59B
ImageSize: 0000A000
File version: 6.1.7601.17556
Product version: 6.1.7601.17556
File type: 3.A Driver
InternalName: kdcom.dll
OriginalFilename: kdcom.dll
ProductVersion: 6.1.7601.17556
FileVersion: 6.1.7601.17556 (win7sp1_gdr.110204-2120)
FileDescription: Serial Kernel Debugger
fffff880`00c00000 fffff880`00c5c000 volmgrx (deferred)
Mapped memory image file: c:\windows\system32\drivers\volmgrx.sys
Image path: \SystemRoot\System32\drivers\volmgrx.sys
Image name: volmgrx.sys
Timestamp: Sat Nov 20 10:20:43 2010 (4CE792EB)
CheckSum: 00065F6D
ImageSize: 0005C000
File type: 3.7 Driver
InternalName: volmgrx.sys
OriginalFilename: volmgrx.sys
FileDescription: Volume Manager Extension Driver
fffff880`00c69000 fffff880`00cb8000 mcupdate_GenuineIntel (deferred)
Mapped memory image file: c:\windows\system32\mcupdate_GenuineIntel.dll
Image path: \SystemRoot\system32\mcupdate_GenuineIntel.dll
Image name: mcupdate_GenuineIntel.dll
Timestamp: Sat Nov 20 14:03:51 2010 (4CE7C737)
CheckSum: 0004F97E
ImageSize: 0004F000
InternalName: mcupdate.dll
OriginalFilename: mcupdate_GenuineIntel.dll
FileDescription: Intel Microcode Update Library
fffff880`00cb8000 fffff880`00ccc000 PSHED (deferred)
Mapped memory image file: c:\windows\system32\PSHED.dll
Image path: \SystemRoot\system32\PSHED.dll
Image name: PSHED.dll
Timestamp: Tue Jul 14 03:32:23 2009 (4A5BE027)
CheckSum: 0000F762
ImageSize: 00014000
File version: 6.1.7600.16385
Product version: 6.1.7600.16385
InternalName: pshed.dll
OriginalFilename: pshed.dll
ProductVersion: 6.1.7600.16385
FileVersion: 6.1.7600.16385 (win7_rtm.090713-1255)
FileDescription: Platform Specific Hardware Error Driver
fffff880`00ccc000 fffff880`00d2a000 CLFS (deferred)
Mapped memory image file: c:\windows\system32\CLFS.SYS
Image path: \SystemRoot\system32\CLFS.SYS
Image name: CLFS.SYS
Timestamp: Tue Jul 14 01:19:57 2009 (4A5BC11D)
CheckSum: 00065C46
ImageSize: 0005E000
Translations: 0000.04b0
InternalName: clfs.sys
OriginalFilename: Clfs.Sys
FileDescription: Common Log File System Driver
fffff880`00d2a000 fffff880`00dea000 CI (deferred)
Mapped memory image file: c:\windows\system32\CI.dll
Image path: \SystemRoot\system32\CI.dll
Image name: CI.dll
Timestamp: Sat Nov 20 14:12:36 2010 (4CE7C944)
CheckSum: 000CB0F6
ImageSize: 000C0000
InternalName: ci.dll
OriginalFilename: ci.dll
FileDescription: Code Integrity Module
fffff880`00e37000 fffff880`00edb000 Wdf01000 (deferred)
Mapped memory image file: c:\windows\system32\drivers\Wdf01000.sys
Image path: \SystemRoot\system32\drivers\Wdf01000.sys
Image name: Wdf01000.sys
Timestamp: Tue Jul 14 01:22:07 2009 (4A5BC19F)
CheckSum: 000A2E74
ImageSize: 000A4000
File version: 1.9.7600.16385
Product version: 1.9.7600.16385
InternalName: wdf01000.sys
OriginalFilename: wdf01000.sys
ProductVersion: 1.9.7600.16385
FileVersion: 1.9.7600.16385 (win7_rtm.090713-1255)
FileDescription: Kernel Mode Driver Framework Runtime
fffff880`00edb000 fffff880`00eea000 WDFLDR (deferred)
Mapped memory image file: c:\windows\system32\drivers\WdfLdr.sys
Image path: \SystemRoot\system32\drivers\WDFLDR.SYS
Image name: WDFLDR.SYS
Timestamp: Tue Jul 14 01:19:54 2009 (4A5BC11A)
CheckSum: 00011010
ImageSize: 0000F000
InternalName: wdfldr.sys
OriginalFilename: wdfldr.sys
FileDescription: Kernel Mode Driver Framework Loader
fffff880`00eea000 fffff880`00f41000 ACPI (deferred)
Mapped memory image file: c:\windows\system32\drivers\acpi.sys
Image path: \SystemRoot\system32\drivers\ACPI.sys
Image name: ACPI.sys
Timestamp: Sat Nov 20 10:19:16 2010 (4CE79294)
CheckSum: 0005ACF6
ImageSize: 00057000
InternalName: ACPI.sys
OriginalFilename: ACPI.sys
FileDescription: ACPI Driver for NT
fffff880`00f41000 fffff880`00f4a000 WMILIB (deferred)
Mapped memory image file: c:\windows\system32\drivers\wmilib.sys
Image path: \SystemRoot\system32\drivers\WMILIB.SYS
Image name: WMILIB.SYS
Timestamp: Tue Jul 14 01:19:51 2009 (4A5BC117)
CheckSum: 00005007
ImageSize: 00009000
InternalName: WmiLib.sys
OriginalFilename: WmiLib.sys
FileDescription: WMILIB WMI support library Dll
fffff880`00f4a000 fffff880`00f54000 msisadrv (deferred)
Mapped memory image file: c:\windows\system32\drivers\msisadrv.sys
Image path: \SystemRoot\system32\drivers\msisadrv.sys
Image name: msisadrv.sys
Timestamp: Tue Jul 14 01:19:26 2009 (4A5BC0FE)
CheckSum: 0001320D
ImageSize: 0000A000
InternalName: msisadrv.sys
OriginalFilename: msisadrv.sys
FileDescription: ISA Driver
fffff880`00f54000 fffff880`00f87000 pci (deferred)
Mapped memory image file: c:\windows\system32\drivers\pci.sys
Image path: \SystemRoot\system32\drivers\pci.sys
Image name: pci.sys
Timestamp: Sat Nov 20 10:19:11 2010 (4CE7928F)
CheckSum: 00033150
ImageSize: 00033000
File type: 2.0 Dll
InternalName: pci.sys
OriginalFilename: pci.sys
FileDescription: NT Plug and Play PCI Enumerator
fffff880`00f87000 fffff880`00f94000 vdrvroot (deferred)
Mapped memory image file: c:\windows\system32\drivers\vdrvroot.sys
Image path: \SystemRoot\system32\drivers\vdrvroot.sys
Image name: vdrvroot.sys
Timestamp: Tue Jul 14 02:01:31 2009 (4A5BCADB)
CheckSum: 0000C04B
ImageSize: 0000D000
File type: 2.0 Dll
InternalName: vdrvroot.sys
OriginalFilename: vdrvroot.sys
FileDescription: Virtual Drive Root Enumerator
fffff880`00f94000 fffff880`00f9d000 iusb3hcs (deferred)
Mapped memory image file: c:\windows\system32\drivers\iusb3hcs.sys
Image path: \SystemRoot\system32\DRIVERS\iusb3hcs.sys
Image name: iusb3hcs.sys
Timestamp: Fri Jan 27 10:37:23 2012 (4F227053)
CheckSum: 00008B4D
ImageSize: 00009000
File version: 1.0.3.214
Product version: 1.0.3.214
File flags: 8 (Mask 3F) Private
CompanyName: Intel Corporation
ProductName: USB 3.0 Host Controller Switch Driver
InternalName: IUSB3XHC.SYS
OriginalFilename: IUSB3XHC.SYS
ProductVersion: 1.0.3.214
FileVersion: 1.0.3.214 built by: WinDDK
FileDescription: Intel(R) USB 3.0 Host Controller Switch Driver
LegalCopyright: (C) 2010-2011 Intel Corporation
fffff880`00f9d000 fffff880`00fb2000 partmgr (deferred)
Mapped memory image file: c:\windows\system32\drivers\partmgr.sys
Image path: \SystemRoot\System32\drivers\partmgr.sys
Image name: partmgr.sys
Timestamp: Sat Mar 17 06:06:09 2012 (4F641BC1)
CheckSum: 0001DFC8
ImageSize: 00015000
File version: 6.1.7601.17796
Product version: 6.1.7601.17796
InternalName: partmgr.sys
OriginalFilename: partmgr.sys
ProductVersion: 6.1.7601.17796
FileVersion: 6.1.7601.17796 (win7sp1_gdr.120316-1742)
FileDescription: Partition Management Driver
fffff880`00fb2000 fffff880`00fc7000 volmgr (deferred)
Mapped memory image file: c:\windows\system32\drivers\volmgr.sys
Image path: \SystemRoot\system32\drivers\volmgr.sys
Image name: volmgr.sys
Timestamp: Sat Nov 20 10:19:28 2010 (4CE792A0)
CheckSum: 00019F72
ImageSize: 00015000
InternalName: volmgr.sys
OriginalFilename: volmgr.sys
FileDescription: Volume Manager Driver
fffff880`00fc7000 fffff880`00fe1000 mountmgr (deferred)
Mapped memory image file: c:\windows\system32\drivers\mountmgr.sys
Image path: \SystemRoot\System32\drivers\mountmgr.sys
Image name: mountmgr.sys
Timestamp: Sat Nov 20 10:19:21 2010 (4CE79299)
CheckSum: 00022621
ImageSize: 0001A000
InternalName: mountmgr.sys
OriginalFilename: mountmgr.sys
FileDescription: Mount Point Manager
fffff880`0100d000 fffff880`01049000 vmbus (deferred)
Mapped memory image file: c:\windows\system32\drivers\vmbus.sys
Image path: \SystemRoot\system32\drivers\vmbus.sys
Image name: vmbus.sys
Timestamp: Sat Nov 20 10:57:29 2010 (4CE79B89)
CheckSum: 0003F6CF
ImageSize: 0003C000
InternalName: vmbus.sys
OriginalFilename: vmbus.sys
FileDescription: Virtual Machine Bus
fffff880`01049000 fffff880`0105d000 winhv (deferred)
Mapped memory image file: c:\windows\system32\drivers\winhv.sys
Image path: \SystemRoot\system32\drivers\winhv.sys
Image name: winhv.sys
Timestamp: Sat Nov 20 10:20:02 2010 (4CE792C2)
CheckSum: 00017BFE
ImageSize: 00014000
InternalName: WinHv.sys
OriginalFilename: WinHv.sys
FileDescription: Windows Hypervisor Interface Driver
fffff880`0105d000 fffff880`0106c000 asahci64 (deferred)
Mapped memory image file: c:\windows\system32\drivers\asahci64.sys
Image path: \SystemRoot\system32\DRIVERS\asahci64.sys
Image name: asahci64.sys
Timestamp: Wed Sep 21 11:42:57 2011 (4E79B1A1)
CheckSum: 00010EE2
ImageSize: 0000F000
File version: 1.3.1.0
Product version: 1.3.1.0
CompanyName: Asmedia Technology
ProductName: Asmedia 106x SATA Host Controller Driver
InternalName: asahci.sys
OriginalFilename: asahci.sys
ProductVersion: 1.3.1.000
FileVersion: 1.3.1.000 built by: WinDDK
FileDescription: Asmedia 106x SATA Host Controller Driver
LegalCopyright: © Asmedia Technology.
fffff880`0106c000 fffff880`010b8000 fltmgr (deferred)
Mapped memory image file: c:\windows\system32\drivers\fltMgr.sys
Image path: \SystemRoot\system32\drivers\fltmgr.sys
Image name: fltmgr.sys
Timestamp: Sat Nov 20 10:19:24 2010 (4CE7929C)
CheckSum: 0005452D
ImageSize: 0004C000
InternalName: fltMgr.sys
OriginalFilename: fltMgr.sys
FileDescription: Microsoft Filesystem Filter Manager
fffff880`010b8000 fffff880`010cc000 fileinfo (deferred)
Mapped memory image file: c:\windows\system32\drivers\fileinfo.sys
Image path: \SystemRoot\system32\drivers\fileinfo.sys
Image name: fileinfo.sys
Timestamp: Tue Jul 14 01:34:25 2009 (4A5BC481)
CheckSum: 00015644
ImageSize: 00014000
InternalName: FileInfo.sys
OriginalFilename: FileInfo.sys
FileDescription: FileInfo Filter Driver
fffff880`010cc000 fffff880`0112a000 msrpc (deferred)
Mapped memory image file: c:\windows\system32\drivers\msrpc.sys
Image path: \SystemRoot\System32\Drivers\msrpc.sys
Image name: msrpc.sys
Timestamp: Sat Nov 20 10:21:56 2010 (4CE79334)
CheckSum: 0005E9E7
ImageSize: 0005E000
InternalName: krpcdd.sys
OriginalFilename: krpcdd.sys
FileDescription: Kernel Remote Procedure Call Provider
fffff880`0112a000 fffff880`0119c000 cng (deferred)
Mapped memory image file: c:\windows\system32\drivers\cng.sys
Image path: \SystemRoot\System32\Drivers\cng.sys
Image name: cng.sys
Timestamp: Sat Jun 02 05:25:51 2012 (4FC987BF)
CheckSum: 00075788
ImageSize: 00072000
File version: 6.1.7601.17856
Product version: 6.1.7601.17856
InternalName: cng.sys
OriginalFilename: cng.sys
ProductVersion: 6.1.7601.17856
FileVersion: 6.1.7601.17856 (win7sp1_gdr.120601-1505)
FileDescription: Kernel Cryptography, Next Generation
fffff880`0119c000 fffff880`011e6000 fwpkclnt (deferred)
Mapped memory image file: c:\windows\system32\drivers\FWPKCLNT.SYS
Image path: \SystemRoot\System32\drivers\fwpkclnt.sys
Image name: fwpkclnt.sys
Timestamp: Wed Aug 22 17:10:49 2012 (5034F679)
CheckSum: 00055FFF
ImageSize: 0004A000
File version: 6.1.7601.17939
Product version: 6.1.7601.17939
File type: 2.0 Dll
InternalName: fwpkclnt.sys
OriginalFilename: fwpkclnt.sys
ProductVersion: 6.1.7601.17939
FileVersion: 6.1.7601.17939 (win7sp1_gdr.120822-0331)
FileDescription: FWP/IPsec Kernel-Mode API
fffff880`01200000 fffff880`0122a000 ataport (deferred)
Mapped memory image file: c:\windows\system32\drivers\ataport.sys
Image path: \SystemRoot\system32\drivers\ataport.SYS
Image name: ataport.SYS
Timestamp: Sat Nov 20 10:19:15 2010 (4CE79293)
CheckSum: 000287EF
ImageSize: 0002A000
InternalName: ataport.sys
OriginalFilename: ataport.sys
FileDescription: ATAPI Driver Extension
fffff880`0122c000 fffff880`015d0000 iaStor (deferred)
Mapped memory image file: c:\windows\system32\drivers\iaStor.sys
Image path: \SystemRoot\system32\DRIVERS\iaStor.sys
Image name: iaStor.sys
Timestamp: Wed Nov 30 04:39:19 2011 (4ED5A567)
CheckSum: 0009778C
ImageSize: 003A4000
File version: 11.0.0.1032
Product version: 11.0.0.1032
ProductName: Intel Rapid Storage Technology driver
InternalName: iaStor.sys
OriginalFilename: iaStor.sys
ProductVersion: 11.0.0.1032
FileVersion: 11.0.0.1032
PrivateBuild: 11.0.0.1032
SpecialBuild: 11.0.0.1032
FileDescription: Intel Rapid Storage Technology driver - x64
LegalCopyright: Copyright(C) Intel Corporation 1994-2011
LegalTrademarks: Copyright(C) Intel Corporation 1994-2011
Comments: -x64
fffff880`015d0000 fffff880`015d9000 atapi (deferred)
Mapped memory image file: c:\windows\system32\drivers\atapi.sys
Image path: \SystemRoot\system32\drivers\atapi.sys
Image name: atapi.sys
Timestamp: Tue Jul 14 01:19:47 2009 (4A5BC113)
CheckSum: 000065BB
ImageSize: 00009000
InternalName: atapi.sys
OriginalFilename: atapi.sys
FileDescription: ATAPI IDE Miniport Driver
fffff880`015d9000 fffff880`015e4000 msahci (deferred)
Mapped memory image file: c:\windows\system32\drivers\msahci.sys
Image path: \SystemRoot\system32\drivers\msahci.sys
Image name: msahci.sys
Timestamp: Sat Nov 20 11:33:58 2010 (4CE7A416)
CheckSum: 00017292
ImageSize: 0000B000
InternalName: msahci.sys
OriginalFilename: msahci.sys
FileDescription: MS AHCI 1.0 Standard Driver
fffff880`015e4000 fffff880`015f4000 PCIIDEX (deferred)
Mapped memory image file: c:\windows\system32\drivers\pciidex.sys
Image path: \SystemRoot\system32\drivers\PCIIDEX.SYS
Image name: PCIIDEX.SYS
Timestamp: Tue Jul 14 01:19:48 2009 (4A5BC114)
CheckSum: 00019CC5
ImageSize: 00010000
InternalName: pciidex.sys
OriginalFilename: pciidex.sys
FileDescription: PCI IDE Bus Driver Extension
fffff880`015f4000 fffff880`015ff000 amdxata (deferred)
Mapped memory image file: c:\windows\system32\drivers\amdxata.sys
Image path: \SystemRoot\system32\drivers\amdxata.sys
Image name: amdxata.sys
Timestamp: Fri Mar 19 17:18:18 2010 (4BA3A3CA)
CheckSum: 000092B7
ImageSize: 0000B000
File version: 1.1.2.5
Product version: 1.1.2.5
CompanyName: Advanced Micro Devices
ProductName: Storage Filter Driver
InternalName: vadd.sys
OriginalFilename: vadd.sys
ProductVersion: 1.1.2.5
FileVersion: 1.1.2.5 (NT.091202-1659)
FileDescription: Storage Filter Driver
LegalCopyright: Copyright © 2008-2010 AMD, Inc.
fffff880`01600000 fffff880`0160a000 Fs_Rec (deferred)
Mapped memory image file: c:\windows\system32\drivers\fs_rec.sys
Image path: \SystemRoot\System32\Drivers\Fs_Rec.sys
Image name: Fs_Rec.sys
Timestamp: Thu Mar 01 04:41:06 2012 (4F4EEFD2)
CheckSum: 00012F92
ImageSize: 0000A000
File version: 6.1.7601.17787
Product version: 6.1.7601.17787
InternalName: fs_rec.sys
OriginalFilename: fs_rec.sys
ProductVersion: 6.1.7601.17787
FileVersion: 6.1.7601.17787 (win7sp1_gdr.120229-1502)
FileDescription: File System Recognizer Driver
fffff880`0162b000 fffff880`017ce000 Ntfs (deferred)
Mapped memory image file: c:\windows\system32\drivers\ntfs.sys
Image path: \SystemRoot\System32\Drivers\Ntfs.sys
Image name: Ntfs.sys
Timestamp: Fri Aug 31 17:14:14 2012 (5040D4C6)
CheckSum: 0019EA7B
ImageSize: 001A3000
File version: 6.1.7601.17945
Product version: 6.1.7601.17945
InternalName: ntfs.sys
OriginalFilename: ntfs.sys
ProductVersion: 6.1.7601.17945
FileVersion: 6.1.7601.17945 (win7sp1_gdr.120831-0331)
FileDescription: NT File System Driver
fffff880`017ce000 fffff880`017e9000 ksecdd (deferred)
Mapped memory image file: c:\windows\system32\drivers\ksecdd.sys
Image path: \SystemRoot\System32\Drivers\ksecdd.sys
Image name: ksecdd.sys
Timestamp: Sat Jun 02 04:50:23 2012 (4FC97F6F)
CheckSum: 00024C2C
ImageSize: 0001B000
InternalName: ksecdd.sys
OriginalFilename: ksecdd.sys
FileDescription: Kernel Security Support Provider Interface
fffff880`017e9000 fffff880`017fa000 pcw (deferred)
Mapped memory image file: c:\windows\system32\drivers\pcw.sys
Image path: \SystemRoot\System32\drivers\pcw.sys
Image name: pcw.sys
Timestamp: Tue Jul 14 01:19:27 2009 (4A5BC0FF)
CheckSum: 00014B5E
ImageSize: 00011000
File type: 3.8 Driver
InternalName: pcw.sys
OriginalFilename: pcw.sys
FileDescription: Performance Counters for Windows Driver
fffff880`01841000 fffff880`01933000 ndis (deferred)
Mapped memory image file: c:\windows\system32\drivers\ndis.sys
Image path: \SystemRoot\system32\drivers\ndis.sys
Image name: ndis.sys
Timestamp: Wed Aug 22 17:11:46 2012 (5034F6B2)
CheckSum: 000E8B11
ImageSize: 000F2000
File type: 3.6 Driver
InternalName: NDIS.SYS
OriginalFilename: NDIS.SYS
FileDescription: NDIS 6.20 driver
fffff880`01933000 fffff880`01993000 NETIO (deferred)
Mapped memory image file: c:\windows\system32\drivers\netio.sys
Image path: \SystemRoot\system32\drivers\NETIO.SYS
Image name: NETIO.SYS
Timestamp: Wed Aug 22 17:11:28 2012 (5034F6A0)
CheckSum: 00067D76
ImageSize: 00060000
InternalName: netio.sys
OriginalFilename: netio.sys
FileDescription: Network I/O Subsystem
fffff880`01993000 fffff880`019bd000 ksecpkg (deferred)
Mapped memory image file: c:\windows\system32\drivers\ksecpkg.sys
Image path: \SystemRoot\System32\Drivers\ksecpkg.sys
Image name: ksecpkg.sys
Timestamp: Sat Jun 02 05:27:11 2012 (4FC9880F)
CheckSum: 00026530
ImageSize: 0002A000
InternalName: ksecpkg.sys
OriginalFilename: ksecpkg.sys
FileDescription: Kernel Security Support Provider Interface Packages
fffff880`019bd000 fffff880`019cd000 vmstorfl (deferred)
Mapped memory image file: c:\windows\system32\drivers\vmstorfl.sys
Image path: \SystemRoot\system32\drivers\vmstorfl.sys
Image name: vmstorfl.sys
Timestamp: Sat Nov 20 10:57:30 2010 (4CE79B8A)
CheckSum: 0000ED21
ImageSize: 00010000
InternalName: vmstorfl.sys
OriginalFilename: vmstorfl.sys
FileDescription: Virtual Storage Filter Driver
fffff880`01a00000 fffff880`01c00000 tcpip (pdb symbols) c:\symbols\tcpip.pdb\9EFE92FF052D4253ADA74F2DF6B4AB662\tcpip.pdb
Loaded symbol image file: tcpip.sys
Mapped memory image file: c:\windows\system32\drivers\tcpip.sys
Image path: \SystemRoot\System32\drivers\tcpip.sys
Image name: tcpip.sys
Timestamp: Wed Aug 22 17:13:43 2012 (5034F727)
CheckSum: 001E219D
ImageSize: 00200000
InternalName: tcpip.sys
OriginalFilename: tcpip.sys
FileDescription: TCP/IP Driver
fffff880`01c0e000 fffff880`01c97000 afd (deferred)
Mapped memory image file: c:\windows\system32\drivers\afd.sys
Image path: \SystemRoot\system32\drivers\afd.sys
Image name: afd.sys
Timestamp: Wed Dec 28 04:59:20 2011 (4EFA9418)
CheckSum: 000873E8
ImageSize: 00089000
File version: 6.1.7601.17752
Product version: 6.1.7601.17752
InternalName: afd.sys
OriginalFilename: afd.sys
ProductVersion: 6.1.7601.17752
FileVersion: 6.1.7601.17752 (win7sp1_gdr.111227-1505)
FileDescription: Ancillary Function Driver for WinSock
fffff880`01c97000 fffff880`01cb8000 raspptp (deferred)
Mapped memory image file: c:\windows\system32\drivers\raspptp.sys
Image path: \SystemRoot\system32\DRIVERS\raspptp.sys
Image name: raspptp.sys
Timestamp: Sat Nov 20 11:52:31 2010 (4CE7A86F)
CheckSum: 000251CB
ImageSize: 00021000
InternalName: RASPPTP.SYS
OriginalFilename: RASPPTP.SYS
FileDescription: Peer-to-Peer Tunneling Protocol
fffff880`01cd1000 fffff880`01d1d000 volsnap (deferred)
Mapped memory image file: c:\windows\system32\drivers\volsnap.sys
Image path: \SystemRoot\system32\drivers\volsnap.sys
Image name: volsnap.sys
Timestamp: Sat Nov 20 10:20:08 2010 (4CE792C8)
CheckSum: 000527ED
ImageSize: 0004C000
InternalName: volsnap.sys
OriginalFilename: volsnap.sys
FileDescription: Volume Shadow Copy Driver
fffff880`01d1d000 fffff880`01d25000 spldr (deferred)
Mapped memory image file: c:\windows\system32\drivers\spldr.sys
Image path: \SystemRoot\System32\Drivers\spldr.sys
Image name: spldr.sys
Timestamp: Mon May 11 18:56:27 2009 (4A0858BB)
CheckSum: 0000E0E9
ImageSize: 00008000
File version: 6.1.7127.0
Product version: 6.1.7127.0
File type: 3.0 Driver
InternalName: spldr.sys
OriginalFilename: spldr.sys
ProductVersion: 6.1.7127.0
FileVersion: 6.1.7127.0 (fbl_security_bugfix(sepbld-s).090511-0943)
FileDescription: loader for security processor
fffff880`01d25000 fffff880`01d5f000 rdyboost (deferred)
Mapped memory image file: c:\windows\system32\drivers\rdyboost.sys
Image path: \SystemRoot\System32\drivers\rdyboost.sys
Image name: rdyboost.sys
Timestamp: Sat Nov 20 10:43:10 2010 (4CE7982E)
CheckSum: 00037356
ImageSize: 0003A000
InternalName: rdyboost.sys
OriginalFilename: rdyboost.sys
FileDescription: ReadyBoost Driver
fffff880`01d5f000 fffff880`01d71000 mup (deferred)
Mapped memory image file: c:\windows\system32\drivers\mup.sys
Image path: \SystemRoot\System32\Drivers\mup.sys
Image name: mup.sys
Timestamp: Tue Jul 14 01:23:45 2009 (4A5BC201)
CheckSum: 00015DFD
ImageSize: 00012000
InternalName: MUP.SYS
OriginalFilename: MUP.SYS
FileDescription: Multiple UNC Provider Driver
fffff880`01d71000 fffff880`01d7a000 hwpolicy (deferred)
Mapped memory image file: c:\windows\system32\drivers\hwpolicy.sys
Image path: \SystemRoot\System32\drivers\hwpolicy.sys
Image name: hwpolicy.sys
Timestamp: Sat Nov 20 10:18:54 2010 (4CE7927E)
CheckSum: 0000D9F4
ImageSize: 00009000
File type: 2.0 Dll
InternalName: hwpolicy.sys
OriginalFilename: hwpolicy.sys
FileDescription: Hardware Policy Driver
fffff880`01d7a000 fffff880`01db4000 fvevol (deferred)
Mapped memory image file: c:\windows\system32\drivers\fvevol.sys
Image path: \SystemRoot\System32\DRIVERS\fvevol.sys
Image name: fvevol.sys
Timestamp: Sat Nov 20 10:24:06 2010 (4CE793B6)
CheckSum: 000389BC
ImageSize: 0003A000
InternalName: FVEVOL.SYS
OriginalFilename: FVEVOL.SYS
FileDescription: BitLocker Drive Encryption Driver
fffff880`01db4000 fffff880`01dca000 disk (deferred)
Mapped memory image file: c:\windows\system32\drivers\disk.sys
Image path: \SystemRoot\system32\DRIVERS\disk.sys
Image name: disk.sys
CheckSum: 0001FF1D
ImageSize: 00016000
InternalName: disk.sys
OriginalFilename: disk.sys
FileDescription: PnP Disk Driver
fffff880`01dca000 fffff880`01dfa000 CLASSPNP (deferred)
Mapped memory image file: c:\windows\system32\drivers\Classpnp.sys
Image path: \SystemRoot\system32\DRIVERS\CLASSPNP.SYS
Image name: CLASSPNP.SYS
Timestamp: Sat Nov 20 10:19:23 2010 (4CE7929B)
CheckSum: 000318BE
ImageSize: 00030000
InternalName: Classpnp.sys
OriginalFilename: Classpnp.sys
FileDescription: SCSI Class System Dll
fffff880`03000000 fffff880`03009000 RDPCDD (deferred)
Mapped memory image file: c:\windows\system32\drivers\RDPCDD.sys
Image path: \SystemRoot\System32\DRIVERS\RDPCDD.sys
Image name: RDPCDD.sys
Timestamp: Tue Jul 14 02:16:34 2009 (4A5BCE62)
CheckSum: 0000FFAC
ImageSize: 00009000
File type: 3.4 Driver
InternalName: RDPCDD.SYS
OriginalFilename: RDPCDD.SYS
FileDescription: RDP Miniport
fffff880`03009000 fffff880`03012000 rdpencdd (deferred)
Mapped memory image file: c:\windows\system32\drivers\RDPENCDD.sys
Image path: \SystemRoot\system32\drivers\rdpencdd.sys
Image name: rdpencdd.sys
CheckSum: 000074D5
ImageSize: 00009000
InternalName: RDPENCDD.SYS
OriginalFilename: RDPENCDD.SYS
FileDescription: RDP Encoder Miniport
fffff880`03012000 fffff880`0301b000 rdprefmp (deferred)
Mapped memory image file: c:\windows\system32\drivers\RDPREFMP.sys
Image path: \SystemRoot\system32\drivers\rdprefmp.sys
Image name: rdprefmp.sys
Timestamp: Tue Jul 14 02:16:35 2009 (4A5BCE63)
CheckSum: 0000ABCD
ImageSize: 00009000
InternalName: RDPREFMP.SYS
OriginalFilename: RDPREFMP.SYS
FileDescription: RDP Reflector Driver Miniport
fffff880`0301b000 fffff880`03026000 Msfs (deferred)
Mapped memory image file: c:\windows\system32\drivers\msfs.sys
Image path: \SystemRoot\System32\Drivers\Msfs.SYS
Image name: Msfs.SYS
CheckSum: 00007126
ImageSize: 0000B000
InternalName: MSFS.SYS
OriginalFilename: MSFS.SYS
FileDescription: Mailslot driver
fffff880`03026000 fffff880`03037000 Npfs (deferred)
Mapped memory image file: c:\windows\system32\drivers\npfs.sys
Image path: \SystemRoot\System32\Drivers\Npfs.SYS
Image name: Npfs.SYS
CheckSum: 00019AED
ImageSize: 00011000
InternalName: npfs.sys
OriginalFilename: npfs.sys
FileDescription: NPFS Driver
fffff880`03037000 fffff880`03059000 tdx (deferred)
Mapped memory image file: c:\windows\system32\drivers\tdx.sys
Image path: \SystemRoot\system32\DRIVERS\tdx.sys
Image name: tdx.sys
Timestamp: Sat Nov 20 10:21:54 2010 (4CE79332)
CheckSum: 000288B2
ImageSize: 00022000
InternalName: tdx.sys
OriginalFilename: tdx.sys
FileDescription: TDI Translation Driver
fffff880`03059000 fffff880`03066000 TDI (deferred)
Mapped memory image file: c:\windows\system32\drivers\tdi.sys
Image path: \SystemRoot\system32\DRIVERS\TDI.SYS
Image name: TDI.SYS
Timestamp: Sat Nov 20 10:22:06 2010 (4CE7933E)
CheckSum: 00016255
ImageSize: 0000D000
InternalName: tdi.sys
OriginalFilename: tdi.sys
FileDescription: TDI Wrapper
fffff880`03066000 fffff880`03078000 aswTdi (deferred)
Mapped memory image file: c:\windows\system32\drivers\aswTdi.sys
Image path: \SystemRoot\System32\Drivers\aswTdi.SYS
Image name: aswTdi.SYS
Timestamp: Tue Aug 21 11:05:01 2012 (50334F3D)
CheckSum: 0000F1F0
ImageSize: 00012000
File version: 7.0.1466.549
Product version: 7.0.1466.549
CompanyName: AVAST Software
ProductName: avast! Antivirus
InternalName: aswTdi.sys
OriginalFilename: aswTdi.sys
ProductVersion: 7.0.1466.549
FileVersion: 7.0.1466.549 built by: WinDDK
FileDescription: avast! TDI Filter Driver
LegalCopyright: Copyright (c) 2012 AVAST Software
fffff880`03078000 fffff880`03088000 aswrdr2 (deferred)
Mapped memory image file: c:\windows\system32\drivers\aswRdr2.sys
Image path: \SystemRoot\System32\Drivers\aswrdr2.sys
Image name: aswrdr2.sys
Timestamp: Tue Aug 21 11:05:16 2012 (50334F4C)
CheckSum: 00017625
ImageSize: 00010000
InternalName: aswRdr.sys
OriginalFilename: aswRdr.sys
FileDescription: avast! WFP Redirect Driver
fffff880`03088000 fffff880`030a6000 dfsc (deferred)
Mapped memory image file: c:\windows\system32\drivers\dfsc.sys
Image path: \SystemRoot\System32\Drivers\dfsc.sys
Image name: dfsc.sys
Timestamp: Sat Nov 20 10:26:31 2010 (4CE79447)
CheckSum: 0001D647
ImageSize: 0001E000
InternalName: dfsclient.sys
OriginalFilename: dfsclient.sys
FileDescription: DFS Namespace Client Driver
fffff880`030a6000 fffff880`030b5000 mouclass (deferred)
Mapped memory image file: c:\windows\system32\drivers\mouclass.sys
Image path: \SystemRoot\system32\drivers\mouclass.sys
Image name: mouclass.sys
Timestamp: Tue Jul 14 01:19:50 2009 (4A5BC116)
CheckSum: 0000E5DE
ImageSize: 0000F000
InternalName: mouclass.sys
OriginalFilename: mouclass.sys
FileDescription: Mouse Class Driver
fffff880`030ba000 fffff880`031aa000 aswSnx (deferred)
Mapped memory image file: c:\windows\system32\drivers\aswSnx.sys
Image path: \SystemRoot\System32\Drivers\aswSnx.SYS
Image name: aswSnx.SYS
Timestamp: Tue Aug 21 11:05:56 2012 (50334F74)
CheckSum: 000F3B11
ImageSize: 000F0000
InternalName: aswSnx.sys
OriginalFilename: aswSnx.sys
FileDescription: avast! Virtualization Driver
fffff880`031aa000 fffff880`031b3000 Null (deferred)
Mapped memory image file: c:\windows\system32\drivers\null.sys
Image path: \SystemRoot\System32\Drivers\Null.SYS
Image name: Null.SYS
Timestamp: Tue Jul 14 01:19:37 2009 (4A5BC109)
CheckSum: 0000E9DB
ImageSize: 00009000
InternalName: null.sys
OriginalFilename: null.sys
FileDescription: NULL Driver
fffff880`031b3000 fffff880`031ba000 Beep (deferred)
Mapped memory image file: c:\windows\system32\drivers\beep.sys
Image path: \SystemRoot\System32\Drivers\Beep.SYS
Image name: Beep.SYS
Timestamp: Tue Jul 14 02:00:13 2009 (4A5BCA8D)
CheckSum: 000036EB
ImageSize: 00007000
InternalName: beep.sys
OriginalFilename: beep.sys
FileDescription: BEEP Driver
fffff880`031ba000 fffff880`031c8000 vga (deferred)
Mapped memory image file: c:\windows\system32\drivers\vga.sys
Image path: \SystemRoot\System32\drivers\vga.sys
Image name: vga.sys
Timestamp: Tue Jul 14 01:38:47 2009 (4A5BC587)
CheckSum: 00013E6F
ImageSize: 0000E000
InternalName: vga.sys
OriginalFilename: vga.sys
FileDescription: VGA/Super VGA Video Driver
fffff880`031c8000 fffff880`031ed000 VIDEOPRT (deferred)
Mapped memory image file: c:\windows\system32\drivers\videoprt.sys
Image path: \SystemRoot\System32\drivers\VIDEOPRT.SYS
Image name: VIDEOPRT.SYS
Timestamp: Tue Jul 14 01:38:51 2009 (4A5BC58B)
CheckSum: 00028FC7
ImageSize: 00025000
InternalName: videoprt.sys
OriginalFilename: videoprt.sys
FileDescription: Video Port Driver
fffff880`031ed000 fffff880`031fd000 watchdog (deferred)
Mapped memory image file: c:\windows\system32\drivers\watchdog.sys
Image path: \SystemRoot\System32\drivers\watchdog.sys
Image name: watchdog.sys
Timestamp: Tue Jul 14 01:37:35 2009 (4A5BC53F)
CheckSum: 00019CBE
ImageSize: 00010000
File type: 2.0 Dll
InternalName: watchdog.sys
OriginalFilename: watchdog.sys
FileDescription: Watchdog Driver
fffff880`04200000 fffff880`0422a000 cdrom (deferred)
Mapped memory image file: c:\windows\system32\drivers\cdrom.sys
Image path: \SystemRoot\system32\drivers\cdrom.sys
Image name: cdrom.sys
Timestamp: Sat Nov 20 10:19:20 2010 (4CE79298)
CheckSum: 0002B742
ImageSize: 0002A000
InternalName: cdrom.sys
OriginalFilename: cdrom.sys
FileDescription: SCSI CD-ROM Driver
fffff880`0422a000 fffff880`045ce000 dump_iaStor (deferred)
Image path: \SystemRoot\System32\Drivers\dump_iaStor.sys
Image name: dump_iaStor.sys
CheckSum: 0009778C
ImageSize: 003A4000
Comments: -x64
fffff880`04600000 fffff880`04683000 csc (deferred)
Mapped memory image file: c:\windows\system32\drivers\csc.sys
Image path: \SystemRoot\system32\drivers\csc.sys
Image name: csc.sys
Timestamp: Sat Nov 20 10:27:12 2010 (4CE79470)
CheckSum: 0008519D
ImageSize: 00083000
InternalName: csc.sys
OriginalFilename: CSC.Sys
FileDescription: Windows Client Side Caching Driver
fffff880`04683000 fffff880`04694000 blbdrive (deferred)
Mapped memory image file: c:\windows\system32\drivers\blbdrive.sys
Image path: \SystemRoot\system32\DRIVERS\blbdrive.sys
Image name: blbdrive.sys
Timestamp: Tue Jul 14 01:35:59 2009 (4A5BC4DF)
CheckSum: 00019567
ImageSize: 00011000
InternalName: blbdrive.sys
OriginalFilename: blbdrive.sys
FileDescription: BLB Drive Driver
fffff880`046a0000 fffff880`046e5000 netbt (deferred)
Mapped memory image file: c:\windows\system32\drivers\netbt.sys
Image path: \SystemRoot\System32\DRIVERS\netbt.sys
Image name: netbt.sys
Timestamp: Sat Nov 20 10:23:18 2010 (4CE79386)
CheckSum: 00041134
ImageSize: 00045000
InternalName: netbt.sys
OriginalFilename: netbt.sys
FileDescription: MBT Transport driver
fffff880`046e5000 fffff880`046ee000 wfplwf (deferred)
Mapped memory image file: c:\windows\system32\drivers\wfplwf.sys
Image path: \SystemRoot\system32\DRIVERS\wfplwf.sys
Image name: wfplwf.sys
Timestamp: Tue Jul 14 02:09:26 2009 (4A5BCCB6)
CheckSum: 0000B17B
ImageSize: 00009000
InternalName: WFPLWF.SYS
OriginalFilename: WFPLWF.SYS
FileDescription: WFP NDIS 6.20 Lightweight Filter Driver
fffff880`046ee000 fffff880`04714000 pacer (deferred)
Mapped memory image file: c:\windows\system32\drivers\pacer.sys
Image path: \SystemRoot\system32\DRIVERS\pacer.sys
Image name: pacer.sys
Timestamp: Sat Nov 20 11:52:18 2010 (4CE7A862)
CheckSum: 00020DCF
ImageSize: 00026000
InternalName: pacer.sys
OriginalFilename: pacer.sys
FileDescription: QoS Packet Scheduler
fffff880`04714000 fffff880`04723000 netbios (deferred)
Mapped memory image file: c:\windows\system32\drivers\netbios.sys
Image path: \SystemRoot\system32\DRIVERS\netbios.sys
Image name: netbios.sys
CheckSum: 00011668
ImageSize: 0000F000
InternalName: NETBIOS.SYS
OriginalFilename: NETBIOS.SYS
FileDescription: NetBIOS interface driver
fffff880`04723000 fffff880`04740000 serial (deferred)
Mapped memory image file: c:\windows\system32\drivers\serial.sys
Image path: \SystemRoot\system32\DRIVERS\serial.sys
Image name: serial.sys
Timestamp: Tue Jul 14 02:00:40 2009 (4A5BCAA8)
CheckSum: 0001D422
ImageSize: 0001D000
InternalName: serial.sys
OriginalFilename: serial.sys
FileDescription: Serial Device Driver
fffff880`04740000 fffff880`0475b000 wanarp (deferred)
Mapped memory image file: c:\windows\system32\drivers\wanarp.sys
Image path: \SystemRoot\system32\DRIVERS\wanarp.sys
Image name: wanarp.sys
Timestamp: Sat Nov 20 11:52:36 2010 (4CE7A874)
CheckSum: 00017CCC
ImageSize: 0001B000
InternalName: WANARP.SYS
OriginalFilename: WANARP.SYS
FileDescription: MS Remote Access and Routing ARP Driver
fffff880`0475b000 fffff880`0476f000 termdd (deferred)
Mapped memory image file: c:\windows\system32\drivers\termdd.sys
Image path: \SystemRoot\system32\drivers\termdd.sys
Image name: termdd.sys
Timestamp: Sat Nov 20 12:03:40 2010 (4CE7AB0C)
CheckSum: 00019E15
ImageSize: 00014000
InternalName: termdd.sys
OriginalFilename: termdd.sys
FileDescription: Remote Desktop Server Driver
fffff880`0476f000 fffff880`047c0000 rdbss (deferred)
Mapped memory image file: c:\windows\system32\drivers\rdbss.sys
Image path: \SystemRoot\system32\DRIVERS\rdbss.sys
Image name: rdbss.sys
Timestamp: Sat Nov 20 10:27:51 2010 (4CE79497)
CheckSum: 0004D76F
ImageSize: 00051000
InternalName: rdbss.sys
OriginalFilename: RDBSS.Sys
FileDescription: Redirected Drive Buffering SubSystem Driver
fffff880`047c0000 fffff880`047cc000 nsiproxy (deferred)
Mapped memory image file: c:\windows\system32\drivers\nsiproxy.sys
Image path: \SystemRoot\system32\drivers\nsiproxy.sys
Image name: nsiproxy.sys
Timestamp: Tue Jul 14 01:21:02 2009 (4A5BC15E)
CheckSum: 00013ED5
ImageSize: 0000C000
InternalName: nsiproxy.sys
OriginalFilename: nsiproxy.sys
FileDescription: NSI Proxy
fffff880`047cc000 fffff880`047d7000 mssmbios (deferred)
Mapped memory image file: c:\windows\system32\drivers\mssmbios.sys
Image path: \SystemRoot\system32\drivers\mssmbios.sys
Image name: mssmbios.sys
Timestamp: Tue Jul 14 01:31:10 2009 (4A5BC3BE)
CheckSum: 0000F474
ImageSize: 0000B000
InternalName: smbios.sys
OriginalFilename: smbios.sys
FileDescription: System Management BIOS Driver
fffff880`047d7000 fffff880`047e6000 discache (deferred)
Mapped memory image file: c:\windows\system32\drivers\discache.sys
Image path: \SystemRoot\System32\drivers\discache.sys
Image name: discache.sys
Timestamp: Tue Jul 14 01:37:18 2009 (4A5BC52E)
CheckSum: 00015F3F
ImageSize: 0000F000
File type: 2.0 Dll
InternalName: syscache.sys
OriginalFilename: syscache.sys
FileDescription: System Indexer/Cache Driver
fffff880`047e6000 fffff880`04800000 rassstp (deferred)
Mapped memory image file: c:\windows\system32\drivers\rassstp.sys
Image path: \SystemRoot\system32\DRIVERS\rassstp.sys
Image name: rassstp.sys
Timestamp: Tue Jul 14 02:10:25 2009 (4A5BCCF1)
CheckSum: 0002274B
ImageSize: 0001A000
InternalName: rassstp.sys
OriginalFilename: rassstp.sys
FileDescription: RAS SSTP Miniport Call Manager
fffff880`04800000 fffff880`04863000 asmtxhci (deferred)
Mapped memory image file: c:\windows\system32\drivers\asmtxhci.sys
Image path: \SystemRoot\system32\DRIVERS\asmtxhci.sys
Image name: asmtxhci.sys
Timestamp: Fri Mar 04 08:54:59 2011 (4D709AD3)
CheckSum: 0006C1A9
ImageSize: 00063000
File version: 1.10.1.0
Product version: 1.10.1.0
CompanyName: ASMedia Technology Inc
InternalName: asmtxhci.sys
FileVersion: V1.10.1
FileDescription: ASMEDIA XHCI Host Controller Driver
fffff880`04863000 fffff880`04873000 CompositeBus (deferred)
Mapped memory image file: c:\windows\system32\drivers\CompositeBus.sys
Image path: \SystemRoot\system32\drivers\CompositeBus.sys
Image name: CompositeBus.sys
Timestamp: Sat Nov 20 11:33:17 2010 (4CE7A3ED)
CheckSum: 0000983B
ImageSize: 00010000
File type: 2.0 Dll
InternalName: compositebus.sys
OriginalFilename: compositebus.sys
FileDescription: Multi-Transport Composite Bus Enumerator
fffff880`04873000 fffff880`04889000 AgileVpn (deferred)
Mapped memory image file: c:\windows\system32\drivers\agilevpn.sys
Image path: \SystemRoot\system32\DRIVERS\AgileVpn.sys
Image name: AgileVpn.sys
Timestamp: Tue Jul 14 02:10:24 2009 (4A5BCCF0)
CheckSum: 000192BE
ImageSize: 00016000
InternalName: agilevpn.sys
OriginalFilename: agilevpn.sys
FileDescription: RAS Agile Vpn Miniport Call Manager
fffff880`04889000 fffff880`048ad000 rasl2tp (deferred)
Mapped memory image file: c:\windows\system32\drivers\rasl2tp.sys
Image path: \SystemRoot\system32\DRIVERS\rasl2tp.sys
Image name: rasl2tp.sys
Timestamp: Sat Nov 20 11:52:34 2010 (4CE7A872)
CheckSum: 0002CCA3
ImageSize: 00024000
InternalName: rasl2tp.sys
OriginalFilename: rasl2tp.sys
FileDescription: RAS L2TP mini-port/call-manager driver
fffff880`048ad000 fffff880`048bc000 kbdclass (deferred)
Mapped memory image file: c:\windows\system32\drivers\kbdclass.sys
Image path: \SystemRoot\system32\DRIVERS\kbdclass.sys
Image name: kbdclass.sys
CheckSum: 0001B4C5
ImageSize: 0000F000
InternalName: kbdclass.sys
OriginalFilename: kbdclass.sys
FileDescription: Keyboard Class Driver
fffff880`048be000 fffff880`0491b000 aswSP (deferred)
Mapped memory image file: c:\windows\system32\drivers\aswSP.sys
Image path: \SystemRoot\System32\Drivers\aswSP.SYS
Image name: aswSP.SYS
Timestamp: Tue Aug 21 11:05:54 2012 (50334F72)
CheckSum: 00060B45
ImageSize: 0005D000
InternalName: aswSP.sys
OriginalFilename: aswSP.sys
FileDescription: avast! self protection module
fffff880`0491b000 fffff880`04922000 AsrAppCharger (deferred)
Mapped memory image file: c:\windows\system32\drivers\AsrAppCharger.sys
Image path: \SystemRoot\system32\DRIVERS\AsrAppCharger.sys
Image name: AsrAppCharger.sys
Timestamp: Tue May 10 10:28:46 2011 (4DC8F73E)
CheckSum: 0000BF68
ImageSize: 00007000
CompanyName: Windows (R) Win 7 DDK provider
ProductName: Windows (R) Win 7 DDK driver
InternalName: AsrAppCharger.sys
OriginalFilename: AsrAppCharger.sys
FileVersion: 6.1.7600.16385 built by: WinDDK
FileDescription: ASRock App Charger Driver
LegalCopyright: ASRock Inc.
fffff880`04922000 fffff880`04948000 tunnel (deferred)
Mapped memory image file: c:\windows\system32\drivers\tunnel.sys
Image path: \SystemRoot\system32\DRIVERS\tunnel.sys
Image name: tunnel.sys
Timestamp: Sat Nov 20 11:51:50 2010 (4CE7A846)
CheckSum: 0002CD96
ImageSize: 00026000
InternalName: tunnel.sys
OriginalFilename: tunnel.sys
FileDescription: Microsoft Tunnel Interface Driver
fffff880`04948000 fffff880`0498e000 dxgmms1 (deferred)
Mapped memory image file: c:\windows\system32\drivers\dxgmms1.sys
Image path: \SystemRoot\System32\drivers\dxgmms1.sys
Image name: dxgmms1.sys
Timestamp: Sat Nov 20 10:49:53 2010 (4CE799C1)
CheckSum: 00047A89
ImageSize: 00046000
InternalName: dxgmms1.sys
OriginalFilename: dxgmms1.sys
FileDescription: DirectX Graphics MMS
fffff880`0498e000 fffff880`049b2000 HDAudBus (deferred)
Mapped memory image file: c:\windows\system32\drivers\hdaudbus.sys
Image path: \SystemRoot\system32\DRIVERS\HDAudBus.sys
Image name: HDAudBus.sys
Timestamp: Sat Nov 20 11:43:42 2010 (4CE7A65E)
CheckSum: 0002BFAB
ImageSize: 00024000
File type: 3.9 Driver
InternalName: hdaudbus.sys
OriginalFilename: hdaudbus.sys
FileDescription: High Definition Audio Bus Driver
fffff880`049b2000 fffff880`049e1000 ndiswan (deferred)
Mapped memory image file: c:\windows\system32\drivers\ndiswan.sys
Image path: \SystemRoot\system32\DRIVERS\ndiswan.sys
Image name: ndiswan.sys
Timestamp: Sat Nov 20 11:52:32 2010 (4CE7A870)
CheckSum: 0002BB81
ImageSize: 0002F000
InternalName: NDISWAN.SYS
OriginalFilename: NDISWAN.SYS
FileDescription: MS PPP Framing Driver (Strong Encryption)
fffff880`049e1000 fffff880`049fc000 raspppoe (deferred)
Mapped memory image file: c:\windows\system32\drivers\raspppoe.sys
Image path: \SystemRoot\system32\DRIVERS\raspppoe.sys
Image name: raspppoe.sys
Timestamp: Tue Jul 14 02:10:17 2009 (4A5BCCE9)
CheckSum: 00019A00
ImageSize: 0001B000
InternalName: raspppoe.sys
OriginalFilename: raspppoe.sys
FileDescription: RAS PPPoE mini-port/call-manager driver
fffff880`04c00000 fffff880`04c05200 ksthunk (deferred)
Mapped memory image file: c:\windows\system32\drivers\ksthunk.sys
Image path: \SystemRoot\system32\drivers\ksthunk.sys
Image name: ksthunk.sys
Timestamp: Tue Jul 14 02:00:19 2009 (4A5BCA93)
CheckSum: 0000AF92
ImageSize: 00005200
InternalName: ksthunk.sys
OriginalFilename: ksthunk.sys
FileDescription: Kernel Streaming WOW Thunk Service
fffff880`04c16000 fffff880`04c59000 ks (deferred)
Mapped memory image file: c:\windows\system32\drivers\ks.sys
Image path: \SystemRoot\system32\drivers\ks.sys
Image name: ks.sys
Timestamp: Sat Nov 20 11:33:23 2010 (4CE7A3F3)
CheckSum: 00045588
ImageSize: 00043000
InternalName: ks.sys
OriginalFilename: ks.sys
FileDescription: Kernel CSA Library
fffff880`04c59000 fffff880`04c6b000 umbus (deferred)
Mapped memory image file: c:\windows\system32\drivers\umbus.sys
Image path: \SystemRoot\system32\DRIVERS\umbus.sys
Image name: umbus.sys
Timestamp: Sat Nov 20 11:44:37 2010 (4CE7A695)
CheckSum: 0001AF58
ImageSize: 00012000
File type: 2.0 Dll
InternalName: umbus.sys
OriginalFilename: umbus.sys
FileDescription: User-Mode Bus Enumerator
fffff880`04c6b000 fffff880`04cc5000 usbhub (deferred)
Mapped memory image file: c:\windows\system32\drivers\usbhub.sys
Image path: \SystemRoot\system32\DRIVERS\usbhub.sys
Image name: usbhub.sys
Timestamp: Fri Mar 25 04:29:25 2011 (4D8C0C15)
CheckSum: 00054F31
ImageSize: 0005A000
File version: 6.1.7601.17586
Product version: 6.1.7601.17586
File type: 2.0 Dll
InternalName: usbhub.sys
OriginalFilename: usbhub.sys
ProductVersion: 6.1.7601.17586
FileVersion: 6.1.7601.17586 (win7sp1_gdr.110324-1501)
FileDescription: Default Hub Driver for USB
fffff880`04cc5000 fffff880`04cfb000 fastfat (deferred)
Mapped memory image file: c:\windows\system32\drivers\fastfat.sys
Image path: \SystemRoot\System32\Drivers\fastfat.SYS
Image name: fastfat.SYS
Timestamp: Tue Jul 14 01:23:28 2009 (4A5BC1F0)
CheckSum: 0003AE1E
ImageSize: 00036000
InternalName: fastfat.sys
OriginalFilename: FastFAT.Sys
FileDescription: Fast FAT File System Driver
fffff880`04cfb000 fffff880`04d10000 NDProxy (deferred)
Mapped memory image file: c:\windows\system32\drivers\ndproxy.sys
Image path: \SystemRoot\System32\Drivers\NDProxy.SYS
Image name: NDProxy.SYS
Timestamp: Sat Nov 20 11:52:20 2010 (4CE7A864)
CheckSum: 00019428
ImageSize: 00015000
InternalName: ndproxy.sys
OriginalFilename: ndproxy.sys
FileDescription: NDIS Proxy
fffff880`04d10000 fffff880`04d6d000 iusb3hub (deferred)
Mapped memory image file: c:\windows\system32\drivers\iusb3hub.sys
Image path: \SystemRoot\system32\DRIVERS\iusb3hub.sys
Image name: iusb3hub.sys
Timestamp: Fri Jan 27 10:35:25 2012 (4F226FDD)
CheckSum: 0006032D
ImageSize: 0005D000
File type: 2.0 Dll
ProductName: USB 3.0 Device Driver
InternalName: IUSB3HUB.SYS
OriginalFilename: IUSB3HUB.SYS
FileVersion: 1.0.3.214 (iusb3drv.20120127-0133)
FileDescription: Intel(R) USB 3.0 Hub Driver
LegalCopyright: (C) 2010-2012 Intel Corporation
fffff880`04d6d000 fffff880`04d9f000 nvhda64v (deferred)
Mapped memory image file: c:\windows\system32\drivers\nvhda64v.sys
Image path: \SystemRoot\system32\drivers\nvhda64v.sys
Image name: nvhda64v.sys
Timestamp: Tue Jul 03 17:25:04 2012 (4FF30ED0)
CheckSum: 00035E14
ImageSize: 00032000
File version: 1.3.18.0
Product version: 1.3.18.0
CompanyName: NVIDIA Corporation
ProductName: NVIDIA HDMI Audio Driver
InternalName: nvhda.sys
OriginalFilename: nvhda.sys
ProductVersion: 1.3.18.0
FileVersion: 1.3.18.0 built by: WinDDK
FileDescription: NVIDIA HDMI Audio Driver
LegalCopyright: (C) NVIDIA Corporation. All rights reserved.
fffff880`04d9f000 fffff880`04ddc000 portcls (deferred)
Mapped memory image file: c:\windows\system32\drivers\portcls.sys
Image path: \SystemRoot\system32\drivers\portcls.sys
Image name: portcls.sys
Timestamp: Tue Jul 14 02:06:27 2009 (4A5BCC03)
CheckSum: 00047A50
ImageSize: 0003D000
InternalName: portcls.sys
OriginalFilename: portcls.sys
FileDescription: Port Class (Class Driver for Port/Miniport Devices)
fffff880`04ddc000 fffff880`04dfe000 drmk (deferred)
Mapped memory image file: c:\windows\system32\drivers\drmk.sys
Image path: \SystemRoot\system32\drivers\drmk.sys
Image name: drmk.sys
Timestamp: Tue Jul 14 03:01:25 2009 (4A5BD8E5)
CheckSum: 0002966E
ImageSize: 00022000
File type: 2.0 Dll
InternalName: drmk.sys
OriginalFilename: drmk.sys
FileDescription: Microsoft Trusted Audio Drivers
fffff880`0562c000 fffff880`056f5000 HTTP (deferred)
Mapped memory image file: c:\windows\system32\drivers\http.sys
Image path: \SystemRoot\system32\drivers\HTTP.sys
Image name: HTTP.sys
Timestamp: Sat Nov 20 10:24:30 2010 (4CE793CE)
CheckSum: 000C56EE
ImageSize: 000C9000
InternalName: http.sys
OriginalFilename: http.sys
FileDescription: HTTP Protocol Stack
fffff880`056f5000 fffff880`05713000 bowser (deferred)
Mapped memory image file: c:\windows\system32\drivers\bowser.sys
Image path: \SystemRoot\system32\DRIVERS\bowser.sys
Image name: bowser.sys
Timestamp: Wed Feb 23 05:55:04 2011 (4D649328)
CheckSum: 00022D38
ImageSize: 0001E000
File version: 6.1.7601.17565
Product version: 6.1.7601.17565
InternalName: browser.sys
OriginalFilename: browser.sys
ProductVersion: 6.1.7601.17565
FileVersion: 6.1.7601.17565 (win7sp1_gdr.110222-1630)
FileDescription: NT Lan Manager Datagram Receiver Driver
fffff880`05713000 fffff880`0572b000 mpsdrv (deferred)
Mapped memory image file: c:\windows\system32\drivers\mpsdrv.sys
Image path: \SystemRoot\System32\drivers\mpsdrv.sys
Image name: mpsdrv.sys
Timestamp: Tue Jul 14 02:08:25 2009 (4A5BCC79)
CheckSum: 0001C76E
ImageSize: 00018000
InternalName: mpsdrv.sys
OriginalFilename: mpsdrv.sys
FileDescription: Microsoft Protection Service Driver
fffff880`0572b000 fffff880`05758000 mrxsmb (deferred)
Mapped memory image file: c:\windows\system32\drivers\mrxsmb.sys
Image path: \SystemRoot\system32\DRIVERS\mrxsmb.sys
Image name: mrxsmb.sys
Timestamp: Wed Apr 27 04:40:38 2011 (4DB78226)
CheckSum: 00030225
ImageSize: 0002D000
File version: 6.1.7601.17605
Product version: 6.1.7601.17605
InternalName: MRxSmb.sys
OriginalFilename: MRXSMB.Sys
ProductVersion: 6.1.7601.17605
FileVersion: 6.1.7601.17605 (win7sp1_gdr.110426-1503)
FileDescription: Windows NT SMB Minirdr
fffff880`05758000 fffff880`057a6000 mrxsmb10 (deferred)
Mapped memory image file: c:\windows\system32\drivers\mrxsmb10.sys
Image path: \SystemRoot\system32\DRIVERS\mrxsmb10.sys
Image name: mrxsmb10.sys
Timestamp: Sat Jul 09 04:46:28 2011 (4E17C104)
CheckSum: 000503C4
ImageSize: 0004E000
File version: 6.1.7601.17647
Product version: 6.1.7601.17647
InternalName: MRxSmb0.sys
OriginalFilename: MRXSMB0.Sys
ProductVersion: 6.1.7601.17647
FileVersion: 6.1.7601.17647 (win7sp1_gdr.110708-1503)
FileDescription: Longhorn SMB Downlevel SubRdr
fffff880`057a6000 fffff880`057ca000 mrxsmb20 (deferred)
Mapped memory image file: c:\windows\system32\drivers\mrxsmb20.sys
Image path: \SystemRoot\system32\DRIVERS\mrxsmb20.sys
Image name: mrxsmb20.sys
Timestamp: Wed Apr 27 04:39:37 2011 (4DB781E9)
CheckSum: 0002D8BD
ImageSize: 00024000
InternalName: MRxSmb20.sys
OriginalFilename: MRXSMB20.Sys
FileDescription: Longhorn SMB 2.0 Redirector
fffff880`05a00000 fffff880`05a1d000 usbccgp (deferred)
Mapped memory image file: c:\windows\system32\drivers\usbccgp.sys
Image path: \SystemRoot\system32\DRIVERS\usbccgp.sys
Image name: usbccgp.sys
Timestamp: Fri Mar 25 04:29:14 2011 (4D8C0C0A)
CheckSum: 0001B399
ImageSize: 0001D000
File type: 2.0 Dll
InternalName: USBCCGP.SYS
OriginalFilename: USBCCGP.SYS
FileDescription: USB Common Class Generic Parent Driver
fffff880`05a1d000 fffff880`05a37c80 usbaudio (deferred)
Mapped memory image file: c:\windows\system32\drivers\USBAUDIO.sys
Image path: \SystemRoot\system32\drivers\usbaudio.sys
Image name: usbaudio.sys
Timestamp: Sat Nov 20 11:43:52 2010 (4CE7A668)
CheckSum: 000205AA
ImageSize: 0001AC80
File type: 2.0 Dll
InternalName: USBAudio.sys
OriginalFilename: USBAudio.sys
FileDescription: USB Audio Class Driver
fffff880`05a38000 fffff880`05a8ba80 lvrs64 (deferred)
Mapped memory image file: c:\windows\system32\drivers\lvrs64.sys
Image path: \SystemRoot\system32\DRIVERS\lvrs64.sys
Image name: lvrs64.sys
Timestamp: Wed Jan 18 07:40:36 2012 (4F166964)
CheckSum: 00061E9E
ImageSize: 00053A80
File version: 13.31.1044.0
Product version: 13.31.1044.0
File flags: 0 (Mask 30003F)
File type: 2.0 Dll
Translations: 0409.04e4
CompanyName: Logitech Inc.
ProductName: Logitech Webcam Software
InternalName: LVRS.sys
OriginalFilename: LVRS.sys
ProductVersion: 13.31.1044.0
FileVersion: 13.31.1044.0
FileDescription: Logitech Kernel Audio Improvement Filter Driver
LegalCopyright: (c) 1996-2012 Logitech. All rights reserved.
fffff880`05a8c000 fffff880`05aa1000 lltdio (deferred)
Mapped memory image file: c:\windows\system32\drivers\lltdio.sys
Image path: \SystemRoot\system32\DRIVERS\lltdio.sys
Image name: lltdio.sys
Timestamp: Tue Jul 14 02:08:50 2009 (4A5BCC92)
CheckSum: 0001109D
ImageSize: 00015000
InternalName: LLTDIO.SYS
OriginalFilename: LLTDIO.SYS
FileDescription: Link-Layer Topology Mapper I/O Driver
fffff880`05aa1000 fffff880`05ab9000 rspndr (deferred)
Mapped memory image file: c:\windows\system32\drivers\rspndr.sys
Image path: \SystemRoot\system32\DRIVERS\rspndr.sys
Image name: rspndr.sys
CheckSum: 0001656B
ImageSize: 00018000
InternalName: RSPNDR.SYS
OriginalFilename: RSPNDR.SYS
FileDescription: Link-Layer Topology Responder Driver for NDIS 6
fffff880`05ad8000 fffff880`05f5b680 RTKVHD64 (deferred)
Mapped memory image file: c:\windows\system32\drivers\RTKVHD64.sys
Image path: \SystemRoot\system32\drivers\RTKVHD64.sys
Image name: RTKVHD64.sys
Timestamp: Tue Jan 31 11:55:06 2012 (4F27C88A)
CheckSum: 00490DF5
ImageSize: 00483680
File version: 6.0.1.6559
Product version: 6.0.1.6559
CompanyName: Realtek Semiconductor Corp.
ProductName: Realtek(r) High Definition Audio Function Driver
InternalName: RTKVHD64.sys 6559
OriginalFilename: RtkHDAud.sys
ProductVersion: 6.0.1.6559
FileVersion: 6.0.1.6559 built by: WinDDK
FileDescription: Realtek(r) High Definition Audio Function Driver
LegalCopyright: Copyright (c) Realtek Semiconductor Corp.1998-2012
fffff880`05f5c000 fffff880`05f6a000 MBfilt64 (deferred)
Mapped memory image file: c:\windows\system32\drivers\MBfilt64.sys
Image path: \SystemRoot\system32\drivers\MBfilt64.sys
Image name: MBfilt64.sys
Timestamp: Fri Jul 31 05:40:32 2009 (4A7267B0)
CheckSum: 0000FF02
ImageSize: 0000E000
File version: 6.10.0.8
Product version: 6.10.0.8
File type: 2.0 Dll
Translations: 0809.04b0
CompanyName: Creative Technology Ltd.
FileVersion: 6.10.00.0008
FileDescription: Creative Audio Driver
LegalCopyright: Copyright © Creative Technology Ltd. 2009
fffff880`05f6a000 fffff880`05fc6000 HdAudio (deferred)
Mapped memory image file: c:\windows\system32\drivers\HdAudio.sys
Image path: \SystemRoot\system32\drivers\HdAudio.sys
Image name: HdAudio.sys
Timestamp: Sat Nov 20 11:44:23 2010 (4CE7A687)
CheckSum: 000598DA
ImageSize: 0005C000
InternalName: HDAudio.sys
OriginalFilename: HDAudio.sys
FileDescription: High Definition Audio Function Driver
fffff880`05fc6000 fffff880`05fe9000 asmthub3 (deferred)
Mapped memory image file: c:\windows\system32\drivers\asmthub3.sys
Image path: \SystemRoot\system32\DRIVERS\asmthub3.sys
Image name: asmthub3.sys
Timestamp: Fri Mar 04 08:55:10 2011 (4D709ADE)
CheckSum: 00022F2C
ImageSize: 00023000
InternalName: asmthub3.sys
FileDescription: ASMedia USB3 Hub Driver
fffff880`05fe9000 fffff880`05ff5000 Dxapi (deferred)
Mapped memory image file: c:\windows\system32\drivers\dxapi.sys
Image path: \SystemRoot\System32\drivers\Dxapi.sys
Image name: Dxapi.sys
Timestamp: Tue Jul 14 01:38:28 2009 (4A5BC574)
CheckSum: 0001418E
ImageSize: 0000C000
InternalName: dxapi.sys
OriginalFilename: dxapi.sys
FileDescription: DirectX API Driver
fffff880`05ff5000 fffff880`05ff9300 lvbflt64 (deferred)
Mapped memory image file: c:\windows\system32\drivers\lvbflt64.sys
Image path: \SystemRoot\system32\DRIVERS\lvbflt64.sys
Image name: lvbflt64.sys
Timestamp: Wed Jan 18 07:39:53 2012 (4F166939)
CheckSum: 00008028
ImageSize: 00004300
File type: 2.0 Dll
InternalName: lvbusflt.sys
OriginalFilename: lvbusflt.sys
FileDescription: Logitech USB Video Class Filter Driver
fffff880`06000000 fffff880`0600c000 imsevent (deferred)
Mapped memory image file: c:\windows\system32\drivers\imsevent.sys
Image path: \SystemRoot\system32\DRIVERS\imsevent.sys
Image name: imsevent.sys
Timestamp: Wed Jan 04 01:35:31 2012 (4F039ED3)
CheckSum: 0001060D
ImageSize: 0000C000
File version: 1.0.2.0
Product version: 1.0.2.0
File flags: 0 (Mask 17)
ProductName: Intel Mouse Class Upper Filter Driver
InternalName: Intel Mouse Class Upper Filter Driver
OriginalFilename: imsevent.sys
ProductVersion: 1, 0, 2, 0
FileVersion: 1, 0, 2, 0
FileDescription: Intel Mouse Class Upper Filter Driver
LegalCopyright: Copyright (C) 2011
fffff880`0600c000 fffff880`0601a000 kbdhid (deferred)
Mapped memory image file: c:\windows\system32\drivers\kbdhid.sys
Image path: \SystemRoot\system32\DRIVERS\kbdhid.sys
Image name: kbdhid.sys
Timestamp: Sat Nov 20 11:33:25 2010 (4CE7A3F5)
CheckSum: 0000D561
ImageSize: 0000E000
File type: 2.0 Dll
InternalName: kbdhid.sys
OriginalFilename: kbdhid.sys
FileDescription: HID Keyboard Filter Driver
fffff880`0601a000 fffff880`06026000 ikbevent (deferred)
Mapped memory image file: c:\windows\system32\drivers\ikbevent.sys
Image path: \SystemRoot\system32\DRIVERS\ikbevent.sys
Image name: ikbevent.sys
Timestamp: Wed Jan 04 01:35:09 2012 (4F039EBD)
CheckSum: 000134A4
ImageSize: 0000C000
ProductName: Intel Keyboard Class Upper Filter Driver
InternalName: Intel Keyboard Class Upper Filter Driver
OriginalFilename: ikbevent.sys
FileDescription: Intel Keyboard Class Upper Filter Driver
fffff880`06026000 fffff880`06034000 crashdmp (deferred)
Mapped memory image file: c:\windows\system32\drivers\crashdmp.sys
Image path: \SystemRoot\System32\Drivers\crashdmp.sys
Image name: crashdmp.sys
Timestamp: Tue Jul 14 02:01:01 2009 (4A5BCABD)
CheckSum: 000178C7
ImageSize: 0000E000
InternalName: crashdmp.sys
OriginalFilename: crashdmp.sys
FileDescription: Crash Dump Driver
fffff880`06034000 fffff880`06047000 dump_dumpfve (deferred)
Mapped memory image file: c:\windows\system32\drivers\dumpfve.sys
Image path: \SystemRoot\System32\Drivers\dump_dumpfve.sys
Image name: dump_dumpfve.sys
Timestamp: Tue Jul 14 01:21:51 2009 (4A5BC18F)
CheckSum: 00010DEA
ImageSize: 00013000
InternalName: dumpfve.sys
OriginalFilename: dumpfve.sys
FileDescription: Bitlocker Drive Encryption Crashdump Filter
fffff880`06047000 fffff880`0606a000 luafv (deferred)
Mapped memory image file: c:\windows\system32\drivers\luafv.sys
Image path: \SystemRoot\system32\drivers\luafv.sys
Image name: luafv.sys
Timestamp: Tue Jul 14 01:26:13 2009 (4A5BC295)
CheckSum: 00027BF1
ImageSize: 00023000
InternalName: luafv.sys
OriginalFilename: luafv.sys
FileDescription: LUA File Virtualization Filter Driver
fffff880`0606a000 fffff880`0608c000 aswMonFlt (deferred)
Mapped memory image file: c:\windows\system32\drivers\aswMonFlt.sys
Image path: \??\C:\Windows\system32\drivers\aswMonFlt.sys
Image name: aswMonFlt.sys
Timestamp: Tue Aug 21 11:05:00 2012 (50334F3C)
CheckSum: 00014F0D
ImageSize: 00022000
InternalName: aswMonFlt.sys
OriginalFilename: aswMonFlt.sys
FileDescription: avast! File System Minifilter for Windows 2003/Vista
fffff880`0608c000 fffff880`06095000 aswFsBlk (deferred)
Mapped memory image file: c:\windows\system32\drivers\aswFsBlk.sys
Image path: \SystemRoot\System32\Drivers\aswFsBlk.SYS
Image name: aswFsBlk.SYS
Timestamp: Tue Aug 21 11:04:55 2012 (50334F37)
CheckSum: 0000D607
ImageSize: 00009000
InternalName: aswFsBlk.sys
OriginalFilename: aswFsBlk.sys
FileDescription: avast! File System Access Blocking Driver
fffff880`06095000 fffff880`060b6000 WudfPf (deferred)
Mapped memory image file: c:\windows\system32\drivers\WUDFPf.sys
Image path: \SystemRoot\system32\drivers\WudfPf.sys
Image name: WudfPf.sys
Timestamp: Sat Nov 20 11:42:44 2010 (4CE7A624)
CheckSum: 00021FC8
ImageSize: 00021000
InternalName: WUDFPf.sys
OriginalFilename: WUDFPf.sys
FileDescription: Windows Driver Foundation - User-mode Driver Framework Platform Driver
fffff880`060c5000 fffff880`06566d00 lvuvc64 (deferred)
Mapped memory image file: c:\windows\system32\drivers\lvuvc64.sys
Image path: \SystemRoot\system32\DRIVERS\lvuvc64.sys
Image name: lvuvc64.sys
Timestamp: Wed Jan 18 07:41:08 2012 (4F166984)
CheckSum: 004B0494
ImageSize: 004A1D00
File type: 2.0 Dll
InternalName: lvuvc.sys
OriginalFilename: lvuvc.sys
FileDescription: Logitech USB Video Class Driver
fffff880`06567000 fffff880`06584000 cdfs (deferred)
Mapped memory image file: c:\windows\system32\drivers\cdfs.sys
Image path: \SystemRoot\system32\DRIVERS\cdfs.sys
Image name: cdfs.sys
Timestamp: Tue Jul 14 01:19:46 2009 (4A5BC112)
CheckSum: 00022C4F
ImageSize: 0001D000
InternalName: cdfs.sys
OriginalFilename: cdfs.sys
FileDescription: CD-ROM File System Driver
fffff880`06584000 fffff880`06592000 monitor (deferred)
Mapped memory image file: c:\windows\system32\drivers\monitor.sys
Image path: \SystemRoot\system32\DRIVERS\monitor.sys
Image name: monitor.sys
Timestamp: Tue Jul 14 01:38:52 2009 (4A5BC58C)
CheckSum: 000092BF
ImageSize: 0000E000
InternalName: monitor.sys
OriginalFilename: monitor.sys
FileDescription: Monitor Driver
fffff880`06592000 fffff880`065a0000 hidusb (deferred)
Mapped memory image file: c:\windows\system32\drivers\hidusb.sys
Image path: \SystemRoot\system32\DRIVERS\hidusb.sys
Image name: hidusb.sys
Timestamp: Sat Nov 20 11:43:49 2010 (4CE7A665)
CheckSum: 00012706
ImageSize: 0000E000
File type: 2.0 Dll
InternalName: HIDUSB.SYS
OriginalFilename: HIDUSB.SYS
FileDescription: USB Miniport Driver for Input Devices
fffff880`065a0000 fffff880`065b9000 HIDCLASS (deferred)
Mapped memory image file: c:\windows\system32\drivers\hidclass.sys
Image path: \SystemRoot\system32\DRIVERS\HIDCLASS.SYS
Image name: HIDCLASS.SYS
CheckSum: 00015D32
ImageSize: 00019000
File type: 2.0 Dll
InternalName: hidclass.sys
OriginalFilename: hidclass.sys
FileDescription: Hid Class Library
fffff880`065b9000 fffff880`065c1080 HIDPARSE (deferred)
Mapped memory image file: c:\windows\system32\drivers\hidparse.sys
Image path: \SystemRoot\system32\DRIVERS\HIDPARSE.SYS
Image name: HIDPARSE.SYS
Timestamp: Tue Jul 14 02:06:17 2009 (4A5BCBF9)
CheckSum: 0000D669
ImageSize: 00008080
File type: 2.0 Dll
InternalName: hidparse.sys
OriginalFilename: hidparse.sys
FileDescription: Hid Parsing Library
fffff880`065c2000 fffff880`065d8000 LHidFilt (deferred)
Mapped memory image file: c:\windows\system32\drivers\LHidFilt.Sys
Image path: \SystemRoot\system32\DRIVERS\LHidFilt.Sys
Image name: LHidFilt.Sys
Timestamp: Fri Sep 02 08:23:09 2011 (4E60764D)
CheckSum: 0001071C
ImageSize: 00016000
File version: 5.33.10.0
Product version: 5.33.10.0
File flags: 22 (Mask 3F) Pre-release Special
CompanyName: Logitech, Inc.
ProductName: Logitech SetPoint(TM)
InternalName: LHidFilt.Sys
OriginalFilename: LHidFilt.Sys
ProductVersion: 5.33.10.0
FileVersion: 5.33.10.0
FileDescription: Logitech HID Filter Driver.
LegalCopyright: © Logitech, Inc. 1987-2011. All rights reserved.
Comments: Logitech HID Filter Driver. Win2K/XP Client. (64-bit)
fffff880`065d8000 fffff880`065e5000 mouhid (deferred)
Mapped memory image file: c:\windows\system32\drivers\mouhid.sys
Image path: \SystemRoot\system32\DRIVERS\mouhid.sys
Image name: mouhid.sys
Timestamp: Tue Jul 14 02:00:20 2009 (4A5BCA94)
CheckSum: 00009604
ImageSize: 0000D000
File type: 2.0 Dll
InternalName: mouhid.sys
OriginalFilename: mouhid.sys
FileDescription: HID Mouse Filter Driver
fffff880`065e5000 fffff880`065f9000 LMouFilt (deferred)
Mapped memory image file: c:\windows\system32\drivers\LMouFilt.Sys
Image path: \SystemRoot\system32\DRIVERS\LMouFilt.Sys
Image name: LMouFilt.Sys
Timestamp: Fri Sep 02 08:23:15 2011 (4E607653)
CheckSum: 0001BEE5
ImageSize: 00014000
InternalName: LMouFilt.Sys
OriginalFilename: LMouFilt.Sys
FileDescription: Logitech Mouse Filter Driver.
Comments: Logitech Mouse Filter Driver. Win2K/XP Client. (64-bit)
fffff880`08a31000 fffff880`08ad7000 peauth (deferred)
Mapped memory image file: c:\windows\system32\drivers\PEAuth.sys
Image path: \SystemRoot\system32\drivers\peauth.sys
Image name: peauth.sys
Timestamp: Tue Jul 14 03:01:19 2009 (4A5BD8DF)
CheckSum: 000AB7C9
ImageSize: 000A6000
File flags: 0 (Mask 3F)
File OS: 40004 NT Win32
File date: 00000000.00000000
Translations: 0409.04b0
CompanyName: Microsoft Corporation
ProductName: Microsoft® Windows® Operating System
InternalName: PEAuth.sys
OriginalFilename: PEAuth.sys
FileDescription: Protected Environment Authentication and Authorization Export Driver
LegalCopyright: © Microsoft Corporation. All rights reserved.
fffff880`08ad7000 fffff880`08ae2000 secdrv (deferred)
Mapped memory image file: c:\windows\system32\drivers\secdrv.sys
Image path: \SystemRoot\System32\Drivers\secdrv.SYS
Image name: secdrv.SYS
Timestamp: Wed Sep 13 15:18:38 2006 (4508052E)
CheckSum: 00010B40
ImageSize: 0000B000
File version: 4.3.86.0
Product version: 4.3.86.0
CompanyName: Macrovision Corporation, Macrovision Europe Limited, and Macrovision Japan and Asia K.K.
ProductName: Macrovision SECURITY Driver
InternalName: SECDRV
OriginalFilename: SECDRV.SYS
ProductVersion: SECURITY Driver 4.03.086 2006/09/13
FileVersion: 4.03.086
FileDescription: Macrovision SECURITY Driver
LegalCopyright: © 2006 Macrovision Corporation
Comments: StringFileInfo: U.S. English
fffff880`08ae2000 fffff880`08b13000 srvnet (deferred)
Mapped memory image file: c:\windows\system32\drivers\srvnet.sys
Image path: \SystemRoot\System32\DRIVERS\srvnet.sys
Image name: srvnet.sys
Timestamp: Fri Apr 29 05:05:35 2011 (4DBA2AFF)
CheckSum: 0003409F
ImageSize: 00031000
File version: 6.1.7601.17608
Product version: 6.1.7601.17608
InternalName: SRVNET.SYS
OriginalFilename: SRVNET.SYS
ProductVersion: 6.1.7601.17608
FileVersion: 6.1.7601.17608 (win7sp1_gdr.110428-1525)
FileDescription: Server Network driver
fffff880`08b13000 fffff880`08b25000 tcpipreg (deferred)
Mapped memory image file: c:\windows\system32\drivers\tcpipreg.sys
Image path: \SystemRoot\System32\drivers\tcpipreg.sys
Image name: tcpipreg.sys
Timestamp: Sat Nov 20 11:51:48 2010 (4CE7A844)
CheckSum: 0000F328
ImageSize: 00012000
File version: 6.1.7601.17514
Product version: 6.1.7601.17514
File type: 1.0 App
InternalName: tcpipreg.sys
OriginalFilename: tcpipreg.sys
ProductVersion: 6.1.7601.17514
FileVersion: 6.1.7601.17514 (win7sp1_rtm.101119-1850)
FileDescription: TCP/IP Registry Compatibility Driver
fffff880`08b25000 fffff880`08b8e000 srv2 (deferred)
Mapped memory image file: c:\windows\system32\drivers\srv2.sys
Image path: \SystemRoot\System32\DRIVERS\srv2.sys
Image name: srv2.sys
Timestamp: Fri Apr 29 05:05:46 2011 (4DBA2B0A)
CheckSum: 0006CA1E
ImageSize: 00069000
InternalName: SRV2.SYS
OriginalFilename: SRV2.SYS
FileDescription: Smb 2.0 Server driver
fffff880`08e71000 fffff880`08e7c000 asyncmac (deferred)
Mapped memory image file: c:\windows\system32\drivers\asyncmac.sys
Image path: \SystemRoot\system32\DRIVERS\asyncmac.sys
Image name: asyncmac.sys
Timestamp: Tue Jul 14 02:10:13 2009 (4A5BCCE5)
CheckSum: 0000682A
ImageSize: 0000B000
File version: 6.1.7600.16385
Product version: 6.1.7600.16385
InternalName: ASYNCMAC.SYS
OriginalFilename: ASYNCMAC.SYS
ProductVersion: 6.1.7600.16385
FileVersion: 6.1.7600.16385 (win7_rtm.090713-1255)
FileDescription: MS Remote Access serial network driver
fffff880`08ef2000 fffff880`08f8a000 srv (deferred)
Mapped memory image file: c:\windows\system32\drivers\srv.sys
Image path: \SystemRoot\System32\DRIVERS\srv.sys
Image name: srv.sys
Timestamp: Fri Apr 29 05:06:06 2011 (4DBA2B1E)
CheckSum: 0007C839
ImageSize: 00098000
InternalName: SRV.SYS
OriginalFilename: SRV.SYS
FileDescription: Server driver
fffff880`08f8a000 fffff880`08f96000 WPRO_41_2001 (deferred)
Mapped memory image file: c:\windows\system32\drivers\WPRO_41_2001.sys
Image path: \SystemRoot\system32\drivers\WPRO_41_2001.sys
Image name: WPRO_41_2001.sys
Timestamp: Mon Nov 07 22:04:48 2011 (4EB847F0)
CheckSum: 00015ADC
ImageSize: 0000C000
Translations: 0000.04b0 0000.04e4 0409.04b0 0409.04e4
fffff880`08f9c000 fffff880`08f9da80 MSPQM (deferred)
Mapped memory image file: c:\windows\system32\drivers\mspqm.sys
Image path: \SystemRoot\system32\drivers\MSPQM.sys
Image name: MSPQM.sys
Timestamp: Tue Jul 14 02:00:17 2009 (4A5BCA91)
CheckSum: 0000CC3D
ImageSize: 00001A80
InternalName: mspqm.sys
OriginalFilename: mspqm.sys
FileDescription: MS Proxy Quality Manager
fffff880`08f9e000 fffff880`08f9fc00 MSPCLOCK (deferred)
Mapped memory image file: c:\windows\system32\drivers\mspclock.sys
Image path: \SystemRoot\system32\drivers\MSPCLOCK.sys
Image name: MSPCLOCK.sys
CheckSum: 0000AF33
ImageSize: 00001C00
InternalName: mspclock.sys
OriginalFilename: mspclock.sys
FileDescription: MS Proxy Clock
fffff880`0f400000 fffff880`0f40c000 ndistapi (deferred)
Mapped memory image file: c:\windows\system32\drivers\ndistapi.sys
Image path: \SystemRoot\system32\DRIVERS\ndistapi.sys
Image name: ndistapi.sys
Timestamp: Tue Jul 14 02:10:00 2009 (4A5BCCD8)
CheckSum: 000063EA
ImageSize: 0000C000
InternalName: NDISTAPI.SYS
OriginalFilename: NDISTAPI.SYS
FileDescription: NDIS 3.0 connection wrapper driver
fffff880`0f40d000 fffff880`10101000 nvlddmkm (deferred)
Mapped memory image file: c:\windows\system32\drivers\nvlddmkm.sys
Image path: \SystemRoot\system32\DRIVERS\nvlddmkm.sys
Image name: nvlddmkm.sys
Timestamp: Tue Oct 02 20:21:13 2012 (506B3099)
CheckSum: 00CD4613
ImageSize: 00CF4000
File version: 9.18.13.697
Product version: 9.18.13.697
ProductName: NVIDIA Windows Kernel Mode Driver, Version 306.97
InternalName: nvlddmkm.sys, NV_LDDM:8318, NV_LDDM_DDK_BUILD:120411
OriginalFilename: nvlddmkm.sys
ProductVersion: 9.18.13.0697
FileVersion: 9.18.13.0697
FileDescription: NVIDIA Windows Kernel Mode Driver, Version 306.97
LegalCopyright: (C) 2012 NVIDIA Corporation. All rights reserved.
fffff880`10101000 fffff880`101f5000 dxgkrnl (deferred)
Mapped memory image file: c:\windows\system32\drivers\dxgkrnl.sys
Image path: \SystemRoot\System32\drivers\dxgkrnl.sys
Image name: dxgkrnl.sys
Timestamp: Sat Nov 20 10:50:50 2010 (4CE799FA)
CheckSum: 000FA948
ImageSize: 000F4000
File type: 3.7 Driver
InternalName: dxgkrnl.sys
OriginalFilename: dxgkrnl.sys
FileDescription: DirectX Graphics Kernel
fffff880`101f5000 fffff880`10200000 rdpbus (deferred)
Mapped memory image file: c:\windows\system32\drivers\rdpbus.sys
Image path: \SystemRoot\system32\DRIVERS\rdpbus.sys
Image name: rdpbus.sys
Timestamp: Tue Jul 14 02:17:46 2009 (4A5BCEAA)
CheckSum: 0000C3AD
ImageSize: 0000B000
InternalName: RDPBUS.SYS
OriginalFilename: RDPBUS.SYS
FileDescription: Microsoft RDP Bus Device driver
fffff880`10200000 fffff880`1026a000 k57nd60a (deferred)
Mapped memory image file: c:\windows\system32\drivers\k57nd60a.sys
Image path: \SystemRoot\system32\DRIVERS\k57nd60a.sys
Image name: k57nd60a.sys
Timestamp: Tue May 10 06:42:30 2011 (4DC8C236)
CheckSum: 00076E0F
ImageSize: 0006A000
File version: 14.8.0.5
Product version: 14.8.0.5
File flags: 8 (Mask 3F) Private
CompanyName: Broadcom Corporation
ProductName: Broadcom NetLink (TM) Gigabit Ethernet Driver
InternalName: k57nd60a.sys (b57nd6x-rel_14.8-lhdepot1106.CL-143196)
OriginalFilename: k57nd60a.sys
ProductVersion: 14.8.0.5
FileVersion: 14.8.0.5 (cbuild.05092011-2141,b57nd6x-rel_14.8-lhdepot1106.CL-143196)
FileDescription: Broadcom NetLink (TM) Gigabit Ethernet NDIS6.x Unified Driver.
LegalCopyright: Copyright 2000-2011, Broadcom Corporation.
fffff880`1026a000 fffff880`10276000 serenum (deferred)
Mapped memory image file: c:\windows\system32\drivers\serenum.sys
Image path: \SystemRoot\system32\DRIVERS\serenum.sys
Image name: serenum.sys
Timestamp: Tue Jul 14 02:00:33 2009 (4A5BCAA1)
CheckSum: 00013C2F
ImageSize: 0000C000
File type: 2.0 Dll
InternalName: serenum.sys
OriginalFilename: serenum.sys
FileDescription: Serial Port Enumerator
fffff880`10276000 fffff880`1027f000 wmiacpi (deferred)
Mapped memory image file: c:\windows\system32\drivers\wmiacpi.sys
Image path: \SystemRoot\system32\drivers\wmiacpi.sys
Image name: wmiacpi.sys
Timestamp: Tue Jul 14 01:31:02 2009 (4A5BC3B6)
CheckSum: 000042C0
ImageSize: 00009000
InternalName: wmiacpi.sys
OriginalFilename: wmiacpi.sys
FileDescription: Windows Management Interface for ACPI
fffff880`1027f000 fffff880`1028f000 ISCTD64 (deferred)
Mapped memory image file: c:\windows\system32\drivers\ISCTD64.sys
Image path: \SystemRoot\system32\DRIVERS\ISCTD64.sys
Image name: ISCTD64.sys
Timestamp: Tue Aug 23 19:32:39 2011 (4E53E437)
CheckSum: 000109D7
ImageSize: 00010000
File version: 1.0.0.1002
Product version: 1.0.0.1002
ProductName: ISCT Driver
InternalName: ISCT and IFFS Driver
OriginalFilename: ISCTD.sys
ProductVersion: 1, 0, 0, 1002
FileVersion: 1, 0, 0, 1002
FileDescription: ISCT and IFFS Driver
fffff880`1028f000 fffff880`10290480 swenum (deferred)
Mapped memory image file: c:\windows\system32\drivers\swenum.sys
Image path: \SystemRoot\system32\drivers\swenum.sys
Image name: swenum.sys
Timestamp: Tue Jul 14 02:00:18 2009 (4A5BCA92)
CheckSum: 0000934E
ImageSize: 00001480
InternalName: swenum.sys
OriginalFilename: swenum.sys
FileDescription: Plug and Play Software Device Enumerator
fffff880`10294000 fffff880`110a4000 igdkmd64 (deferred)
Mapped memory image file: c:\windows\system32\drivers\igdkmd64.sys
Image path: \SystemRoot\system32\DRIVERS\igdkmd64.sys
Image name: igdkmd64.sys
Timestamp: Tue Mar 20 00:31:54 2012 (4F67C1EA)
CheckSum: 00E13247
ImageSize: 00E10000
File version: 8.15.10.2696
Product version: 8.15.10.2696
CompanyName: Intel Corporation
ProductName: Intel Graphics Accelerator Drivers for Windows 7(R)
InternalName: igdkmd64.sys
OriginalFilename: igdkmd64.sys
ProductVersion: 8.15.10.2696
FileVersion: 8.15.10.2696
FileDescription: Intel Graphics Kernel Mode Driver
LegalCopyright: Copyright (c) 1998-2006 Intel Corporation.
fffff880`110a4000 fffff880`11168000 iusb3xhc (deferred)
Mapped memory image file: c:\windows\system32\drivers\iusb3xhc.sys
Image path: \SystemRoot\system32\DRIVERS\iusb3xhc.sys
Image name: iusb3xhc.sys
Timestamp: Fri Jan 27 10:35:28 2012 (4F226FE0)
CheckSum: 000C193B
ImageSize: 000C4000
File version: 1.0.3.214
Product version: 1.0.3.214
File type: 2.0 Dll
InternalName: IUSB3XHC.SYS
OriginalFilename: IUSB3XHC.SYS
ProductVersion: 1.0.3.214
FileDescription: Intel(R) USB 3.0 eXtensible Host Controller Driver
fffff880`11168000 fffff880`11169f00 USBD (deferred)
Mapped memory image file: c:\windows\system32\drivers\usbd.sys
Image path: \SystemRoot\system32\DRIVERS\USBD.SYS
Image name: USBD.SYS
Timestamp: Fri Mar 25 04:28:59 2011 (4D8C0BFB)
CheckSum: 00005257
ImageSize: 00001F00
File type: 2.0 Dll
InternalName: usbd.sys
OriginalFilename: usbd.sys
FileDescription: Universal Serial Bus Driver
fffff880`1116a000 fffff880`1117b000 HECIx64 (deferred)
Mapped memory image file: c:\windows\system32\drivers\HECIx64.sys
Image path: \SystemRoot\system32\DRIVERS\HECIx64.sys
Image name: HECIx64.sys
Timestamp: Thu Nov 10 01:52:25 2011 (4EBB2049)
CheckSum: 0001B4FE
ImageSize: 00011000
File version: 8.0.0.1262
Product version: 8.0.0.1262
ProductName: Intel(R) Management Engine Interface
InternalName: HECIx64.sys
OriginalFilename: HECIx64.sys
ProductVersion: 8.0.0.1262
FileVersion: 8.0.0.1262 built by: WinDDK
FileDescription: Intel(R) Management Engine Interface
LegalCopyright: Copyright © 2006-2011, Intel Corporation. All rights reserved.
fffff880`1117b000 fffff880`1118c000 usbehci (deferred)
Mapped memory image file: c:\windows\system32\drivers\usbehci.sys
Image path: \SystemRoot\system32\drivers\usbehci.sys
Image name: usbehci.sys
Timestamp: Fri Mar 25 04:29:04 2011 (4D8C0C00)
CheckSum: 0000DE59
ImageSize: 00011000
File type: 2.0 Dll
InternalName: USBEHCI.sys
OriginalFilename: USBEHCI.sys
FileDescription: EHCI eUSB Miniport Driver
fffff880`1118c000 fffff880`111e2000 USBPORT (deferred)
Mapped memory image file: c:\windows\system32\drivers\usbport.sys
Image path: \SystemRoot\system32\drivers\USBPORT.SYS
Image name: USBPORT.SYS
Timestamp: Fri Mar 25 04:29:12 2011 (4D8C0C08)
CheckSum: 00056970
ImageSize: 00056000
File type: 2.0 Dll
InternalName: usbport.sys
OriginalFilename: usbport.sys
FileDescription: USB 1.1 & 2.0 Port Driver
fffff880`111e2000 fffff880`111f8000 intelppm (deferred)
Mapped memory image file: c:\windows\system32\drivers\intelppm.sys
Image path: \SystemRoot\system32\DRIVERS\intelppm.sys
Image name: intelppm.sys
Timestamp: Tue Jul 14 01:19:25 2009 (4A5BC0FD)
CheckSum: 0000F4EC
ImageSize: 00016000
InternalName: intelppm.sys
OriginalFilename: intelppm.sys
FileDescription: Processor Device Driver
fffff960`00030000 fffff960`00345000 win32k (deferred)
Mapped memory image file: c:\windows\system32\win32k.sys
Image path: \SystemRoot\System32\win32k.sys
Image name: win32k.sys
Timestamp: Wed Jul 18 20:14:37 2012 (5006FD0D)
CheckSum: 00306830
ImageSize: 00315000
File version: 6.1.7601.17904
Product version: 6.1.7601.17904
InternalName: win32k.sys
OriginalFilename: win32k.sys
ProductVersion: 6.1.7601.17904
FileVersion: 6.1.7601.17904 (win7sp1_gdr.120718-0607)
FileDescription: Multi-User Win32 Driver
fffff960`004b0000 fffff960`004ba000 TSDDD (deferred)
Mapped memory image file: c:\windows\system32\TSDDD.dll
Image path: \SystemRoot\System32\TSDDD.dll
Image name: TSDDD.dll
CheckSum: 00009E96
ImageSize: 0000A000
InternalName: framebuf.dll
OriginalFilename: framebuf.dll
FileDescription: Framebuffer Display Driver
fffff960`00760000 fffff960`00787000 cdd (deferred)
Mapped memory image file: c:\windows\system32\cdd.dll
Image path: \SystemRoot\System32\cdd.dll
Image name: cdd.dll
Timestamp: unavailable (00000000)
CheckSum: 00000000
ImageSize: 00027000
InternalName: cdd.dll
OriginalFilename: cdd.dll
FileDescription: Canonical Display Driver
Unloaded modules:
fffff880`08e85000 fffff880`08e8e000 cpuz135_x64.
Checksum: 00000000
ImageSize: 00009000
fffff880`08e7c000 fffff880`08e85000 cpuz135_x64.
Checksum: 00000000
ImageSize: 00009000
fffff880`08e00000 fffff880`08e71000 spsys.sys
Checksum: 00000000
ImageSize: 00071000
fffff880`08f96000 fffff880`08f9c000 RTCore64.sys
Checksum: 00000000
ImageSize: 00006000
fffff880`01c00000 fffff880`01c0e000 crashdmp.sys
Checksum: 00000000
ImageSize: 0000E000
fffff880`0423e000 fffff880`045e2000 dump_iaStor.
Checksum: 00000000
ImageSize: 003A4000
fffff880`045e2000 fffff880`045f5000 dump_dumpfve
Checksum: 00000000
ImageSize: 00013000
