Marcellus5000
Hier mal meine Blur Config.
Schalte den Init Beep ein , dann hörst schon beim Programmstart ob er gefunden wurde.Code:[Options] UseAutoPad=0 #use 0 to 1; automatically make other PAD to PAD1 after detecting movement UseInitBeep=1 #use 0 to 1; default 1; beep on init # Original Xbox Controller [PAD1] Index=0 #controller index in game controllers list; 0 is first; -1 to ignore this pad Left Analog X=1 #axis index; use - to invert; precede with 's' for a slider eg; s-1; 7 to disable Left Analog Y=-2 #axis index; use - to invert; precede with 's' for a slider eg; s-1; 7 to disable Right Analog X=6 #axis index; use - to invert; precede with 's' for a slider eg; s-1; 7 to disable Right Analog Y=-3 #axis index; use - to invert; precede with 's' for a slider eg; s-1; 7 to disable Left Analog X Linear=0 #-100 to +100 raise this number to increase sensitivity near center Left Analog Y Linear=0 #-100 to +100 raise this number to increase sensitivity near center Right Analog X Linear=-50 #-100 to +100 raise this number to increase sensitivity near center Right Analog Y Linear=-50 #-100 to +100 raise this number to increase sensitivity near center Left Analog X+ Button=0 #button id; 0 to disable Left Analog X- Button=0 #button id; 0 to disable Left Analog Y+ Button=0 #button id; 0 to disable Left Analog Y- Button=0 #button id; 0 to disable Right Analog X+ Button=0 #button id; 0 to disable Right Analog X- Button=0 #button id; 0 to disable Right Analog Y+ Button=0 #button id; 0 to disable Right Analog Y- Button=0 #button id; 0 to disable D-pad POV=1 #POV index; 0 to disable D-pad Up=0 #button id; 0 to disable D-pad Down=0 #button id; 0 to disable D-pad Left=0 #button id; 0 to disable D-pad Right=0 #button id; 0 to disable A=1 #button id; 0 to disable B=2 #button id; 0 to disable X=8 #button id; 0 to disable Y=10 #button id; 0 to disable Left Shoulder=11 #button id; 0 to disable Right Shoulder=4 #button id; 0 to disable Back=0 #button id; 0 to disable Start=9 #button id; 0 to disable Left Thumb=3 #button id; 0 to disable Right Thumb=6 #button id; 0 to disable Left Trigger=5 #button id; precede with 'a' for an axis or 'h' for a half-axis; eg; a-6 or h3; for a slider precede with 's' eg; s-1 Right Trigger=7 #button id; precede with 'a' for an axis or 'h' for a half-axis; eg; a-6 or h3; for a slider precede with 's' eg; s-1 UseForceFeedback=0 #use 0 to 1; default 0
Kopier xinput1_3.dll und benenne sie ..1_1.dll - ...1_4.dll. Also quasi 4 Kopien, nur mit anderer Nummer am Ende.
Ich hatte noch keine Probleme bisher.
Danke!
Habe wie beschieben verfahren (dlls kopiert und deine Config genommen). Kein Piepen, das Spieler erkennt keinen Controller. (x360ce.exe jedoch erkennt einen Kontroller)
Ich habe wie gesagt Windows 7 64 Bit (schreibe das, weil Du XP SP3 hast)
