Die FSB 470 laufen wieder stabil mit Vollrambestückung auf nem P5Q-E und nem Q9550.
.:AI Tweaker:.
AI Overclock Tuner [Manual]
CPU Ratio Setting [8.5]
FSB Frequency [470]
PCI-E Frequency [100]
FSB Strap to North Bridge [333]
DRAM Frequency [DDR2-940]
DRAM CLK Skew on Channel A1 [Auto]
DRAM CLK Skew on Channel A2 [Auto]
DRAM CLK Skew on Channel B1 [Auto]
DRAM CLK Skew on Channel B2 [Auto]
DRAM Timing Control [Manual]
1st Information : 5-5-5-18-3-45-6-3
CAS# Latency [5]
DRAM RAS# to CAS# Delay [5]
DRAM RAS# Precharge [5]
DRAM RAS# Activate to Precharge [18]
RAS# to RAS# Delay [Auto]
Row Refresh Cycle Time [Auto]
Write Recovery Time [Auto]
Read to Precharge Time [Auto]
2nd Information : X-X-X-X-X-X-X
READ to WRITE Delay (S/D) [Auto]
Write to Read Delay (S) [Auto]
WRITE to READ Delay (D) [Auto]
READ to READ Delay (S) [Auto]
READ to READ Delay (D) [Auto]
WRITE to WRITE Delay (S) [Auto]
WRITE to WRITE Delay (D) [Auto]
3rd Information : XX-X-X-X-X
WRITE to PRE Delay [Auto]
READ to PRE Delay [Auto]
PRE to PRE Delay [Auto]
ALL PRE to ACT Delay [Auto]
ALL PRE to REF Delay [Auto]
DRAM Static Read Control [Disabled]
DRAM Read Training [Disabled]
MEM. OC Charger [aktiviert]
AI Clock Twister [lighter]
AI Transaction Booster [manuell]
Common Performance Level [PL 10]
Pull-In of CHA PH1 [Disabled]
Pull-In of CHA PH2 [Disabled]
Pull-In of CHA PH3 [Disabled]
Pull-In of CHA PH4 [Disabled]
Pull-In of CHB PH1 [Disabled]
Pull-In of CHB PH2 [Disabled]
Pull-In of CHB PH3 [Disabled]
Pull-In of CHB PH4 [Disabled]
******** Please key in numbers directly! ********
CPU Voltage [1.34xxx]
CPU GTL 0/2 Voltage Reference [0,680]
CPU GTL 1/3 Voltage Reference [0,640]
CPU PLL Voltage [1,52]
FSB Termination Voltage [1.26]
DRAM Voltage [1.84]
NB Voltage [1.34]
NB GTL Reference [0,635]
SBridge Voltage [1,20]
PCIE SATA Voltage [1,50]
Load Line Calibration [Disabled]
CPU Spread Spectrum [Disabled]
PCIE Spread Spectrum [Disabled]
CPU Clock Skew [+100ps]
NB Clock Skew [+200ps]
CPU Margin Enhancement [Performance Mode]
.:Advanced - CPU Configuration:.
CPU Ratio Setting [Auto]
C1E Suppport [Enable]
Max CPUID Value Limit [Enable]
Intel (R) Virtualization Tech [Enabled]
CPU TM Function [Enabled]
Execute Disable Bit [Enable]
Intel (R) SpeedStep (TM) Tech [Enable]
Intel (R) C-STATE Tech [Enable]
Vcore @ linx: 1,248 bei 73/73/71/71
gekühlt mit nem Noctua NH-U12P und 2 Xigmatek´s XLF-F125x. Damit wirds der Nb auch kaum warm, müsste es nochmal messen, bei 1,32vnb und FSB 450 hat die ingame maximal 59,5°C. Der 2te Lüfter bringt eben seine guten 8°C.
Hat schon nen halben prime large run hinter sich, seine 20 runs Linx auch, ein 8:20min Video gerendert, auf 21,75mbit, und damit wurden auch schon 3h gespielt ^^ Einen 100er Run muss ich aber noch machen.
Edit:
Hab mal die Northbridge gemessen, 15 Minuten Prime large und Furmark, um die höchst-mögliche Temperatur festzustellen, Zimmertemperatur war bei 24°C.
Über 60,7°C ging die Temperatur nicht hinaus, und als ich mal Metro spielte kam der kaum auf 58,5°C.
Alles noch im grünen, einzig die CPU Temperatur ist schon etwas hoch, ingame kommt der zwar an seine 69°C, aber das sind ja nur die Core-temps ^^
