Nein eine ganz alten 552.44 der voll am perfomantesten sein soll fur meine GTX 1660 Super. Ich bin wirklich uberfragt.
_________________________________________________________________________________________________________
CONCLUSION
Your system appears to be having trouble handling real-time audio and other tasks. You are likely to experience buffer underruns appearing as drop outs, clicks or pops. One
or more DPC routines that belong to a driver running in your system appear to be executing for too long. One problem may be related to power management, disable CPU
throttling settings in Control Panel and BIOS setup. Check for BIOS updates.
LatencyMon has been analyzing your system for 0:37:37 (h:mm:ss) on all processors.
SYSTEM INFORMATION
Computer name: DENNY
OS version: Windows 11, 10.0, version 2009, build: 26200 (x64)
Hardware: System Product Name, ASUS
BIOS: 3634
CPU: AuthenticAMD AMD Ryzen 7 5800X 8-Core Processor
Logical processors: 16
Processor groups: 1
Processor group size: 16
RAM: 32680 MB total
CPU SPEED
Reported CPU speed (WMI): 3801 MHz
Reported CPU speed (registry): 380 MHz
Note: reported execution times may be calculated based on a fixed reported CPU speed. Disable variable speed settings like Intel Speed Step and AMD Cool N Quiet in the BIOS
setup for more accurate results.
MEASURED INTERRUPT TO USER PROCESS LATENCIES
The interrupt to process latency reflects the measured interval that a usermode process needed to respond to a hardware request from the moment the interrupt service
routine started execution. This includes the scheduling and execution of a DPC routine, the signaling of an event and the waking up of a usermode thread from an idle wait
state in response to that event.
Highest measured interrupt to process latency (µs): 408,10
Average measured interrupt to process latency (µs): 12,881591
Highest measured interrupt to DPC latency (µs): 400,20
Average measured interrupt to DPC latency (µs): 5,933144
REPORTED ISRs
Interrupt service routines are routines installed by the OS and device drivers that execute in response to a hardware interrupt signal.
Highest ISR routine execution time (µs): 419,350
Driver with highest ISR routine execution time: dxgkrnl.sys - DirectX Graphics Kernel, Microsoft Corporation
Highest reported total ISR routine time (%): 0,136707
Driver with highest ISR total time: dxgkrnl.sys - DirectX Graphics Kernel, Microsoft Corporation
Total time spent in ISRs (%) 0,141370
ISR count (execution time <250 µs): 2460582
ISR count (execution time 250-500 µs): 0
ISR count (execution time 500-1000 µs): 9
ISR count (execution time 1000-2000 µs): 0
ISR count (execution time 2000-4000 µs): 0
ISR count (execution time >=4000 µs): 0
REPORTED DPCs
DPC routines are part of the interrupt servicing dispatch mechanism and disable the possibility for a process to utilize the CPU while it is interrupted until the DPC has
finished execution.
Highest DPC routine execution time (µs): 4507,240
Driver with highest DPC routine execution time: nvlddmkm.sys - NVIDIA Windows Kernel Mode Driver, Version 552.44 , NVIDIA Corporation
Highest reported total DPC routine time (%): 0,068955
Driver with highest DPC total execution time: dxgkrnl.sys - DirectX Graphics Kernel, Microsoft Corporation
Total time spent in DPCs (%) 0,161516
DPC count (execution time <250 µs): 4573511
DPC count (execution time 250-500 µs): 0
DPC count (execution time 500-10000 µs): 153
DPC count (execution time 1000-2000 µs): 0
DPC count (execution time 2000-4000 µs): 1
DPC count (execution time >=4000 µs): 4
REPORTED HARD PAGEFAULTS
Hard pagefaults are events that get triggered by making use of virtual memory that is not resident in RAM but backed by a memory mapped file on disk. The process of
resolving the hard pagefault requires reading in the memory from disk while the process is interrupted and blocked from execution.
NOTE: some processes were hit by hard pagefaults. If these were programs producing audio, they are likely to interrupt the audio stream resulting in dropouts, clicks and
pops. Check the Processes tab to see which programs were hit.
Process with highest pagefault count: explorer.exe
Total number of hard pagefaults 6086
Hard pagefault count of hardest hit process: 2075
Number of processes hit: 61
PER CPU DATA
CPU 0 Interrupt cycle time (s): 177,105580
CPU 0 ISR highest execution time (µs): 419,350
CPU 0 ISR total execution time (s): 51,029927
CPU 0 ISR count: 2459575
CPU 0 DPC highest execution time (µs): 4507,240
CPU 0 DPC total execution time (s): 56,250027
CPU 0 DPC count: 4303963
CPU 1 Interrupt cycle time (s): 7,015474
CPU 1 ISR highest execution time (µs): 101,830
CPU 1 ISR total execution time (s): 0,031587
CPU 1 ISR count: 1016
CPU 1 DPC highest execution time (µs): 220,340
CPU 1 DPC total execution time (s): 0,070495
CPU 1 DPC count: 7757
CPU 2 Interrupt cycle time (s): 8,988974
CPU 2 ISR highest execution time (µs): 0,0
CPU 2 ISR total execution time (s): 0,0
CPU 2 ISR count: 0
CPU 2 DPC highest execution time (µs): 241,120
CPU 2 DPC total execution time (s): 0,164071
CPU 2 DPC count: 27258
CPU 3 Interrupt cycle time (s): 9,578012
CPU 3 ISR highest execution time (µs): 0,0
CPU 3 ISR total execution time (s): 0,0
CPU 3 ISR count: 0
CPU 3 DPC highest execution time (µs): 313,50
CPU 3 DPC total execution time (s): 0,171789
CPU 3 DPC count: 27989
CPU 4 Interrupt cycle time (s): 5,971643
CPU 4 ISR highest execution time (µs): 0,0
CPU 4 ISR total execution time (s): 0,0
CPU 4 ISR count: 0
CPU 4 DPC highest execution time (µs): 277,20
CPU 4 DPC total execution time (s): 0,069553
CPU 4 DPC count: 9422
CPU 5 Interrupt cycle time (s): 6,084959
CPU 5 ISR highest execution time (µs): 0,0
CPU 5 ISR total execution time (s): 0,0
CPU 5 ISR count: 0
CPU 5 DPC highest execution time (µs): 279,960
CPU 5 DPC total execution time (s): 0,080379
CPU 5 DPC count: 12621
CPU 6 Interrupt cycle time (s): 7,227505
CPU 6 ISR highest execution time (µs): 0,0
CPU 6 ISR total execution time (s): 0,0
CPU 6 ISR count: 0
CPU 6 DPC highest execution time (µs): 295,480
CPU 6 DPC total execution time (s): 0,064040
CPU 6 DPC count: 8185
CPU 7 Interrupt cycle time (s): 7,216437
CPU 7 ISR highest execution time (µs): 0,0
CPU 7 ISR total execution time (s): 0,0
CPU 7 ISR count: 0
CPU 7 DPC highest execution time (µs): 87,880
CPU 7 DPC total execution time (s): 0,071567
CPU 7 DPC count: 9244
CPU 8 Interrupt cycle time (s): 9,489403
CPU 8 ISR highest execution time (µs): 0,0
CPU 8 ISR total execution time (s): 0,0
CPU 8 ISR count: 0
CPU 8 DPC highest execution time (µs): 276,970
CPU 8 DPC total execution time (s): 0,143599
CPU 8 DPC count: 20941
CPU 9 Interrupt cycle time (s): 9,390763
CPU 9 ISR highest execution time (µs): 0,0
CPU 9 ISR total execution time (s): 0,0
CPU 9 ISR count: 0
CPU 9 DPC highest execution time (µs): 293,770
CPU 9 DPC total execution time (s): 0,164012
CPU 9 DPC count: 24119
CPU 10 Interrupt cycle time (s): 7,858532
CPU 10 ISR highest execution time (µs): 0,0
CPU 10 ISR total execution time (s): 0,0
CPU 10 ISR count: 0
CPU 10 DPC highest execution time (µs): 286,340
CPU 10 DPC total execution time (s): 0,075915
CPU 10 DPC count: 10638
CPU 11 Interrupt cycle time (s): 7,464871
CPU 11 ISR highest execution time (µs): 0,0
CPU 11 ISR total execution time (s): 0,0
CPU 11 ISR count: 0
CPU 11 DPC highest execution time (µs): 273,140
CPU 11 DPC total execution time (s): 0,086987
CPU 11 DPC count: 12291
CPU 12 Interrupt cycle time (s): 8,563228
CPU 12 ISR highest execution time (µs): 0,0
CPU 12 ISR total execution time (s): 0,0
CPU 12 ISR count: 0
CPU 12 DPC highest execution time (µs): 284,370
CPU 12 DPC total execution time (s): 0,103527
CPU 12 DPC count: 13494
CPU 13 Interrupt cycle time (s): 8,199119
CPU 13 ISR highest execution time (µs): 0,0
CPU 13 ISR total execution time (s): 0,0
CPU 13 ISR count: 0
CPU 13 DPC highest execution time (µs): 127,840
CPU 13 DPC total execution time (s): 0,114920
CPU 13 DPC count: 15115
CPU 14 Interrupt cycle time (s): 9,894032
CPU 14 ISR highest execution time (µs): 0,0
CPU 14 ISR total execution time (s): 0,0
CPU 14 ISR count: 0
CPU 14 DPC highest execution time (µs): 288,510
CPU 14 DPC total execution time (s): 0,315191
CPU 14 DPC count: 32586
CPU 15 Interrupt cycle time (s): 9,818781
CPU 15 ISR highest execution time (µs): 0,0
CPU 15 ISR total execution time (s): 0,0
CPU 15 ISR count: 0
CPU 15 DPC highest execution time (µs): 286,880
CPU 15 DPC total execution time (s): 0,391876
CPU 15 DPC count: 38046
