FXAA Injector danoc1 v1.25 SETTINGS
// TODO: Normalize values to be on a human range scale, whole numbers prefered, decimals usable for micro adjustments
// These values should have min/max limit checks included in their functions, so that the end user doesn't get crazy results
FILTER SELECTION
// Comment to deactivate an effect.
// Example: To disable the tonemap effect, use // in front of #define USE_TONEMAP
#define USE_ANTI_ALIASING
#define USE_PRE_SHARPEN
//#define USE_BLOOM
#define USE_TECHNICOLOR
#define USE_TONEMAP
#define USE_SEPIA
//#define USE_VIGNETTE
#define USE_POST_SHARPEN
//#define USE_FINAL_LIMITER
FXAA SHADER
// Set values to calculate the amount of Anti Aliasing applied
float fxaaQualitySubpix = 0.65; // Default: 0.75 Raise to increase amount of blur
float fxaaQualityEdgeThreshold = 0.063; // Lower the value for more smoothing
float fxaaQualityEdgeThresholdMin = 0.312; // Lower the value for more smoothing
PRE_SHARPEN
//For higher precision in the calculation of contour, requires slightly more processing power
bool highQualitySharpen = 1; //0 = Disable | 1 = Enable
// Set values to calculate the amount of AA produced blur to consider for the sharpening pass
#define Average 0.7
#define CoefBlur 2
// Set values of the sharpening amount
#define SharpenEdge 0.22
#define Sharpen_val0 1.2
BLOOM
// Number of samples per pixel taken for the Bloom effect. Don't set it to high! 4 = 25spp, 8 = 81spp, 16 = 289spp
#define NUM_SAMPLES2 16
float BloomPreset = 0;
float BloomThreshold = 0;
float BloomWidth = 0;
float BloomPower = 0;
TECHNICOLOR
#define TechniAmount 0.18 // 1.00 = Max
#define TechniPower 3.6
// lower values = stronger channel
#define redNegativeAmount 0.9 // 1.00 = Max
#define greenNegativeAmount 1.0 // 1.00 = Max
#define blueNegativeAmount 1.0 // 1.00 = Max
TONEMAP
#define Gamma 0.9
#define Exposure 0.01
#define Saturation 0.2
#define BlueShift 0.01
#define Bleach 0.01
#define Defog 0.1
#define FogColor float4(0.05, 0.11, 0.16, 2.0)
SEPIA
#define Earthyellow // Color Tone, available tones can be seen in ColorTones.PNG (Do not use spaces in the name!)
#define GreyPower 0.0
#define SepiaPower 0.02
VIGNETTE
// Vignette effect, process by which there is loss in clarity towards the corners and sides of the image, like a picture frame
#define VignetteCenter float2(0.500, 0.500)
#define VignetteRadius 1.00
#define VignetteAmount -0.90
POST_SHARPEN
// Controls additional sharpening applied after previous processing. Strength should be max 0.25!
float Sharpen = 0.1;
FINAL_LIMITER
// Controls the strenght of the limiter. 1.000 for default setting
int LimiterStrenght = 1.000;
