*********************** Log Started 2013-03-09T18:42:15Z ***********************
18:42:15:************************* Folding@home Client *************************
18:42:15: Website:
Folding@home
18:42:15: Copyright: (c) 2009-2012 Stanford University
18:42:15: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
18:42:15: Args: --lifeline 1692 --command-port=36330
18:42:15: Config: C:/Dokumente und
18:42:15: Einstellungen/Markus/Anwendungsdaten/FAHClient/config.xml
18:42:15:******************************** Build ********************************
18:42:15: Version: 7.2.9
18:42:15: Date: Oct 3 2012
18:42:15: Time: 18:05:48
18:42:15: SVN Rev: 3578
18:42:15: Branch: fah/trunk/client
18:42:15: Compiler: Intel(R) C++ MSVC 1500 mode 1200
18:42:15: Options: /TP /nologo /EHa /Qdiag-disable:4297,4103,1786,279 /Ox -arch:SSE
18:42:15: /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qopenmp /Qrestrict /MT /Qmkl
18:42:15: Platform: win32 XP
18:42:15: Bits: 32
18:42:15: Mode: Release
18:42:15:******************************* System ********************************
18:42:15: CPU: Intel(R) Core(TM) i7 CPU K 875 @ 2.93GHz
18:42:15: CPU ID: GenuineIntel Family 6 Model 30 Stepping 5
18:42:15: CPUs: 8
18:42:15: Memory: 2.99GiB
18:42:15: Free Memory: 2.41GiB
18:42:15: Threads: WINDOWS_THREADS
18:42:15: On Battery: false
18:42:15: UTC offset: 1
18:42:15: PID: 3892
18:42:15: CWD: C:/Dokumente und Einstellungen/Markus/Anwendungsdaten/FAHClient
18:42:15: OS: Microsoft Windows XP Service Pack 3
18:42:15: OS Arch: X86
18:42:15: GPUs: 2
18:42:15: GPU 0: NVIDIA:2 GF110 [Geforce GTX 560 Ti]
18:42:15: GPU 1: NVIDIA:2 GF110 [Geforce GTX 560 Ti]
18:42:15: CUDA: 2.0
18:42:15: CUDA Driver: 5000
18:42:15:Win32 Service: false
18:42:15:***********************************************************************
18:42:15:<config>
18:42:15: <service-description v='Folding@home Client'/>
18:42:15: <service-restart v='true'/>
18:42:15: <service-restart-delay v='5000'/>
18:42:15:
18:42:15: <!-- Client Control -->
18:42:15: <cycle-rate v='4'/>
18:42:15: <cycles v='-1'/>
18:42:15: <data-directory v='.'/>
18:42:15: <disable-project-lookup v='false'/>
18:42:15: <exec-directory v='D:\Programme\FAHClient'/>
18:42:15: <exit-when-done v='false'/>
18:42:15: <threads v='4'/>
18:42:15:
18:42:15: <!-- Configuration -->
18:42:15: <config-rotate v='true'/>
18:42:15: <config-rotate-dir v='configs'/>
18:42:15: <config-rotate-max v='16'/>
18:42:15:
18:42:15: <!-- Debugging -->
18:42:15: <assignment-servers>
18:42:15: assign3.stanford.edu:8080 assign4.stanford.edu:80
18:42:15: </assignment-servers>
18:42:15: <capture-directory v='capture'/>
18:42:15: <capture-sockets v='false'/>
18:42:15: <debug-sockets v='false'/>
18:42:15: <exception-locations v='true'/>
18:42:15: <gpu-assignment-servers>
18:42:15: assign-GPU.stanford.edu:80 assign-GPU.stanford.edu:8080
18:42:15: </gpu-assignment-servers>
18:42:15: <stack-traces v='false'/>
18:42:15:
18:42:15: <!-- Error Handling -->
18:42:15: <max-slot-errors v='5'/>
18:42:15: <max-unit-errors v='5'/>
18:42:15:
18:42:15: <!-- FahCore Control -->
18:42:15: <checkpoint v='5'/>
18:42:15: <core-dir v='cores'/>
18:42:15: <core-priority v='low'/>
18:42:15: <cpu-affinity v='false'/>
18:42:15: <cpu-usage v='100'/>
18:42:15: <no-assembly v='false'/>
18:42:15:
18:42:15: <!-- Folding Slot Configuration -->
18:42:15: <cause-pref v='ANY'/>
18:42:15: <client-subtype v='STDCLI'/>
18:42:15: <client-type v='normal'/>
18:42:15: <cpu-species v='X86_PENTIUM_II'/>
18:42:15: <cpu-type v='X86'/>
18:42:15: <cpus v='-1'/>
18:42:15: <cuda-index v='0'/>
18:42:15: <extra-core-args v='fermi'/>
18:42:15: <gpu v='true'/>
18:42:15: <gpu-usage v='100'/>
18:42:15: <max-packet-size v='normal'/>
18:42:15: <opencl-index v='0'/>
18:42:15: <os-species v='WIN_XP'/>
18:42:15: <os-type v='WIN32'/>
18:42:15: <project-key v='0'/>
18:42:15: <smp v='false'/>
18:42:15:
18:42:15: <!-- Logging -->
18:42:15: <log v='log.txt'/>
18:42:15: <log-color v='false'/>
18:42:15: <log-crlf v='true'/>
18:42:15: <log-date v='false'/>
18:42:15: <log-date-periodically v='21600'/>
18:42:15: <log-debug v='true'/>
18:42:15: <log-domain v='false'/>
18:42:15: <log-header v='true'/>
18:42:15: <log-level v='true'/>
18:42:15: <log-no-info-header v='true'/>
18:42:15: <log-redirect v='false'/>
18:42:15: <log-rotate v='true'/>
18:42:15: <log-rotate-dir v='logs'/>
18:42:15: <log-rotate-max v='16'/>
18:42:15: <log-short-level v='false'/>
18:42:15: <log-simple-domains v='true'/>
18:42:15: <log-thread-id v='false'/>
18:42:15: <log-thread-prefix v='true'/>
18:42:15: <log-time v='true'/>
18:42:15: <log-to-screen v='true'/>
18:42:15: <log-truncate v='false'/>
18:42:15: <verbosity v='5'/>
18:42:15:
18:42:15: <!-- Network -->
18:42:15: <proxy v=':8080'/>
18:42:15: <proxy-enable v='false'/>
18:42:15: <proxy-pass v=''/>
18:42:15: <proxy-user v=''/>
18:42:15:
18:42:15: <!-- Process Control -->
18:42:15: <child v='false'/>
18:42:15: <daemon v='false'/>
18:42:15: <pid v='false'/>
18:42:15: <pid-file v='Folding@home Client.pid'/>
18:42:15: <respawn v='false'/>
18:42:15: <service v='false'/>
18:42:15:
18:42:15: <!-- Remote Command Server -->
18:42:15: <command-address v='0.0.0.0'/>
18:42:15: <command-allow v='0.0.0.0/0'/>
18:42:15: <command-allow-no-pass v='0.0.0.0/0'/>
18:42:15: <command-deny v='0.0.0.0/0'/>
18:42:15: <command-deny-no-pass v='0.0.0.0/0'/>
18:42:15: <command-port v='36330'/>
18:42:15:
18:42:15: <!-- Slot Control -->
18:42:15: <max-shutdown-wait v='60'/>
18:42:15: <pause-on-battery v='false'/>
18:42:15: <pause-on-start v='false'/>
18:42:15:
18:42:15: <!-- User Information -->
18:42:15: <machine-id v='0'/>
18:42:15: <passkey v='********************************'/>
18:42:15: <team v='70335'/>
18:42:15: <user v='folding_hoomer'/>
18:42:15:
18:42:15: <!-- Work Unit Control -->
18:42:15: <dump-after-deadline v='true'/>
18:42:15: <max-queue v='16'/>
18:42:15: <max-units v='0'/>
18:42:15: <next-unit-percentage v='99'/>
18:42:15:
18:42:15: <!-- Folding Slots -->
18:42:15: <slot id='0' type='GPU'>
18:42:15: <client-type v='beta'/>
18:42:15: <extra-core-args v='-gpu-vendor=nvidia'/>
18:42:15: <max-packet-size v='big'/>
18:42:15: </slot>
18:42:15: <slot id='1' type='GPU'>
18:42:15: </slot>
18:42:15:</config>
18:42:16:Trying to access database...
18:42:16:Successfully acquired database lock
18:42:16:Enabled folding slot 00: READY gpu:0:"GF110 [Geforce GTX 560 Ti]"
18:42:16:Enabled folding slot 01: READY gpu:1:"GF110 [Geforce GTX 560 Ti]"
18:42:16:WARNING:WU00:Missing data files, dumping
18:42:16:Started thread 1 on PID 3892
18:42:16:Started thread 3 on PID 3892
18:42:16:Started thread 4 on PID 3892
18:42:16:Started thread 6 on PID 3892
18:42:16:Started thread 5 on PID 3892
18:42:16:WU00:FS00:Cleaning up
18:42:16:WU02:FS01:Starting
18:42:16:WU02:FS01:Running FahCore: D:\Programme\FAHClient/FAHCoreWrapper.exe "C:/Dokumente und Einstellungen/Markus/Anwendungsdaten/FAHClient/cores/www.stanford.edu/~pande/Win32/x86/NVIDIA/Fermi/Core_15.fah/FahCore_15.exe" -dir 02 -suffix 01 -version 702 -lifeline 3892 -checkpoint 5 -gpu 1 fermi
18:42:16:WU02:FS01:Started FahCore on PID 2100
18:42:16:Started thread 7 on PID 3892
18:42:16:WU02:FS01:Core PID:2316
18:42:16:WU02:FS01:FahCore 0x15 started
18:42:16:WU00:FS00:Connecting to assign-GPU.stanford.edu:80
18:42:16:WU02:FS01:0x15:
18:42:16:WU02:FS01:0x15:*------------------------------*
18:42:16:WU02:FS01:0x15:Folding@Home GPU Core
18:42:16:WU02:FS01:0x15:Version 2.25 (Wed May 9 17:03:01 EDT 2012)
18:42:16:WU02:FS01:0x15:Build host AmoebaRemote
18:42:16:WU02:FS01:0x15:Board Type NVIDIA/CUDA
18:42:16:WU02:FS01:0x15:Core 15
18:42:16:WU02:FS01:0x15:GPU device info vendor=0 device=0 name=NA match=0 deviceId=1
18:42:16:WU02:FS01:0x15:Window's signal control handler registered.
reparing to commence simulation
18:42:16:WU02:FS01:0x15:- Looking at optimizations...
18:42:16:WU02:FS01:0x15:- Files status OK
18:42:16:WU02:FS01:0x15:sizeof(CORE_PACKET_HDR) = 512 file=<>
18:42:16:WU02:FS01:0x15:- Expanded 59120 -> 261034 (decompressed 441.5 percent)
18:42:16:WU02:FS01:0x15:Called DecompressByteArray: compressed_data_size=59120 data_size=261034, decompressed_data_size=261034 diff=0
18:42:16:WU02:FS01:0x15:- Digital signature verified
roject: 8043 (Run 0, Clone 437, Gen 61)
18:42:16:WU02:FS01:0x15:Assembly optimizations on if available.
18:42:16:WU02:FS01:0x15:Entering M.D.
18:42:18:WU02:FS01:0x15:Will resume from checkpoint file 02/wudata_01.ckp
18:42:18:WU02:FS01:0x15:Tpr hash 02/wudata_01.tpr: 1613030285 2366021248 972581607 1065645276 311691476
18:42:18:WU02:FS01:0x15:GPU device id=1
18:42:18:WU02:FS01:0x15:Working on GROningen MAchine for Chemical Simulation
18:42:18:WU02:FS01:0x15:Client config unavailable.
18:42:18:WU02:FS01:0x15:Starting GUI Server
18:42:19:Started thread 8 on PID 3892
18:42:19:Server connection id=1 on 0.0.0.0:36330 from 127.0.0.1
18:42:19:WU00:FS00:News: Welcome to Folding@Home
18:42:19:WU00:FS00:Assigned to work server 171.67.108.36
18:42:19:WU00:FS00:Requesting new work unit for slot 00: READY gpu:0:"GF110 [Geforce GTX 560 Ti]" from 171.67.108.36
18:42:19:WU00:FS00:Connecting to 171.67.108.36:8080
18:42:20:WU00:FS00
ownloading 58.01KiB
18:42:21:WU00:FS00
ownload complete
18:42:21:WU00:FS00:Received Unit: id:00 state
OWNLOAD error:NO_ERROR project:8071 run:73 clone:4 gen:58 core:0x15 unit:0x000000406652edb45122e1184e39e8df
18:42:21:WU00:FS00:Starting
18:42:21:WU00:FS00:Running FahCore: D:\Programme\FAHClient/FAHCoreWrapper.exe "C:/Dokumente und Einstellungen/Markus/Anwendungsdaten/FAHClient/cores/www.stanford.edu/~pande/Win32/x86/NVIDIA/Fermi/Core_15.fah/FahCore_15.exe" -dir 00 -suffix 01 -version 702 -lifeline 3892 -checkpoint 5 -gpu 0 -gpu-vendor=nvidia
18:42:21:WU00:FS00:Started FahCore on PID 3136
18:42:21:Started thread 9 on PID 3892
18:42:21:WU00:FS00:Core PID:3148
18:42:21:WU00:FS00:FahCore 0x15 started
18:42:22:WU00:FS00:0x15:
18:42:22:WU00:FS00:0x15:*------------------------------*
18:42:22:WU00:FS00:0x15:Folding@Home GPU Core
18:42:22:WU00:FS00:0x15:Version 2.25 (Wed May 9 17:03:01 EDT 2012)
18:42:22:WU00:FS00:0x15:Build host AmoebaRemote
18:42:22:WU00:FS00:0x15:Board Type NVIDIA/CUDA
18:42:22:WU00:FS00:0x15:Core 15
18:42:22:WU00:FS00:0x15:Window's signal control handler registered.
18:42:22:WU00:FS00:0x15:- Looking at optimizations...
eleteFrameFiles: successfully deleted file=00/wudata_01.ckp
18:42:22:WU00:FS00:0x15:- Created dyn
18:42:22:WU00:FS00:0x15:- Files status OK
18:42:22:WU00:FS00:0x15:sizeof(CORE_PACKET_HDR) = 512 file=<>
18:42:22:WU00:FS00:0x15:- Expanded 58886 -> 259314 (decompressed 440.3 percent)
18:42:22:WU00:FS00:0x15:Called DecompressByteArray: compressed_data_size=58886 data_size=259314, decompressed_data_size=259314 diff=0
18:42:22:WU00:FS00:0x15:- Digital signature verified
roject: 8071 (Run 73, Clone 4, Gen 58)
18:42:22:WU00:FS00:0x15:Assembly optimizations on if available.
18:42:22:WU00:FS00:0x15:Entering M.D.
18:42:23:WU00:FS00:0x15:Tpr hash 00/wudata_01.tpr: 3008189601 27477380 2626181868 1242874335 164449307
18:42:23:WU00:FS00:0x15:GPU device id=0
18:42:23:WU00:FS00:0x15:Working on Glycine aRginine prOline Methionine Alanine Cystine Serine t= 73.00000
18:42:23:WU00:FS00:0x15:Client config unavailable.
18:42:24:WU00:FS00:0x15:Starting GUI Server
18:42:40:Server connection id=2 on 0.0.0.0:36330 from 192.168.2.100
18:42:40:Started thread 10 on PID 3892
18:43:29:WU02:FS01:0x15:Resuming from checkpoint
18:43:29:WU02:FS01:0x15:fcCheckPointResume: retreived and current tpr file hash:
18:43:29:WU02:FS01:0x15: 0 1613030285 1613030285
18:43:29:WU02:FS01:0x15: 1 2366021248 2366021248
18:43:29:WU02:FS01:0x15: 2 972581607 972581607
18:43:29:WU02:FS01:0x15: 3 1065645276 1065645276
18:43:29:WU02:FS01:0x15: 4 311691476 311691476
18:43:29:WU02:FS01:0x15:fcCheckPointResume: file hashes same.
18:43:29:WU02:FS01:0x15:fcCheckPointResume: state restored.
18:43:29:WU02:FS01:0x15:fcCheckPointResume: name 02/wudata_01.log Verified 02/wudata_01.log
18:43:29:WU02:FS01:0x15:fcCheckPointResume: name 02/wudata_01.trr Verified 02/wudata_01.trr
18:43:29:WU02:FS01:0x15:fcCheckPointResume: name 02/wudata_01.xtc Verified 02/wudata_01.xtc
18:43:29:WU02:FS01:0x15:fcCheckPointResume: name 02/wudata_01.edr Verified 02/wudata_01.edr
18:43:29:WU02:FS01:0x15:fcCheckPointResume: state restored 2
18:43:29:WU02:FS01:0x15:Resumed from checkpoint
18:43:29:WU02:FS01:0x15:Setting checkpoint frequency: 500000
18:43:29:WU02:FS01:0x15:Completed 13500001 out of 50000000 steps (27%).
18:43:29:WU00:FS00:0x15:Setting checkpoint frequency: 500000
18:43:29:WU00:FS00:0x15:Completed 3 out of 50000000 steps (0%).
