[05:13:46] Completed 445000 out of 500000 steps (89 percent)
[05:24:34] Writing local files
[05:24:34] Completed 450000 out of 500000 steps (90 percent)
[05:32:23] Quit 101 - NaN detected: (ener[25])
[05:32:23]
[05:32:23] Simulation instability has been encountered. The run has entered a
[05:32:23] state from which no further progress can be made.
[05:32:23] This may be the correct result of the simulation, however if you
[05:32:23] often see other project units terminating early like this
[05:32:23] too, you may wish to check the stability of your computer (issues
[05:32:23] such as high temperature, overclocking, etc.).
[05:32:23] Going to send back what have done.
[05:32:23] logfile size: 66650
[05:32:23] - Writing 67200 bytes of core data to disk...
[05:32:23] ... Done.
[05:32:23] - Failed to delete work/wudata_03.arc
[05:32:23] - Failed to delete work/wudata_03.xtc
[05:32:23] No C.P. to delete.
[05:32:23] - Failed to delete work/wudata_03.dyn
[05:32:23] - Failed to delete work/wudata_03.bed
[05:32:23] - Failed to delete work/wudata_03.xvg
[05:32:23] Warning: check for stray files
[05:34:23]
[05:34:23] Folding@home Core Shutdown: EARLY_UNIT_END
Hatte am späten Abend einige reboots zu Testzwecken gehabt und mußte den Client mehrmals schließen. Vermutlich ist Obiges wohl das Resultat daraus. Demnach ist mehrmaliges Rebooten kein guter Tipp zum schnellen Falten
![Ugly :ugly: :ugly:](/styles/ctec/images/smilies/s000.gif)
Schade nur um die Punkte
![Mauer :wall: :wall:](/styles/ctec/images/smilies/76.gif)
