WaggelDaggel88
Habe eine sehr gute wasserkühlung und meine RAM´s verfügen über 2133 MHz!! Aber ok ich setze es mal herunter und dann??
IMAGE_NAME: memory_corruption
FAILURE_BUCKET_ID: X64_0xA_nt!MmZeroPageThread
Unable to verify timestamp for ntoskrnl.exe
Microsoft (R) Windows Debugger Version 6.2.9200.20512 AMD64
Copyright (c) Microsoft Corporation. All rights reserved.
Loading Dump File [C:\Windows\Minidump\030414-5413-01.dmp]
Mini Kernel Dump File: Only registers and stack trace are available
Symbol search path is: SRV*C:\symbols*http://msdl.microsoft.com/download/symbol;SRV*C:\symbols*http://msdl.microsoft.com/download/symbols
Executable search path is:
Windows 7 Kernel Version 7601 (Service Pack 1) MP (8 procs) Free x64
Product: WinNt, suite: TerminalServer SingleUserTS
Built by: 7601.18247.amd64fre.win7sp1_gdr.130828-1532
Machine Name:
Kernel base = 0xfffff800`02e05000 PsLoadedModuleList = 0xfffff800`030486d0
Debug session time: Tue Mar 4 18:24:26.025 2014 (UTC + 1:00)
System Uptime: 0 days 0:00:04.806
Loading Kernel Symbols
Loading User Symbols
Loading unloaded module list
* Bugcheck Analysis *
Use !analyze -v to get detailed debugging information.
BugCheck 1A, {41287, 0, 0, 0}
*** WARNING: Unable to verify timestamp for aswSP.sys
*** ERROR: Module load completed but symbols could not be loaded for aswSP.sys
Probably caused by : aswSP.sys ( aswSP+109b6 )
Followup: MachineOwner
6: kd> !analyze –v
Symbol search path is: SRV*C:\symbols*http://msdl.microsoft.com/download/symbols
Machine Name:
6: kd> !analyze -v
MEMORY_MANAGEMENT (1a)
# Any other values for parameter 1 must be individually examined.
Arguments:
Arg1: 0000000000041287, An illegal page fault occurred while holding working set synchronization.
Parameter 2 contains the referenced virtual address.
Arg2: 0000000000000000
Arg3: 0000000000000000
Arg4: 0000000000000000
Debugging Details:
BUGCHECK_STR: 0x1a_41287
CUSTOMER_CRASH_COUNT: 1
DEFAULT_BUCKET_ID: WIN7_DRIVER_FAULT
PROCESS_NAME: spoolsv.exe
CURRENT_IRQL: 0
TRAP_FRAME: fffff88005de84a0 -- (.trap 0xfffff88005de84a0)
NOTE: The trap frame does not contain all registers.
Some register values may be zeroed or incorrect.
rax=0000000000000000 rbx=0000000000000000 rcx=0000000000000001
rdx=0000000000000001 rsi=0000000000000000 rdi=0000000000000000
rip=fffff80002ea2967 rsp=fffff88005de8638 rbp=fffffa8009c7f6c8
r8=0000000000000000 r9=00000000ffffffff r10=fffffa8000000000
r11=fffffa8009c7f778 r12=0000000000000000 r13=0000000000000000
r14=0000000000000000 r15=0000000000000000
iopl=0 nv up ei pl zr na po nc
nt!MiInsertNode+0xa7:
fffff800`02ea2967 498b08 mov rcx,qword ptr [r8] ds:00000000`00000000=????????????????
Resetting default scope
LAST_CONTROL_TRANSFER: from fffff80002e13d2e to fffff80002e7abc0
STACK_TEXT:
fffff880`05de8338 fffff800`02e13d2e : 00000000`0000001a 00000000`00041287 00000000`00000000 00000000`00000000 : nt!KeBugCheckEx
fffff880`05de8340 fffff800`02e78cee : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`0001a000 : nt! ?? ::FNODOBFM::`string'+0x454f5
fffff880`05de84a0 fffff800`02ea2967 : fffff800`02eaee12 fffffa80`09cc5df0 00000000`00000000 fffff880`05de8930 : nt!KiPageFault+0x16e
fffff880`05de8638 fffff800`02eaee12 : fffffa80`09cc5df0 00000000`00000000 fffff880`05de8930 fffff880`05de8938 : nt!MiInsertNode+0xa7
fffff880`05de8640 fffff800`03199a1f : 00000000`0001a000 fffffa80`09c7f548 00000000`00000000 00000000`00001ffb : nt!MiGetWsAndInsertVad+0x62
fffff880`05de8680 fffff800`03195db7 : fffffa80`09cc5df0 fffffa80`09c7f330 fffff880`05de8930 fffff880`05de8928 : nt!MiMapViewOfImageSection+0x683
fffff880`05de87d0 fffff800`031960be : fffff880`00000004 fffffa80`09c7f330 fffff880`05de8930 00000000`00000000 : nt!MiMapViewOfSection+0x367
fffff880`05de88c0 fffff880`047579b6 : 00000000`00000010 00000000`00000000 ffffffff`ffffffff 00000000`00000001 : nt!NtMapViewOfSection+0x2bd
fffff880`05de8990 00000000`00000010 : 00000000`00000000 ffffffff`ffffffff 00000000`00000001 00000000`00000000 : aswSP+0x109b6
fffff880`05de8998 00000000`00000000 : ffffffff`ffffffff 00000000`00000001 00000000`00000000 00000000`00000000 : 0x10
STACK_COMMAND: kb
FOLLOWUP_IP:
aswSP+109b6
fffff880`047579b6 ?? ???
SYMBOL_STACK_INDEX: 8
SYMBOL_NAME: aswSP+109b6
FOLLOWUP_NAME: MachineOwner
MODULE_NAME: aswSP
IMAGE_NAME: aswSP.sys
DEBUG_FLR_IMAGE_TIMESTAMP: 52deabc3
FAILURE_BUCKET_ID: X64_0x1a_41287_aswSP+109b6
Von daher betrachtet, sieht es ganz so aus, als ob du Glück hast und kein Hardwareproblem vorliegt.
