BlueScreen wie jetzt weiter
Okay....
Der Memtest lief gestern 9 Stunden durch ohne Ergebnis. Bios habe ich grade auch geupdatet.
Dann hoffe ich mal, dass jetzt wieder alles funktioniert.
Danke noch für den Tipp mit der Festplatte, die hat in der Tat schon ein paar mal rumgezickt. Kabel sitzt wieder, wenn sich da noch was tut, gibts mal ein neues ;)
Edit:
Grade ist der PC wieder abgestürzt. Hier die Auswertung:
Microsoft (R) Windows Debugger Version 6.2.9200.20512 X86
Copyright (c) Microsoft Corporation. All rights reserved.
Loading Dump File [C:\Windows\Minidump\060413-22120-01.dmp]
Mini Kernel Dump File: Only registers and stack trace are available
Symbol search path is: SRV*C:\symbols*http://msdl.microsoft.com/download/symbols
Executable search path is:
Windows 7 Kernel Version 7601 (Service Pack 1) MP (4 procs) Free x86 compatible
Product: WinNt, suite: TerminalServer SingleUserTS Personal
Built by: 7601.18113.x86fre.win7sp1_gdr.130318-1533
Machine Name:
Kernel base = 0xe3c0c000 PsLoadedModuleList = 0xe3d554d0
Debug session time: Tue Jun 4 21:55:52.010 2013 (UTC + 2:00)
System Uptime: 0 days 2:22:14.727
Loading Kernel Symbols
Loading User Symbols
Loading unloaded module list
* Bugcheck Analysis *
Use !analyze -v to get detailed debugging information.
BugCheck 1000008E, {c0000005, abb163cd, c69d798c, 0}
Probably caused by : dxgmms1.sys ( dxgmms1!VIDMM_SEGMENT::TrimAllProcesses+10b )
Followup: MachineOwner
2: kd> !analyze -v
KERNEL_MODE_EXCEPTION_NOT_HANDLED_M (1000008e)
This is a very common bugcheck. Usually the exception address pinpoints
the driver/function that caused the problem. Always note this address
as well as the link date of the driver/image that contains this address.
Some common problems are exception code 0x80000003. This means a hard
coded breakpoint or assertion was hit, but this system was booted
/NODEBUG. This is not supposed to happen as developers should never have
hardcoded breakpoints in retail code, but ...
If this happens, make sure a debugger gets connected, and the
system is booted /DEBUG. This will let us see why this breakpoint is
happening.
Arguments:
Arg1: c0000005, The exception code that was not handled
Arg2: abb163cd, The address that the exception occurred at
Arg3: c69d798c, Trap Frame
Arg4: 00000000
Debugging Details:
EXCEPTION_CODE: (NTSTATUS) 0xc0000005 - Die Anweisung in 0x%08lx verweist auf Speicher 0x%08lx. Der Vorgang %s konnte nicht im Speicher durchgef hrt werden.
FAULTING_IP:
abb163cd 8b5068 mov edx,dword ptr [eax+68h]
TRAP_FRAME: c69d798c -- (.trap 0xffffffffc69d798c)
ErrCode = 00000000
eax=ffffffff ebx=9f00eaa0 ecx=9fe39000 edx=de65af14 esi=9edd6610 edi=c9627880
eip=abb163cd esp=c69d7a00 ebp=c69d7a38 iopl=0 nv up ei pl nz na po nc
cs=0008 ss=0010 ds=0023 es=0023 fs=0030 gs=0000 efl=00010202
dxgmms1!VIDMM_SEGMENT::TrimAllProcesses+0x10b:
abb163cd 8b5068 mov edx,dword ptr [eax+68h] ds:0023:00000067=????????
Resetting default scope
CUSTOMER_CRASH_COUNT: 1
DEFAULT_BUCKET_ID: WIN7_DRIVER_FAULT
BUGCHECK_STR: 0x8E
PROCESS_NAME: dwm.exe
CURRENT_IRQL: 0
LAST_CONTROL_TRANSFER: from abb17e98 to abb163cd
STACK_TEXT:
c69d7a38 abb17e98 0000000c 00000000 d9c3e2f0 dxgmms1!VIDMM_SEGMENT::TrimAllProcesses+0x10b
c69d7a50 abb09898 00000005 00000000 9e304008 dxgmms1!VIDMM_SEGMENT::MarkCandidateForEviction+0x66
c69d7a78 abb0b23c d9c3e2f0 9ed94900 c69d7bd8 dxgmms1!VIDMM_GLOBAL::AllocateResourceForPinnedAllocation+0x44
c69d7ae0 abb0bef8 c69d7c14 c69d7bb0 c69d7be0 dxgmms1!VIDMM_GLOBAL::ProcessDeferredCommand+0x142
c69d7af8 abb213b9 c69d7bd8 9ed94900 9ed94900 dxgmms1!VidMmiProcessSystemCommand+0x20
c69d7b14 abb22293 9ed94bb0 9ed94008 c69d7b54 dxgmms1!VidSchiSubmitSystemCommand+0x33
c69d7b24 abafd6dc 9ed94900 9ed94900 9edd8dd0 dxgmms1!VidSchiSubmitQueueCommand+0x7b
c69d7b54 abb22466 9fbfb000 c69d7b78 9edd8dd0 dxgmms1!VidSchiSubmitQueueCommandDirect+0x1ae
c69d7b7c abb1d7f1 01d94900 9fe39000 a870607e dxgmms1!VidSchiSubmitCommandPacketToQueue+0x180
c69d7b94 abb0bf5f 9ed94008 abb0bed8 c69d7bd8 dxgmms1!VidSchSubmitSystemCommand+0xab
c69d7bc4 abb0bfc6 c69d7bd8 a2632008 9e304008 dxgmms1!VIDMM_GLOBAL::QueueSystemCommandAndWait+0x41
c69d7bfc abb0d863 c69d7c14 a2632008 a263213c dxgmms1!VIDMM_GLOBAL::QueueDeferredCommandAndWait+0x3c
c69d7c24 abb0e079 9e304008 00000000 00000000 dxgmms1!VIDMM_GLOBAL::PinOneAllocation+0x31
c69d7c38 abaf13ee d1672ee8 00000000 00000000 dxgmms1!VIDMM_GLOBAL::PinAllocation+0x19
c69d7c4c abaa3c49 9fe39000 d1672ee8 00000000 dxgmms1!VidMmPinAllocation+0x16
c69d7c7c abaa42ee 00000000 6d384e51 00dbf2a8 dxgkrnl!DXGDEVICE::PinPrimaryAllocations+0x10e
c69d7d18 b96d2444 00dbf2a8 00dbf280 c69d7d34 dxgkrnl!DxgkSetDisplayMode+0x64c
c69d7d28 e3c498ba 00dbf2a8 00dbf2d8 77867094 win32k!NtGdiDdDDISetDisplayMode+0x14
c69d7d28 77867094 00dbf2a8 00dbf2d8 77867094 nt!KiFastCallEntry+0x12a
WARNING: Frame IP not in any known module. Following frames may be wrong.
00dbf2d8 00000000 00000000 00000000 00000000 0x77867094
STACK_COMMAND: kb
FOLLOWUP_IP:
SYMBOL_STACK_INDEX: 0
SYMBOL_NAME: dxgmms1!VIDMM_SEGMENT::TrimAllProcesses+10b
FOLLOWUP_NAME: MachineOwner
MODULE_NAME: dxgmms1
IMAGE_NAME: dxgmms1.sys
DEBUG_FLR_IMAGE_TIMESTAMP: 5164d8b5
FAILURE_BUCKET_ID: 0x8E_dxgmms1!VIDMM_SEGMENT::TrimAllProcesses+10b
Das sieht jetzt auch wieder nach Grafikkarte aus.
Welche Treiberversion (Grafik) ist installiert? Schon andere (neueren, oder älteren) Grafiktreiber getestet?
Hast du die Möglichkeit eine andere Grafikkarte zu testen (von einem anderen Rechner, einem Bekannten)?
Wenn nicht, könntest du auch testweise die Taktraten der Grafikkarte (3D Last) absenken und testen, ob das Problem bleibt. Das Absenken der Taktraten kann über den CCC oder mittels Afterburner erfolgen.
Poste bitte noch mal einen aktuellen (nach dem Bios Update) Screenshot von CPU-Z -> Reiter Memory.
Für die Grafikkarte ist die neueste Treiberversion installiert. Mit einer älteren Version trat das Problem ebenfalls auf.
Eine andere Grafikkarte habe ich im Moment leider nicht zur Verfügung. Auf welche Taktraten soll ich die Grafikkarte denn senken?
Zur Zeit läuft die GPU mit 870 MHz und der Speicher mit 1050 MHz.
hi
habe auch seit paar tagen immer weider bluescreens.
hier mal das ergebnis vom debugger tool
WHEA_UNCORRECTABLE_ERROR (124)
A fatal hardware error has occurred. Parameter 1 identifies the type of error
source that reported the error. Parameter 2 holds the address of the
WHEA_ERROR_RECORD structure that describes the error conditon.
Arguments:
Arg1: 0000000000000000, Machine Check Exception
Arg2: fffffa800798b8f8, Address of the WHEA_ERROR_RECORD structure.
Arg3: 0000000000000000, High order 32-bits of the MCi_STATUS value.
Arg4: 0000000000000000, Low order 32-bits of the MCi_STATUS value.
Debugging Details:
BUGCHECK_STR: 0x124_AuthenticAMD
PROCESS_NAME: System
CURRENT_IRQL: 0
STACK_TEXT:
fffff880`031a86f0 fffff800`030c9ca9 : fffffa80`0798b8d0 fffffa80`06ab8040 00000000`0000000f 00000000`00000000 : nt!WheapCreateLiveTriageDump+0x6c
fffff880`031a8c10 fffff800`02faae87 : fffffa80`0798b8d0 fffff800`030242d8 fffffa80`06ab8040 00000000`00000000 : nt!WheapCreateTriageDumpFromPreviousSession+0x49
fffff880`031a8c40 fffff800`02f12285 : fffff800`03085ae0 00000000`00000001 fffffa80`0797d820 fffffa80`06ab8040 : nt!WheapProcessWorkQueueItem+0x57
fffff880`031a8c80 fffff800`02e88251 : fffff880`01103e00 fffff800`02f12260 fffffa80`06ab8000 00000000`00000000 : nt!WheapWorkQueueWorkerRoutine+0x25
fffff880`031a8cb0 fffff800`0311cede : 00000000`00000000 fffffa80`06ab8040 00000000`00000080 fffffa80`06a1d040 : nt!ExpWorkerThread+0x111
fffff880`031a8d40 fffff800`02e6f906 : fffff880`02f64180 fffffa80`06ab8040 fffff880`02f6efc0 00000000`00000000 : nt!PspSystemThreadStartup+0x5a
fffff880`031a8d80 00000000`00000000 : fffff880`031a9000 fffff880`031a3000 fffff880`03d06740 00000000`00000000 : nt!KiStartSystemThread+0x16
STACK_COMMAND: kb
MODULE_NAME: AuthenticAMD
IMAGE_NAME: AuthenticAMD
DEBUG_FLR_IMAGE_TIMESTAMP: 0
FAILURE_BUCKET_ID: X64_0x124_AuthenticAMD_PROCESSOR_BUS_PRV
und direkt ein screen vom cpu z
bilderhoster.net - cpuZ.jpg - Bilder hochladen
hatte vor 2 tagen sogar das problem das die win7 installation nicht mehr erkiennt wurde nach einem bluescreen.
daher neu aufgesetzt auf einer neuen hdd.
was könnte der fehler sein?
schonmal im vorraus vielen lieben dank für die mühen
lg timo
Hast du die CPU Einstellungen im Bios verändert (übertaktet oder undervoltet)?
Ist es immer der gleiche Stop 0x124 Fehler, der bei einem Bluescreen angezeigt wird?
Bei welchen Gelegenheiten tritt das Problem auf? Nur unter Last (z.B. beim zocken), oder auch wenn nichts am PC gemacht wird?
Lade die Dump Datei bitte mal hier hoch (vorher mit WinZIP einpacken).
immer der gleiche Fehler.
Im Bios habe ich nix übertaktet oder sonst was.
im grunde sind da alles default einstellungen.
beim starten des rechners zeigt das asus startmenu lediglich an "4 Cores are activatet"
auftreten tut der Fehler im grunde bei jeder gelegenheit.
z.b. wenn ich nur nen browser auf habe und 2-3 tabs offen habe.
oder wenn ich nur im teamspeak am reden bin z.b.
im anhang mal 4 dumb dateien. aber wenn ich das richtig gesehen habe ist es immer die gleiche meldung gewesen nach dem neustart.
danke dir
Die Dumps schaue ich mir heute Abend näher an.
Die Bluescreens treten aber nicht zufällig seit der Installation des (zur Zeit) aktuellsten Grafikkartentreibers auf?
Welche Treiberversion ist denn installiert?
Leider bin ich noch nicht zu der Auswertung gekommen, bitte noch um etwas geduld.
schon der 320.18 vom 23.05.
aber die bluescreens tauchten erst einige tage später auf (meine ich)
ich kann ja mal den vorletzen installieren und das im auge behalten
Den 320er würde ich auf jeden Fall wieder deinstallieren, um sicher zu gehen, dass es nicht daran liegt (wurde von einigen schon negatives berichtet; auch wenn das natürlich nicht generell für alle gilt).
Edit:
Die Auswertung der Dumps ergibt einen Bus-Fehler. Gut möglich, dass dieser durch den Grafiktreiber verursacht wird.
Dein X4 Prozessor ist ein echter 4-Kerner, oder ein 2-3 Kerner, der freigeschaltet wurde?
Common Platform Error Record @ fffffa80079818f8
Record Id : 01ce64ed4c0f0aa1
Severity : Fatal (1)
Length : 928
Creator : Microsoft
Notify Type : Machine Check Exception
Timestamp : 6/9/2013 8:42:47 (UTC)
Flags : 0x00000002 PreviousError
Section 0 : Processor Generic
Descriptor @ fffffa8007981978
Section @ fffffa8007981a50
Offset : 344
Length : 192
Flags : 0x00000001 Primary
Severity : Fatal
Proc. Type : x86/x64
Instr. Set : x64
Error Type : BUS error
Operation : Generic
Flags : 0x00
Level : 3
CPU Version : 0x0000000000100f43
Processor ID : 0x0000000000000000
phenom 2 x4 965
also nen richtiger denk ich.
hab schon gelesen das asus 4 cores blakeks könbnte ich im bios deaktivieren da es kein unterschied machen würde.
hab den treiber von märz 13 mal installiert.
beobachte das ganze mal.
habe auhc nebenbei von den "problemen" des neuen treibers gelsesn. vor allem traten die bluescreens im browser auf.
evtl liegt es wirklich "nur" daran
Guten Morgen,
danke für die Anleitung des "debugging tools" selbst als Laie, wie ich kommt man damit gut zurecht.
Ich hoffe das hier alle einfach so posten können, auch wenn ich nicht wirklich zur Community gehöre.
Ich habe seit 1 1/2 Wochen regelmäßig "blue screens" bzw. stop-Fehler auf meinem Dell XPS Desktop (gute 4 Jahre alte, WIN7 (64 bit)).
Laut google soll ein Ram kaputt sein, allerdings kommen die "blue screens bzw. crashs" einfach so oder beim zocken. Manchmal läuft das ganze System auch über Stunden völlig stabil.
Ich füge nun das Ergebniss des "debugging programs" bei :
Microsoft (R) Windows Debugger Version 6.2.9200.20512 AMD64
Loading Dump File [C:\Windows\MEMORY.DMP]
Kernel Summary Dump File: Only kernel address space is available
Symbol search path is: SRV*c:\symbols*http://msdl.microsoft.com/download/symbols
Windows 7 Kernel Version 7601 (Service Pack 1) MP (8 procs) Free x64
Built by: 7601.18113.amd64fre.win7sp1_gdr.130318-1533
Machine Name:
Kernel base = 0xfffff800`02e53000 PsLoadedModuleList = 0xfffff800`03096670
Debug session time: Sat Jun 29 09:54:19.703 2013 (UTC + 2:00)
System Uptime: 0 days 0:03:59.702
BugCheck D1, {ffffe4802e0af774, 2, 0, fffff880063b816b}
*** ERROR: Symbol file could not be found. Defaulted to export symbols for nvlddmkm.sys -
Probably caused by : dxgmms1.sys ( dxgmms1!VidSchiProcessDpcVSyncCookie+307 )
7: kd> !analyze -v
DRIVER_IRQL_NOT_LESS_OR_EQUAL (d1)
An attempt was made to access a pageable (or completely invalid) address at an
interrupt request level (IRQL) that is too high. This is usually
caused by drivers using improper addresses.
If kernel debugger is available get stack backtrace.
Arguments:
Arg1: ffffe4802e0af774, memory referenced
Arg2: 0000000000000002, IRQL
Arg3: 0000000000000000, value 0 = read operation, 1 = write operation
Arg4: fffff880063b816b, address which referenced memory
Debugging Details:
READ_ADDRESS: ffffe4802e0af774
CURRENT_IRQL: 2
FAULTING_IP:
fffff880`063b816b 4283bcb6c402000000 cmp dword ptr [rsi+r14*4+2C4h],0
BUGCHECK_STR: 0xD1
TAG_NOT_DEFINED_c000000f: FFFFF880033B5FB0
TRAP_FRAME: fffff880033ae760 -- (.trap 0xfffff880033ae760)
NOTE: The trap frame does not contain all registers.
Some register values may be zeroed or incorrect.
rax=0000000000003c05 rbx=0000000000000000 rcx=000000000000a5e0
rdx=0000000000000017 rsi=0000000000000000 rdi=0000000000000000
rip=fffff880063b816b rsp=fffff880033ae8f0 rbp=fffffa80089809a0
r8=000000000000b81c r9=0000000000000000 r10=fffffa800888ebd0
r11=fffff880033ae9a8 r12=0000000000000000 r13=0000000000000000
r14=0000000000000000 r15=0000000000000000
iopl=0 nv up ei pl zr na po nc
dxgmms1!VidSchiProcessDpcVSyncCookie+0x307:
fffff880`063b816b 4283bcb6c402000000 cmp dword ptr [rsi+r14*4+2C4h],0 ds:00000000`000002c4=????????
LAST_CONTROL_TRANSFER: from fffff80002ec81a9 to fffff80002ec8c00
STACK_TEXT:
fffff880`033ae618 fffff800`02ec81a9 : 00000000`0000000a ffffe480`2e0af774 00000000`00000002 00000000`00000000 : nt!KeBugCheckEx
fffff880`033ae620 fffff800`02ec6e20 : fffff880`033ae7a0 fffff880`05a38fba fffffa80`054f9000 fffffa80`0888e410 : nt!KiBugCheckDispatch+0x69
fffff880`033ae760 fffff880`063b816b : fffff880`033ae930 00000000`00000000 fffffa80`0897f000 fffff880`059f390c : nt!KiPageFault+0x260
fffff880`033ae8f0 fffff880`063b7cf4 : 00000100`00000000 00000000`00000017 fffff880`00000000 00000000`00000000 : dxgmms1!VidSchiProcessDpcVSyncCookie+0x307
fffff880`033ae9b0 fffff880`063b7c58 : 00000000`00000000 fffffa80`0888e410 fffff880`033aeb00 00000000`00000000 : dxgmms1!VidSchDdiNotifyDpcWorker+0x80
fffff880`033aea00 fffff880`062be1cf : fffffa80`07eaa480 00000000`00000000 00000000`00000000 00000000`00000000 : dxgmms1!VidSchDdiNotifyDpc+0x94
fffff880`033aea50 fffff880`058c6bdf : fffffa80`07ec7000 fffffa80`07ec7000 00000000`00000000 00000000`00000000 : dxgkrnl!DxgNotifyDpcCB+0x77
fffff880`033aea80 fffff880`058c6e12 : fffff880`058c6b76 fffffa80`07ec7000 fffffa80`08897000 00001f80`00000000 : nvlddmkm+0xb4bdf
fffff880`033aeb10 fffff880`058c71c6 : fffff880`058c6dae fffffa80`00000000 fffffa80`07ec7000 fffffa80`07ec7000 : nvlddmkm+0xb4e12
fffff880`033aeba0 fffff880`05923541 : fffff880`058c6fec fffff880`058c705e fffffa80`07ec7000 fffffa80`07ec70c8 : nvlddmkm+0xb51c6
fffff880`033aec40 fffff800`02ed32fc : fffff880`059234dd fffff880`03386180 00000000`00000000 00000000`000000fe : nvlddmkm+0x111541
fffff880`033aecd0 fffff800`02ec090a : fffff880`03386180 fffff880`033910c0 00000000`00000000 fffff880`05923868 : nt!KiRetireDpcList+0x1bc
fffff880`033aed80 00000000`00000000 : fffff880`033af000 fffff880`033a9000 fffff880`033aed40 00000000`00000000 : nt!KiIdleLoop+0x5a
STACK_COMMAND: kb
FOLLOWUP_IP:
SYMBOL_STACK_INDEX: 3
SYMBOL_NAME: dxgmms1!VidSchiProcessDpcVSyncCookie+307
DEBUG_FLR_IMAGE_TIMESTAMP: 5164dc13
FAILURE_BUCKET_ID: X64_0xD1_dxgmms1!VidSchiProcessDpcVSyncCookie+307
Vorab bereits vielen Dank für eure Hilfe !
Beste Grüße
Matze
Hi, klar geht das ;)
ist es immer der Stop 0xD1 Fehler, der bei einem Bluescreen auftritt? (Falls du das noch weist, nachvollziehen lässt sich das nur schwer, da die Dumps bei dem vollständigen Kernelspeicherabbild standardmäßig überschrieben werden (Loading Dump File [C:\Windows\MEMORY.DMP])
Wenn es immer der 0xD1 Fehler ist, wäre der Hauptverdächtige zunächst ein fehlerhafter Gerätetreiber.
STACK_TEXT:
Da bei dir ebenfalls beim Absturz der Nvidia-Grafikkartentreiber involviert ist, auch hier die Frage, welche Treiberversion installiert ist (zufällig die 320.18 Version?).
Poste bitte auch noch ein paar Screenshots von CPU-Z (Reiter Mainboard, CPU, Memory und SPD) und einen von GPU-Z, damit wir eine kleine Übersicht über dein System bekommen.
Hallo Simpel,
vom Gefühl würde ich sagen, dass es immer der gleiche Fehler ist, wobei ich nicht bei jedem Crash einen "blue screen" kriege.
Manchmal hängt er sich auf oder macht direkt einen Neustart ohne "blue screen".
Ich kanns nicht 100 % sagen, aber nach meinen Gefühl tretten die crash seit einem Windows Update auf.
Ich habe die Bilder/Daten von den beiden Programmen angehänt als PNG-Datei, ist das okay für euch oder möchtet ihr die in einem anderen Format haben ?
Die Text-Datei die man sich von CPU-Z erstellen lassen kann lässt sich leider nicht hochladen, da meckert mein Firefox.
Bei meiner Grafikkarte steht, dass es Version "311.06" ist !
Danke das ihr euch Zeit nehmt :)
Beste Grüße
Matze
