yummycandy
Jatzt offiziell die 2. Customkarte: ASUS Launches ROG Strix RX Vega 64 and 56 OC Edition Graphics Cards | PC Perspective
2 1/2 Slot Design +
Edit:
Hier noch eine Quelle: ASUS ROG Strix RX Vega 64 and 56 OC Cards Incoming | eTeknix
Und die Daten dazu:
2 1/2 Slot Design +
The cards have two 8-pin PCI-E power connectors feeding ASUS' Super Alloy Power II VRMs. Other connectors include hybrid fan headers for system fans and an Aurora Sync RGB LED header. Display outputs are "VR Ready" and include two HDMI, two DisplayPort, and a single DVI output.
While ASUS has not yet revealed clockspeeds on the RX Vega 56 card, eTeknix has gotten their hands on the ROG Strix RX Vega 64 graphics card and figured out the clocks for that card. Specifically, the Vega 64 card clocks its 4096 GPU cores at 1298 MHz base and 1590 MHz boost. The site further lists the memory clockspeed at 945 MHz which doesn't appear to be overclocked as it matches the referece Vega 64 HBM2 clocks of 1890 MHz. Users can use the GPU Tweak II software to push the card further on their own though.
Edit:
Und die Daten dazu:
Graphics Engine: AMD Radeon RX VEGA 64
OpenGL: OpenGL®4.5
Video Memory: 8GB HBM2
Engine Clock: 1590 MHz
Memory Clock: 945 MHz
Stream Processors: 4096
Memory Interface: 2048-bit
Resolution:
Digital Max Resolution: 7680×4320
Interface:
DVI Output: Yes x 1 (Native) (DVI-D)
HDMI Output: Yes x 2 (Native) (HDMI 2.0)
Display Port: Yes x 2 (Native) (Regular DP)
HDCP Support: Yes
Power Connectors: 2 x 8-pin
Accessories
CD x 1
Quick Guide x 1
ROG Velcro Hook & Loop x 1
Software:
ASUS GPU Tweak II & Driver
Aura (Graphics Card) Utility
Dimensions:
11.73 ” x 5.47 ” x 2.07 ” Inch
29.8 x 13.9 x5.25 Centimetre
Features
In addition, both cards boast the following features:
MaxContact Technology that is 2X more contact with GPU for improved thermal transfer.
Patented Wing-Blade IP5X-Certified Fans for maximum airflow and longer fan lifespan.
ASUS FanConnect II equips with hybrid controlled fan headers for optimal system cooling.
Industry Only Auto-Extreme Technology with Super Alloy Power II delivers premium quality and best reliability.
ASUS Aura Sync RGB LED synchronization enables a gaming system personalization.
VR-friendly HDMI ports let you enjoy VR experiences anytime without having to swap cables.
GPU Tweak II with XSplit Gamecaster provides intuitive performance tweaking and real-time streaming.
Graphics Engine: AMD Radeon RX VEGA 56
Bus Standard: PCI Express 3.0
Interface:
HDCP Support: Yes
Accessories:
CD x 1
Quick Guide x 1
Power cable x 1
ROG Velcro Hook & Loop x 2
Software: ASUS GPU Tweak II & Driver
nur meine Meinung
