Duvar
Kokü-Junkie (m/w)
Weiß nicht, ob ihr es schon gelesen habt. In der Kommentarsektion drüben bei Videocardz, behauptet ein user, dass folgender chinesischer Typ http://tieba.baidu.com/p/4635395755, welcher Amds chinesischem PR team angehören soll, den bereits verlinkten post verfasst haben soll. Darin erzählt er über die 480 und dessen Pro und Contra Facetten. --->
Goods
1. A new control center for RX series card. You can customize clockspeed, voltage, power limit, performance, and fanspeed. This tool still need some improvements but it's getting there.
2. Three modes available for RX series card, that is Default mode (Boost), Fixed mode (Base), and OC mode. Card doesn't stutter or throttle in game under Fixed mode.
3. PCB, VRM etc of reference card are made of high quality materials, at least when compared to reference version of 1070.
Bads
1. No LED light and no backplate.
2. Heatsink is bad, no heatpipe.
3. Temperature. One of the worst ref card in the history of AMD/Ati. Only Fixed mode won't throttle. When playing games under fixed mode, card is 100% under load without throttling IF you manually set the fan profile to 4000rpm and the temperature is around 82°C. But if you leave the fan profile at default, when gaming it will go all the way up to 100°C but due to temperature wall of 92°C, the clockspeed will throttle down in order to reduce temp.
4. Noise. Under 2000rpm, very silent. 2000-3500 is perfect balance between performance and noise. 3500-4000 is not acceptable, unless you're wearing a headphone. 4000-5200rpm is like helicopter taking off.
5. BIOS and drivers: Default fan profile needs some tweaking, some minor bugs.
Hoffe das englische ist kein Problem, ansonsten lasst es euch mal übersetzen.
Edit: Mal schnell den google Übersetzer drüber laufen lassen, welcher natürlich sehr oft merkwürdige Übersetzungen an den Tag legt^^
Pro
1. Eine neue Schaltzentrale für RX-Serie-Karte. Sie können Taktgeschwindigkeit, Spannung, Leistungsbegrenzung, Leistung und Ventilatorstufe anpassen. Dieses Tool noch einige Verbesserungen brauchen, aber es ist da immer.
2. Drei Modi für die RX-Serie-Karte zur Verfügung, ist, dass Standard-Modus (Boost), Fest Modus (Basis) und OC-Modus. Die Karte funktioniert nicht stottern oder drosseln im Spiel unter Fixed-Modus.
3. PCB, VRM etc Referenzkarte sind aus hochwertigen Materialien gefertigt, zumindest im Vergleich zu Referenzversion von 1070.
Kontra
1. Keine LED-Licht und keine Rückplatte.
2. Heatsink ist schlecht, keine Heatpipe.
3. Temperatur. Eine der schlimmsten ref Karte in der Geschichte der AMD / Ati. Nur Fixed-Modus wird nicht drosseln. Wenn Spiele unter festgelegten Modus zu spielen, ist Karte 100% unter Last ohne Drosselung Wenn Sie manuell die Lüfterprofil auf 4000rpm und die Temperatur liegt bei etwa 82 ° C eingestellt. Aber wenn Sie das Lüfterprofil auf Vorgabe, beim Spielen wird es bis zu 100 ° C den ganzen Weg gehen, aber auf Grund von Temperaturwand von 92 ° C, wird die Taktrate um drosseln zu Temperatur reduzieren.
4. Lärm. Unter 2000rpm, sehr leise. 2000-3500 ist perfekte Balance zwischen Leistung und Lärm. 3500-4000 ist nicht akzeptabel, wenn Sie einen Kopfhörer beim Tragen. 4000-5200rpm ist wie Hubschrauber auszuziehen.
5. BIOS und Treiber: Standard Lüfterprofil braucht einige Optimierungen, einige kleinere Fehler.
Goods
Bads
Pro
Kontra
