Wie findet ihr dieser Konfiguration? Habt ihr Verbersserungsvorschlaege?
qnur
What do you guys think about the following config?
Knowing that I am not a heavy Gamer, I enjoy FPS Action games mostly.But I play occassionally, like 2 intense months of Gaming a year and then 2 hrs a week or less, I also own a PS3, so not tied to the PC only.
I do as a hobby Digital Painting and 3D Modelling, ZBrush, Photoshop CS5, AutoCad,Maya, 3d max.
Visual Studio, Eclipse, Android programming a lil bit.(For the last three the config is too good I think)
But this is pretty much what I do with a PC and I want to learn programming using CUDA as next.
Core i5 3570 3.4Ghz 6mbL3
8GB Crosair Venegeance DDR3 1600 CL9
Samsung SSD 120GB Evo
WD Black 500 GB Sata3 64Mb Cache
Liteon BluRay/DVD 33 Eur(viele beschweren sich davon, werde vllt dannn nur ein DVD LW anstatt ein teuerer BD LW)
ASUS GTX670-DCMOC-2GD5 2GB GDDR5 OR a GTX660ti or no ti?
MB: Gigabyte GA-Z77-D3H / or MSI Z77A-G45 / ASRock Z77 Extreme4
I need help on the choice of the Motherboard, I prefer not to pay more than 100 Eur. Are they any good?
Also, do I need a non-CPU Cooler, if yes which one would be good for such a config, with limited budget.
And for the Power Supply is 550W enough? which brand should I get, how much should I invest concrete suggestion are very welcome?
Now for the Graphics Card, I dont know what to choose, I want the PC to be usable for the next 7 yrs at least, so If I take the GTX660 will it last that long.
I dont expect to play the games of the year 2017, but for the rest of the tasks, will it be good?
Any ideas what Case I should get too? considering a limited budget at the moment.
I am expecting to pay around 900 Euros, more or less depending on the choice of the Graphics (from 660 to 670 there is a 40 Eur difference), may be I can save on the SSD and get a 64 one?
I know you guys thing I am must be very cheap.
Thanks for your Help
Ihr konnt gerne auf Deutsch schreiben, mein Deutsch ist aber nicht so gut zu schreiben.
Both configurations are very good, but i'd prefer the last one, because the cpu is better. The only thing i would change in this configuration, is the graphics card, because a gtx 670 is a bit faster and cheaper than the gtx 760
