Hello everyone, I am building a new PC and need advice. I will play and want to get into stable diffusion/AI as well.
Games I know I'll buy: Starfield ($100 game comes with AMD) Red Dead Redemption 2 MW2 Fortnite
As for the AMD, I know it has better raster performance and 16GB of VRAM.
Nvidia is considered better https://9apps.ooo/ for AI, but only has 12GB VRAM and less raw power
Both are similar prices (considering the Starfield bundle, you will technically be spending less on AMD)
I'm not sure which way to go. My total budget for the entire build is $1,500, so I'm guessing around $600 for the GPU is reasonable. Do you all think I should increase my GPU budget? Right now $600 is 40% of the budget.
