WaKü i7 8700K und RTX 2080Ti
darkEmperor
Hallo Leute
Ich wollte euch bitten das ihr mein Warenkorb anschaut und mir Tipps gibt was noch fehlt oder was ich austauschen soll.
Das es eine Externe Lösung sein soll hab ich mich schon entschieden.
Was soll gekühlt werden:
- Intel Core I7 8700K
- Gigabyte RTX 2080 Ti Windforce OC 11G REV 1.0
Warenkorb:
HEATKILLER® IV for RTX 2080 Ti - ACRYL Ni-Bl: https://sage-shop.com/epages/Waterc...?ObjectPath=/Shops/WatercooleK/Products/15622
HEATKILLER® IV eBC - Backplate: https://sage-shop.com/epages/Waterc...?ObjectPath=/Shops/WatercooleK/Products/16066
HEATKILLER® IV PRO (INTEL processor) BLACK COPPER: https://sage-shop.com/epages/Waterc...?ObjectPath=/Shops/WatercooleK/Products/18034
HEATKILLER® IV Backplate INTEL: https://sage-shop.com/epages/Waterc...?ObjectPath=/Shops/WatercooleK/Products/10013
MO-RA3 420 LT: https://sage-shop.com/epages/Waterc...?ObjectPath=/Shops/WatercooleK/Products/25100
Paar MO-RA3 Standfüsse: https://sage-shop.com/epages/Waterc...?ObjectPath=/Shops/WatercooleK/Products/22200
9x Yate Loon 140mm D14SM-12: https://sage-shop.com/epages/Waterc...?ObjectPath=/Shops/WatercooleK/Products/60151
1x HEATKILLER® D5-TOP: https://sage-shop.com/epages/Waterc...?ObjectPath=/Shops/WatercooleK/Products/30009
HEATKILLER® Tube 200: https://sage-shop.com/epages/Waterc...?ObjectPath=/Shops/WatercooleK/Products/30202
Barrow Compression Fitting 13/10 : https://sage-shop.com/epages/Waterc...?ObjectPath=/Shops/WatercooleK/Products/50316
Schnellverbinder Koolance QD3 - 13/10mm: https://sage-shop.com/epages/Waterc...?ObjectPath=/Shops/WatercooleK/Products/50705
Schnellverbinder Koolance QD3 - 13/10mm: https://sage-shop.com/epages/Waterc...?ObjectPath=/Shops/WatercooleK/Products/50704
Schlauch Mayhems Ultra Clear 13/10mm: https://sage-shop.com/epages/Waterc...?ObjectPath=/Shops/WatercooleK/Products/50300
Thermal Grizzly - Kryonaut - Wärmeleitpaste 12,5 W/mk: https://sage-shop.com/epages/Waterc...?ObjectPath=/Shops/WatercooleK/Products/60505
unbenannt-png.1037819
Schonmal besten dank für eure Tipps
Gruss darkEmperor
AW: WaKü I7 8700K und Rtx 2080 Ti
Das sieht soweit erstmal sehr gut aus, ein paar Anregungen hätte ich noch.
1. Deine Lüfter sind 3pin, bedenke, dass deine Steuerung für 9 Lüfter etwas mehr Leistung braucht. Auf voller Geschwindigkeit würde ich sie jedenfalls nicht laufen lassen, das wäre mir definitiv zu laut. Über die eigentlich Lüfterqualität kann ich erstmal nichts sagen, ich hab sie nie selber in der Hand gehabt. Von den 3pin Splittern brauchst du auch mehr.
2. Pumpe und Agb getrennt zu haben kann man machen, es kann bei der Entkopplung der Pumpe helfen, aber in dem Kreislauf kannst du die Pumpe auch auf lautlos drosseln. Die bessere Idee wäre hier, die D5 Version des Heatkillers zu kaufen, die D5 darunter und alles mit Watercools Montagematerial an den den Mora. Das Montagematerial brauchst du extra, mit dem beiliegenden gehts nicht.
3. Anschlüsse und Schlauch sind zwar gut, 13/10 ist aber weniger knickresistent als 16/10, gerade bei einer externen Lösung so eine Sache. Zudem kannst du dank externer Lösung mit genügend Schlauch den Mora auch in einiger Entfernung aufstellen und hörst damit deutlich weniger, als wenn das Teil direkt neben dir steht.
4. Schnelltrenner sind ne tolle Sache um alles zu transportieren, wenn man das System bewegt, z.B. zu einer Lan, sonst eher weniger nötig. Zudem wäre ne Gehäusedurchführung sinnvoll, nicht dass noch ungewollt Zug auf die Komponenten kommt.
Kann man so machen, ich frage mich allerdings warum du die ersatzpads benötigst für die 2080 Ti und wofür du die Backplate benötigst beim CPU Kühler. Geht auch ohne :)
Ansonsten kannste das so machen, auch wenn mir persönlich der Mora überhaupt nicht gefällt und du je nach Gehäuse das ganze auch Intern gut kühlen könntest. Aber das entscheidest natürlich du
@Sinusspass
Der/die Heattube aushalb vom Gehäuse ist doch ein optisches Verbrechen:)
@TE
Welches Gehäuse hast du?
Die Lüfter kenne ich nicht, daher empfehle ich die mal die hier, die gehen per PWM auf 200rpm runter bie den 3Pin weiß ich das nicht.
P14 PWM PST | Pressure-optimised 140 mm PWM PST Case Fan | ARCTICP14 PWM PST | 140 mm PWM PST Luefter optimiert fuer statischen Druck | ARCTIC
Du gibst sehr viel Geld, da ist dann bestimmt auch noch Geld für eine gescheite Lüftersteuerung mit Wassertemperatursensor drin. (Aquacomputer Quadro oder Aquero + Sensor.
Sonst gute Auswahl.
@ Pelle: Da würde ich an sich sogar mitgehen, aber ich persönlich finde, externe Radiatoren generell sind bereits ein optisches Verbrechen, ihre Leistung ist allerdings nicht von der Hand zu weisen. Wenn man schon extern macht, dann auch richtig, nämlich weit weg mit allen beweglichen Teilen.
Eine eigenständige Steuerung ist bei ausreichender Fläche nicht dringend nötig, die Lüfter fix auf 5 oder 7v zu stellen mittels Lötkolben am Molexstecker und Lüfteradapter funktioniert genauso gut, wenn die Lüfter mit diesen Spannungen anlaufen und die Lautstärke passt.
Danke schonmal für eure Tipps. Ja extern ist nicht so schön aber ich will halt Leistung das ich noch was übertakten kann.
Overclockingpotenzial bekommt man durch eine Wasserkühlung kaum dazu, sofern die Komponenten vorher nicht schon nahe dem thermischen Limit waren, sodass sie gedrosselt haben. Da würde ich auch nicht allzu viel erwarten, im besten Fall 50 Mhz, wahrscheinlich eher 25 Mhz durch bessere Temperaturen. Der entscheidende Vorteil der Wasserkühlung ist die geringe bis nicht vorhandene Lautstärke. Gerade ein Mora hat eine derart hohe Kühlleistung, dass man problemlos niedrige Lüfterdrehzahlen nutzen kann und das Wasser trotzdem nicht warm wird. Abgesehen davon macht das Basteln ziemlich viel Spaß (gut, am dritten Tag in Folge nicht mehr, aber das bei dir ist in paar Stunden erledigt).
vielleicht solltest du vorher noch wissen das im Jahre 2019 eine Wasserkühlung nicht wirklich mehr bringt als eine Luftkühlung. Das ist oftmals nur Optik und stille. Es gibt inzwischen super gute Luftkühler. Ein Noctua Nh-D15 würde deine CPU sicherlich genausogut kühlen. Ich z.b. habe meine Custom Wasserkühlung nur gemacht weil ich die 2080 Ti nichtmehr ertragen hab von Temperatur und Lautstärke her und der Morpheus war mir einfach zu hässlich in meinem sichtbaren Gehäuse.
Leute, wie wäre es mal, wenn ihr bei diesem Thema bleibt?
Hallo Leute
Es wird mittlerweile jeder zweite Thread zugemüllt und zu einem Off-Topic gemacht. Vergleicht eure Sch...länge woanders. Denn das hilft dem TE sicher nicht!
@darkEmperor:
Ich würde dir auch empfehlen einen Adapter und dazu 20cm Lüfter für dein MoRa zu nehmen. Dann noch die "Quadro" von AquaComputer und noch paar Temp-Sensoren. Du kannst alles an Quadro anschließen und über Aquasuite auslesen und steuern. Beim Schlauch 16/10 nehmen. Um MoRa mit meinem Gehäuse zu verbinden habe ich diese Gehäusedurchführung verwendet:
Bitspower Gehaeusedurchfuehrung IG 1/4 Zoll auf IG 1/4 Z…
Schwachsinn! Meinen 8700K konnte nur deswegen nicht dauerhaft mit 5.0...5.2GHz laufen lassen mit Lüftkühlung (Thermalright Silver Arrow SB-E), weil ich ihn nicht kühl bekommen habe. Bei 4.7GHz war Schluss. Durch die WaKü habe ich meine Max-Temps um 18°C reduziert und kann jetzt enspannt die CPU mit 5.0GHz laufen lassen. Vom thermischen Limit bin ich noch einiges entfernt!
Totaler Quatsch den du da schreibst, das würde ein guter Lüftkühler genauso hinbekommen. Aber der TE will ne Waserkühlung beratung also bekommt er diese :)
Jup, so siehts aus... TE, dein Warenkorb ist ok.
Nö, Jhonny das was du schreibst ist (um deine Worte zu benutzen) Totaler Quatsch!
Soll ich es dir auch in einer anderen Sprache erklären? Denn Deutsch verstehst du anscheinend nicht.
wie willste das denn machen? Du kannst doch nur Deutsch. Denkst du wegen dem Satz bist du jetzt im Recht ? Ist doch sowieso völlig Banane. Der TE soll die 800€ ausgeben und freut sich dann über die Leistung seiner Wasserkühlung :)
Der Sinn dieses Forums ist unter anderem Hilfeleistung für diejenigen, die sich wenig oder gar nicht mit dem Thema WaKü auskennen. So erging es mir auch, ich habe mich nach 20 Jahren Luftkühlung entschieden auf WaKü zu wechseln aus 2 Gründen: Niedrigere Temp und höheres OC-Potential. Auf dem Gebiet WaKü bin ich immer noch ein "Anfänger", aus meiner eigenen Erfahrung mit Luft-Kü und WaKü versuche ich jedem hier, so gut ich kann, zu helfen. Und ich bin froh, dass ich zu meiner Zeit hier gut beraten wurde! Wenn ich aber sehe, was für ein Mist hier teilweise aufgetischt wird, kann ich nicht ruhig bleiben.
Also war die Cpu bei 4,7 Ghz bei 95°C+?
Abgesehen davon, es gibt Leute, die ihren 9900k auf 5 Ghz laufen lassen und dabei einen Nh D15 verwenden. Im Zweifel gibt es immer noch 100% Lüfterdrehzahl, da schafft ein Luftkühler so einiges. Und genau hier setzt die Wasserkühlung an, denn derartige Drehzahlen sind nicht schön, und mittels Wasserkühlung gehts nunmal leiser.
Ich sage ja selber, dass es Sinn macht, eine (custom) Wasserkühlung zu verwenden, aber faktisch kann man auch alles mit Luft kühlen, von erträglicher Lautstärke kann dann aber beim besten Willen nicht mehr die Rede sein
Gut, ich habe mal für einen Freund einen Pc mit 8700k (vorerst ungeköpft) und Nh D15 gebaut, lief bei 4,7 Ghz unter Prime mit 180 Watt bzw. 80°C. Leise war er damit zwar nicht wirklich, funktioniert hats schon. Ich vermute eher, bei dir hat die Grafikkarte das Gehäuseinnere gut geheizt, wodurch dann auch der Kühler nicht mehr so gut kühlen konnte.
