Naja, Intels Probleme sind eher hausgemachter Art die man grob mit Management-Versagen (zu viel auf einmal verlangt von 'nem zu kleinen, monolithischen Team) zusammen fassen kann. Gab da erst letztens einen recht aufschlussreichen Post zu auf 'nem einschlägigen Image-Board der das sehr schön verdeutlicht hat, TSMC hat ja offenbar diese Probleme nicht:
I've been saying it for over a year, Intel's 10nm wound up as a tangled up experiment. In short, Intel management wanted such a massive shrink that would ensure their domination of the process market and attract customers to their fabs. The load combined with budget cuts and layoffs (and their other stunts) in the manufacturing group killed 10nm. In Long: There were three primary mistakes Intel made, Cobalt Metal Layers, Contact Over Active Gate (COAG), and plain ole hubris. In 2013, Intel was late. The Self Aligned Dual Patterning (SADP) required by the feature size of 14nm had a bad learning curve, yields were very bad at first, to the point where Broadwell was mostly a paper launch in 2014, two quarters behind schedule. This was not a critical problem and it was fixed gradually, such that Skylake was not delayed. Behind the scenes though, the long ramp time created a problem. As Intel has only a single (large) process development team, not leapfrogging teams, the 14nm delay led to a delay of 10nm.
The specifications it would shoot for were not set in stone until 2014. Managers gave them a difficult task. To win mobile they had to be power efficient and dense. To win desktop they needed to be fast. To win servers they needed excellent yields. And above all they needed to be better than the competition to attract new customers. In order to reach the goals set by management, the manufacturing group had to get creative. To that end a number of techniques never put into a production process before were adopted. COAG, SAQP, Cobalt, Ruthenium Liners, Tungsten contacts, single dummy gate, etc. This push is directly what led to the death of the process. Of those, only really COAG and Cobalt are causing the issues. I'll go into the specific problems next. If anyone is to blame, its the management, and their firing of the CEO with a bullshit reason shows the board will not accept responsibility for the companies failings. They will not come clean in the foreseeable future. Their foundries are virtually dead after all the firings and cost cutting.
The idea with Contact Over Active Gate is that instead of extending a gate such that it connects up with a contact to the side (thus using space on the side), the Contact stretches directly from the metal layer to the gate, rather than laying onto the substrate. This means there is NO room for error on manufacturing. The slightest misalignment leads to fucked contacts. Thermal expansion, micro-vibrations from people walking nearby, changes in air pressure, imagine a cause, and it'll affect yields. I bet you the bloody position of the Moon can affect it. This kills the yields. To hit the targets Intel set, a minimum metal pitch of 36nm was selected. When you have Copper wires on a process they need to have a liner around them, this prevents diffusion, electromigration, and other nasty electrical fun.
But this liner needs to be a certain thickness, so when the overall size of the wire gets smaller, the liner takes up a larger portion of it. Below 40nm it was thought that Cobalt would have superior electrical properties, despite it having a higher bulk electrical resistance. Its far more resistant to electromigration and needs a miniscule barrier to prevent it, while its resistance decreases at a slower rate as the wire size gets smaller. However, Intel overlooked two key problems: ductility/malleability, and thermal conductivity. Even at those tiny levels, Copper wires would be able to handle thermal expansion mechanical loads, bending and stretching ever so slightly as a processor made its rounds. And copper is Very good at transferring heat, letting the lower metal layers sink heat into the upper ones. Meanwhile Cobalt is hilariously brittle and has a sixth the thermal conductivity as Copper.
On operation hot spots start to form, heat can't get away, brittle nature creates microfractures, and higher voltage to cross the fracture boundaries. Means the voltage/frequency curve is hilariously bad. This kills the performance and power usage. So where does it leave us at? 10nm was meant to launch end of 2015, after 14nm this was pushed to 2016. It was Q3 2018 when i originally wrote much of what is outlined here, and the only 10nm chip at that time was a minuscule dual core made in a one-off batch of 100k units that took 6 months to assemble. Yields are sub 1%, the GPU doesn't function, and power usage was higher than 22nm. TSMC and at the time GloFlo were both ramping their 7nm processes, and while they're comparable to the 10nm in density, they actually work. They both are using SAQP for the transistors, but the choice of 40nm metal pitch allowed for SADP for that particular layer. GloFlo was using Copper with a Cobalt/Tantalum liner while TSMC is using straight Copper/Tantalum. Neither screwed with COAG or Single Dummy, but GloFlo was using Cobalt contacts.
TSMC 7nm has been volume production, GloFlo meant enter it in a few months after TSMC initially did, but has since put it on hold indefinitely in favor of pursuing nodes beyond that. Consumer products on both of them meant to enter the market in mid-2019. TSMC did, latter didn't due to aforementioned reasons. Regardless, They're both going to outperform Intel's 10nm. Their manufacturing group failed at all levels. To make matters worse they didn't even bother backporting their improved cores to 14nm. Icelake has been inhouse since early 2017. The design is finalized, they just can't make the damn thing and didn't backport it. Management thought they couldn't fail. It is in my personal opinion that their 10nm process will never be financially viable. They were literally creating 10nm micro housefires that burned their own chips.
Cannonlake is virtually dead. Ice Lake-U and Y (sub 15w mobile dual cores) came out as predicted still in mid-2019. I doubt Ice Lake-S (quads) will see anything beyond a paper launch ala Broadwell quads. Ice Lake-SP is a dead proposition, there's no way they're going to be able to make a server core based off that 10nm. Tiger Lake and Sapphire Rapids? Who the hell knows. Why worry about something that isn't going to happen. Intel's chance lies with 7nm, but people already predicted it won't arrive until 2021 at the earliest. After Cascade Lake is Cooper Lake; Kaby Lake-U is being replaced by Whiskey Lake, which'll be replaced by Comet Lake to run alongside the Ice Lake-U/Y dual cores. Amber Lake will replace Kaby Lake-Y until Ice Lake-Y. All those new code names are 14nm, and all are just tweaked Skylake. Also, The whole 14nm+++++ tripe is meaningless and has been for years. They're standard PDK updates. Everyone in the industry does them. It wasn't until recently that they started being branded, in this case by Intel.
