Treiber fpr igpu lässt sich nicht installieren
nik45
ich wollte die integrierte Graka der i9 10850k nutzen. Im BIOS habe ich VGA detect of auto stehen (geht nur auto oder off). Nun habe ich von der MSI Seite die Treiber heruntergeladen, allerdigns will der die nicht installiren mit dem Error log. Steht der in Konflikt mit der RTX oder was ist das los?
2022/05/27 11:28:41.753|INFO|Logging started on 2022/05/27 11:28:41.716 ||
2022/05/27 11:28:41.771|INFO|Installer version: 1.0.496.0 ||
2022/05/27 11:28:41.771|INFO|The application has been launched with the parameters: NULL ||
2022/05/27 11:28:41.774|INFO|Language of the user interface: [en-US]. ||
2022/05/27 11:28:41.774|INFO|Operating system specification: Microsoft Windows NT 10.0.19042.0 ||
2022/05/27 11:28:41.815|INFO|CPU base clock: 3600Mhz. ||
2022/05/27 11:28:41.815|INFO|Test Signing: OFF. ||
2022/05/27 11:28:41.815|INFO|Windows Media Player status: Installed ||
2022/05/27 11:28:41.953|INFO|Benchmark test result: 99,6452 milliseconds (0,0996452 sec). ||
2022/05/27 11:28:42.918|INFO|No Unknown PCI devices were found. ||
List of Graphics and Other Devices in Device Manager:{
Device detected: NVIDIA GeForce RTX 3090
Version: 30.0.15.1295
Device Instance Path: PCI\VEN_10DE&DEV_2204&SUBSYS_161319DA&REV_A1\4&20DB0AC4&0&0008
Device manufacturer: NVIDIA
2022/05/27 11:28:42.948|WARN|The specified section does not exist. SectionName = "Version". ||
2022/05/27 11:28:43.314|INFO|
Found Graphics and Other devices with matching INF files:
Device
Device name: NVIDIA GeForce RTX 3090
Device instance path: PCI\VEN_10DE&DEV_2204&SUBSYS_161319DA&REV_A1\4&20DB0AC4&0&0008
Matching Driver Store INF: "NULL"
Matching Installer INF: "NULL"
2022/05/27 11:28:43.314|INFO|No Unknown PCI devices were found. ||
2022/05/27 11:28:43.322|INFO|No Intel media devices were found. ||
2022/05/27 11:28:43.322|ERROR|We cannot find any graphics and other devices. ||
2022/05/27 11:28:45.453|ERROR|Could not find driver file. ||
Keine Ahnung, wie das bei Deinem Board und unter WIN 10 oder in 11 ist, bei WIN 7 hatte ich dasselbe Problem mit einem MSI Board. Lösung was, Grafintreiber deinstallieren, Grafikkarte ausbauen, Monitor an Mainboard anschließen, IGP Treiber installieren, Grafikkarte wieder einbauen, Grafikkartentreiber installieren.
Also normalerweise sollte die iGPU von alleine funktionieren, wenn Du den PC ohne dedizierte GPU hochfährst, denn den Treiber dafür solltest Du per Windows Update automatisch verpasst bekommen haben oder er sollte sich spätestens dann automatisch installieren.
Warum genau willst Du die iGPU nutzen, obwohl Du eine Grafikkarte im Rechner hast?
Wenn einfach gingen würde, hätte es mich gewundert.
Den Treiber kannst auch direkt von Intel beziehen. Möglich ist auch mit dem "Intel Treiber- und Support-Assistent", dann wird der Treiber automatisch erkannt und nach Eingabe von dir installiert.
Das hat leider nicht funktioniert. Der installiert zwar etwas und möchte einen restart, aber es tut sichh halt nichts. Vielleicht muss ich tatächlich die RTX ausmontieren...
Ich muss bei mir nichts ausbauen, nur im Bios auf Multimonitor umstellen und dann läuft bei mir die Grafikkarte + Grafikeinheit des Prozessors. Sollte nach dem Umstellen noch kein Treiber installiert sein, dann installiert Windows von sich aus direkt einen und mittels Treiber- und Support-Assistenten wird mir dann auch ein Treiber dazu mit angezeigt.
Hast du den aktuellen Chipsatz Treiber drauf?
