AW: Shader auf Radeon R9 Fury freischalten: Nützliches Tool verfügbar
versuch mal mit cmd und atiflash.
gibt mal in cmd ein: atiflash -i
wenn ich das richtig bestehe, dann gibt der dir dann nummer deiner karte aus. die musst du dann beim flashen berücksichtigen.
atiflash hat folgende parameter:
C:\Fiji_Unlock\AtiFlash>atiflash
--- ATIFLASH v2.70 ---
-h, -?, /h, /? Help (this screen)
Format: ATIFLASH [command] [parameter1] [parameter2] [parameter3] <option/s>
[command]:
-i [Num] Display information of ATI adapters in the system.
Display information of adapter [Num] if specified.
-ai [Num] Display advanced information of ATI adapters on system.
Display advanced information of adapter [Num]
if specified.
-biosfileinfo <File> Displays the Bios info in file <file>
-p <Num> <File> Write BIOS image in file <File> to flash ROM in Adapter
<Num>.
-pa <File> Write BIOS image <File> to all appropriate adapters.
-s <Num> <File> [Size] Save BIOS image from adapter <Num> to file <File>.
First [Size] kbytes (except for Theater in bytes) of ROM
content is saved if [Size] is specified.
-cf <File> [Size] [Sum] Calculate 16-bit checksum for file <File>.
Checksum for the first [Size] kbytes of the file is
calculated if [Size] is specified.
-cb <Num> [Size] [Sum] Calculate 16-bit BIOS image checksum for adapter <Num>.
Checksum for the first [Size] kbytes of the ROM content
is calculated if [Size] is specified.
