http://3dmark.com/images/productlogos/3dm11_logo.png
Version: 1.0.3
SystemInfo Version: 4.6
17.03.12 17:45:45
Score:
P7044 3DMarks
PC Health Check BETA
http://3dmark.com/images/pchealthcheck/true.png
Your Score is Comparable to Similar Systems.
Your PC appears to be functioning normally.
Tips for improving your score
Zum Vergleich hinzufügen
AMD Radeon HD 7950 video card 3DMark 11 benchmark test score
Name
Beschreibung
Prozessor
Prozessor
http://ecom.futuremark.com/ecom/images/getit_orb.gif Intel Core i7-930 Processor Prozessortakt
2931 MHz Physische/logische Prozessoren
1 / 8 Anzahl der Cores
4
Grafikkarte
Grafikkarte
http://ecom.futuremark.com/ecom/images/getit_orb.gif AMD Radeon HD 7950 Vendor
PC Partner Limited Anzahl der Karten
1 SLI / CrossFire
Off Speicher
1024 MB Core-Takt
300 MHz Speichertakt
150 MHz Treibername
Treiberversion
8.950.0.0 Treiberstatus
FM Approved
Allgemein
Betriebssystem
64-bit Windows 7 (6.1.7601) Hauptplatine
Gigabyte Technology Co., Ltd. X58A-UD5 Speicher
6144 MB Modul 1
2048 MB Corsair 9 @ 667 MHz
Modul 2
Modul 3
Festplattenmodell
1.000GB WDC WD1001FALS-00J7B0 ATA Device
Detaillierte Scores
3DMark Score
P7044
Graphics Score
7216
Physics Score
6837
Combined Score
6217
GraphicsTest1
31.06 FPS
GraphicsTest2
35.74 FPS
GraphicsTest3
45.11 FPS
GraphicsTest4
22.15 FPS
PhysicsTest
21.71 FPS
CombinedTest
28.92 FPS
Einstellungen
Standardeinstellungen verwendet
Ja Edition
Basic Dxgi Adapter Luid
0 Screen Width
1280 Screen Height
720 Msaa Sample Count
1 Texture Filtering Mode
Trilinear Max Af Anisotropy
1 Tessellation Detail
5 Max Tessellation Factor
10 ShadowMapSize
5 Shadow Cascade Count
4 Surface Shadow Sample Count
16 Volumetric Illumination Quality
5 Ambient Occlusion Quality
5 Depth Of Field Quality
5 Enable Window Mode
Off Enable Vertical Sync
Off Enable Triple Buffering
Off Enable Wireframe
Off Color Saturation
100% System Info Guid
E05CD61E-9828-411D-9CDC-FABD91975085
