Patch 1.1 für Crysis (auch für die deutsche Version)
Updates:
* Added: Motion Blur UI and V.SYNC UI options
* Optimized: Motion blur
* Optimized: FSAA (Full Scene Anti-Aliasing)
* Optimized sound id implementation
* Enabled VSync functionality in D3D10
* New benchmarking files for ice CPU benchmark.
* http/xmlrpc password protected remote control session
* Marked debug cvars as cheat
* F12 (screenshot) now works in restricted mode as well
Fixes:
* Fixed: Potential crash in D3D10
* Fixed: Orange boxes apearing when hispec savegame loaded into lowspec game.
* Fixed: Inconsistent damage dealt to vehicles when shot by LAW.
* Fixed: Reflection resolution on D3D10, MultiGPU reflection update fix
* Fixed: Memory leak with FSAA modes
* Fixed: Infinite ammo hacks.
* Fixed: Memory leak in D3D10 when switching screen modes
* Fixed: Muti optimizations
* Fixed: When player melees during gun raise animation, their gun will be in a permanantly raised position.
* Fixed: Crash when loading savegame with level exported recently by editor
* Fixed: Virtual keyboard does not function properly when a game pad is connected
* Fixed: Users can lose the ability to look around with the Right Stick
* Fixed: Setting screen resolution to "default" stops user from selecting last resolution
* Fixed: Bug when changing resolution in D3D10
* Fixed: Issues with Depth of field and water droplets in D3D10
* Fixed: Crash on NaN warning
Tweaks:
* Reduced LAW splash damage vs. infantry in PowerStruggle mode
* Slowed Rocket projectile speed down in MP slightly
* Disabled automatic turret bounding boxes on vehicles to prevent issues with LAW hit detection
* Reduced grenade explosion radius in multiplayer
* Clamped water tesselation to avoid cheating in MP
* MultiGPU improvements with depth map updates
Problemlos läuft es bei mir auch nur der MP spinnt ein wenig.
Hab sogar teilweise Login Probleme.
So, gegen 3 begonnen, bin jetzt durch. Fazit: Sehr intensives Gefühl, permanent Druck unter dem Hintern, macht laune. Nicht wundern, ich habe auf Easy gespielt, weil ich mir einen Eindruck verschaffen wollte. Storytechnisch interessant, nichts aussergewöhnliches, Grafisch auf einem sehr guten Niveau, aber ich denke, dass die Cryengine 3 wesentlich mehr Potential hat, was hier ordentlich verschenkt wurde, wenn man manche Textur bedenkt oder aber die Möglichkeiten, die DX11 im Vergleich zu DX9 bietet. Audiomäßig auch auf sehr hohem Niveau, nichts zum Beanstanden. Die KI ist gar nicht mal blöde, wenn sie zumindest nicht in eine dumme Situation gerät und weiß, mich auf Trab zu halten. Ich hatte eigentlich kein Gefühl von "Schlauchleveln", aber mir fehlte dann doch mehr bezug zur Umwelt und weniger Konfliktorientierung, sodass viel immersives Potential verschenkt wird. Die Waffen sind alles in allem sehr nett, nichts aussergewöhnliches dabei, aber solide um jeden Spieler zu befriedigen. Auch sind die Stellen meist gut gemacht, sodass stures "Mit-dem-Kopf-durch-die-Wand" recht schnell in die Hose geht und der Spieler gefordert bleibt. Mir fehlte nur mehr Freiheit mit den Fahrzeugen, was sicherlich noch einiges hergemacht hätte. Beim nächsten Versuch werde ich aber die Schwierigkeit hochstellen, da es sonst enttäuschend einfach von statten geht. Ein letzter Kritikpunkt bleibt: Alcatraz hätte ruhig eine eigene Stimme haben können.
Ob ich den Multiplayer mal anspiele - wer weiß.
Meine Einstellungen: 1920x1080, Extreme. Alles flüssig.
System:
AMD Phenom II X4 965 BE
ASUS Crosshair IV Formula
4GB Corsair DDR3-1600 @ DDR-1333
ASUS HD6950 DirectCU
ASUS Xonar Essence STX
Mein Fazit: 8/10.
-DX10,11 habe ich nicht vermisst so auch so gut aus
Mal ne Frage das Spiel ist ja jetzt draußen : kann man wirklich die Grafik nicht selber einstellen ?!
s|n|s schrieb:Die Auflösung ist einstellbar, also zum Beispiel 1920x1080 und 3 verschiedene Einstellungen: hoch, sehr hoch, extrem. Das wars.
.gif)
Nichts übertaktet. Zumeist bin ich mit etwa 40 FPS rumgelatscht, natürlich gab es auch mal Situationen, wo es etwas geruckelt hat, aber das war eher die Ausnahme.welche Frames hattest du?? GPU übertaktet??
So, uns war langweilig, und deshalb gibt es einen Benchmark-Test mit 16 Grafikkarten bei Crysis 2.![]()
sooo hier mal ein Config-Tool ...kann ja mal jemand testen?? Crysis 2 Advanced Graphics Options Application - Steam Users' Forums
