Maybe i can helb you out a bit Raja. I have just read the PCI-E 3 specifications and they are telling me something different. In my understanding the 75 watt isnt the maximum limit, its just the default value on startup of the motherboard. The motherboard it self sets the maximum allowed watt per slot in the "Slot Capabilities Register" which you can configure up to over 300 watt per slot. In the bits 7 to 14 "Slot Power Limit Value" you can set 250, 275, 300 and above 300 watt. This will be multiplied with bits 15 to 16 "Slot Power Limit Scale" in steps x1 ,x0.1, x0.01 and x0.001. So its up to the motherboard manufacturer and the power management on it how many watt the slot is capable of. The Specifications do define the protocol and not the hardware specs of the PCI-E slot. If a manufacturer uses better parts which can handle higher amps on the contacts and the lines, they can allow the devie in the slot a higher power consumption than 75 watt via these registers. Sadly most people doesnt even read the specifications and judge things they dont understand.
