kerryblue88
F@H-Team-Member (m/w)
Kartenmischung, Bitte um Hilfe, Klärung...
--- Opening Log file [November 23 23:22:40 UTC]
# Windows GPU Console Edition #################################################
Folding@Home Client Version 6.23
http://folding.stanford.edu
Launch directory: C:\Users\f@h\Desktop\gpu1\Folding@home-Win32-GPU_Vista-623
Executable: C:\Users\f@h\Desktop\gpu1\Folding@home-Win32-GPU_Vista-623\Folding@h
ome-Win32-GPU.exe
Arguments: -forcegpu -local -advmethods -gpu 1
[23:22:40] - Ask before connecting: No
[23:22:40] - User name: kerryblue88 (Team 70335)
[23:22:40] - User ID: 1E22FBF16F53D819
[23:22:40] - Machine ID: 2
[23:22:40]
[23:22:40] Loaded queue successfully.
[23:22:40] - Preparing to get new work unit...
[23:22:40] + Attempting to get work packet
[23:22:40] - Connecting to assignment server
[23:22:41] + No appropriate work server was available; will try again in a bit.
[23:22:41] + Couldn't get work instructions.
[23:22:41] - Attempt #1 to get work failed, and no other work to do.
Waiting before retry.
[23:22:46] + Attempting to get work packet
[23:22:46] - Connecting to assignment server
[23:22:47] + No appropriate work server was available; will try again in a bit.
[23:22:47] + Couldn't get work instructions.
[23:22:47] - Attempt #2 to get work failed, and no other work to do.
[23:23:07] + Attempting to get work packet
[23:23:07] - Connecting to assignment server
[23:23:08] + No appropriate work server was available; will try again in a bit.
[23:23:08] + Couldn't get work instructions.
[23:23:08] - Attempt #3 to get work failed, and no other work to do.
[23:23:31] + Attempting to get work packet
[23:23:31] - Connecting to assignment server
[23:23:32] + No appropriate work server was available; will try again in a bit.
[23:23:32] + Couldn't get work instructions.
[23:23:32] - Attempt #4 to get work failed, and no other work to do.
... dies ist die Meldung, die mich schon seit zwei Tagen begleitet...
Zuerst hatte ich eine 285er und eine 260er zusammen ohne SLI-Brücke am Falten und es gab keine Probleme. Dann 260er raus und 470er rein. Dann ging kaum noch was.
Dann habe ich die 285er entfernt und die 470er als GPU0 (also erste Karte eingesetzt) und alleine Falten lassen. Prima. Diese arbeitet mit dem Viewer bzw. dieser Version. 285er als zweite Karte installiert und mit dem normalen Client versucht zum Laufen zu bringen. Trotz verschiedenster Einstellungen kam nur die obige Meldung.
Kann ich in der Version mit dem Viewer weitere (welche? als Beispiel) zuweisen, die nicht in der Eingabemaske vorhanden sind durch Häckchensetzen bzw. wie kann ich diese überprüfen?
Vielleicht hat einer eine Idee. Danke
ome-Win32-GPU.exe
[23:22:40]
