Meine ASIC quality: 44.0% ............. und nun?
We've found the ways in which AMD and NVIDIA segregate their freshly-made GPU ASICs based on the electrical leakages the chips produce (to increase yield by allotting them in different SKUs and performance bins), and we've found ways in which ASIC quality can be quantified and displayed.
hm...
Was meinen die mit electrical leakage? Die berüchtigten Leckströme?
Ja weniger, desto besser... desto weniger Verlustleistung.
Dann baue ich mir eine Arche und nehme immer Pärchen mit, GPU braucht CPU, HDD braucht SSD, usw.Wirst du sterben falls 2012 wirklich die Welt untergeht.
Dich nehme ich nicht mit.
hm...
Soll das ein Witz sein?könnte besser sein
it's from the gpu silicon, and it's used to calculate the gpu voltage.
"bad" gpus get a higher voltage so they make the default clock. "good" gpus can do it with lower voltage
as you've seen in this thread, the scale for nvidia isnt perfect yet, so i'll apply some fixes once I have more data that suggests the typical ranges of gpu leakages
