ehm.. warum?
Knutowskie
Heute schon wieder... woran kann das liegen? Hat da jemand Erfahrung mit? Ist der SMP2 Client...
Code:
[06:32:24] + Processing work unit
[06:32:24] Core required: FahCore_a3.exe
[06:32:24] Core found.
[06:32:24] Working on queue slot 09 [November 16 06:32:24 UTC]
[06:32:24] + Working ...
[06:32:24]
[06:32:24] *------------------------------*
[06:32:24] Folding@Home Gromacs SMP Core
[06:32:24] Version 2.22 (Mar 12, 2010)
[06:32:24]
[06:32:24] Preparing to commence simulation
[06:32:24] - Assembly optimizations manually forced on.
[06:32:24] - Not checking prior termination.
[06:32:24] - Expanded 763991 -> 1404481 (decompressed 183.8 percent)
[06:32:24] Called DecompressByteArray: compressed_data_size=763991 data_size=1404481, decompressed_data_size=1404481 diff=0
[06:32:24] - Digital signature verified
[06:32:24]
[06:32:24] Project: 6701 (Run 51, Clone 34, Gen 58)
[06:32:24]
[06:32:24] Assembly optimizations on if available.
[06:32:24] Entering M.D.
[06:32:31] Completed 0 out of 2000000 steps  (0%)
[12:20:34] CoreStatus = C0000029 (-1073741783)
[12:20:34] Client-core communications error: ERROR 0xc0000029
[12:20:34] Deleting current work unit & continuing...
[12:20:46] - Preparing to get new work unit...
[12:20:46] Cleaning up work directory
[12:20:47] + Attempting to get work packet
[12:20:47] Passkey found
[12:20:47] - Connecting to assignment server
[12:20:49] - Successful: assigned to (171.64.65.54).
[12:20:49] + News From Folding@Home: Welcome to Folding@Home
[12:20:49] Loaded queue successfully.
[12:20:53] + Closed connections
[12:20:58]
Danke schonmal!
Ich gehe mal davon aus, dass du schon einige "Pseudo-BIG's" wie die 6701 erfolgreich durchgekaut hast
Also ich an deiner Stelle würde erstmal "aufräumen"
Will heissen
- Work-Ordner komplett leeren
- Queue.dat löschen
- unitinfo löschen
- Fahcore_a3 löschen
- sämtliche FAHLog löschen
Danach runterfahren, 30 Sekunden warten und wieder booten
Wenn du danach SMP neu startest müsste er die notwendigen Daten neu herunterladen und hoffentlich wieder anfangen zu falten
Meld dich ob's wieder funzt
Hey!
Also Windows sagt fahcore_a3.exe funzt nich mehr. Wenn ich den SMP direkt neu starte, fängt der auch an zu rattern und macht. Wenn er mal wieder fertsch ist, loesch ich mal alles was du sagtest.
Memtest ist natürlich auch echt mal dran.
"Mal sehn, obs was zu hören gibt" sagte der Blinde zum Tauben...
LG Knutowskie
ich hab aktuell nen problem mit dem tray client der hat tage lang gut funktioniert bis er vor knapp ner woche abgestürzt ist und irgend ne dll oder so nit finden kann ..... system neu installiert usw hat alles net geklappt. hab jetzt auf smp2 umgestellt und da kommen keine punkte bei rum aktuell ^^
kannst auch den ram tester von windows 7 nutzen.
Mfg Alex
p.s. hast du aktuell irgendwas übertaktet an dem pc ?
bzw mal nen neuen graka treiber oder so drauf gemacht ?
Mfg Alex
Überprüfe mal deinen Namen und das Team, welche du eingetragen hast.
Schickt er fertige WUs denn ab und gibt eine Rückmeldung über dessen Erfolg aus?
Welche Flags hast du gesetzt?
Falls deine Profilangaben aktuell sind, sollten es
Code:
-smp 4 -verbosity 9 -advmethods
sein.
