Player007
PCGHX-HWbot-Member (m/w)
auf der CB Site sind nun die neuen Treiber Versionen verfügbar:
ATi Catalyst Komplettpaket Download - ComputerBase
Die Downloads auf der AMD Site sind weiter unten aufgeführt.
In den Release Notes sind man ein paar deutlichere Verbesserungen, z.B. in Crysis oder Company of Heroes. Außerdem wurde die Stabilität des Treibers unter Windows Vista, XP und 7 verbessert.
Hier sind die einzelnen Verbesserungen im englischen:
GrußPerformance Improvements
Catalyst™ 9.6 brings performance benefits in several cases where framerates are CPUlimited.
Some measured examples are:
- Company of Heroes – performance improves up to 25% with HD 4600 series
products and below as well as improvements of up to 10% on HD 4800 series
- Crysis – performance improves up to 13% in multi-GPU configurations
- Crysis Warhead – performance improves up to 11% in multi-GPU configurations
- World in Conflict – performance improvements of up to 30% can be seen in settings that were previously CPU limited
Resolved Issues for All Windows Operating System
This section provides information on resolved issues in this release of the ATI Catalyst™
Software Suite for all Windows OS. These include:
- Opening Crossfire pages no longer causes Catalyst Control Center to stop responding
- Catalyst Control Center: With some multi adapter systems in clone mode, disabling
the primary display is now possible
- Changing the bitrate slider values, while transcoding WMV files, no longer causes
- Catalyst Control Center: On some systems configurations, the Overdrive options no
longer fails to display
- Catalyst Control Center content no longer appears interlaced when automatic
deinterlacing is enabled
- Catalyst Control Center: Display settings no longer missing when hot plugging a CRT display in clone mode
- Catalyst Control Center: Scaling option slider is no longer inadvertently enabled when using a non-HDTV resolution
- Fixed a regression in ATI CAL that caused certain IL kernels that compiled and executed properly with Catalyst version prior to 9.4 to no longer work properly with Catalyst 9.4 or later
Resolved Issues for the Windows Vista Operating System
Software Suite for Windows Vista. These include:
- On some configurations, video artifacts are no longer visible during playback of transcoded video files
- Second adapter will now run at default minimum clock values, instead of custom GPU clock values, without requiring the user to launch and exit the 3D game in full screen mode
- Corruption and flickering no longer visible when switching between window and full screen mode when playing Crysis
Resolved Issues for the Windows XP Operating System
Software Suite for Windows XP. These include:
- Catalyst Control Center: Scaling option slider is no longer incorrectly enabled when
using non-HDTV resolutions
- System instability no longer observed when task switching to desktop when playing
"Tom Clancy's HAWK"
- Catalyst Control Center: On some configurations, the scaling options are no longer
missing for HDMI or component video displays
- Team Fortress 2 some slowdowns no longer occur during gameplay
Resolved Issues for the Windows 7 Operating System
Software Suite for Windows 7. These include:
- Some systems with both a component video display and a secondary display, it is
now possible to duplicate the displays using the display settings
- Catalyst Control Center: Graphics corruption no longer visible when updating the
ATI Graphics Power settings
- Catalyst Control Center: System no longer fails to set the Component Video modes
- Catalyst Control Center no longer shows Crossfire as disabled
- Catalyst Control Center: Default HDTV modes can now be enabled properly
- Enabling CrossFire under specific system configurations no longer causes Catalyst
- Intermittent corruption no longer visible throughout Enemy Territory Quake Wars
levels
Download-Links:
Drivers & Tools | GAME.AMD.COM
