Bulletstorm Installationsfehler
Status
JASONv8824
nach einigen Versuchen Bulletstorm zu installieren bekomme ich immer den Fehler "0x800b0100". Dieser Fehler kommt nachdem
"Warten Sie. Windows konfiguriert Bulletstorm" steht. Hat irgendwer eine Idee was das sein könnte? :huh:
Logging Started: 05/03/2011 14:30:17
Source Folder: C:\Programm Files (x86)\EA\Bulletstorm
OS v6.1 Service Pack 1 (build 7601) 64 bit
OS Product Type: 0x00000001
User Default LCID: 0x0c07
(14:30:17) Initialized
(14:30:17) Loading C:\Windows\SysWOW64\XLiveInstall.dll
(14:30:18) Resources initialized
(14:30:20) Create Desktop Shortcut: 0
(14:30:20) Create Start Menu Shortcut: 0
(14:30:20) Install Folder: C:\Program Files (x86)\EA\Bulletstorm
(14:30:20) LCID: 0x0407
(14:30:20) Install Started
(14:30:20) Language Choice: 0x00000407
(14:30:21) Passed EULA
(14:30:24) Passed ProductKey
(14:30:24) Install Start Notification
(14:30:24) Verifying 0MB of 7084MB (0%)
(14:30:24) Verifying 1806MB of 7084MB (5%)
(14:30:24) Progress 5%
(14:31:38) Fehler aufgetreten. Fehlercode: 0x800b0100
(14:31:38) InstallProduct Error: 0x800b0100
(14:30:18) IsMainPackageInstalled INSTALLSTATE:-1
(14:30:20) Installing C:\Programm Files (x86)\EA\Bulletstorm to C:\Program Files (x86)\EA\Bulletstorm. Flags: 0x00000000
(14:30:20) Parsed C:\Programm Files (x86)\EA\Bulletstorm\ChainInstall.xml from C:\Programm Files (x86)\EA\Bulletstorm [Code:0x00000000]
(14:30:20) Languages: 7 Selected:0x00000407 [Code:0x00000000]
(14:30:21) EULAs: 1 [Code:0x00000000]
(14:30:24) ProductKey [Code:0x00000000]
(14:30:24) Prompt result [Code:0x00000000]
(14:30:24) Verifying 846 files
(14:31:38) Verifying C:\Programm Files (x86)\EA\Bulletstorm\Media1.cab failed [Code:0x80073602]
(14:31:38) File 'C:\Programm Files (x86)\EA\Bulletstorm\Media1.cab' was not signed correctly or its contents are invalid.
(14:31:38) Verified files [Code:0x800b0100]
(14:31:38) Stage 0: Error. Reason:Install [Code:0x800b0100] Msg:
(14:31:38) Stage 0: Error. Reason:Generic 1 [Code:0x800b0100] Msg:
(14:31:38) InstallProduct exit [Code:0x800b0100]
hast wahrscheinlich UAC an, führe die setup exe mit admid rechten aus, oder stelle die Dooofe UAC aus.Nervt sowiso nur.
Zu deen nörglern diese Feature was einen tierisch aufn sack geht, ist zwar nett aber nur für windows anfänger besonders internet anfänger gedacht.Man kann diese UAC nur mit der professional und der ultimnate version vernünftig einstellen.
Daher jeder der die Home versionen von Windows hatt sollte diese UAC abstellen.oder jedesmal bei jeden winrar archiv was entpackt wird als admid ausführen, jedes programm das auf die systempfade zugreifen will als admidausführen.
jeden download auf dem Desktop speichern, jeden zugriff von active x im browser doppelt zustimmen.In fakt es nervt. besonders bei vista win 7 ist da gnädiger aber verschweigt es, wenn durch UAC programme nicht mehr funktionieren.
Muss daran liegen ansonsten die Komplette DVD auf die festplatte kopieren und von der Festplatte aus installieren.Dann liegt es am DVD laufwerk ,welches die DVD nicht richtig liest.
Status
