2023-08-06 23:17:08 - Attempting to retrieve the root directory of the data partition.
2023-08-06 23:17:08 - Found 6 handles that supported SimpleFileSystem
2023-08-06 23:17:08 - Checking handle 0 (69F1F618)
2023-08-06 23:17:08 - Handle is own partition
2023-08-06 23:17:08 - Checking handle 1 (69EF3418)
2023-08-06 23:17:08 - HD node found: MBR type(2), Signature type(2), Part #(2), Start LBA(524288), Num Sectors(524288)
2023-08-06 23:17:08 - Self node: MBR type(2), Signature type(2), Part #(1), Start LBA(2048), Num Sectors(522240)
2023-08-06 23:17:08 - Checking handle 2 (6BDD5618)
2023-08-06 23:17:08 - Checking handle 3 (6BDC5E18)
2023-08-06 23:17:08 - Checking handle 4 (6BDC5D18)
2023-08-06 23:17:08 - Checking handle 5 (6BDD8E98)
2023-08-06 23:17:08 - Found 12 handles that supported Block I/O protocol
2023-08-06 23:17:08 - HD node found: MBR type(2), Signature type(2), Signature(50415353-CE04-4F8F-AC32-6F3693F43704), Part #(1), Start LBA(2048), Num Sectors(522240)
2023-08-06 23:17:08 - HD node found: MBR type(2), Signature type(2), Signature(50415353-6343-46C0-B68C-69EE6326F32B), Part #(2), Start LBA(524288), Num Sectors(524288)
2023-08-06 23:17:08 - HD node found: MBR type(2), Signature type(2), Signature(50415353-2A40-4503-B2F7-474E00EBFBAA), Part #(3), Start LBA(1048576), Num Sectors(1048543)
2023-08-06 23:17:08 - Found DMA Test Partition
2023-08-06 23:17:08 - Successfully obtained Block I/O protocol
2023-08-06 23:17:08 - Successfully obtained Partition Info protocol
2023-08-06 23:17:08 - Revision: 0x1000
2023-08-06 23:17:08 - Type: 0x2
2023-08-06 23:17:08 - System: 0x0
2023-08-06 23:17:08 - GPT - PartitionTypeGUID: EBD0A0A2-B9E5-4433-87C0-68B6B72699C7
2023-08-06 23:17:08 - GPT - UniquePartitionGUID: 50415353-2A40-4503-B2F7-474E00EBFBAA
2023-08-06 23:17:08 - GPT - StartingLBA: 0x100000
2023-08-06 23:17:08 - GPT - EndingLBA: 0x1FFFDE
2023-08-06 23:17:08 - GPT - Attributes: 0x0
2023-08-06 23:17:08 - GPT - PartitionName: DMA Test Partition
2023-08-06 23:17:08 - Media ID: 0x00000000
2023-08-06 23:17:08 - Removable: yes
2023-08-06 23:17:08 - Media Present: yes
2023-08-06 23:17:08 - Logical Part: yes
2023-08-06 23:17:08 - Read-only: no
2023-08-06 23:17:08 - Write cache: no
2023-08-06 23:17:08 - Block size: 512
2023-08-06 23:17:08 - Align: 0
2023-08-06 23:17:08 - Last block: 0xFFFDE
2023-08-06 23:17:08 - Lowest LBA: 0x0
2023-08-06 23:17:08 - Log blks per phys blk: 0
2023-08-06 23:17:09 - Optimal transfer len: 0
2023-08-06 23:17:09 - [FS0]
2023-08-06 23:17:09 - PciRoot(0x0)/Pci(0x8,0x1)/Pci(0x0,0x4)/USB(0x3,0x0)/USB(0x3,0x0)/HD(1,GPT,50415353-CE04-4F8F-AC32-6F3693F43704,0x800,0x7F800)
2023-08-06 23:17:09 - Label: "", Mode: RW, Free space: 246 MB / 254 MB (0%)
2023-08-06 23:17:09 - [FS1]
2023-08-06 23:17:09 - PciRoot(0x0)/Pci(0x8,0x1)/Pci(0x0,0x4)/USB(0x3,0x0)/USB(0x3,0x0)/HD(2,GPT,50415353-6343-46C0-B68C-69EE6326F32B,0x80000,0x80000)
2023-08-06 23:17:09 - Label: "", Mode: RW, Free space: 247 MB / 255 MB (0%)
2023-08-06 23:17:09 - [FS2]
2023-08-06 23:17:09 - PciRoot(0x0)/Pci(0x2,0x1)/Pci(0x0,0x0)/Pci(0x0,0x0)/Pci(0x0,0x0)/NVMe(0x1,9C-69-BB-21-BC-38-25-00)/HD(1,GPT,E5A0EFC7-D549-4027-89EB-23ED32E696E9,0x800,0x32000)
2023-08-06 23:17:09 - Label: "", Mode: RW, Free space: 64 MB / 96 MB (0%)
2023-08-06 23:17:09 - [FS3]
2023-08-06 23:17:09 - PciRoot(0x0)/Pci(0x2,0x1)/Pci(0x0,0x0)/Pci(0x0,0x0)/Pci(0x0,0x0)/NVMe(0x1,9C-69-BB-21-BC-38-25-00)/HD(3,GPT,A0189FF7-BEB6-471A-BE87-18502831AA8F,0x3A800,0x7458B000)
2023-08-06 23:17:09 - Label: "", Mode: RO, Free space: 0 MB / 953109 MB (0%)
2023-08-06 23:17:09 - [FS4]
2023-08-06 23:17:09 - PciRoot(0x0)/Pci(0x2,0x1)/Pci(0x0,0x0)/Pci(0x0,0x0)/Pci(0x0,0x0)/NVMe(0x1,9C-69-BB-21-BC-38-25-00)/HD(4,GPT,2679DD3D-CAAE-4137-BB1E-D2EA251E219F,0x745C5800,0x140800)
2023-08-06 23:17:09 - Label: "", Mode: RO, Free space: 0 MB / 640 MB (0%)
2023-08-06 23:17:09 - [FS5]
2023-08-06 23:17:09 - PciRoot(0x0)/Pci(0x2,0x2)/Pci(0x0,0x0)/NVMe(0x1,99-69-BB-21-BC-38-25-00)/HD(2,GPT,F0B5F234-0951-4CAB-A01B-D14AC012D30D,0x8000,0x746FE000)
2023-08-06 23:17:09 - Label: "Volume", Mode: RO, Free space: 0 MB / 953851 MB (0%)
2023-08-06 23:17:09 - Disabling watchdog timer (Result: Success)
2023-08-06 23:17:09 - Could not find Simple Network protocol from image device handle
2023-08-06 23:17:09 - Could not get list of handles that support Simple Network protocol: Not Found
2023-08-06 23:17:09 - Found 0 handles that supported Simple Network
2023-08-06 23:17:09 - =============================================
2023-08-06 23:17:09 - MemTest86 V10.5 Free Build: 1000 (64-bit)
2023-08-06 23:17:09 - SMBIOS BIOS INFO Vendor: "American Megatrends Inc.", Version: "0809", Release Date: "10/23/2022"
2023-08-06 23:17:09 - SMBIOS SYSTEM INFO Manufacturer: "ASUS", Product: "System Product Name", Version: "System Version", S/N: "System Serial Number", SKU: "", Family: ""
2023-08-06 23:17:09 - SMBIOS: Found SMBIOS BaseboardInformation (pbLinAddr=0x79CAD0B8, FormattedLen=15, iTotalLen=123)
2023-08-06 23:17:09 - SMBIOS BASEBOARD INFO Manufacturer: "ASUSTeK COMPUTER INC.", Product: "ROG STRIX B650E-F GAMING WIFI", Version: "Rev 1.xx", S/N: "221112278400947", AssetTag: "Default string", LocationInChassis: "Default string"
2023-08-06 23:17:09 - EFI Specifications: 2.80
2023-08-06 23:17:09 - Found blacklist file
2023-08-06 23:17:09 - [BLACKLIST] Adding "Mac-F42C88C8" (BIOS: "", FLAGS: 1) to blacklist
2023-08-06 23:17:09 - [BLACKLIST] Adding "Mac-F42386C8" (BIOS: "", FLAGS: 1) to blacklist
2023-08-06 23:17:09 - [BLACKLIST] Adding "Mac-F4238CC8" (BIOS: "", FLAGS: 8) to blacklist
2023-08-06 23:17:09 - [BLACKLIST] Adding "Mac-F4208DC8" (BIOS: "", FLAGS: 8) to blacklist
2023-08-06 23:17:09 - [BLACKLIST] Adding "Mac-27ADBB7B4CEE8E61" (BIOS: "", FLAGS: 20) to blacklist
2023-08-06 23:17:09 - [BLACKLIST] Adding "Mac-7BA5B2DFE22DDD8C" (BIOS: "", FLAGS: 4) to blacklist
2023-08-06 23:17:09 - [BLACKLIST] Adding "Mac-7BA5B2D9E42DDD94" (BIOS: "", FLAGS: 2) to blacklist
2023-08-06 23:17:09 - [BLACKLIST] Adding "Mac-AF89B6D9451A490B" (BIOS: "", FLAGS: 4) to blacklist
2023-08-06 23:17:09 - [BLACKLIST] Adding "Mac-CFF7D910A743CAAF" (BIOS: "", FLAGS: 4) to blacklist
2023-08-06 23:17:09 - [BLACKLIST] Adding "Mac-AA95B1DDAB278B95" (BIOS: "", FLAGS: 4) to blacklist
2023-08-06 23:17:09 - [BLACKLIST] Adding "Mac-27AD2F918AE68F61" (BIOS: "", FLAGS: 40) to blacklist
2023-08-06 23:17:09 - [BLACKLIST] Adding "80AF" (BIOS: "", FLAGS: 2) to blacklist
2023-08-06 23:17:09 - [BLACKLIST] Adding "Z97MX-Gaming 5" (BIOS: "", FLAGS: 2) to blacklist
2023-08-06 23:17:09 - [BLACKLIST] Adding "Z170MX-Gaming 5" (BIOS: "", FLAGS: 2) to blacklist
2023-08-06 23:17:09 - [BLACKLIST] Adding "Z170X-Gaming 3" (BIOS: "", FLAGS: 2) to blacklist
2023-08-06 23:17:09 - [BLACKLIST] Adding "Z170X-Gaming 7" (BIOS: "", FLAGS: 2) to blacklist
2023-08-06 23:17:09 - [BLACKLIST] Adding "Z170X-Gaming GT" (BIOS: "", FLAGS: 2) to blacklist
2023-08-06 23:17:09 - [BLACKLIST] Adding "Z170X-UD3-CF" (BIOS: "", FLAGS: 2) to blacklist
2023-08-06 23:17:09 - [BLACKLIST] Adding "Z170-HD3P" (BIOS: "", FLAGS: 2) to blacklist
2023-08-06 23:17:09 - [BLACKLIST] Adding "990FXA-UD3" (BIOS: "", FLAGS: 2) to blacklist
2023-08-06 23:17:09 - [BLACKLIST] Adding "990FX Extreme3" (BIOS: "", FLAGS: 2) to blacklist
2023-08-06 23:17:09 - [BLACKLIST] Adding "970A-DS3P" (BIOS: "", FLAGS: 2) to blacklist
2023-08-06 23:17:09 - [BLACKLIST] Adding "X99-Ultra Gaming-CF" (BIOS: "", FLAGS: 2) to blacklist
2023-08-06 23:17:09 - [BLACKLIST] Adding "M5A97 R2.0" (BIOS: "", FLAGS: 2) to blacklist
2023-08-06 23:17:09 - [BLACKLIST] Adding "M5A97 EVO R2.0" (BIOS: "", FLAGS: 2) to blacklist
2023-08-06 23:17:10 - [BLACKLIST] Adding "M5A99FX PRO R2.0" (BIOS: "", FLAGS: 2) to blacklist
2023-08-06 23:17:10 - [BLACKLIST] Adding "M5A99X EVO R2.0" (BIOS: "", FLAGS: 2) to blacklist
2023-08-06 23:17:10 - [BLACKLIST] Adding "X99-A" (BIOS: "3701", FLAGS: 2) to blacklist
2023-08-06 23:17:10 - [BLACKLIST] Adding "X99-A/USB 3.1" (BIOS: "3701", FLAGS: 2) to blacklist
2023-08-06 23:17:10 - [BLACKLIST] Adding "X99-A II" (BIOS: "1701", FLAGS: 2) to blacklist
2023-08-06 23:17:10 - [BLACKLIST] Adding "X99-A" (BIOS: "1701", FLAGS: 2) to blacklist
2023-08-06 23:17:10 - [BLACKLIST] Adding "Sabertooth X99" (BIOS: "3701", FLAGS: 2) to blacklist
2023-08-06 23:17:10 - [BLACKLIST] Adding "SABERTOOTH 990FX R2.0" (BIOS: "", FLAGS: 2) to blacklist
2023-08-06 23:17:10 - [BLACKLIST] Adding "SABERTOOTH 990FX R3.0" (BIOS: "", FLAGS: 2) to blacklist
2023-08-06 23:17:10 - [BLACKLIST] Adding "SABERTOOTH 990FX/GEN3 R2.0" (BIOS: "", FLAGS: 2) to blacklist
2023-08-06 23:17:10 - [BLACKLIST] Adding "STRIX X99 GAMING" (BIOS: "1701", FLAGS: 2) to blacklist
2023-08-06 23:17:10 - [BLACKLIST] Adding "X99-DELUXE" (BIOS: "3701", FLAGS: 2) to blacklist
2023-08-06 23:17:10 - [BLACKLIST] Adding "X99-DELUXE II" (BIOS: "1701", FLAGS: 2) to blacklist
2023-08-06 23:17:10 - [BLACKLIST] Adding "RAMPAGE V EXTREME" (BIOS: "3701", FLAGS: 2) to blacklist
2023-08-06 23:17:10 - [BLACKLIST] Adding "RAMPAGE V EDITION 10" (BIOS: "", FLAGS: 2) to blacklist
2023-08-06 23:17:10 - [BLACKLIST] Adding "MAXIMUS VIII RANGER" (BIOS: "", FLAGS: 2) to blacklist
2023-08-06 23:17:10 - [BLACKLIST] Adding "P9X79 WS" (BIOS: "", FLAGS: 40) to blacklist
2023-08-06 23:17:10 - [BLACKLIST] Adding "P9X79-E WS" (BIOS: "", FLAGS: 40) to blacklist
2023-08-06 23:17:10 - [BLACKLIST] Adding "Z9PE-D8 WS" (BIOS: "", FLAGS: 40) to blacklist
2023-08-06 23:17:10 - [BLACKLIST] Adding "Z10PE-D8 WS" (BIOS: "", FLAGS: 2) to blacklist
2023-08-06 23:17:10 - [BLACKLIST] Adding "X9DRW" (BIOS: "", FLAGS: 2) to blacklist
2023-08-06 23:17:10 - [BLACKLIST] Adding "X9DRW-3LN4F+/X9DRW-3TF+" (BIOS: "", FLAGS: 2) to blacklist
2023-08-06 23:17:10 - [BLACKLIST] Adding "X9DR3-F" (BIOS: "", FLAGS: 40) to blacklist
2023-08-06 23:17:10 - [BLACKLIST] Adding "X9SRL-F" (BIOS: "", FLAGS: 2) to blacklist
2023-08-06 23:17:10 - [BLACKLIST] Adding "X9DRD-iF" (BIOS: "", FLAGS: 2) to blacklist
2023-08-06 23:17:10 - [BLACKLIST] Adding "X9SRA/X9SRA-3" (BIOS: "", FLAGS: 2) to blacklist
2023-08-06 23:17:10 - [BLACKLIST] Adding "X9DRL-7F" (BIOS: "", FLAGS: 2) to blacklist
2023-08-06 23:17:10 - [BLACKLIST] Adding "151-BE-E097" (BIOS: "", FLAGS: 2) to blacklist
2023-08-06 23:17:10 - [BLACKLIST] Adding "131-HE-E095" (BIOS: "", FLAGS: 2) to blacklist
2023-08-06 23:17:10 - [BLACKLIST] Adding "131-HE-E095-KR" (BIOS: "", FLAGS: 2) to blacklist
2023-08-06 23:17:10 - [BLACKLIST] Adding "151-HE-E999-KR" (BIOS: "", FLAGS: 2) to blacklist
2023-08-06 23:17:10 - [BLACKLIST] Adding "PRIME B350-PLUS" (BIOS: "", FLAGS: 2) to blacklist
2023-08-06 23:17:10 - [BLACKLIST] Adding "PRIME X370-PRO" (BIOS: "", FLAGS: 4) to blacklist
2023-08-06 23:17:10 - [BLACKLIST] Adding "CROSSHAIR VI HERO" (BIOS: "1602", FLAGS: 4) to blacklist
2023-08-06 23:17:10 - [BLACKLIST] Adding "CROSSHAIR V FORMULA-Z" (BIOS: "", FLAGS: 4) to blacklist
2023-08-06 23:17:10 - [BLACKLIST] Adding "ROG STRIX X370-F GAMING" (BIOS: "4012", FLAGS: 4) to blacklist
2023-08-06 23:17:10 - [BLACKLIST] Adding "OEMSH Product" (BIOS: "", FLAGS: 8) to blacklist
2023-08-06 23:17:10 - [BLACKLIST] Adding "OEMAL Product" (BIOS: "", FLAGS: 10) to blacklist
2023-08-06 23:17:10 - [BLACKLIST] Adding "OEMCT Product" (BIOS: "", FLAGS: 10) to blacklist
2023-08-06 23:17:10 - [BLACKLIST] Adding "OEMWY Product" (BIOS: "", FLAGS: 10) to blacklist
2023-08-06 23:17:10 - [BLACKLIST] Adding "LNVNB161216" (BIOS: "", FLAGS: 10) to blacklist
2023-08-06 23:17:10 - [BLACKLIST] Adding "GA-990FX-GAMING" (BIOS: "", FLAGS: 2) to blacklist
2023-08-06 23:17:10 - [BLACKLIST] Adding "X399 SLI PLUS (MS-7B09)" (BIOS: "", FLAGS: 2) to blacklist
2023-08-06 23:17:10 - [BLACKLIST] Adding "X570 I AORUS PRO WIFI" (BIOS: "F32", FLAGS: 2) to blacklist
2023-08-06 23:17:10 - [BLACKLIST] Adding "MS-17EK" (BIOS: "", FLAGS: 2) to blacklist
2023-08-06 23:17:10 - [BLACKLIST] Adding "0F685W" (BIOS: "", FLAGS: 80) to blacklist
2023-08-06 23:17:10 - [BLACKLIST] Adding "00V5FJ" (BIOS: "", FLAGS: 100) to blacklist
2023-08-06 23:17:10 - [BLACKLIST] Adding "ProLiant DL325 Gen10" (BIOS: "", FLAGS: 4) to blacklist
2023-08-06 23:17:10 - [BLACKLIST] Adding "ProLiant DL385 Gen10" (BIOS: "", FLAGS: 4) to blacklist
2023-08-06 23:17:10 - [BLACKLIST] Adding "ProLiant DL385 Gen10 Plus" (BIOS: "", FLAGS: 4) to blacklist
2023-08-06 23:17:10 - [BLACKLIST] Adding "06CDVY" (BIOS: "", FLAGS: 10) to blacklist
2023-08-06 23:17:10 - [BLACKLIST] Adding "Surface Book" (BIOS: "", FLAGS: 10) to blacklist
2023-08-06 23:17:10 - [BLACKLIST] Adding "Surface Book 2" (BIOS: "", FLAGS: 10) to blacklist
2023-08-06 23:17:10 - [BLACKLIST] Adding "Surface Pro" (BIOS: "", FLAGS: 10) to blacklist
2023-08-06 23:17:10 - [BLACKLIST] Adding "Surface Pro 7" (BIOS: "", FLAGS: 10) to blacklist
2023-08-06 23:17:11 - [BLACKLIST] Adding "Surface Laptop 4" (BIOS: "", FLAGS: 10) to blacklist
2023-08-06 23:17:11 - [BLACKLIST] Adding "Surface Laptop" (BIOS: "", FLAGS: 10) to blacklist
2023-08-06 23:17:11 - [BLACKLIST] Adding "MACH-WX9-PCB" (BIOS: "", FLAGS: 10) to blacklist
2023-08-06 23:17:11 - [BLACKLIST] Adding "MACH-WX9" (BIOS: "", FLAGS: 10) to blacklist
2023-08-06 23:17:11 - [BLACKLIST] Adding "8873" (BIOS: "", FLAGS: 10) to blacklist
2023-08-06 23:17:11 - [BLACKLIST] Adding "0P4NHH" (BIOS: "", FLAGS: 10) to blacklist
2023-08-06 23:17:11 - [BLACKLIST] Adding "XPS 17 9710" (BIOS: "", FLAGS: 10) to blacklist
2023-08-06 23:17:11 - [BLACKLIST] Adding "XPS 15 9510" (BIOS: "", FLAGS: 10) to blacklist
2023-08-06 23:17:11 - [BLACKLIST] Adding "01V4T3" (BIOS: "", FLAGS: 10) to blacklist
2023-08-06 23:17:11 - [BLACKLIST] Adding "H12DST-B" (BIOS: "", FLAGS: 2) to blacklist
2023-08-06 23:17:11 - [BLACKLIST] 91 boards added to blacklist
2023-08-06 23:17:11 - Console Control protocol workaround enabled
2023-08-06 23:17:11 - Number of console modes: 4
2023-08-06 23:17:11 - Mode 0: 80 x 25
2023-08-06 23:17:11 - Mode 1: 80 x 50
2023-08-06 23:17:11 - Mode 2: 100 x 31
2023-08-06 23:17:11 - Mode 3: 240 x 56
2023-08-06 23:17:11 - Console attribute: 15
2023-08-06 23:17:11 - Initializing localization strings
2023-08-06 23:17:11 - Language en-US is supported
2023-08-06 23:17:11 - Language fr-FR is supported
2023-08-06 23:17:11 - Language it-IT is supported
2023-08-06 23:17:11 - Language es-AR is supported
2023-08-06 23:17:11 - GetGlyph failed for character 0x00C3 (Warning Unknown Glyph)
2023-08-06 23:17:11 - Language pt-BR is not supported
2023-08-06 23:17:11 - Language ca-ES is supported
2023-08-06 23:17:11 - Language de-DE is supported
2023-08-06 23:17:11 - GetGlyph failed for character 0x010C (Warning Unknown Glyph)
2023-08-06 23:17:11 - Language cs-CZ is not supported
2023-08-06 23:17:11 - GetGlyph failed for character 0x0104 (Warning Unknown Glyph)
2023-08-06 23:17:11 - Language pl-PL is not supported
2023-08-06 23:17:11 - Language ru-RU is supported
2023-08-06 23:17:11 - GetGlyph failed for character 0x3041 (Warning Unknown Glyph)
2023-08-06 23:17:11 - Language ja-JP is not supported
2023-08-06 23:17:11 - GetGlyph failed for character 0x4E0F (Warning Unknown Glyph)
2023-08-06 23:17:11 - Language zh-CN is not supported
2023-08-06 23:17:11 - GetGlyph failed for character 0xF944 (Warning Unknown Glyph)
2023-08-06 23:17:11 - Language zh-HK is not supported
2023-08-06 23:17:11 - Font does not support all languages. Installing unicode font...
2023-08-06 23:17:11 - InitFont - Font header version: 1.1
2023-08-06 23:17:11 - InitFont - Number of narrow glyphs: 7110
2023-08-06 23:17:11 - InitFont - Number of wide glyphs: 49976
2023-08-06 23:17:11 - Language pt-BR is supported
2023-08-06 23:17:11 - Language cs-CZ is supported
2023-08-06 23:17:11 - Language pl-PL is supported
2023-08-06 23:17:11 - Language ja-JP is supported
2023-08-06 23:17:11 - Language zh-CN is supported
2023-08-06 23:17:11 - Language zh-HK is supported
2023-08-06 23:17:12 - iMS support is NOT available
2023-08-06 23:17:12 - Initializing screen for graphics
2023-08-06 23:17:12 - Number of graphics modes: 12
2023-08-06 23:17:12 - Mode 0: 1920 x 1080
2023-08-06 23:17:12 - Mode 1: 640 x 480
2023-08-06 23:17:12 - Mode 2: 800 x 600
2023-08-06 23:17:12 - Mode 3: 1024 x 768 [Current]
2023-08-06 23:17:12 - Mode 4: 1280 x 720
2023-08-06 23:17:12 - Mode 5: 1280 x 800
2023-08-06 23:17:12 - Mode 6: 1280 x 1024
2023-08-06 23:17:12 - Mode 7: 1366 x 768
2023-08-06 23:17:12 - Mode 8: 1440 x 900
2023-08-06 23:17:12 - Mode 9: 1400 x 1050
2023-08-06 23:17:12 - Mode 10: 1680 x 1050
2023-08-06 23:17:12 - Mode 11: 1920 x 1080
2023-08-06 23:17:12 - Getting CPUID
2023-08-06 23:17:12 - Getting cache size
2023-08-06 23:17:12 - get_cache_size - Vendor ID: AuthenticAMD Brand ID: AMD Ryzen 9 7950X 16-Core Processor
2023-08-06 23:17:12 - CPU CorePPack: 32 (0x0000501F)
2023-08-06 23:17:12 - L1 instruction cache size: 32 x 32KB
2023-08-06 23:17:12 - L1 data cache size: 32 x 32KB
2023-08-06 23:17:12 - L2 cache size: 32 x 1024KB
2023-08-06 23:17:12 - L3 cache size: 1 x 65536KB
2023-08-06 23:17:12 - Measuring CPU/cache/mem speed
2023-08-06 23:17:12 - hpet_init - Found RSDP. Version: 2
2023-08-06 23:17:12 - hpet_init - Found XSDT. Entry Count: 30
2023-08-06 23:17:12 - hpet_init - Found ACPI table: FACP Version: 6
2023-08-06 23:17:12 - hpet_init - Found ACPI table: SSDT Version: 1
2023-08-06 23:17:12 - hpet_init - Found ACPI table: IVRS Version: 2
2023-08-06 23:17:12 - hpet_init - Found ACPI table: SSDT Version: 2
2023-08-06 23:17:12 - hpet_init - Found ACPI table: FIDT Version: 1
2023-08-06 23:17:12 - hpet_init - Found ACPI table: MCFG Version: 1
2023-08-06 23:17:12 - hpet_init - Found ACPI table: HPET Version: 1
2023-08-06 23:17:12 - hpet_init - HPET base address: 0xFED00000
2023-08-06 23:17:12 - hpet_init - HPET gen cap: 0x429B17E10228201 (Period: 69841278fs)
2023-08-06 23:17:12 - hpet_init - HPET gen cfg: 0x0
2023-08-06 23:17:12 - hpet_init - HPET is disabled
2023-08-06 23:17:12 - cpuspeed - rdtsc instruction supported: 1
2023-08-06 23:17:12 - cpuspeed - start ticks: 378526527855, end ticks: 378752456340 (difference: 225928485)
2023-08-06 23:17:12 - cpu_cache_speed - (Attempt 1) clock cycle (ms): 4518569
2023-08-06 23:17:12 - cpuspeed - start ticks: 379005394230, end ticks: 379229977755 (difference: 224583525)
2023-08-06 23:17:12 - cpu_cache_speed - (Attempt 2) clock cycle (ms): 4491670
2023-08-06 23:17:13 - cpuspeed - start ticks: 379485377145, end ticks: 379709961480 (difference: 224584335)
2023-08-06 23:17:13 - cpu_cache_speed - (Attempt 3) clock cycle (ms): 4491686
2023-08-06 23:17:13 - cpuspeed - rdtsc instruction supported: 1
2023-08-06 23:17:13 - cpuspeed - start ticks: 379953936990, end ticks: 380178519480 (difference: 224582490)
2023-08-06 23:17:13 - cpu_cache_speed - (Attempt 4) clock cycle (ms): 4491649
2023-08-06 23:17:13 - cpu_cache_speed - Using average of last 3 samples (4491649, 4491686, 4491670)
2023-08-06 23:17:13 - cpu_cache_speed - CPU speed: 4491.6MHz
2023-08-06 23:17:13 - cpu_cache_speed - measuring L1 cache speed at 0x692D6000 (32 KB)
2023-08-06 23:17:13 - cpu_cache_speed - L1 cache speed: 310034 MB/s
2023-08-06 23:17:13 - cpu_cache_speed - measuring L2 cache speed at 0x691DE000 (1024 KB)
2023-08-06 23:17:13 - cpu_cache_speed - L2 cache speed: 111819 MB/s
2023-08-06 23:17:13 - cpu_cache_speed - measuring L3 cache speed at 0x62D27000 (65536 KB)
2023-08-06 23:17:14 - cpu_cache_speed - L3 cache speed: 64639 MB/s
2023-08-06 23:17:14 - get_mem_speed - measuring mem speed at 0x32319000 (532992 KB)
2023-08-06 23:17:14 - get_mem_speed - mem speed: 48294 MB/s
2023-08-06 23:17:14 - memory latency - allocate memory
2023-08-06 23:17:14 - memory latency - randomize range
2023-08-06 23:17:14 - memory latency - build linked list
2023-08-06 23:17:14 - memory latency - start test
2023-08-06 23:17:15 - memory latency - test completed (loops=4, rpl=2097152)
2023-08-06 23:17:15 - cpu_cache_speed - Memory latency: 66.041 ns
2023-08-06 23:17:15 - Retrieving CPU MSR data
2023-08-06 23:17:15 - GetAMDFamilyMSRInfo - CPU AMD Ryzen 9 7950X 16-Core Processor : 19h.61h
2023-08-06 23:17:15 - IsAMDTurboCoreSupported - CPUID[0x80000007][EDX] = 00006799
2023-08-06 23:17:15 - HWCR register found. CPB enable/disable functionality supported
2023-08-06 23:17:15 - CPB is: enabled
2023-08-06 23:17:15 - GetAMDFamilyMSRInfo - MSR[0xC0010292] = 0000000104003789
2023-08-06 23:17:15 - GetAMDFamilyMSRInfo - MSR Max Pstates/#boosted states: 8, -1
2023-08-06 23:17:15 - GetAMDFamilyMSRInfo - MSR[C0010064] = 800000004B7248B4
2023-08-06 23:17:15 - GetAMDMult - CPUDid_P = 8, CPUFid_P = 180
2023-08-06 23:17:15 - GetAMDFamilyMSRInfo - Multiplier_P[0] = 45000
2023-08-06 23:17:15 - GetAMDFamilyMSRInfo - MSR[C0010065] = 80000000479E4878
2023-08-06 23:17:15 - GetAMDMult - CPUDid_P = 8, CPUFid_P = 120
2023-08-06 23:17:15 - GetAMDFamilyMSRInfo - Multiplier_P[1] = 30000
2023-08-06 23:17:15 - GetAMDFamilyMSRInfo - MSR[C0010066] = 0000000000000000
2023-08-06 23:17:15 - GetAMDMult - CPUDid_P = 0, CPUFid_P = 0
2023-08-06 23:17:15 - GetAMDFamilyMSRInfo - Multiplier_P[2] = 0
2023-08-06 23:17:15 - GetAMDFamilyMSRInfo - MSR[C0010067] = 0000000000000000
2023-08-06 23:17:15 - GetAMDFamilyMSRInfo - Multiplier_P[3] = 0
2023-08-06 23:17:15 - GetAMDFamilyMSRInfo - MSR[C0010068] = 0000000000000000
2023-08-06 23:17:15 - GetAMDFamilyMSRInfo - Multiplier_P[4] = 0
2023-08-06 23:17:15 - GetAMDFamilyMSRInfo - MSR[C0010069] = 0000000000000000
2023-08-06 23:17:15 - GetAMDFamilyMSRInfo - Multiplier_P[5] = 0
2023-08-06 23:17:15 - GetAMDFamilyMSRInfo - MSR[C001006A] = 0000000000000000
2023-08-06 23:17:16 - GetAMDFamilyMSRInfo - Multiplier_P[6] = 0
2023-08-06 23:17:16 - GetAMDFamilyMSRInfo - MSR[C001006B] = 0000000000000000
2023-08-06 23:17:16 - GetAMDMult - CPUDid_P = 0, CPUFid_P = 0
2023-08-06 23:17:16 - GetAMDFamilyMSRInfo - Multiplier_P[7] = 0
2023-08-06 23:17:16 - EnableAMDCPB - MSR[0xC0010015] = 0000000189006011
2023-08-06 23:17:16 - EnableAMDCPB - New MSR[0xC0010015] = 0000000189006011
2023-08-06 23:17:16 - AMD MSR enable CPD: MSR[00000000C0010062] = 0x0000000000000000
2023-08-06 23:17:16 - AMD Set PStateCtl: 0x0000000000000000
2023-08-06 23:17:16 - Get_MPERF_APERF - CPUID[0x6][ECX] = 00000001
2023-08-06 23:17:16 - Get_MPERF_APERF - high perf counter freq = 4491668000
2023-08-06 23:17:16 - MSR 0xC0010293: 00000000003848D8
2023-08-06 23:17:16 - GetAMDMult - CPUDid_P = 8, CPUFid_P = 216
2023-08-06 23:17:16 - MSR 0xC0010063: 0000000000000000
2023-08-06 23:17:16 - MSR 0xC0010062: 0000000000000000
2023-08-06 23:17:16 - MSR 0xC0010061: 0000000000000010 (CurPState=0, MaxPState=1)
2023-08-06 23:17:16 - Get_MPERF_APERF - time in ns = 276962
2023-08-06 23:17:16 - Get_MPERF_APERF - FreqMPERF in KHz = 4494443, FreqAPERF in KHz = 5296018
2023-08-06 23:17:17 - MSR 0xC0010293: 00000000003848D7
2023-08-06 23:17:17 - GetAMDMult - CPUDid_P = 8, CPUFid_P = 215
2023-08-06 23:17:17 - MSR 0xC0010063: 0000000000000000
2023-08-06 23:17:17 - MSR 0xC0010062: 0000000000000000
2023-08-06 23:17:17 - MSR 0xC0010061: 0000000000000010 (CurPState=0, MaxPState=1)
2023-08-06 23:17:17 - Get_MPERF_APERF - time in ns = 267675
2023-08-06 23:17:17 - Get_MPERF_APERF - FreqMPERF in KHz = 4493527, FreqAPERF in KHz = 5365865
2023-08-06 23:17:18 - MSR 0xC0010293: 00000000003808D7
2023-08-06 23:17:18 - GetAMDMult - CPUDid_P = 8, CPUFid_P = 215
2023-08-06 23:17:18 - MSR 0xC0010063: 0000000000000000
2023-08-06 23:17:18 - MSR 0xC0010062: 0000000000000000
2023-08-06 23:17:18 - MSR 0xC0010061: 0000000000000010 (CurPState=0, MaxPState=1)
2023-08-06 23:17:18 - Get_MPERF_APERF - time in ns = 273907
2023-08-06 23:17:18 - Get_MPERF_APERF - FreqMPERF in KHz = 4493477, FreqAPERF in KHz = 5365876
2023-08-06 23:17:18 - GetAMDFamilyMSRInfo - APERF = 5365876, MPERF = 4494443, Mult = 54000
2023-08-06 23:17:18 - GetAMDFamilyMSRInfo - BaseClock = 9936
2023-08-06 23:17:18 - GetAMDFamilyMSRInfo - Turbo Core supported
2023-08-06 23:17:18 - DisableAMDCPB - MSR[0xC0010015] = 0000000189006011
2023-08-06 23:17:18 - DisableAMDCPB - New MSR[0xC0010015] = 000000018B006011
2023-08-06 23:17:18 - AMD MSR disable CPD: MSR[00000000C0010062] = 0x0000000000000000
2023-08-06 23:17:18 - AMD Set PStateCtl: 0x0000000000000000
2023-08-06 23:17:18 - Get_MPERF_APERF - CPUID[0x6][ECX] = 00000001
2023-08-06 23:17:18 - Get_MPERF_APERF - high perf counter freq = 4491668000
2023-08-06 23:17:18 - MSR 0xC0010293: 00000000006588B4
2023-08-06 23:17:18 - GetAMDMult - CPUDid_P = 8, CPUFid_P = 180
2023-08-06 23:17:18 - MSR 0xC0010063: 0000000000000001
2023-08-06 23:17:18 - Get_MPERF_APERF - time in ns = 319641
2023-08-06 23:17:18 - Get_MPERF_APERF - FreqMPERF in KHz = 4493369, FreqAPERF in KHz = 4492305
2023-08-06 23:17:19 - MSR 0xC0010293: 000000000065C8B4
2023-08-06 23:17:19 - GetAMDMult - CPUDid_P = 8, CPUFid_P = 180
2023-08-06 23:17:19 - MSR 0xC0010063: 0000000000000001
2023-08-06 23:17:19 - MSR 0xC0010062: 0000000000000000
2023-08-06 23:17:19 - MSR 0xC0010061: 0000000000000010 (CurPState=0, MaxPState=1)
2023-08-06 23:17:19 - Get_MPERF_APERF - time in ns = 319611
2023-08-06 23:17:19 - Get_MPERF_APERF - FreqMPERF in KHz = 4493368, FreqAPERF in KHz = 4492357
2023-08-06 23:17:19 - Get_MPERF_APERF - time in ns = 319721
2023-08-06 23:17:19 - Get_MPERF_APERF - FreqMPERF in KHz = 4493370, FreqAPERF in KHz = 4492335
2023-08-06 23:17:19 - GetAMDFamilyMSRInfo - (CPB disabled) APERF = 4492357, MPERF = 4493370, Mult = 45000
2023-08-06 23:17:19 - GetAMDFamilyMSRInfo - (CPB disabled) BaseClock = 9983
2023-08-06 23:17:19 - GetAMDFamilyMSRInfo - CPUSpeedTurboTheoreticalMax = 4492350
2023-08-06 23:17:19 - GetAMDFamilyMSRInfo - (Before sanity check) Freq: 4492357KHz (Ratio: 45000, ExtClk: 9983Khz), Turbo: 5365876KHz (Ratio: 54000, ExtClk: 9983KHz) (Theoretical Max: 5365876Khz)
2023-08-06 23:17:19 - GetAMDFamilyMSRInfo - Freq: 4492357, 45000, 9983, Turbo: 5365876, 0, 9983 (5365876)
2023-08-06 23:17:19 - Getting memory size
2023-08-06 23:17:19 - 0x000000000000 - 0x00000009EFFF (636KB) {Free Memory}
2023-08-06 23:17:19 - 0x00000009F000 - 0x00000009FFFF (4KB) {Boot Services Data}
2023-08-06 23:17:19 - 0x000000100000 - 0x000000FFFFFF (15MB) {Free Memory}
2023-08-06 23:17:19 - 0x000001000000 - 0x00000107FFFF (512KB) {Boot Services Data}
2023-08-06 23:17:19 - 0x000001080000 - 0x000009AFEFFF (138MB) {Free Memory}
2023-08-06 23:17:19 - 0x000009AFF000 - 0x000009FFFFFF (5MB) {Reserved Memory}
2023-08-06 23:17:19 - 0x00000A000000 - 0x00000A1FFFFF (2MB) {Free Memory}
2023-08-06 23:17:19 - 0x00000A200000 - 0x00000A20FFFF (64KB) {ACPI Non-volatile}
2023-08-06 23:17:19 - 0x00000A210000 - 0x00000AFFFFFF (13MB) {Free Memory}
2023-08-06 23:17:20 - 0x00000B000000 - 0x00000B020FFF (132KB) {Reserved Memory}
2023-08-06 23:17:20 - 0x00000B021000 - 0x000052B98FFF (1147MB) {Free Memory}
2023-08-06 23:17:20 - 0x000052B99000 - 0x000052CF1FFF (1380KB) {Loader Code}
2023-08-06 23:17:20 - 0x000052CF2000 - 0x0000542FAFFF (22MB) {Loader Data}
2023-08-06 23:17:20 - 0x0000542FB000 - 0x000054300FFF (24KB) {Free Memory}
2023-08-06 23:17:20 - 0x000054301000 - 0x00005430DFFF (52KB) {Loader Data}
2023-08-06 23:17:20 - 0x00005430E000 - 0x00005430FFFF (8KB) {Free Memory}
2023-08-06 23:17:20 - 0x000054310000 - 0x000061C6AFFF (217MB) {Loader Data}
2023-08-06 23:17:20 - 0x000061C6B000 - 0x000061D91FFF (1180KB) {ACPI Tables}
2023-08-06 23:17:20 - 0x000061D92000 - 0x000061D92FFF (4KB) {Loader Data}
2023-08-06 23:17:20 - 0x000061D93000 - 0x000066D26FFF (79MB) {Free Memory}
2023-08-06 23:17:20 - 0x000066D27000 - 0x000066F66FFF (2MB) {Boot Services Data}
2023-08-06 23:17:20 - 0x000066F67000 - 0x0000675FFFFF (6MB) {Free Memory}
2023-08-06 23:17:20 - 0x000067600000 - 0x000067C11FFF (6MB) {Boot Services Data}
2023-08-06 23:17:20 - 0x000067C12000 - 0x000067C13FFF (8KB) {Free Memory}
2023-08-06 23:17:20 - 0x000067C14000 - 0x000067C4AFFF (220KB) {Boot Services Data}
2023-08-06 23:17:20 - 0x000067C4B000 - 0x000067C4EFFF (16KB) {Free Memory}
2023-08-06 23:17:20 - 0x000067C4F000 - 0x000067C4FFFF (4KB) {Boot Services Data}
2023-08-06 23:17:20 - 0x000067C50000 - 0x000067C51FFF (8KB) {Free Memory}
2023-08-06 23:17:20 - 0x000067C52000 - 0x0000691B5FFF (21MB) {Boot Services Data}
2023-08-06 23:17:20 - 0x0000691B6000 - 0x0000692DAFFF (1172KB) {Free Memory}
2023-08-06 23:17:20 - 0x0000692DB000 - 0x00006DD92FFF (74MB) {Boot Services Data}
2023-08-06 23:17:20 - 0x00006DD93000 - 0x00006EC5CFFF (14MB) {Free Memory}
2023-08-06 23:17:20 - 0x00006EC5D000 - 0x00006FD92FFF (17MB) {Boot Services Code}
2023-08-06 23:17:20 - 0x00006FD93000 - 0x0000765DEFFF (104MB) {Reserved Memory}
2023-08-06 23:17:20 - 0x0000765DF000 - 0x0000767BAFFF (1904KB) {ACPI Tables}
2023-08-06 23:17:20 - 0x0000767BB000 - 0x0000787BAFFF (32MB) {ACPI Non-volatile}
2023-08-06 23:17:20 - 0x0000787BB000 - 0x00007A07EFFF (24MB) {Runtime Services Data}
2023-08-06 23:17:20 - 0x00007A07F000 - 0x00007A1FEFFF (1536KB) {Runtime Services Code}
2023-08-06 23:17:20 - 0x00007A1FF000 - 0x00007A7FFFFF (6MB) {Boot Services Data}
2023-08-06 23:17:20 - 0x00007A800000 - 0x00007A8A4FFF (660KB) {Free Memory}
2023-08-06 23:17:20 - 0x00007A8A5000 - 0x00007A9A4FFF (1024KB) {Boot Services Data}
2023-08-06 23:17:20 - 0x00007A9A5000 - 0x00007A9BFFFF (108KB) {Boot Services Code}
2023-08-06 23:17:20 - 0x00007A9C0000 - 0x00007A9EAFFF (172KB) {Boot Services Data}
2023-08-06 23:17:20 - 0x00007A9EB000 - 0x00007AA0CFFF (136KB) {Boot Services Code}
2023-08-06 23:17:20 - 0x00007AA0D000 - 0x00007AA24FFF (96KB) {Boot Services Data}
2023-08-06 23:17:20 - 0x00007AA25000 - 0x00007AA41FFF (116KB) {Boot Services Code}
2023-08-06 23:17:20 - 0x00007AA42000 - 0x00007BEB9FFF (20MB) {Boot Services Data}
2023-08-06 23:17:20 - 0x00007BEBA000 - 0x00007BEBCFFF (12KB) {Boot Services Code}
2023-08-06 23:17:20 - 0x00007BEBD000 - 0x00007BECFFFF (76KB) {Boot Services Data}
2023-08-06 23:17:20 - 0x00007BED0000 - 0x00007BEE8FFF (100KB) {Boot Services Code}
2023-08-06 23:17:20 - 0x00007BEE9000 - 0x00007BFEBFFF (1036KB) {Boot Services Data}
2023-08-06 23:17:20 - 0x00007BFEC000 - 0x00007BFF2FFF (28KB) {Boot Services Code}
2023-08-06 23:17:20 - 0x00007BFF3000 - 0x00007BFFAFFF (32KB) {Boot Services Data}
2023-08-06 23:17:20 - 0x00007BFFB000 - 0x00007BFFFFFF (20KB) {Runtime Services Data}
2023-08-06 23:17:20 - 0x000100000000 - 0x000857FFFFFF (30080MB) {Free Memory}
2023-08-06 23:17:20 - 0x0000000A0000 - 0x0000000FFFFF (384KB) {Reserved Memory}
2023-08-06 23:17:20 - 0x00007C000000 - 0x00007CFFFFFF (16MB) {Reserved Memory}
2023-08-06 23:17:20 - 0x00007D7F5000 - 0x00007FFFFFFF (40MB) {Reserved Memory}
2023-08-06 23:17:20 - 0x0000F0000000 - 0x0000F7FFFFFF (128MB) {OS Memory-mapped IO}
2023-08-06 23:17:20 - 0x0000FD000000 - 0x0000FEDFFFFF (30MB) {OS Memory-mapped IO}
2023-08-06 23:17:20 - 0x0000FEE00000 - 0x0000FEE00FFF (4KB) {OS Memory-mapped IO}
2023-08-06 23:17:20 - 0x0000FEE01000 - 0x0000FFFFFFFF (17MB) {OS Memory-mapped IO}
2023-08-06 23:17:20 - 0x000858000000 - 0x000877FFFFFF (512MB) {Reserved Memory}
2023-08-06 23:17:20 - 0x00087EEC0000 - 0x00087FFFFFFF (17MB) {Reserved Memory}
2023-08-06 23:17:20 - 0x000880000000 - 0x0008A01FFFFF (514MB) {OS Memory-mapped IO}
2023-08-06 23:17:20 - 0x00FD00000000 - 0x00FFFFFFFFFF (12288MB) {Reserved Memory}
2023-08-06 23:17:20 - Available Memory: 0x7B0C57000 (30GB)
2023-08-06 23:17:20 - Reserved Memory: 0x372EF4000 (13GB)
2023-08-06 23:17:21 - mem_size - Number of entries: 66
2023-08-06 23:17:21 - mem_size - Max address: 0x10000000000
2023-08-06 23:17:21 - mem_size - Total memory size (33472782336 bytes)
2023-08-06 23:17:21 - Getting memory SPD info
2023-08-06 23:17:21 - Attempting to enable any disabled SMBus controllers...
2023-08-06 23:17:21 - Attempting to enable SMBUS:
2023-08-06 23:17:21 - Searching PCI for SMBus Controller
2023-08-06 23:17:21 - MMIO PM DECODEEN: E3070BF7 (smbus0sel=0)
2023-08-06 23:17:21 - {00:14:00} SMBus Configuration Registers:
2023-08-06 23:17:21 - 00: 790B1022 02200403 0C050071 00800000
2023-08-06 23:17:21 - 10: 00000000 00000000 00000000 00000000
2023-08-06 23:17:21 - 20: 00000000 00000000 00000000 88771043
2023-08-06 23:17:21 - 30: 00000000 00000000 00000000 00000000
2023-08-06 23:17:21 - 40: 00000000 00000000 00000000 00000000
2023-08-06 23:17:21 - 50: 00000000 00000000 00000000 00000000
2023-08-06 23:17:21 - 60: 00000000 00000000 00000000 00000000
2023-08-06 23:17:21 - 70: 00000000 00000000 00000000 00000000
2023-08-06 23:17:21 - 80: 00000000 00000000 00000000 00000000
2023-08-06 23:17:21 - 90: 00000000 00000000 00000000 00000000
2023-08-06 23:17:21 - A0: 00000000 00000000 00000000 00000000
2023-08-06 23:17:21 - B0: 00000000 00000000 00000000 00000000
2023-08-06 23:17:21 - C0: 00000000 00000000 00000000 00000000
2023-08-06 23:17:21 - D0: 00000000 00000000 00000000 00000000
2023-08-06 23:17:21 - E0: 00000000 00000000 00000000 00000000
2023-08-06 23:17:21 - F0: 00009EFD 00000000 00000000 00000000
2023-08-06 23:17:21 - Found SMBus device: VID:1022 DID:790B Bus:00 Dev:14 Fun:00 IO Add:0B00 IO (2) Add:0000 MMIO Add:0 PCI Add:{00:00:00:0000} Rev:71 [AMD Hudson-3 SMBus]
2023-08-06 23:17:21 - Finished searching PCI for SMBus Controller
2023-08-06 23:17:21 - Found 1 SMBus controllers
2023-08-06 23:17:21 - [AMD Hudson-3 SMBus Bus:00 Dev:14 Fun:00 Add:0B00] Looking for SPD
2023-08-06 23:17:21 - Previous MMIO PM DECODEEN: E3070BF7 (smbus0sel=0)
2023-08-06 23:17:21 - Device detected on SMBUS at address 51 (PIIX4)
2023-08-06 23:17:21 - Expanding SPD info array (0 => 16)
2023-08-06 23:17:21 - MemoryInfo(0x692C6018, 89600 bytes) RawSPD(0x692C1018, 16384 bytes)
2023-08-06 23:17:21 - Raw SPD bytes for DIMM#0 (Channel -1, Slot -1):
2023-08-06 23:17:21 - 51 18 12 80 B3 03 52 00 00 00 00 00 FF 3F 00 55
2023-08-06 23:17:21 - 00 00 00 00 00 00 00 00 00 00 00 00 70 03 00 00
2023-08-06 23:17:21 - 50 05 00 00 00 00 00 00 00 00 00 00 00 00 00 00
2023-08-06 23:17:21 - 00 B0 02 00 00 00 00 00 00 00 00 00 00 00 00 00
2023-08-06 23:17:21 - 00 00 00 00 00 00 00 00 00 00 F0 00 00 00 00 00
2023-08-06 23:17:21 - 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
2023-08-06 23:17:21 - 30 10 12 02 04 00 20 62 04 00 20 62 60 00 00 00
2023-08-06 23:17:21 - 00 00 00 00 A0 01 E8 03 72 0D 00 00 00 00 1A 41
2023-08-06 23:17:21 - 1A 41 1A 41 00 7D 1A BE 30 75 27 01 A0 00 82 00
2023-08-06 23:17:21 - 00 00 00 00 00 00 88 13 08 88 13 08 20 4E 20 10
2023-08-06 23:17:21 - 27 10 15 34 20 10 27 10 C4 09 04 4C 1D 0C 00 00
2023-08-06 23:17:21 - 00 00 00 00 00 00 00 00 00 00 00 00 00 00 9D 9B
2023-08-06 23:17:22 - RAM type: DDR5
2023-08-06 23:17:22 - SPD rev: 0x18
2023-08-06 23:17:22 - Length of SPD (256) not valid
2023-08-06 23:17:22 - Device detected on SMBUS at address 53 (PIIX4)
2023-08-06 23:17:22 - Raw SPD bytes for DIMM#0 (Channel -1, Slot -1):
2023-08-06 23:17:22 - 51 18 12 80 B3 03 52 00 00 00 00 00 FF 3F 00 55
2023-08-06 23:17:22 - 00 00 00 00 00 00 00 00 00 00 00 00 70 03 00 00
2023-08-06 23:17:22 - 50 05 00 00 00 00 00 00 00 00 00 00 00 00 00 00
2023-08-06 23:17:22 - 00 A0 02 00 00 00 00 00 00 00 00 00 00 00 00 00
2023-08-06 23:17:22 - 00 00 00 00 00 00 00 00 00 00 F0 00 00 00 00 00
2023-08-06 23:17:22 - 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
2023-08-06 23:17:22 - 30 10 12 02 04 00 20 62 04 00 20 62 60 00 00 00
2023-08-06 23:17:22 - 00 00 00 00 A0 01 E8 03 72 0D 00 00 00 00 1A 41
2023-08-06 23:17:22 - 1A 41 1A 41 00 7D 1A BE 30 75 27 01 A0 00 82 00
2023-08-06 23:17:22 - 00 00 00 00 00 00 88 13 08 88 13 08 20 4E 20 10
2023-08-06 23:17:22 - 27 10 15 34 20 10 27 10 C4 09 04 4C 1D 0C 00 00
2023-08-06 23:17:22 - 00 00 00 00 00 00 00 00 00 00 00 00 00 00 9D 9B
2023-08-06 23:17:22 - Previous MMIO PM DECODEEN: E3070BF7 (smbus0sel=0)
2023-08-06 23:17:22 - Writing MMIO PM DECODEEN: E30F0BF7 (smbus0sel=1)
2023-08-06 23:17:22 - Restoring MMIO PM DECODEEN: E3070BF7 (smbus0sel=0)
2023-08-06 23:17:22 - Writing MMIO PM DECODEEN: E3170BF7 (smbus0sel=2)
2023-08-06 23:17:22 - Writing MMIO PM DECODEEN: E31F0BF7 (smbus0sel=3)
2023-08-06 23:17:22 - A - Setting page address to 0
2023-08-06 23:17:22 - A - Finished setting page address to 0
2023-08-06 23:17:22 - A - Setting page address to 1
2023-08-06 23:17:22 - A - Finished setting page address to 1
2023-08-06 23:17:22 - A - Setting page address to 2
2023-08-06 23:17:22 - A - Finished setting page address to 2
2023-08-06 23:17:22 - A - Setting page address to 3
2023-08-06 23:17:22 - A - Finished setting page address to 3
2023-08-06 23:17:22 - A - Setting page address to 4
2023-08-06 23:17:22 - A - Finished setting page address to 4
2023-08-06 23:17:23 - A - Setting page address to 5
2023-08-06 23:17:23 - A - Finished setting page address to 5
2023-08-06 23:17:23 - A - Setting page address to 6
2023-08-06 23:17:23 - A - Finished setting page address to 6
2023-08-06 23:17:23 - A - Setting page address to 7
2023-08-06 23:17:23 - A - Finished setting page address to 7
2023-08-06 23:17:23 - Raw SPD bytes for DIMM#0 (Channel -1, Slot -1):
2023-08-06 23:17:23 - 30 10 12 02 04 00 20 62 04 00 20 62 60 00 00 00
2023-08-06 23:17:23 - 00 00 00 00 A0 01 E8 03 72 0D 00 00 00 00 1A 41
2023-08-06 23:17:23 - 1A 41 1A 41 00 7D 1A BE 30 75 27 01 A0 00 82 00
2023-08-06 23:17:23 - 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
2023-08-06 23:17:23 - 00 00 00 00 00 00 88 13 08 88 13 08 20 4E 20 10
2023-08-06 23:17:23 - 27 10 15 34 20 10 27 10 C4 09 04 4C 1D 0C 00 00
2023-08-06 23:17:23 - 00 00 00 00 00 00 00 00 00 00 00 00 00 00 9D 9B
2023-08-06 23:17:23 - 10 00 80 B3 80 12 8A 8C 82 12 00 00 00 00 00 00
2023-08-06 23:17:23 - 00 00 00 00 00 00 15 33 00 85 00 22 00 00 00 00
2023-08-06 23:17:23 - 00 00 00 00 00 00 00 00 00 00 00 00 00 00 9E 75
2023-08-06 23:17:23 - 02 9E 00 23 02 00 00 00 00 43 4D 4B 33 32 47 58
2023-08-06 23:17:23 - 35 4D 32 42 35 36 30 30 43 33 36 00 00 00 00 00
2023-08-06 23:17:23 - 00 00 00 00 00 00 00 00 80 CE 42 00 00 00 00 00
2023-08-06 23:17:23 - 0C 4A 30 01 00 8A 8C 01 00 12 00 00 00 00 50 72
2023-08-06 23:17:23 - 6F 66 69 6C 65 20 31 00 00 00 00 00 00 00 00 00
2023-08-06 23:17:23 - 00 00 00 00 00 00 00 00 00 00 00 00 00 00 2A 0C
2023-08-06 23:17:24 - 30 25 25 00 24 65 01 72 AD 00 00 00 00 34 32 34
2023-08-06 23:17:24 - 32 34 32 FC 69 30 9C 30 75 27 01 A0 00 82 00 88
2023-08-06 23:17:24 - 13 08 20 4E 20 10 27 10 10 27 10 C4 09 04 88 13
2023-08-06 23:17:24 - 08 4C 1D 0C A4 2C 20 00 00 00 00 03 10 00 79 3A
2023-08-06 23:17:24 - 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
2023-08-06 23:17:24 - RAM type: DDR5
2023-08-06 23:17:24 - SPD rev: 0x10
2023-08-06 23:17:24 - Calculated CRC16 (5B9E) does not match stored CRC16 (759E)
2023-08-06 23:17:24 - Module type: UDIMM
2023-08-06 23:17:24 - Size: 16384 MB
2023-08-06 23:17:24 - Banks x Rows x Columns x Bits: 32 x 16 x 10 x 32
2023-08-06 23:17:24 - Ranks: 1
2023-08-06 23:17:24 - SDRAM Device Width: 8
2023-08-06 23:17:24 - SDRAM Package Type: Monolithic SDRAM
2023-08-06 23:17:24 - Operable voltages: 1.1V
2023-08-06 23:17:24 - SDRAM Nominal Voltage, VDD: 1.1V
2023-08-06 23:17:24 - SDRAM Nominal Voltage, VDDQ: 1.1V
2023-08-06 23:17:24 - SDRAM Nominal Voltage, VPP: 1.8V
2023-08-06 23:17:24 - ECC: No
2023-08-06 23:17:24 - Minimum clock cycle time (ns): 0.416
2023-08-06 23:17:24 - Maximum clock cycle time (ns): 1.000
2023-08-06 23:17:24 - Maximum clock speed: 2400 MHz
2023-08-06 23:17:24 - Maximum module speed: 4800 MT/s (PC5-38400)
2023-08-06 23:17:24 - Supported CAS: 22 28 30 32 36 40 42
2023-08-06 23:17:24 - Minimum CAS latency time (tAA): 16.666
2023-08-06 23:17:24 - Minimum RAS to CAS delay time (tRCD): 16.666
2023-08-06 23:17:24 - Minimum row precharge time (tRP): 16.666
2023-08-06 23:17:24 - Minimum active to precharge time (tRAS): 32.000
2023-08-06 23:17:24 - Supported timing at highest clock speed (2400 MHz) : 40-40-40-77
2023-08-06 23:17:24 - SPD present: Yes
2023-08-06 23:17:24 - SPD device type: SPD5118
2023-08-06 23:17:24 - PMIC 0 present: Yes
2023-08-06 23:17:24 - PMIC 0 device type: PMIC5100
2023-08-06 23:17:24 - PMIC 1 present: No
2023-08-06 23:17:24 - PMIC 1 device type: PMIC5010
2023-08-06 23:17:24 - PMIC 2 present: No
2023-08-06 23:17:24 - PMIC 2 device type: PMIC5010
2023-08-06 23:17:24 - Thermal Sensor 0 present: No
2023-08-06 23:17:24 - Thermal Sensor 1 present: No
2023-08-06 23:17:24 - Module Height (mm): 35 - 36
2023-08-06 23:17:25 - Module Thickness (mm): front 3-4 , back 3-4
2023-08-06 23:17:25 - Module reference card: Raw Card A Rev. 0
2023-08-06 23:17:25 - Rank Mix: Symmetrical
2023-08-06 23:17:25 - Number of Package Ranks per Channel: 1
2023-08-06 23:17:25 - Number of Channels per DIMM: 2
2023-08-06 23:17:25 - Bus width extension per Channel: 0 bits
2023-08-06 23:17:25 - Primary bus width per Channel: 32 bits
2023-08-06 23:17:25 - Module Manufacturer: Corsair (Bank: 3, ID: 0x9E)
2023-08-06 23:17:25 - Module manufacturing location: 0x00
2023-08-06 23:17:25 - Manufacturing Date: Year 2023 Week 2
2023-08-06 23:17:25 - Module serial number: 0x00000000
2023-08-06 23:17:25 - Module Part Number: CMK32GX5M2B5600C36
2023-08-06 23:17:25 - Revision Code: 0x00
2023-08-06 23:17:25 - DRAM Manufacturer: Samsung (Bank: 1, ID: 0xCE)
2023-08-06 23:17:25 - DRAM Stepping: 0x42
2023-08-06 23:17:25 - Module Manufacturer's Specific Data raw bytes:
2023-08-06 23:17:25 - 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
2023-08-06 23:17:25 - XMP supported: Yes
2023-08-06 23:17:25 - XMP version: 3.0
2023-08-06 23:17:25 - XMP PMIC Vendor ID: 8A8C
2023-08-06 23:17:25 - XMP number of PMICs: 1
2023-08-06 23:17:25 - XMP PMIC OC capabilities (capable: No, enabled: No, voltage default step size: 5mV, global reset function: Disabled)
2023-08-06 23:17:25 - XMP spec revision: 1.2
2023-08-06 23:17:25 - XMP Validation and Certification Capabilities (Self-certified: No, PMIC validated by Intel AVL level: No
2023-08-06 23:17:25 - XMP Base Configuration Section CRC16: 0x0C2A
2023-08-06 23:17:25 - [XMP Profile 1] Profile enabled: Yes (certified: No)
2023-08-06 23:17:25 - [XMP Profile 1] recommended DIMMs per channel: 1
2023-08-06 23:17:25 - [XMP Profile 1] profile name: Profile 1
2023-08-06 23:17:25 - Module VPP Voltage Level: 1.8V
2023-08-06 23:17:25 - Module VDD Voltage Level: 1.25V
2023-08-06 23:17:25 - Module VDDQ Voltage Level: 1.25V
2023-08-06 23:17:25 - Memory controller Voltage Level: 1.2V
2023-08-06 23:17:25 - SDRAM Minimum Cycle Time (tCKAVGmin): 0.357
2023-08-06 23:17:25 - Maximum clock speed: 2800 MHz
2023-08-06 23:17:25 - Supported CAS: 22 28 30 32 36 40 42 46 50
2023-08-06 23:17:25 - Minimum CAS Latency Time (tAAmin): 12.852
2023-08-06 23:17:25 - Minimum RAS to CAS Delay Time (tRCDmin): 12.852
2023-08-06 23:17:25 - Minimum Row Precharge Delay Time (tRPmin): 12.852
2023-08-06 23:17:25 - Minimum Active to Precharge Delay Time (tRASmin): 27.132
2023-08-06 23:17:25 - Minimum Active to Active/Refresh Delay Time (tRCmin): 39.984
2023-08-06 23:17:25 - Minimum Write Recovery Time (tWRmin): 30.000
2023-08-06 23:17:25 - Minimum Refresh Recovery Delay Time (tRFC1min): 295.000
2023-08-06 23:17:25 - Minimum Refresh Recovery Delay Time (tRFC2min): 160.000
2023-08-06 23:17:25 - Minimum Refresh Recovery Delay Time (tRFCsb): 130.000
2023-08-06 23:17:25 - Minimum Read to Read Command Delay Time, Same Bank Group (tCCD_L): 5.000
2023-08-06 23:17:25 - Minimum Write to Write Command Delay Time, Same Bank Group (tCCD_L_WR): 20.000
2023-08-06 23:17:25 - SDRAM Minimum Write to Write Command Delay Time, Second Write not RMW, Same Bank Group (tCCD_L_WR2): 10.000
2023-08-06 23:17:25 - SDRAM Minimum Write to Read Command Delay Time, Same Bank Group (tCCD_L_WTR): 10.000
2023-08-06 23:17:25 - SDRAM Minimum Write to Read Command Delay Time, Different Bank Group (tCCD_S_WTR): 2.500
2023-08-06 23:17:25 - SDRAM Minimum Active to Active Command Delay Time, Same Bank Group (tRRD_L): 5.000
2023-08-06 23:17:25 - SDRAM Minimum Read to Precharge Command Delay Time, (tRTP): 7.500
2023-08-06 23:17:25 - SDRAM Minimum Four Activate Window (tFAW min): 11.428
2023-08-06 23:17:25 - Advanced Memory Overclocking Features: Real-Time Memory Frequency Overclocking: supported, Intel® Dynamic Memory Boost: supported
2023-08-06 23:17:25 - System CMD Rate Mode: 16n
2023-08-06 23:17:25 - Vendor Personality Byte: 00
2023-08-06 23:17:25 - [XMP Profile 2] Profile enabled: No (certified: No)
2023-08-06 23:17:25 - [XMP Profile 2] recommended DIMMs per channel: 1
2023-08-06 23:17:25 - [XMP Profile 3] Profile enabled: No (certified: No)
2023-08-06 23:17:25 - [XMP Profile 3] recommended DIMMs per channel: 1
2023-08-06 23:17:25 - [XMP Profile 4] User profile
2023-08-06 23:17:25 - [XMP Profile 5] User profile
2023-08-06 23:17:26 - DIMM#0 (Channel -1, Slot -1) serial number: 00000000
2023-08-06 23:17:26 - A - Setting page address to 0
2023-08-06 23:17:26 - A - Finished setting page address to 0
2023-08-06 23:17:26 - A - Setting page address to 1
2023-08-06 23:17:26 - A - Finished setting page address to 1
2023-08-06 23:17:26 - A - Setting page address to 2
2023-08-06 23:17:26 - A - Finished setting page address to 2
2023-08-06 23:17:26 - A - Setting page address to 3
2023-08-06 23:17:26 - A - Finished setting page address to 3
2023-08-06 23:17:26 - A - Setting page address to 4
2023-08-06 23:17:26 - A - Finished setting page address to 4
2023-08-06 23:17:26 - A - Setting page address to 5
2023-08-06 23:17:26 - A - Finished setting page address to 5
2023-08-06 23:17:26 - A - Setting page address to 6
2023-08-06 23:17:26 - A - Finished setting page address to 6
2023-08-06 23:17:26 - A - Setting page address to 7
2023-08-06 23:17:26 - A - Finished setting page address to 7
2023-08-06 23:17:26 - Raw SPD bytes for DIMM#1 (Channel -1, Slot -1):
2023-08-06 23:17:26 - 30 10 12 02 04 00 20 62 04 00 20 62 60 00 00 00
2023-08-06 23:17:26 - 00 00 00 00 A0 01 E8 03 72 0D 00 00 00 00 1A 41
2023-08-06 23:17:26 - 1A 41 1A 41 00 7D 1A BE 30 75 27 01 A0 00 82 00
2023-08-06 23:17:26 - 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
2023-08-06 23:17:26 - 00 00 00 00 00 00 88 13 08 88 13 08 20 4E 20 10
2023-08-06 23:17:26 - 27 10 15 34 20 10 27 10 C4 09 04 4C 1D 0C 00 00
2023-08-06 23:17:26 - 00 00 00 00 00 00 00 00 00 00 00 00 00 00 9D 9B
2023-08-06 23:17:26 - 10 00 80 B3 80 12 8A 8C 82 12 00 00 00 00 00 00
2023-08-06 23:17:26 - 00 00 00 00 00 00 15 33 00 85 00 22 00 00 00 00
2023-08-06 23:17:27 - 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
2023-08-06 23:17:27 - 00 00 00 00 00 00 00 00 00 00 00 00 00 00 9E 75
2023-08-06 23:17:27 - 02 9E 00 23 02 00 00 00 00 43 4D 4B 33 32 47 58
2023-08-06 23:17:27 - 35 4D 32 42 35 36 30 30 43 33 36 00 00 00 00 00
2023-08-06 23:17:27 - 00 00 00 00 00 00 00 00 80 CE 42 00 00 00 00 00
2023-08-06 23:17:27 - 0C 4A 30 01 00 8A 8C 01 00 12 00 00 00 00 50 72
2023-08-06 23:17:27 - 6F 66 69 6C 65 20 31 00 00 00 00 00 00 00 00 00
2023-08-06 23:17:27 - 00 00 00 00 00 00 00 00 00 00 00 00 00 00 2A 0C
2023-08-06 23:17:27 - 30 25 25 00 24 65 01 72 AD 00 00 00 00 34 32 34
2023-08-06 23:17:27 - 32 34 32 FC 69 30 9C 30 75 27 01 A0 00 82 00 88
2023-08-06 23:17:27 - 13 08 20 4E 20 10 27 10 10 27 10 C4 09 04 88 13
2023-08-06 23:17:27 - 08 4C 1D 0C A4 2C 20 00 00 00 00 03 10 00 79 3A
2023-08-06 23:17:27 - RAM type: DDR5
2023-08-06 23:17:27 - SPD rev: 0x10
2023-08-06 23:17:27 - Calculated CRC16 (5B9E) does not match stored CRC16 (759E)
2023-08-06 23:17:27 - Module type: UDIMM
2023-08-06 23:17:27 - Size: 16384 MB
2023-08-06 23:17:27 - Banks x Rows x Columns x Bits: 32 x 16 x 10 x 32
2023-08-06 23:17:27 - Ranks: 1
2023-08-06 23:17:27 - SDRAM Device Width: 8
2023-08-06 23:17:27 - SDRAM Package Type: Monolithic SDRAM
2023-08-06 23:17:27 - Operable voltages: 1.1V
2023-08-06 23:17:27 - SDRAM Nominal Voltage, VDD: 1.1V
2023-08-06 23:17:27 - SDRAM Nominal Voltage, VDDQ: 1.1V
2023-08-06 23:17:27 - SDRAM Nominal Voltage, VPP: 1.8V
2023-08-06 23:17:27 - ECC: No
2023-08-06 23:17:27 - Minimum clock cycle time (ns): 0.416
2023-08-06 23:17:28 - Maximum clock cycle time (ns): 1.000
2023-08-06 23:17:28 - Maximum clock speed: 2400 MHz
2023-08-06 23:17:28 - Maximum module speed: 4800 MT/s (PC5-38400)
2023-08-06 23:17:28 - Supported CAS: 22 28 30 32 36 40 42
2023-08-06 23:17:28 - Minimum CAS latency time (tAA): 16.666
2023-08-06 23:17:28 - Minimum RAS to CAS delay time (tRCD): 16.666
2023-08-06 23:17:28 - Minimum row precharge time (tRP): 16.666
2023-08-06 23:17:28 - Minimum active to precharge time (tRAS): 32.000
2023-08-06 23:17:28 - Supported timing at highest clock speed (2400 MHz) : 40-40-40-77
2023-08-06 23:17:28 - SPD present: Yes
2023-08-06 23:17:28 - SPD device type: SPD5118
2023-08-06 23:17:28 - PMIC 0 present: Yes
2023-08-06 23:17:28 - PMIC 0 device type: PMIC5100
2023-08-06 23:17:28 - PMIC 1 present: No
2023-08-06 23:17:28 - PMIC 1 device type: PMIC5010
2023-08-06 23:17:28 - PMIC 2 present: No
2023-08-06 23:17:28 - PMIC 2 device type: PMIC5010
2023-08-06 23:17:28 - Thermal Sensor 0 present: No
2023-08-06 23:17:28 - Thermal Sensor 1 present: No
2023-08-06 23:17:28 - Module Height (mm): 35 - 36
2023-08-06 23:17:28 - Module Thickness (mm): front 3-4 , back 3-4
2023-08-06 23:17:28 - Module reference card: Raw Card A Rev. 0
2023-08-06 23:17:28 - Rank Mix: Symmetrical
2023-08-06 23:17:28 - Number of Package Ranks per Channel: 1
2023-08-06 23:17:28 - Number of Channels per DIMM: 2
2023-08-06 23:17:28 - Bus width extension per Channel: 0 bits
2023-08-06 23:17:28 - Primary bus width per Channel: 32 bits
2023-08-06 23:17:28 - Module Manufacturer: Corsair (Bank: 3, ID: 0x9E)
2023-08-06 23:17:28 - Module manufacturing location: 0x00
2023-08-06 23:17:28 - Manufacturing Date: Year 2023 Week 2
2023-08-06 23:17:28 - Module serial number: 0x00000000
2023-08-06 23:17:28 - Module Part Number: CMK32GX5M2B5600C36
2023-08-06 23:17:28 - Revision Code: 0x00
2023-08-06 23:17:28 - DRAM Manufacturer: Samsung (Bank: 1, ID: 0xCE)
2023-08-06 23:17:28 - DRAM Stepping: 0x42
2023-08-06 23:17:28 - Module Manufacturer's Specific Data raw bytes:
2023-08-06 23:17:28 - 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
2023-08-06 23:17:28 - XMP supported: Yes
2023-08-06 23:17:28 - XMP version: 3.0
2023-08-06 23:17:28 - XMP PMIC Vendor ID: 8A8C
2023-08-06 23:17:28 - XMP number of PMICs: 1
2023-08-06 23:17:28 - XMP PMIC OC capabilities (capable: No, enabled: No, voltage default step size: 5mV, global reset function: Disabled)
2023-08-06 23:17:28 - XMP spec revision: 1.2
2023-08-06 23:17:28 - XMP Validation and Certification Capabilities (Self-certified: No, PMIC validated by Intel AVL level: No
2023-08-06 23:17:28 - XMP Base Configuration Section CRC16: 0x0C2A
2023-08-06 23:17:28 - [XMP Profile 1] Profile enabled: Yes (certified: No)
2023-08-06 23:17:28 - [XMP Profile 1] recommended DIMMs per channel: 1
2023-08-06 23:17:28 - [XMP Profile 1] profile name: Profile 1
2023-08-06 23:17:28 - Module VPP Voltage Level: 1.8V
2023-08-06 23:17:28 - Module VDD Voltage Level: 1.25V
2023-08-06 23:17:28 - Module VDDQ Voltage Level: 1.25V
2023-08-06 23:17:28 - Memory controller Voltage Level: 1.2V
2023-08-06 23:17:28 - SDRAM Minimum Cycle Time (tCKAVGmin): 0.357
2023-08-06 23:17:28 - Maximum clock speed: 2800 MHz
2023-08-06 23:17:28 - Supported CAS: 22 28 30 32 36 40 42 46 50
2023-08-06 23:17:28 - Minimum CAS Latency Time (tAAmin): 12.852
2023-08-06 23:17:28 - Minimum RAS to CAS Delay Time (tRCDmin): 12.852
2023-08-06 23:17:28 - Minimum Row Precharge Delay Time (tRPmin): 12.852
2023-08-06 23:17:29 - Minimum Active to Precharge Delay Time (tRASmin): 27.132
2023-08-06 23:17:29 - Minimum Active to Active/Refresh Delay Time (tRCmin): 39.984
2023-08-06 23:17:29 - Minimum Write Recovery Time (tWRmin): 30.000
2023-08-06 23:17:29 - Minimum Refresh Recovery Delay Time (tRFC1min): 295.000
2023-08-06 23:17:29 - Minimum Refresh Recovery Delay Time (tRFC2min): 160.000
2023-08-06 23:17:29 - Minimum Refresh Recovery Delay Time (tRFCsb): 130.000
2023-08-06 23:17:29 - Minimum Read to Read Command Delay Time, Same Bank Group (tCCD_L): 5.000
2023-08-06 23:17:29 - Minimum Write to Write Command Delay Time, Same Bank Group (tCCD_L_WR): 20.000
2023-08-06 23:17:29 - SDRAM Minimum Write to Write Command Delay Time, Second Write not RMW, Same Bank Group (tCCD_L_WR2): 10.000
2023-08-06 23:17:29 - SDRAM Minimum Write to Read Command Delay Time, Same Bank Group (tCCD_L_WTR): 10.000
2023-08-06 23:17:29 - SDRAM Minimum Write to Read Command Delay Time, Different Bank Group (tCCD_S_WTR): 2.500
2023-08-06 23:17:29 - SDRAM Minimum Active to Active Command Delay Time, Same Bank Group (tRRD_L): 5.000
2023-08-06 23:17:29 - SDRAM Minimum Read to Precharge Command Delay Time, (tRTP): 7.500
2023-08-06 23:17:29 - SDRAM Minimum Four Activate Window (tFAW min): 11.428
2023-08-06 23:17:29 - Advanced Memory Overclocking Features: Real-Time Memory Frequency Overclocking: supported, Intel® Dynamic Memory Boost: supported
2023-08-06 23:17:29 - System CMD Rate Mode: 16n
2023-08-06 23:17:29 - Vendor Personality Byte: 00
2023-08-06 23:17:29 - [XMP Profile 2] Profile enabled: No (certified: No)
2023-08-06 23:17:29 - [XMP Profile 2] recommended DIMMs per channel: 1
2023-08-06 23:17:29 - [XMP Profile 3] Profile enabled: No (certified: No)
2023-08-06 23:17:29 - [XMP Profile 3] recommended DIMMs per channel: 1
2023-08-06 23:17:29 - [XMP Profile 4] User profile
2023-08-06 23:17:29 - [XMP Profile 5] User profile
2023-08-06 23:17:29 - DIMM#1 (Channel -1, Slot -1) serial number: 00000000
2023-08-06 23:17:29 - Previous MMIO PM DECODEEN: E3070BF7 (smbus0sel=0)
2023-08-06 23:17:29 - Writing MMIO PM DECODEEN: E30F0BF7 (smbus0sel=1)
2023-08-06 23:17:29 - Restoring MMIO PM DECODEEN: E3070BF7 (smbus0sel=0)
2023-08-06 23:17:29 - Writing MMIO PM DECODEEN: E3170BF7 (smbus0sel=2)
2023-08-06 23:17:29 - Writing MMIO PM DECODEEN: E31F0BF7 (smbus0sel=3)
2023-08-06 23:17:29 - Enumerating PCI bus...
2023-08-06 23:17:29 - Scanning PCI for devices:
2023-08-06 23:17:29 - VID:1022 DID:14D8 Bus:00 Dev:00 Fun:00 IO Add:0000 IO (2) Add:0000 MMIO Add:0 PCI Add:{00:00:00:0000} Rev:00 [AMD Unknown]
2023-08-06 23:17:29 - VID:1022 DID:14D9 Bus:00 Dev:00 Fun:02 IO Add:0000 IO (2) Add:0000 MMIO Add:0 PCI Add:{00:00:00:0000} Rev:00 [AMD Unknown]
2023-08-06 23:17:29 - VID:1022 DID:14DA Bus:00 Dev:01 Fun:00 IO Add:0000 IO (2) Add:0000 MMIO Add:0 PCI Add:{00:00:00:0000} Rev:00 [AMD Unknown]
2023-08-06 23:17:29 - VID:1022 DID:14DB Bus:00 Dev:01 Fun:01 IO Add:0000 IO (2) Add:0000 MMIO Add:0 PCI Add:{00:00:00:0000} Rev:00 [AMD Unknown]
2023-08-06 23:17:29 - VID:1022 DID:14DA Bus:00 Dev:02 Fun:00 IO Add:0000 IO (2) Add:0000 MMIO Add:0 PCI Add:{00:00:00:0000} Rev:00 [AMD Unknown]
2023-08-06 23:17:29 - VID:1022 DID:14DB Bus:00 Dev:02 Fun:01 IO Add:0000 IO (2) Add:0000 MMIO Add:0 PCI Add:{00:00:00:0000} Rev:00 [AMD Unknown]
2023-08-06 23:17:29 - VID:1022 DID:14DB Bus:00 Dev:02 Fun:02 IO Add:0000 IO (2) Add:0000 MMIO Add:0 PCI Add:{00:00:00:0000} Rev:00 [AMD Unknown]
2023-08-06 23:17:29 - VID:1022 DID:14DA Bus:00 Dev:03 Fun:00 IO Add:0000 IO (2) Add:0000 MMIO Add:0 PCI Add:{00:00:00:0000} Rev:00 [AMD Unknown]
2023-08-06 23:17:29 - VID:1022 DID:14DA Bus:00 Dev:04 Fun:00 IO Add:0000 IO (2) Add:0000 MMIO Add:0 PCI Add:{00:00:00:0000} Rev:00 [AMD Unknown]
2023-08-06 23:17:29 - VID:1022 DID:14DA Bus:00 Dev:08 Fun:00 IO Add:0000 IO (2) Add:0000 MMIO Add:0 PCI Add:{00:00:00:0000} Rev:00 [AMD Unknown]
2023-08-06 23:17:29 - VID:1022 DID:14DD Bus:00 Dev:08 Fun:01 IO Add:0000 IO (2) Add:0000 MMIO Add:0 PCI Add:{00:00:00:0000} Rev:00 [AMD Unknown]
2023-08-06 23:17:29 - VID:1022 DID:14DD Bus:00 Dev:08 Fun:03 IO Add:0000 IO (2) Add:0000 MMIO Add:0 PCI Add:{00:00:00:0000} Rev:00 [AMD Unknown]
2023-08-06 23:17:29 - MMIO PM DECODEEN: E3070BF7 (smbus0sel=0)
2023-08-06 23:17:29 - {00:14:00} SMBus Configuration Registers:
2023-08-06 23:17:29 - 00: 790B1022 02200403 0C050071 00800000
2023-08-06 23:17:29 - 10: 00000000 00000000 00000000 00000000
2023-08-06 23:17:29 - 20: 00000000 00000000 00000000 88771043
2023-08-06 23:17:29 - 30: 00000000 00000000 00000000 00000000
2023-08-06 23:17:29 - 40: 00000000 00000000 00000000 00000000
2023-08-06 23:17:29 - 50: 00000000 00000000 00000000 00000000
2023-08-06 23:17:29 - 60: 00000000 00000000 00000000 00000000
2023-08-06 23:17:29 - 70: 00000000 00000000 00000000 00000000
2023-08-06 23:17:30 - 80: 00000000 00000000 00000000 00000000
2023-08-06 23:17:30 - 90: 00000000 00000000 00000000 00000000
2023-08-06 23:17:30 - A0: 00000000 00000000 00000000 00000000
2023-08-06 23:17:30 - B0: 00000000 00000000 00000000 00000000
2023-08-06 23:17:30 - C0: 00000000 00000000 00000000 00000000
2023-08-06 23:17:30 - D0: 00000000 00000000 00000000 00000000
2023-08-06 23:17:30 - E0: 00000000 00000000 00000000 00000000
2023-08-06 23:17:30 - F0: 00009EFD 00000000 00000000 00000000
2023-08-06 23:17:30 - VID:1022 DID:790B Bus:00 Dev:14 Fun:00 IO Add:0B00 IO (2) Add:0000 MMIO Add:0 PCI Add:{00:00:00:0000} Rev:71 [AMD Hudson-3 SMBus]
2023-08-06 23:17:30 - VID:1022 DID:790E Bus:00 Dev:14 Fun:03 IO Add:0000 IO (2) Add:0000 MMIO Add:0 PCI Add:{00:00:00:0000} Rev:51 [AMD Unknown]
2023-08-06 23:17:30 - VID:1022 DID:14E0 Bus:00 Dev:18 Fun:00 IO Add:0000 IO (2) Add:0000 MMIO Add:0 PCI Add:{00:00:00:0000} Rev:00 [AMD Unknown]
2023-08-06 23:17:30 - VID:1022 DID:14E1 Bus:00 Dev:18 Fun:01 IO Add:0000 IO (2) Add:0000 MMIO Add:0 PCI Add:{00:00:00:0000} Rev:00 [AMD Unknown]
2023-08-06 23:17:30 - VID:1022 DID:14E2 Bus:00 Dev:18 Fun:02 IO Add:0000 IO (2) Add:0000 MMIO Add:0 PCI Add:{00:00:00:0000} Rev:00 [AMD Unknown]
2023-08-06 23:17:30 - VID:1022 DID:14E3 Bus:00 Dev:18 Fun:03 IO Add:0000 IO (2) Add:0000 MMIO Add:0 PCI Add:{00:00:00:0000} Rev:00 [AMD Unknown]
2023-08-06 23:17:30 - VID:1022 DID:14E4 Bus:00 Dev:18 Fun:04 IO Add:0000 IO (2) Add:0000 MMIO Add:0 PCI Add:{00:00:00:0000} Rev:00 [AMD Unknown]
2023-08-06 23:17:30 - VID:1022 DID:14E5 Bus:00 Dev:18 Fun:05 IO Add:0000 IO (2) Add:0000 MMIO Add:0 PCI Add:{00:00:00:0000} Rev:00 [AMD Unknown]
2023-08-06 23:17:30 - VID:1022 DID:14E6 Bus:00 Dev:18 Fun:06 IO Add:0000 IO (2) Add:0000 MMIO Add:0 PCI Add:{00:00:00:0000} Rev:00 [AMD Unknown]
2023-08-06 23:17:30 - VID:1022 DID:14E7 Bus:00 Dev:18 Fun:07 IO Add:0000 IO (2) Add:0000 MMIO Add:0 PCI Add:{00:00:00:0000} Rev:00 [AMD Unknown]
2023-08-06 23:17:30 - VID:10DE DID:2704 Bus:01 Dev:00 Fun:00 IO Add:0000 IO (2) Add:0000 MMIO Add:0 PCI Add:{00:00:00:0000} Rev:A1 [nVidia Unknown]
2023-08-06 23:17:30 - VID:10DE DID:22BB Bus:01 Dev:00 Fun:01 IO Add:0000 IO (2) Add:0000 MMIO Add:0 PCI Add:{00:00:00:0000} Rev:A1 [nVidia Unknown]
2023-08-06 23:17:30 - VID:1022 DID:43F4 Bus:02 Dev:00 Fun:00 IO Add:0000 IO (2) Add:0000 MMIO Add:0 PCI Add:{00:00:00:0000} Rev:01 [AMD Unknown]
2023-08-06 23:17:30 - VID:1022 DID:43F5 Bus:03 Dev:00 Fun:00 IO Add:0000 IO (2) Add:0000 MMIO Add:0 PCI Add:{00:00:00:0000} Rev:01 [AMD Unknown]
2023-08-06 23:17:30 - VID:1022 DID:43F5 Bus:03 Dev:08 Fun:00 IO Add:0000 IO (2) Add:0000 MMIO Add:0 PCI Add:{00:00:00:0000} Rev:01 [AMD Unknown]
2023-08-06 23:17:30 - VID:1022 DID:43F5 Bus:03 Dev:09 Fun:00 IO Add:0000 IO (2) Add:0000 MMIO Add:0 PCI Add:{00:00:00:0000} Rev:01 [AMD Unknown]
2023-08-06 23:17:30 - VID:1022 DID:43F5 Bus:03 Dev:0A Fun:00 IO Add:0000 IO (2) Add:0000 MMIO Add:0 PCI Add:{00:00:00:0000} Rev:01 [AMD Unknown]
2023-08-06 23:17:30 - VID:1022 DID:43F5 Bus:03 Dev:0B Fun:00 IO Add:0000 IO (2) Add:0000 MMIO Add:0 PCI Add:{00:00:00:0000} Rev:01 [AMD Unknown]
2023-08-06 23:17:30 - VID:1022 DID:43F5 Bus:03 Dev:0C Fun:00 IO Add:0000 IO (2) Add:0000 MMIO Add:0 PCI Add:{00:00:00:0000} Rev:01 [AMD Unknown]
2023-08-06 23:17:30 - VID:1022 DID:43F5 Bus:03 Dev:0D Fun:00 IO Add:0000 IO (2) Add:0000 MMIO Add:0 PCI Add:{00:00:00:0000} Rev:01 [AMD Unknown]
2023-08-06 23:17:30 - VID:144D DID:A80A Bus:04 Dev:00 Fun:00 IO Add:0000 IO (2) Add:0000 MMIO Add:0 PCI Add:{00:00:00:0000} Rev:00 [Unknown Unknown]
2023-08-06 23:17:30 - VID:8086 DID:15F3 Bus:07 Dev:00 Fun:00 IO Add:0000 IO (2) Add:0000 MMIO Add:0 PCI Add:{00:00:00:0000} Rev:03 [Intel Unknown]
2023-08-06 23:17:30 - VID:14C3 DID:0608 Bus:08 Dev:00 Fun:00 IO Add:0000 IO (2) Add:0000 MMIO Add:0 PCI Add:{00:00:00:0000} Rev:00 [Unknown Unknown]
2023-08-06 23:17:30 - VID:1022 DID:43F7 Bus:09 Dev:00 Fun:00 IO Add:0000 IO (2) Add:0000 MMIO Add:0 PCI Add:{00:00:00:0000} Rev:01 [AMD Unknown]
2023-08-06 23:17:30 - VID:1022 DID:43F6 Bus:0A Dev:00 Fun:00 IO Add:0000 IO (2) Add:0000 MMIO Add:0 PCI Add:{00:00:00:0000} Rev:01 [AMD Unknown]
2023-08-06 23:17:30 - VID:144D DID:A80A Bus:0B Dev:00 Fun:00 IO Add:0000 IO (2) Add:0000 MMIO Add:0 PCI Add:{00:00:00:0000} Rev:00 [Unknown Unknown]
2023-08-06 23:17:30 - VID:1002 DID:164E Bus:0C Dev:00 Fun:00 IO Add:0000 IO (2) Add:0000 MMIO Add:0 PCI Add:{00:00:00:0000} Rev:C1 [ATI Unknown]
2023-08-06 23:17:30 - VID:1002 DID:1640 Bus:0C Dev:00 Fun:01 IO Add:0000 IO (2) Add:0000 MMIO Add:0 PCI Add:{00:00:00:0000} Rev:00 [ATI Unknown]
2023-08-06 23:17:30 - VID:1022 DID:1649 Bus:0C Dev:00 Fun:02 IO Add:0000 IO (2) Add:0000 MMIO Add:0 PCI Add:{00:00:00:0000} Rev:00 [AMD Unknown]
2023-08-06 23:17:30 - VID:1022 DID:15B6 Bus:0C Dev:00 Fun:03 IO Add:0000 IO (2) Add:0000 MMIO Add:0 PCI Add:{00:00:00:0000} Rev:00 [AMD Unknown]
2023-08-06 23:17:30 - VID:1022 DID:15B7 Bus:0C Dev:00 Fun:04 IO Add:0000 IO (2) Add:0000 MMIO Add:0 PCI Add:{00:00:00:0000} Rev:00 [AMD Unknown]
2023-08-06 23:17:30 - VID:1022 DID:15B8 Bus:0D Dev:00 Fun:00 IO Add:0000 IO (2) Add:0000 MMIO Add:0 PCI Add:{00:00:00:0000} Rev:00 [AMD Unknown]
2023-08-06 23:17:30 - Finished searching PCI for SMBus Controller
2023-08-06 23:17:30 - Getting SMBIOS Memory Device info...
2023-08-06 23:17:30 - Found 4 Memory Devices
2023-08-06 23:17:30 - DEBUG: Get SMB mem device Struct 0
2023-08-06 23:17:30 - DEBUG: Get SMB mem device Struct Get strings (FormattedLen=92, iTotalLen=91)
2023-08-06 23:17:30 - DEBUG: Get SMB mem device Struct: String area len=53
2023-08-06 23:17:30 - DEBUG: Get SMB mem device Struct: parsing v2.3+ strings
2023-08-06 23:17:30 - DEBUG: Get SMB mem device Struct: parsing v3.2+ strings
2023-08-06 23:17:30 - DEBUG: Get SMB mem device Struct end
2023-08-06 23:17:30 - [Slot 0] TotalWidth: 65535, DataWidth: 65535, Size: 0, FormFactor: 2, DeviceSet: 0, MemoryType: 2, Speed: 0, Attributes: 0, ExtendedSize: 0, ConfiguredMemoryClockSpeed: 0, MinimumVoltage: 0, MaximumVoltage: 0, ConfiguredVoltage: 0
2023-08-06 23:17:30 - [Slot 0] DeviceLocator: DIMM 0, BankLocator: P0 CHANNEL A, Manufacturer: Unknown, S/N: Unknown, AssetTag: , PartNumber: Unknown
2023-08-06 23:17:30 - DEBUG: Get SMB mem device Struct 1
2023-08-06 23:17:30 - DEBUG: Get SMB mem device Struct Get strings (FormattedLen=92, iTotalLen=9D)
2023-08-06 23:17:30 - DEBUG: Get SMB mem device Struct: String area len=65
2023-08-06 23:17:30 - [Slot 1] TotalWidth: 64, DataWidth: 64, Size: 16384, FormFactor: 9, DeviceSet: 0, MemoryType: 34, Speed: 4800, Attributes: 1, ExtendedSize: 0, ConfiguredMemoryClockSpeed: 4800, MinimumVoltage: 1100, MaximumVoltage: 1100, ConfiguredVoltage: 1100
2023-08-06 23:17:30 - [Slot 1] DeviceLocator: DIMM 1, BankLocator: P0 CHANNEL A, Manufacturer: Unknown, S/N: 00000000, AssetTag: , PartNumber: CMK32GX5M2B5600C36
2023-08-06 23:17:30 - DEBUG: Get SMB mem device Struct 2
2023-08-06 23:17:30 - [Slot 2] TotalWidth: 65535, DataWidth: 65535, Size: 0, FormFactor: 2, DeviceSet: 0, MemoryType: 2, Speed: 0, Attributes: 0, ExtendedSize: 0, ConfiguredMemoryClockSpeed: 0, MinimumVoltage: 0, MaximumVoltage: 0, ConfiguredVoltage: 0
2023-08-06 23:17:30 - [Slot 2] DeviceLocator: DIMM 0, BankLocator: P0 CHANNEL B, Manufacturer: Unknown, S/N: Unknown, AssetTag: , PartNumber: Unknown
2023-08-06 23:17:30 - DEBUG: Get SMB mem device Struct 3
2023-08-06 23:17:31 - DEBUG: Get SMB mem device Struct: String area len=65
2023-08-06 23:17:31 - DEBUG: Get SMB mem device Struct: parsing v2.3+ strings
2023-08-06 23:17:31 - DEBUG: Get SMB mem device Struct: parsing v3.2+ strings
2023-08-06 23:17:31 - DEBUG: Get SMB mem device Struct end
2023-08-06 23:17:31 - [Slot 3] TotalWidth: 64, DataWidth: 64, Size: 16384, FormFactor: 9, DeviceSet: 0, MemoryType: 34, Speed: 4800, Attributes: 1, ExtendedSize: 0, ConfiguredMemoryClockSpeed: 4800, MinimumVoltage: 1100, MaximumVoltage: 1100, ConfiguredVoltage: 1100
2023-08-06 23:17:31 - [Slot 3] DeviceLocator: DIMM 1, BankLocator: P0 CHANNEL B, Manufacturer: Unknown, S/N: 00000000, AssetTag: , PartNumber: CMK32GX5M2B5600C36
2023-08-06 23:17:31 - Number of non-empty SMBIOS memory devices found: 2
2023-08-06 23:17:31 - [SPD 0] Comparing SMBIOS S/N (00000000) with SPD S/N (00000000)
2023-08-06 23:17:31 - [SPD 0] SMBIOS S/N = 00000000
2023-08-06 23:17:31 - [SPD 0] Found match with SMBIOS 1
2023-08-06 23:17:31 - [SPD 1] Comparing SMBIOS S/N (00000000) with SPD S/N (00000000)
2023-08-06 23:17:31 - [SPD 1] SMBIOS S/N = 00000000
2023-08-06 23:17:31 - [SPD 1] Found match with SMBIOS 3
2023-08-06 23:17:31 - Attempting to enable any disabled TSOD controllers...
2023-08-06 23:17:31 - Attempting to enable SMBUS:
2023-08-06 23:17:31 - Searching PCI for TSOD Controller
2023-08-06 23:17:31 - MMIO PM DECODEEN: E3070BF7 (smbus0sel=0)
2023-08-06 23:17:31 - {00:14:00} SMBus Configuration Registers:
2023-08-06 23:17:31 - 00: 790B1022 02200403 0C050071 00800000
2023-08-06 23:17:31 - 10: 00000000 00000000 00000000 00000000
2023-08-06 23:17:31 - 20: 00000000 00000000 00000000 88771043
2023-08-06 23:17:31 - 30: 00000000 00000000 00000000 00000000
2023-08-06 23:17:31 - 40: 00000000 00000000 00000000 00000000
2023-08-06 23:17:31 - 50: 00000000 00000000 00000000 00000000
2023-08-06 23:17:31 - 60: 00000000 00000000 00000000 00000000
2023-08-06 23:17:31 - 70: 00000000 00000000 00000000 00000000
2023-08-06 23:17:31 - 80: 00000000 00000000 00000000 00000000
2023-08-06 23:17:31 - 90: 00000000 00000000 00000000 00000000
2023-08-06 23:17:31 - A0: 00000000 00000000 00000000 00000000
2023-08-06 23:17:31 - B0: 00000000 00000000 00000000 00000000
2023-08-06 23:17:31 - C0: 00000000 00000000 00000000 00000000
2023-08-06 23:17:31 - D0: 00000000 00000000 00000000 00000000
2023-08-06 23:17:31 - E0: 00000000 00000000 00000000 00000000
2023-08-06 23:17:31 - F0: 00009EFD 00000000 00000000 00000000
2023-08-06 23:17:31 - Found TSOD device: VID:1022 DID:790B Bus:00 Dev:14 Fun:00 IO Add:0B00 IO (2) Add:0000 MMIO Add:0 Rev:71 [AMD Hudson-3 SMBus]
2023-08-06 23:17:31 - Finished searching PCI for SMBus Controller
2023-08-06 23:17:31 - Expanding TSOD info array (0 => 16)
2023-08-06 23:17:31 - Parsing command line: ""
2023-08-06 23:17:31 - Successfully located the PI MpService protocol.
2023-08-06 23:17:31 - BSP is Proc 0
2023-08-06 23:17:31 - This platform has 32 logical processors of which 32 are enabled.
2023-08-06 23:17:31 - ProcID Enabled Type Status Pkg Core Thread Hyperthread?
2023-08-06 23:17:31 - -------- -------- ---- -------- ----- ---- ------ ------------
2023-08-06 23:17:31 - Get Proc Info Proc #0
2023-08-06 23:17:31 - 00000000 Y BSP 00000007 0 0 0 N
2023-08-06 23:17:31 - Get Proc Info Proc #1
2023-08-06 23:17:31 - 00000001 Y AP 00000006 0 0 1 Y
2023-08-06 23:17:31 - Get Proc Info Proc #2
2023-08-06 23:17:31 - 00000002 Y AP 00000006 0 1 0 N
2023-08-06 23:17:31 - Get Proc Info Proc #3
2023-08-06 23:17:31 - 00000003 Y AP 00000006 0 1 1 Y
2023-08-06 23:17:31 - Get Proc Info Proc #4
2023-08-06 23:17:31 - 00000004 Y AP 00000006 0 2 0 N
2023-08-06 23:17:31 - Get Proc Info Proc #5
2023-08-06 23:17:31 - 00000005 Y AP 00000006 0 2 1 Y
2023-08-06 23:17:31 - Get Proc Info Proc #6
2023-08-06 23:17:31 - 00000006 Y AP 00000006 0 3 0 N
2023-08-06 23:17:31 - Get Proc Info Proc #7
2023-08-06 23:17:31 - 00000007 Y AP 00000006 0 3 1 Y
2023-08-06 23:17:31 - Get Proc Info Proc #8
2023-08-06 23:17:31 - 00000008 Y AP 00000006 0 4 0 N
2023-08-06 23:17:31 - Get Proc Info Proc #9
2023-08-06 23:17:31 - 00000009 Y AP 00000006 0 4 1 Y
2023-08-06 23:17:31 - Get Proc Info Proc #10
2023-08-06 23:17:31 - 0000000A Y AP 00000006 0 5 0 N
2023-08-06 23:17:31 - Get Proc Info Proc #11
2023-08-06 23:17:31 - 0000000B Y AP 00000006 0 5 1 Y
2023-08-06 23:17:32 - Get Proc Info Proc #12
2023-08-06 23:17:32 - 0000000C Y AP 00000006 0 6 0 N
2023-08-06 23:17:32 - Get Proc Info Proc #13
2023-08-06 23:17:32 - 0000000D Y AP 00000006 0 6 1 Y
2023-08-06 23:17:32 - Get Proc Info Proc #14
2023-08-06 23:17:32 - 0000000E Y AP 00000006 0 7 0 N
2023-08-06 23:17:32 - Get Proc Info Proc #15
2023-08-06 23:17:32 - 0000000F Y AP 00000006 0 7 1 Y
2023-08-06 23:17:32 - Get Proc Info Proc #16
2023-08-06 23:17:32 - 00000010 Y AP 00000006 0 8 0 N
2023-08-06 23:17:32 - Get Proc Info Proc #17
2023-08-06 23:17:32 - 00000011 Y AP 00000006 0 8 1 Y
2023-08-06 23:17:32 - Get Proc Info Proc #18
2023-08-06 23:17:32 - 00000012 Y AP 00000006 0 9 0 N
2023-08-06 23:17:32 - Get Proc Info Proc #19
2023-08-06 23:17:32 - 00000013 Y AP 00000006 0 9 1 Y
2023-08-06 23:17:32 - Get Proc Info Proc #20
2023-08-06 23:17:32 - 00000014 Y AP 00000006 0 10 0 N
2023-08-06 23:17:32 - Get Proc Info Proc #21
2023-08-06 23:17:32 - 00000015 Y AP 00000006 0 10 1 Y
2023-08-06 23:17:32 - Get Proc Info Proc #22
2023-08-06 23:17:32 - 00000016 Y AP 00000006 0 11 0 N
2023-08-06 23:17:32 - Get Proc Info Proc #23
2023-08-06 23:17:32 - 00000017 Y AP 00000006 0 11 1 Y
2023-08-06 23:17:32 - Get Proc Info Proc #24
2023-08-06 23:17:32 - 00000018 Y AP 00000006 0 12 0 N
2023-08-06 23:17:32 - Get Proc Info Proc #25
2023-08-06 23:17:32 - 00000019 Y AP 00000006 0 12 1 Y
2023-08-06 23:17:32 - Get Proc Info Proc #26
2023-08-06 23:17:32 - 0000001A Y AP 00000006 0 13 0 N
2023-08-06 23:17:32 - Get Proc Info Proc #27
2023-08-06 23:17:32 - 0000001B Y AP 00000006 0 13 1 Y
2023-08-06 23:17:32 - Get Proc Info Proc #28
2023-08-06 23:17:32 - 0000001C Y AP 00000006 0 14 0 N
2023-08-06 23:17:32 - Get Proc Info Proc #29
2023-08-06 23:17:32 - 0000001D Y AP 00000006 0 14 1 Y
2023-08-06 23:17:32 - Get Proc Info Proc #30
2023-08-06 23:17:32 - 0000001E Y AP 00000006 0 15 0 N
2023-08-06 23:17:32 - Get Proc Info Proc #31
2023-08-06 23:17:32 - 0000001F Y AP 00000006 0 15 1 Y
2023-08-06 23:17:32 - Package ProcNum
2023-08-06 23:17:32 - 0 0
2023-08-06 23:17:32 - This platform has 32 logical processors of which 32 are enabled.
2023-08-06 23:17:32 - The number of cores (32) is greater than the maximum supported (16). Limiting the number of cores to 16.
2023-08-06 23:17:32 - Number of hyperthreads detected: 16 (Total threads: 16)
2023-08-06 23:17:32 - Testing MP support
2023-08-06 23:17:32 - MPSupportTestMPServices - AP dispatch test
2023-08-06 23:17:32 - MPSupportTestMPServices - Starting AP#1
2023-08-06 23:17:32 - MPSupportTestMPServices - Starting AP#2
2023-08-06 23:17:32 - MPSupportTestMPServices - Starting AP#3
2023-08-06 23:17:32 - MPSupportTestMPServices - Starting AP#4
2023-08-06 23:17:32 - MPSupportTestMPServices - Starting AP#5
2023-08-06 23:17:32 - MPSupportTestMPServices - Starting AP#6
2023-08-06 23:17:32 - MPSupportTestMPServices - Starting AP#7
2023-08-06 23:17:32 - MPSupportTestMPServices - Starting AP#8
2023-08-06 23:17:32 - MPSupportTestMPServices - Starting AP#9
2023-08-06 23:17:32 - MPSupportTestMPServices - Starting AP#10
2023-08-06 23:17:32 - MPSupportTestMPServices - Starting AP#11
2023-08-06 23:17:32 - MPSupportTestMPServices - Starting AP#12
2023-08-06 23:17:32 - MPSupportTestMPServices - Starting AP#13
2023-08-06 23:17:32 - MPSupportTestMPServices - Starting AP#14
2023-08-06 23:17:32 - MPSupportTestMPServices - Starting AP#15
2023-08-06 23:17:32 - MPSupportTestMPServices - Waiting for AP's to complete execution
2023-08-06 23:17:33 - MPSupportTestMPServices - CPU #1 finished execution
2023-08-06 23:17:33 - MPSupportTestMPServices - CPU #2 finished execution
2023-08-06 23:17:33 - MPSupportTestMPServices - CPU #3 finished execution
2023-08-06 23:17:33 - MPSupportTestMPServices - CPU #10 finished execution
2023-08-06 23:17:33 - MPSupportTestMPServices - CPU #11 finished execution
2023-08-06 23:17:33 - MPSupportTestMPServices - CPU #4 finished execution
2023-08-06 23:17:33 - MPSupportTestMPServices - CPU #5 finished execution
2023-08-06 23:17:33 - MPSupportTestMPServices - CPU #6 finished execution
2023-08-06 23:17:33 - MPSupportTestMPServices - CPU #7 finished execution
2023-08-06 23:17:33 - MPSupportTestMPServices - CPU #8 finished execution
2023-08-06 23:17:33 - MPSupportTestMPServices - CPU #9 finished execution
2023-08-06 23:17:33 - MPSupportTestMPServices - CPU #12 finished execution
2023-08-06 23:17:33 - MPSupportTestMPServices - CPU #13 finished execution
2023-08-06 23:17:33 - MPSupportTestMPServices - CPU #14 finished execution
2023-08-06 23:17:33 - MPSupportTestMPServices - CPU #15 finished execution
2023-08-06 23:17:33 - MPSupportTestMPServices - AP dispatch test complete
2023-08-06 23:17:33 - MP test passed. Setting default CPU mode to PARALLEL
2023-08-06 23:17:33 - Getting memory controller info
2023-08-06 23:17:34 - find_mem_controller - found AMD Ryzen Zen 4 (60h-6fh) (1022:14E2) at 0-24-2
2023-08-06 23:17:34 - AMD Ryzen Zen 4 chipset init
2023-08-06 23:17:34 - MmioCfgBaseAddr=00000000F000001D (Enable=1)
2023-08-06 23:17:34 - MCHBAR=F0000000
2023-08-06 23:17:34 - CfgAddressCntl = 00000000 (SecBusNum=00)
2023-08-06 23:17:34 - CPUID[0x00000001]:EDX[31:0] = 178BFBFF (MCA=1)
2023-08-06 23:17:34 - CPUID[0x80000007]:EBX[31:0] = 0000003B (PfehSupportPresent=1, ScalableMCA=1)
2023-08-06 23:17:34 - PFEH_CFG=0000000000000000 (PfehEnable=0)
2023-08-06 23:17:34 - PFEH_CLOAK_CFG=0000000000000000
2023-08-06 23:17:34 - MCG_CAP=0000000000000120 (Count=32)
2023-08-06 23:17:34 - SdpCtrl[0]=C0800083 (SdpInit=1)
2023-08-06 23:17:34 - [MC0] DramConfiguration=80050960
2023-08-06 23:17:34 - [MC0] DebugMisc=0B0008F8
2023-08-06 23:17:34 - [MC0] DramTiming1=28284D28
2023-08-06 23:17:34 - [MC0] DramTiming2=00280075
2023-08-06 23:17:34 - [MC0] DramTiming3=12000C08
2023-08-06 23:17:34 - [MC0] DramTiming4=00000020
2023-08-06 23:17:34 - [MC0] DramTiming5=00180626
2023-08-06 23:17:34 - [MC0] DramTiming6=00000048
2023-08-06 23:17:34 - [MC0] DramTiming7=00000002
2023-08-06 23:17:34 - [MC0] DramTiming8=05010606
2023-08-06 23:17:34 - [MC0] DramTiming9=11010F0F
2023-08-06 23:17:34 - [MC0] DramTiming10=00001307
2023-08-06 23:17:34 - [MC0] DramTiming11=00312B48
2023-08-06 23:17:34 - [MC0] DramTiming12=00302483
2023-08-06 23:17:34 - [MC0] DramTiming13=20202222
2023-08-06 23:17:34 - [MC0] DramTiming14=060002DC
2023-08-06 23:17:34 - [MC0] DramTiming15=24002000
2023-08-06 23:17:34 - [MC0] DramTiming16=03220C01
2023-08-06 23:17:34 - [MC0] DramTiming17=FE60FF12
2023-08-06 23:17:34 - [MC0] DramTiming18=001020C5
2023-08-06 23:17:34 - [MC0] DramTiming19=00000101
2023-08-06 23:17:34 - [MC0] DramTiming20=00070000
2023-08-06 23:17:34 - [MC0] DramTiming21=000C0D12
2023-08-06 23:17:34 - [MC0] DramTiming22=06221A1C
2023-08-06 23:17:34 - [MC0] DramTiming23=22002A2A
2023-08-06 23:17:34 - UmcCap[0]=0x0001FD08
2023-08-06 23:17:34 - UmcCapHi[0]=0x00000000
2023-08-06 23:17:34 - EccChipKillCap = 0 and EccEnabled = 0 for ch 0
2023-08-06 23:17:34 - SdpCtrl[1]=C0800083 (SdpInit=1)
2023-08-06 23:17:34 - [MC1] DramConfiguration=80050960
2023-08-06 23:17:34 - [MC1] DebugMisc=0B0008F8
2023-08-06 23:17:34 - [MC1] DramTiming1=28284D28
2023-08-06 23:17:34 - [MC1] DramTiming2=00280075
2023-08-06 23:17:34 - [MC1] DramTiming3=12000C08
2023-08-06 23:17:34 - [MC1] DramTiming4=00000020
2023-08-06 23:17:34 - [MC1] DramTiming5=00180626
2023-08-06 23:17:34 - [MC1] DramTiming6=00000048
2023-08-06 23:17:34 - [MC1] DramTiming7=00000002
2023-08-06 23:17:34 - [MC1] DramTiming8=05010606
2023-08-06 23:17:34 - [MC1] DramTiming9=11010F0F
2023-08-06 23:17:34 - [MC1] DramTiming10=00001407
2023-08-06 23:17:34 - [MC1] DramTiming11=00312B48
2023-08-06 23:17:34 - [MC1] DramTiming12=00302483
2023-08-06 23:17:34 - [MC1] DramTiming13=20202222
2023-08-06 23:17:34 - [MC1] DramTiming14=060002DC
2023-08-06 23:17:34 - [MC1] DramTiming15=24002000
2023-08-06 23:17:34 - [MC1] DramTiming16=03220C01
2023-08-06 23:17:34 - [MC1] DramTiming17=FE60FF12
2023-08-06 23:17:34 - [MC1] DramTiming18=001020C5
2023-08-06 23:17:34 - [MC1] DramTiming19=00000101
2023-08-06 23:17:34 - [MC1] DramTiming20=00070000
2023-08-06 23:17:34 - [MC1] DramTiming21=000C0D12
2023-08-06 23:17:34 - [MC1] DramTiming22=06221A1C
2023-08-06 23:17:34 - [MC1] DramTiming23=22002A2A
2023-08-06 23:17:34 - UmcCap[1]=0x0001FD08
2023-08-06 23:17:34 - UmcCapHi[1]=0x00000000
2023-08-06 23:17:34 - EccChipKillCap = 0 and EccEnabled = 0 for ch 1
2023-08-06 23:17:34 - TOP_MEM=0000000080000000
2023-08-06 23:17:34 - SYS_CFG=0000000000740000 (MtrrTom2En=1)
2023-08-06 23:17:34 - TOM2=0000000880000000
2023-08-06 23:17:35 - [MC0] UmcConfig=80000701
2023-08-06 23:17:35 - [MC0] FabricBlockInstanceInformation3=00000000
2023-08-06 23:17:35 - [MC0] DramHoleControl=80000001
2023-08-06 23:17:35 - [MC0] DramOffset=00000000
2023-08-06 23:17:35 - [MC0] SystemFabricIdMask0=0000003F
2023-08-06 23:17:35 - [MC0] SystemFabricIdMask1=00000000
2023-08-06 23:17:35 - [MC0] SystemFabricIdMask2=00000000
2023-08-06 23:17:35 - [UMC0] BeqCtrl0: 00000008 (VcmEn=1)
2023-08-06 23:17:35 - [UMC0] AddrHashPC: 3FFFC001
2023-08-06 23:17:35 - [UMC0] AddrHashPC2: 00000000
2023-08-06 23:17:35 - [MC0,n0] DramBaseAddress=00000000
2023-08-06 23:17:35 - [MC0,n0] DramLimitAddress=00000087
2023-08-06 23:17:35 - [MC0,n0] DramAddressCtl=00000703
2023-08-06 23:17:35 - [MC0,n0] DramAddressIntlv=00000010
2023-08-06 23:17:35 - [UMC0,n0] AddrHashCS: 00000000
2023-08-06 23:17:35 - [UMC0, DIMM0] DimmCfg: 00000000
2023-08-06 23:17:35 - [MC0,n1] DramBaseAddress=00000000
2023-08-06 23:17:35 - [MC0,n1] DramLimitAddress=00000000
2023-08-06 23:17:35 - [MC0,n1] DramAddressCtl=00000700
2023-08-06 23:17:35 - [MC0,n1] DramAddressIntlv=00000000
2023-08-06 23:17:35 - [UMC0,n1] AddrHashCS: 00000000
2023-08-06 23:17:35 - [UMC0, DIMM1] DimmCfg: 00000000
2023-08-06 23:17:35 - [UMC0, CS0] BaseAddr: 00000000
2023-08-06 23:17:35 - [UMC0, CS0] BaseAddrSec: 00000000
2023-08-06 23:17:35 - [UMC0, CS0] AddrMask: 00000000
2023-08-06 23:17:35 - [UMC0, CS0] AddrMaskSec: 00000000
2023-08-06 23:17:35 - [UMC0, CS0] AddrCfg: 00150508
2023-08-06 23:17:35 - [UMC0, CS0] AddrSel: 070CBA98
2023-08-06 23:17:35 - [UMC0, CS0] ColSelLo: 87654321
2023-08-06 23:17:35 - [UMC0, CS0] ColSelHi: A9876543
2023-08-06 23:17:35 - [UMC0, CS0] RmSel: 00000000
2023-08-06 23:17:35 - [UMC0, CS1] BaseAddr: 00000000
2023-08-06 23:17:35 - [UMC0, CS1] BaseAddrSec: 00000000
2023-08-06 23:17:35 - [UMC0, CS1] AddrMask: 00000000
2023-08-06 23:17:35 - [UMC0, CS1] AddrMaskSec: 00000000
2023-08-06 23:17:35 - [UMC0, CS1] AddrCfg: 00150508
2023-08-06 23:17:35 - [UMC0, CS1] AddrSel: 070CBA98
2023-08-06 23:17:35 - [UMC0, CS1] ColSelLo: 87654321
2023-08-06 23:17:35 - [UMC0, CS1] ColSelHi: A9876543
2023-08-06 23:17:35 - [UMC0, CS1] RmSel: 00000000
2023-08-06 23:17:35 - [UMC0, CS2] BaseAddr: 00000001
2023-08-06 23:17:35 - [UMC0, CS2] BaseAddrSec: 00000000
2023-08-06 23:17:35 - [UMC0, CS2] AddrMask: 03FFFFFE
2023-08-06 23:17:35 - [UMC0, CS2] AddrMaskSec: 00000000
2023-08-06 23:17:35 - [UMC0, CS2] AddrCfg: 0025060C
2023-08-06 23:17:35 - [UMC0, CS2] AddrSel: 06074365
2023-08-06 23:17:35 - [UMC0, CS2] ColSelLo: DCB53210
2023-08-06 23:17:35 - [UMC0, CS2] ColSelHi: A9876098
2023-08-06 23:17:35 - [UMC0, CS2] RmSel: 00010000
2023-08-06 23:17:35 - [UMC0, CS3] BaseAddr: 00000000
2023-08-06 23:17:35 - [UMC0, CS3] BaseAddrSec: 00000000
2023-08-06 23:17:35 - [UMC0, CS3] AddrMask: 00000000
2023-08-06 23:17:35 - [UMC0, CS3] AddrMaskSec: 00000000
2023-08-06 23:17:35 - [UMC0, CS3] AddrCfg: 00150508
2023-08-06 23:17:35 - [UMC0, CS3] AddrSel: 070CBA98
2023-08-06 23:17:35 - [UMC0, CS3] ColSelLo: 87654321
2023-08-06 23:17:35 - [UMC0, CS3] ColSelHi: A9876543
2023-08-06 23:17:35 - [UMC0, CS3] RmSel: 00000000
2023-08-06 23:17:35 - [MC1] UmcConfig=80000701
2023-08-06 23:17:35 - [MC1] FabricBlockInstanceInformation3=00000101
2023-08-06 23:17:35 - [MC1] DramHoleControl=80000001
2023-08-06 23:17:35 - [MC1] DramOffset=00000000
2023-08-06 23:17:35 - [MC1] SystemFabricIdMask0=0000003F
2023-08-06 23:17:35 - [MC1] SystemFabricIdMask1=00000000
2023-08-06 23:17:35 - [MC1] SystemFabricIdMask2=00000000
2023-08-06 23:17:35 - [UMC1] BeqCtrl0: 00000008 (VcmEn=1)
2023-08-06 23:17:36 - [UMC1] AddrHashPC: 3FFFC001
2023-08-06 23:17:36 - [UMC1] AddrHashPC2: 00000000
2023-08-06 23:17:36 - [MC1,n0] DramBaseAddress=00000000
2023-08-06 23:17:36 - [MC1,n0] DramLimitAddress=00000087
2023-08-06 23:17:36 - [MC1,n0] DramAddressCtl=00000703
2023-08-06 23:17:36 - [MC1,n0] DramAddressIntlv=00000010
2023-08-06 23:17:36 - [UMC1,n0] AddrHashCS: 00000000
2023-08-06 23:17:36 - [UMC1, DIMM0] DimmCfg: 00000000
2023-08-06 23:17:36 - [MC1,n1] DramBaseAddress=00000000
2023-08-06 23:17:36 - [MC1,n1] DramLimitAddress=00000000
2023-08-06 23:17:36 - [MC1,n1] DramAddressCtl=00000700
2023-08-06 23:17:36 - [MC1,n1] DramAddressIntlv=00000000
2023-08-06 23:17:36 - [UMC1,n1] AddrHashCS: 00000000
2023-08-06 23:17:36 - [UMC1, DIMM1] DimmCfg: 00000000
2023-08-06 23:17:36 - [UMC1, CS0] BaseAddr: 00000000
2023-08-06 23:17:36 - [UMC1, CS0] BaseAddrSec: 00000000
2023-08-06 23:17:36 - [UMC1, CS0] AddrMask: 00000000
2023-08-06 23:17:36 - [UMC1, CS0] AddrMaskSec: 00000000
2023-08-06 23:17:36 - [UMC1, CS0] AddrCfg: 00150508
2023-08-06 23:17:36 - [UMC1, CS0] AddrSel: 070CBA98
2023-08-06 23:17:36 - [UMC1, CS0] ColSelLo: 87654321
2023-08-06 23:17:36 - [UMC1, CS0] ColSelHi: A9876543
2023-08-06 23:17:36 - [UMC1, CS0] RmSel: 00000000
2023-08-06 23:17:36 - [UMC1, CS1] BaseAddr: 00000000
2023-08-06 23:17:36 - [UMC1, CS1] BaseAddrSec: 00000000
2023-08-06 23:17:36 - [UMC1, CS1] AddrMask: 00000000
2023-08-06 23:17:36 - [UMC1, CS1] AddrMaskSec: 00000000
2023-08-06 23:17:36 - [UMC1, CS1] AddrCfg: 00150508
2023-08-06 23:17:36 - [UMC1, CS1] AddrSel: 070CBA98
2023-08-06 23:17:36 - [UMC1, CS1] ColSelLo: 87654321
2023-08-06 23:17:36 - [UMC1, CS1] ColSelHi: A9876543
2023-08-06 23:17:36 - [UMC1, CS1] RmSel: 00000000
2023-08-06 23:17:36 - [UMC1, CS2] BaseAddr: 00000001
2023-08-06 23:17:36 - [UMC1, CS2] BaseAddrSec: 00000000
2023-08-06 23:17:36 - [UMC1, CS2] AddrMask: 03FFFFFE
2023-08-06 23:17:36 - [UMC1, CS2] AddrMaskSec: 00000000
2023-08-06 23:17:36 - [UMC1, CS2] AddrCfg: 0025060C
2023-08-06 23:17:36 - [UMC1, CS2] AddrSel: 06074365
2023-08-06 23:17:36 - [UMC1, CS2] ColSelLo: DCB53210
2023-08-06 23:17:36 - [UMC1, CS2] ColSelHi: A9876098
2023-08-06 23:17:36 - [UMC1, CS2] RmSel: 00010000
2023-08-06 23:17:36 - [UMC1, CS3] BaseAddr: 00000000
2023-08-06 23:17:36 - [UMC1, CS3] BaseAddrSec: 00000000
2023-08-06 23:17:36 - [UMC1, CS3] AddrMask: 00000000
2023-08-06 23:17:36 - [UMC1, CS3] AddrMaskSec: 00000000
2023-08-06 23:17:36 - [UMC1, CS3] AddrCfg: 00150508
2023-08-06 23:17:36 - [UMC1, CS3] AddrSel: 070CBA98
2023-08-06 23:17:36 - [UMC1, CS3] ColSelLo: 87654321
2023-08-06 23:17:36 - [UMC1, CS3] ColSelHi: A9876543
2023-08-06 23:17:36 - [UMC1, CS3] RmSel: 00000000
2023-08-06 23:17:36 - find_mem_controller - AMD Ryzen Zen 4 (60h-6fh) (1022:14E2) at 0-24-2
2023-08-06 23:17:36 - find_mem_controller - AMD Ryzen Zen 4 (60h-6fh) (Ch mode: 2, ECC mode: {detect: no, correct: no, scrub: no, chipkill: no, IBECC: no})
2023-08-06 23:17:36 - ECC polling disabled
2023-08-06 23:17:36 - Applying configurations
2023-08-06 23:17:36 - [CONFIG] This platform has 32 logical processors of which 16 are enabled.
2023-08-06 23:17:36 - [CONFIG] ECCPOLL cannot be enabled as ECC is not available
2023-08-06 23:17:36 - Applying configurations complete
2023-08-06 23:17:36 - Console size = 80 x 25
2023-08-06 23:17:36 - Checking for graphics mode support
2023-08-06 23:17:36 - Graphics mode available
2023-08-06 23:17:36 - Enabling graphics mode
2023-08-06 23:17:36 - Get screen size
2023-08-06 23:17:36 - Current screen size: 1024 x 768
2023-08-06 23:17:36 - Screen size = 1024 x 768
2023-08-06 23:17:36 - Char width=8 height=19
2023-08-06 23:17:36 - Loading images
2023-08-06 23:17:36 - Show splash screen
2023-08-06 23:17:36 - Splash screen start time: 487175907240 (clk=4491668, ConIn=6F011E10, WaitForKey=6BE06B18)
2023-08-06 23:17:43 - Splash screen key press detected: 0 (4)
2023-08-06 23:17:43 - Splash screen user input detected - stopping timer
2023-08-06 23:17:44 - Splash screen key press detected: 0 (4)
2023-08-06 23:17:44 - Splash screen key press detected: 0 (3)
2023-08-06 23:17:45 - Splash screen key press detected: 0 (4)
2023-08-06 23:17:45 - Splash screen key press detected: 0 (3)
2023-08-06 23:17:46 - Splash screen key press detected: 13 (0)
2023-08-06 23:17:46 - Exit splash screen
2023-08-06 23:17:46 - Enabling graphics mode
2023-08-06 23:17:46 - Get screen size
2023-08-06 23:17:46 - Current screen size: 1024 x 768
2023-08-06 23:17:46 - poll_timings_ryzen - [MC0] DramConfiguration=80050960
2023-08-06 23:17:46 - poll_timings_ryzen - [MC0] DebugMisc=0B0008F8
2023-08-06 23:17:46 - poll_timings_ryzen - [MC1] DramConfiguration=80050960
2023-08-06 23:17:46 - poll_timings_ryzen - [MC1] DebugMisc=0B0008F8
2023-08-06 23:17:57 - Initializing spin lock (Align=64)
2023-08-06 23:17:57 - *** TEST SESSION - 2023-08-06 23:17:57 ***
2023-08-06 23:17:57 - CPU selection mode = 1
2023-08-06 23:17:57 - poll_timings_ryzen - [MC0] DramConfiguration=80050960
2023-08-06 23:17:57 - poll_timings_ryzen - [MC0] DebugMisc=0B0008F8
2023-08-06 23:17:57 - poll_timings_ryzen - [MC1] DramConfiguration=80050960
2023-08-06 23:17:57 - poll_timings_ryzen - [MC1] DebugMisc=0B0008F8
2023-08-06 23:17:57 - ReadMemoryRanges - Available Pages = 8063929
2023-08-06 23:17:57 - Locking all memory ranges first...
2023-08-06 23:17:57 - Skipping memory range 0x0 - 0x9F000 (636KB). Range too small.
2023-08-06 23:17:57 - Skipping memory range 0x100000 - 0x1000000 (15360KB). Range too small.
2023-08-06 23:17:57 - Memory range locked: 0x1080000 - 0x9AFF000 (32113896KB of available memory left)
2023-08-06 23:17:57 - Skipping memory range 0xA000000 - 0xA200000 (2048KB). Range too small.
2023-08-06 23:17:57 - Skipping memory range 0xA210000 - 0xB000000 (14272KB). Range too small.
2023-08-06 23:17:57 - Memory range locked: 0xB021000 - 0x52B99000 (30938888KB of available memory left)
2023-08-06 23:17:57 - Skipping memory range 0x542FB000 - 0x54301000 (24KB). Range too small.
2023-08-06 23:17:57 - Skipping memory range 0x5430E000 - 0x54310000 (8KB). Range too small.
2023-08-06 23:17:57 - Memory range locked: 0x61D93000 - 0x66D27000 (30857400KB of available memory left)
2023-08-06 23:17:57 - Skipping memory range 0x66F67000 - 0x67600000 (6756KB). Range too small.
2023-08-06 23:17:57 - Skipping memory range 0x67C12000 - 0x67C14000 (8KB). Range too small.
2023-08-06 23:17:57 - Skipping memory range 0x67C4B000 - 0x67C4F000 (16KB). Range too small.
2023-08-06 23:17:57 - Skipping memory range 0x67C50000 - 0x67C52000 (8KB). Range too small.
2023-08-06 23:17:57 - Skipping memory range 0x691B6000 - 0x69221000 (428KB). Range too small.
2023-08-06 23:17:57 - Skipping memory range 0x69232000 - 0x6923F000 (52KB). Range too small.
2023-08-06 23:17:57 - Skipping memory range 0x69249000 - 0x69253000 (40KB). Range too small.
2023-08-06 23:17:57 - Skipping memory range 0x6926B000 - 0x6926F000 (16KB). Range too small.
2023-08-06 23:17:57 - Skipping memory range 0x69296000 - 0x69297000 (4KB). Range too small.
2023-08-06 23:17:57 - Skipping memory range 0x6DD93000 - 0x6EC5D000 (15144KB). Range too small.
2023-08-06 23:17:57 - Skipping memory range 0x7A800000 - 0x7A8A5000 (660KB). Range too small.
2023-08-06 23:17:57 - Memory range locked: 0x100000000 - 0x858000000 (55480KB of available memory left)
2023-08-06 23:17:57 - All memory ranges successfully locked
2023-08-06 23:17:57 - Starting pass #1 (of 4)
2023-08-06 23:17:57 - Current CPU temperature: 56C
2023-08-06 23:17:57 - Running test #0 (Test 0 [Address test, walking ones, 1 CPU])
2023-08-06 23:17:57 - MtSupportRunAllTests - Setting random seed to 0x50415353
2023-08-06 23:17:58 - MtSupportRunAllTests - Start time: 508 ms
2023-08-06 23:17:58 - MtSupportRunAllTests - Enabling memory cache for test
2023-08-06 23:17:58 - MtSupportRunAllTests - Enabling memory cache complete
2023-08-06 23:17:58 - Start memory range test (0x0 - 0x10000000000)
2023-08-06 23:17:58 - MtSupportRunAllTests - Test execution time: 0.810s (Test 0 cumulative error count: 0, buffer full count: 0)
2023-08-06 23:17:58 - Running test #1 (Test 1 [Address test, own address, 1 CPU])
2023-08-06 23:17:58 - MtSupportRunAllTests - Setting random seed to 0x50415353
2023-08-06 23:17:58 - MtSupportRunAllTests - Start time: 1402 ms
2023-08-06 23:18:02 - MtSupportRunAllTests - Test execution time: 3.575s (Test 1 cumulative error count: 0, buffer full count: 0)
2023-08-06 23:18:02 - Running test #2 (Test 2 [Address test, own address])
2023-08-06 23:18:02 - MtSupportRunAllTests - Setting random seed to 0x50415353
2023-08-06 23:18:02 - MtSupportRunAllTests - Start time: 5057 ms
2023-08-06 23:18:02 - MtSupportRunAllTests - Enabling memory cache for test
2023-08-06 23:18:02 - MtSupportRunAllTests - Enabling memory cache complete
2023-08-06 23:18:02 - Start memory range test (0x0 - 0x10000000000)
2023-08-06 23:18:05 - MtSupportRunAllTests - Test execution time: 3.403s (Test 2 cumulative error count: 0, buffer full count: 0)
2023-08-06 23:18:06 - Running test #3 (Test 3 [Moving inversions, ones & zeroes])
2023-08-06 23:18:06 - MtSupportRunAllTests - Setting random seed to 0x50415353
2023-08-06 23:18:06 - MtSupportRunAllTests - Start time: 8534 ms
2023-08-06 23:18:06 - MtSupportRunAllTests - Enabling memory cache for test
2023-08-06 23:18:06 - MtSupportRunAllTests - Enabling memory cache complete
2023-08-06 23:18:06 - Start memory range test (0x0 - 0x10000000000)
2023-08-06 23:18:21 - MtSupportRunAllTests - Test execution time: 15.523s (Test 3 cumulative error count: 0, buffer full count: 0)
2023-08-06 23:18:21 - Running test #4 (Test 4 [Moving inversions, 8-bit pattern])
2023-08-06 23:18:21 - MtSupportRunAllTests - Setting random seed to 0x50415353
2023-08-06 23:18:21 - MtSupportRunAllTests - Start time: 24132 ms
2023-08-06 23:18:21 - MtSupportRunAllTests - Enabling memory cache for test
2023-08-06 23:18:21 - MtSupportRunAllTests - Enabling memory cache complete
2023-08-06 23:18:21 - Start memory range test (0x0 - 0x10000000000)
2023-08-06 23:18:58 - Current CPU temperature: 70C
2023-08-06 23:19:26 - MtSupportRunAllTests - Test execution time: 64.613s (Test 4 cumulative error count: 0, buffer full count: 0)
2023-08-06 23:19:26 - Running test #5 (Test 5 [Moving inversions, random pattern])
2023-08-06 23:19:26 - MtSupportRunAllTests - Setting random seed to 0x50415353
2023-08-06 23:19:26 - MtSupportRunAllTests - Start time: 88822 ms
2023-08-06 23:19:26 - MtSupportRunAllTests - Enabling memory cache for test
2023-08-06 23:19:26 - MtSupportRunAllTests - Enabling memory cache complete
2023-08-06 23:19:26 - Start memory range test (0x0 - 0x10000000000)
2023-08-06 23:19:58 - Current CPU temperature: 71C
2023-08-06 23:20:33 - MtSupportRunAllTests - Test execution time: 67.611s (Test 5 cumulative error count: 0, buffer full count: 0)
2023-08-06 23:20:33 - Running test #6 (Test 6 [Block move, 64-byte blocks])
2023-08-06 23:20:33 - MtSupportRunAllTests - Setting random seed to 0x50415353
2023-08-06 23:20:34 - MtSupportRunAllTests - Start time: 156511 ms
2023-08-06 23:20:34 - MtSupportRunAllTests - Enabling memory cache for test
2023-08-06 23:20:34 - MtSupportRunAllTests - Enabling memory cache complete
2023-08-06 23:20:34 - Start memory range test (0x0 - 0x10000000000)
2023-08-06 23:20:58 - Current CPU temperature: 59C
2023-08-06 23:21:58 - Current CPU temperature: 60C
2023-08-06 23:22:26 - MtSupportRunAllTests - Test execution time: 112.901s (Test 6 cumulative error count: 0, buffer full count: 0)
2023-08-06 23:22:26 - Running test #7 (Test 7 [Moving inversions, 32-bit pattern])
2023-08-06 23:22:26 - MtSupportRunAllTests - Setting random seed to 0x50415353
2023-08-06 23:22:26 - MtSupportRunAllTests - Start time: 269491 ms
2023-08-06 23:22:27 - MtSupportRunAllTests - Enabling memory cache for test
2023-08-06 23:22:27 - MtSupportRunAllTests - Enabling memory cache complete
2023-08-06 23:22:27 - Start memory range test (0x0 - 0x10000000000)
2023-08-06 23:22:58 - Current CPU temperature: 74C
2023-08-06 23:23:58 - Current CPU temperature: 73C
2023-08-06 23:24:58 - Current CPU temperature: 74C
2023-08-06 23:25:58 - Current CPU temperature: 73C
2023-08-06 23:26:39 - MtSupportRunAllTests - Test execution time: 252.198s (Test 7 cumulative error count: 0, buffer full count: 0)
2023-08-06 23:26:39 - Running test #8 (Test 8 [Random number sequence])
2023-08-06 23:26:39 - MtSupportRunAllTests - Setting random seed to 0x50415353
2023-08-06 23:26:39 - MtSupportRunAllTests - Start time: 521768 ms
2023-08-06 23:26:39 - MtSupportRunAllTests - Enabling memory cache for test
2023-08-06 23:26:39 - MtSupportRunAllTests - Enabling memory cache complete
2023-08-06 23:26:39 - Start memory range test (0x0 - 0x10000000000)
2023-08-06 23:26:43 - [MEM ERROR - Data] Test: 8, CPU: 6, Address: 15411938C, Expected: 21083721, Actual: 61083721
2023-08-06 23:26:50 - [MEM ERROR - Data] Test: 8, CPU: 10, Address: 2E5B5A14C, Expected: C510ACC3, Actual: 8510ACC3
2023-08-06 23:26:58 - Current CPU temperature: 95C
2023-08-06 23:27:13 - [MEM ERROR - Data] Test: 8, CPU: 3, Address: 78ACF194C, Expected: 884AAC27, Actual: C84AAC27
2023-08-06 23:27:16 - MtSupportRunAllTests - Test execution time: 36.992s (Test 8 cumulative error count: 3, buffer full count: 0)
2023-08-06 23:27:16 - Running test #9 (Test 9 [Modulo 20, ones & zeros])
2023-08-06 23:27:16 - MtSupportRunAllTests - Setting random seed to 0x50415353
2023-08-06 23:27:16 - MtSupportRunAllTests - Start time: 558841 ms
2023-08-06 23:27:16 - MtSupportRunAllTests - Enabling memory cache for test
2023-08-06 23:27:16 - MtSupportRunAllTests - Enabling memory cache complete
2023-08-06 23:27:16 - Start memory range test (0x0 - 0x10000000000)
2023-08-06 23:27:58 - Current CPU temperature: 75C
2023-08-06 23:28:58 - Current CPU temperature: 75C
2023-08-06 23:29:58 - Current CPU temperature: 75C
2023-08-06 23:30:15 - MtSupportRunAllTests - Test execution time: 179.188s (Test 9 cumulative error count: 0, buffer full count: 0)
2023-08-06 23:30:15 - Running test #10 (Test 10 [Bit fade test, 2 patterns, 1 CPU])
2023-08-06 23:30:15 - MtSupportRunAllTests - Setting random seed to 0x50415353
2023-08-06 23:30:15 - MtSupportRunAllTests - Start time: 738123 ms
2023-08-06 23:30:15 - MtSupportRunAllTests - Enabling memory cache for test
2023-08-06 23:30:15 - MtSupportRunAllTests - Enabling memory cache complete
2023-08-06 23:30:15 - Start bit fade test (0x0 - 0x10000000000)
2023-08-06 23:30:15 - Starting Stage 0, Pattern=00000000
2023-08-06 23:30:17 - Finished Stage 0, Pattern=00000000
2023-08-06 23:30:17 - Sleep start time: 740210
2023-08-06 23:30:17 - Sleep time: 300000
2023-08-06 23:30:17 - Test 10 - Sleeping (299 seconds remaining)
2023-08-06 23:30:48 - Slept for 30 seconds
2023-08-06 23:30:58 - Current CPU temperature: 56C
2023-08-06 23:31:18 - Slept for 60 seconds
2023-08-06 23:31:48 - Slept for 90 seconds
2023-08-06 23:31:58 - Current CPU temperature: 57C
2023-08-06 23:32:18 - Slept for 121 seconds
2023-08-06 23:32:49 - Slept for 151 seconds
2023-08-06 23:32:59 - Current CPU temperature: 58C
2023-08-06 23:33:19 - Slept for 181 seconds
2023-08-06 23:33:49 - Slept for 212 seconds
2023-08-06 23:33:59 - Current CPU temperature: 58C
2023-08-06 23:34:20 - Slept for 242 seconds
2023-08-06 23:34:50 - Slept for 272 seconds
2023-08-06 23:34:59 - Current CPU temperature: 58C
2023-08-06 23:35:17 - Starting Stage 1, Pattern=00000000
2023-08-06 23:35:21 - Finished Stage 1, Pattern=00000000
2023-08-06 23:35:21 - Starting Stage 0, Pattern=FFFFFFFF
2023-08-06 23:35:23 - Finished Stage 0, Pattern=FFFFFFFF
2023-08-06 23:35:23 - Sleep start time: 1045785
2023-08-06 23:35:23 - Sleep time: 300000
2023-08-06 23:35:23 - Test 10 - Sleeping (299 seconds remaining)
2023-08-06 23:35:53 - Slept for 30 seconds
2023-08-06 23:35:59 - Current CPU temperature: 57C
2023-08-06 23:36:23 - Slept for 60 seconds
2023-08-06 23:36:54 - Slept for 90 seconds
2023-08-06 23:36:59 - Current CPU temperature: 58C
2023-08-06 23:37:24 - Slept for 121 seconds
2023-08-06 23:37:54 - Slept for 151 seconds
2023-08-06 23:37:59 - Current CPU temperature: 58C
2023-08-06 23:38:25 - Slept for 181 seconds
2023-08-06 23:38:55 - Slept for 212 seconds
2023-08-06 23:38:59 - Current CPU temperature: 58C
2023-08-06 23:39:25 - Slept for 242 seconds
2023-08-06 23:39:56 - Slept for 272 seconds
2023-08-06 23:39:59 - Current CPU temperature: 58C
2023-08-06 23:40:23 - Starting Stage 1, Pattern=FFFFFFFF
2023-08-06 23:40:26 - Finished Stage 1, Pattern=FFFFFFFF
2023-08-06 23:40:26 - MtSupportRunAllTests - Test execution time: 611.192s (Test 10 cumulative error count: 0, buffer full count: 0)
2023-08-06 23:40:26 - Running test #13 (Test 13 [Hammer test])
2023-08-06 23:40:26 - MtSupportRunAllTests - Setting random seed to 0x50415353
2023-08-06 23:40:26 - MtSupportRunAllTests - Start time: 1349399 ms
2023-08-06 23:40:26 - MtSupportRunAllTests - Enabling memory cache for test
2023-08-06 23:40:26 - MtSupportRunAllTests - Enabling memory cache complete
2023-08-06 23:40:26 - Start double-sided hammer test (0x0 - 0x10000000000, Step size: 0x1000000)
2023-08-06 23:40:26 - Using random pattern
2023-08-06 23:40:26 - # of segments to hammer: 15 (SegSize=2048MB, SkipSize=0MB)
2023-08-06 23:40:59 - Current CPU temperature: 75C
2023-08-06 23:41:14 - RunHammerTest - Running hammer test on 2 CPUs (573MB each) [0xB021000 - 0x52B99000]
2023-08-06 23:41:59 - Current CPU temperature: 75C
2023-08-06 23:42:20 - RunHammerTest - Running hammer test on 4 CPUs (512MB each) [0x100000000 - 0x180000000]
2023-08-06 23:42:53 - RunHammerTest - Running hammer test on 4 CPUs (512MB each) [0x180000000 - 0x200000000]
2023-08-06 23:42:59 - Current CPU temperature: 74C
2023-08-06 23:43:26 - RunHammerTest - Running hammer test on 4 CPUs (512MB each) [0x200000000 - 0x280000000]
2023-08-06 23:43:59 - RunHammerTest - Running hammer test on 4 CPUs (512MB each) [0x280000000 - 0x300000000]
2023-08-06 23:44:00 - Current CPU temperature: 70C
2023-08-06 23:44:33 - RunHammerTest - Running hammer test on 4 CPUs (512MB each) [0x300000000 - 0x380000000]
2023-08-06 23:45:00 - Current CPU temperature: 71C
2023-08-06 23:45:06 - RunHammerTest - Running hammer test on 4 CPUs (512MB each) [0x380000000 - 0x400000000]
2023-08-06 23:45:39 - RunHammerTest - Running hammer test on 4 CPUs (512MB each) [0x400000000 - 0x480000000]
2023-08-06 23:46:00 - Current CPU temperature: 72C
2023-08-06 23:46:12 - RunHammerTest - Running hammer test on 4 CPUs (512MB each) [0x480000000 - 0x500000000]
2023-08-06 23:46:45 - RunHammerTest - Running hammer test on 4 CPUs (512MB each) [0x500000000 - 0x580000000]
2023-08-06 23:47:00 - Current CPU temperature: 73C
2023-08-06 23:47:19 - RunHammerTest - Running hammer test on 4 CPUs (512MB each) [0x580000000 - 0x600000000]
2023-08-06 23:47:52 - RunHammerTest - Running hammer test on 4 CPUs (512MB each) [0x600000000 - 0x680000000]
2023-08-06 23:48:00 - Current CPU temperature: 73C
2023-08-06 23:48:25 - RunHammerTest - Running hammer test on 4 CPUs (512MB each) [0x680000000 - 0x700000000]
2023-08-06 23:48:58 - RunHammerTest - Running hammer test on 4 CPUs (512MB each) [0x700000000 - 0x780000000]
2023-08-06 23:49:00 - Current CPU temperature: 65C
2023-08-06 23:49:31 - RunHammerTest - Running hammer test on 4 CPUs (512MB each) [0x780000000 - 0x800000000]
2023-08-06 23:50:00 - Current CPU temperature: 70C
2023-08-06 23:50:04 - RunHammerTest - Running hammer test on 2 CPUs (704MB each) [0x800000000 - 0x858000000]
2023-08-06 23:50:22 - MtSupportRunAllTests - Test execution time: 596.018s (Test 13 cumulative error count: 0, buffer full count: 0)
2023-08-06 23:50:23 - Finished pass #1 (of 4) (Cumulative error count: 3, buffer full count: 0)
2023-08-06 23:50:23 - Starting pass #2 (of 4)
2023-08-06 23:50:23 - Running test #0 (Test 0 [Address test, walking ones, 1 CPU])
2023-08-06 23:50:23 - MtSupportRunAllTests - Setting random seed to 0x8565002A
2023-08-06 23:50:23 - MtSupportRunAllTests - Start time: 1945525 ms
2023-08-06 23:50:23 - MtSupportRunAllTests - Enabling memory cache for test
2023-08-06 23:50:23 - MtSupportRunAllTests - Enabling memory cache complete
2023-08-06 23:50:23 - Start memory range test (0x0 - 0x10000000000)
2023-08-06 23:50:23 - MtSupportRunAllTests - Test execution time: 0.804s (Test 0 cumulative error count: 0, buffer full count: 0)
2023-08-06 23:50:23 - Running test #1 (Test 1 [Address test, own address, 1 CPU])
2023-08-06 23:50:23 - MtSupportRunAllTests - Setting random seed to 0x7167934D
2023-08-06 23:50:23 - MtSupportRunAllTests - Start time: 1946407 ms
2023-08-06 23:50:27 - MtSupportRunAllTests - Test execution time: 3.538s (Test 1 cumulative error count: 0, buffer full count: 0)
2023-08-06 23:50:27 - Running test #2 (Test 2 [Address test, own address])
2023-08-06 23:50:27 - MtSupportRunAllTests - Setting random seed to 0x397EF67F
2023-08-06 23:50:27 - MtSupportRunAllTests - Start time: 1950023 ms
2023-08-06 23:50:27 - MtSupportRunAllTests - Enabling memory cache for test
2023-08-06 23:50:27 - MtSupportRunAllTests - Enabling memory cache complete
2023-08-06 23:50:27 - Start memory range test (0x0 - 0x10000000000)
2023-08-06 23:50:30 - MtSupportRunAllTests - Test execution time: 3.394s (Test 2 cumulative error count: 0, buffer full count: 0)
2023-08-06 23:50:31 - Running test #3 (Test 3 [Moving inversions, ones & zeroes])
2023-08-06 23:50:31 - MtSupportRunAllTests - Setting random seed to 0xDB4E17AD
2023-08-06 23:50:31 - MtSupportRunAllTests - Start time: 1953496 ms
2023-08-06 23:50:31 - MtSupportRunAllTests - Enabling memory cache for test
2023-08-06 23:50:31 - MtSupportRunAllTests - Enabling memory cache complete
2023-08-06 23:50:31 - Start memory range test (0x0 - 0x10000000000)
2023-08-06 23:51:00 - Current CPU temperature: 68C
2023-08-06 23:51:04 - MtSupportRunAllTests - Test execution time: 33.915s (Test 3 cumulative error count: 0, buffer full count: 0)
2023-08-06 23:51:04 - Running test #4 (Test 4 [Moving inversions, 8-bit pattern])
2023-08-06 23:51:05 - MtSupportRunAllTests - Setting random seed to 0x6BC33B8D
2023-08-06 23:51:05 - MtSupportRunAllTests - Start time: 1987503 ms
2023-08-06 23:51:05 - MtSupportRunAllTests - Enabling memory cache for test
2023-08-06 23:51:05 - MtSupportRunAllTests - Enabling memory cache complete
2023-08-06 23:51:05 - Start memory range test (0x0 - 0x10000000000)
2023-08-06 23:52:00 - Current CPU temperature: 69C
2023-08-06 23:53:00 - Current CPU temperature: 69C
2023-08-06 23:53:32 - MtSupportRunAllTests - Test execution time: 147.181s (Test 4 cumulative error count: 0, buffer full count: 0)
2023-08-06 23:53:32 - Running test #5 (Test 5 [Moving inversions, random pattern])
2023-08-06 23:53:32 - MtSupportRunAllTests - Setting random seed to 0x6DB02F5B
2023-08-06 23:53:32 - MtSupportRunAllTests - Start time: 2134766 ms
2023-08-06 23:53:32 - MtSupportRunAllTests - Enabling memory cache for test
2023-08-06 23:53:32 - MtSupportRunAllTests - Enabling memory cache complete
2023-08-06 23:53:32 - Start memory range test (0x0 - 0x10000000000)
2023-08-06 23:54:00 - Current CPU temperature: 70C
2023-08-06 23:55:00 - Current CPU temperature: 70C
2023-08-06 23:56:00 - Current CPU temperature: 69C
2023-08-06 23:56:48 - MtSupportRunAllTests - Test execution time: 196.384s (Test 5 cumulative error count: 0, buffer full count: 0)
2023-08-06 23:56:48 - Running test #6 (Test 6 [Block move, 64-byte blocks])
2023-08-06 23:56:48 - MtSupportRunAllTests - Setting random seed to 0xE4B17B9B
2023-08-06 23:56:48 - MtSupportRunAllTests - Start time: 2331233 ms
2023-08-06 23:56:48 - MtSupportRunAllTests - Enabling memory cache for test
2023-08-06 23:56:48 - MtSupportRunAllTests - Enabling memory cache complete
2023-08-06 23:56:48 - Start memory range test (0x0 - 0x10000000000)
2023-08-06 23:57:00 - Current CPU temperature: 59C
2023-08-06 23:58:01 - Current CPU temperature: 58C
2023-08-06 23:59:01 - Current CPU temperature: 59C
2023-08-07 00:00:01 - Current CPU temperature: 59C
2023-08-07 00:01:01 - Current CPU temperature: 59C
2023-08-07 00:02:01 - Current CPU temperature: 59C
2023-08-07 00:02:21 - MtSupportRunAllTests - Test execution time: 332.461s (Test 6 cumulative error count: 0, buffer full count: 0)
2023-08-07 00:02:21 - Running test #7 (Test 7 [Moving inversions, 32-bit pattern])
2023-08-07 00:02:21 - MtSupportRunAllTests - Setting random seed to 0xAA765372
2023-08-07 00:02:21 - MtSupportRunAllTests - Start time: 2663777 ms
2023-08-07 00:02:21 - MtSupportRunAllTests - Enabling memory cache for test
2023-08-07 00:02:21 - MtSupportRunAllTests - Enabling memory cache complete
2023-08-07 00:02:21 - Start memory range test (0x0 - 0x10000000000)
2023-08-07 00:03:01 - Current CPU temperature: 73C
2023-08-07 00:04:01 - Current CPU temperature: 74C
2023-08-07 00:05:01 - Current CPU temperature: 75C
2023-08-07 00:06:01 - Current CPU temperature: 74C
2023-08-07 00:07:02 - Current CPU temperature: 73C
2023-08-07 00:08:02 - Current CPU temperature: 73C
2023-08-07 00:09:02 - Current CPU temperature: 73C
2023-08-07 00:10:02 - Current CPU temperature: 73C
2023-08-07 00:11:02 - Current CPU temperature: 73C
2023-08-07 00:12:02 - Current CPU temperature: 75C
2023-08-07 00:12:07 - MtSupportRunAllTests - Test execution time: 586.288s (Test 7 cumulative error count: 0, buffer full count: 0)
2023-08-07 00:12:07 - Running test #8 (Test 8 [Random number sequence])
2023-08-07 00:12:07 - MtSupportRunAllTests - Setting random seed to 0xE4BC8927
2023-08-07 00:12:07 - MtSupportRunAllTests - Start time: 3250150 ms
2023-08-07 00:12:07 - MtSupportRunAllTests - Enabling memory cache for test
2023-08-07 00:12:07 - MtSupportRunAllTests - Enabling memory cache complete
2023-08-07 00:12:07 - Start memory range test (0x0 - 0x10000000000)
2023-08-07 00:12:22 - [MEM ERROR - Data] Test: 8, CPU: 4, Address: 1AFB41F0C, Expected: 5D38D926, Actual: 1D38D926
2023-08-07 00:12:26 - [MEM ERROR - Data] Test: 8, CPU: 5, Address: 1EAAAE54C, Expected: 3B290BC7, Actual: 7B290BC7
2023-08-07 00:13:00 - [MEM ERROR - Data] Test: 8, CPU: 2, Address: 474B4D14C, Expected: 363C5C4A, Actual: 763C5C4A
2023-08-07 00:13:02 - Current CPU temperature: 95C
2023-08-07 00:13:28 - [MEM ERROR - Data] Test: 8, CPU: 7, Address: 6629461CC, Expected: 093ACD96, Actual: 493ACD96
2023-08-07 00:13:38 - [MEM ERROR - Data] Test: 8, CPU: 1, Address: 7398697CC, Expected: 05CA1A6C, Actual: 45CA1A6C
2023-08-07 00:13:42 - [MEM ERROR - Data] Test: 8, CPU: 4, Address: 76F07BB8C, Expected: 037AE789, Actual: 437AE789
2023-08-07 00:13:53 - MtSupportRunAllTests - Test execution time: 106.221s (Test 8 cumulative error count: 9, buffer full count: 0)
2023-08-07 00:13:53 - Running test #9 (Test 9 [Modulo 20, ones & zeros])
2023-08-07 00:13:54 - MtSupportRunAllTests - Setting random seed to 0x11AE1945
2023-08-07 00:13:54 - MtSupportRunAllTests - Start time: 3356457 ms
2023-08-07 00:13:54 - MtSupportRunAllTests - Enabling memory cache for test
2023-08-07 00:13:54 - MtSupportRunAllTests - Enabling memory cache complete
2023-08-07 00:13:54 - Start memory range test (0x0 - 0x10000000000)
2023-08-07 00:14:02 - Current CPU temperature: 77C
2023-08-07 00:15:02 - Current CPU temperature: 75C
2023-08-07 00:16:02 - Current CPU temperature: 74C
2023-08-07 00:17:03 - Current CPU temperature: 75C
2023-08-07 00:18:03 - Current CPU temperature: 75C
2023-08-07 00:19:03 - Current CPU temperature: 75C
2023-08-07 00:20:03 - Current CPU temperature: 74C
2023-08-07 00:21:03 - Current CPU temperature: 75C
2023-08-07 00:22:03 - Current CPU temperature: 75C
2023-08-07 00:22:48 - MtSupportRunAllTests - Test execution time: 534.416s (Test 9 cumulative error count: 0, buffer full count: 0)
2023-08-07 00:22:48 - Running test #10 (Test 10 [Bit fade test, 2 patterns, 1 CPU])
2023-08-07 00:22:48 - MtSupportRunAllTests - Setting random seed to 0x0D37E379
2023-08-07 00:22:48 - MtSupportRunAllTests - Start time: 3890959 ms
2023-08-07 00:22:48 - MtSupportRunAllTests - Enabling memory cache for test
2023-08-07 00:22:48 - MtSupportRunAllTests - Enabling memory cache complete
2023-08-07 00:22:48 - Start bit fade test (0x0 - 0x10000000000)
2023-08-07 00:22:48 - Starting Stage 0, Pattern=00000000
2023-08-07 00:22:50 - Finished Stage 0, Pattern=00000000
2023-08-07 00:22:50 - Sleep start time: 3893040
2023-08-07 00:22:50 - Sleep time: 300000
2023-08-07 00:22:50 - Test 10 - Sleeping (299 seconds remaining)
2023-08-07 00:23:03 - Current CPU temperature: 57C
2023-08-07 00:23:20 - Slept for 30 seconds
2023-08-07 00:23:51 - Slept for 60 seconds
2023-08-07 00:24:03 - Current CPU temperature: 56C
2023-08-07 00:24:21 - Slept for 90 seconds
2023-08-07 00:24:51 - Slept for 121 seconds
2023-08-07 00:25:03 - Current CPU temperature: 57C
2023-08-07 00:25:22 - Slept for 151 seconds
2023-08-07 00:25:52 - Slept for 181 seconds
2023-08-07 00:26:03 - Current CPU temperature: 57C
2023-08-07 00:26:22 - Slept for 212 seconds
2023-08-07 00:26:53 - Slept for 242 seconds
2023-08-07 00:27:03 - Current CPU temperature: 58C
2023-08-07 00:27:23 - Slept for 272 seconds
2023-08-07 00:27:50 - Starting Stage 1, Pattern=00000000
2023-08-07 00:27:54 - Finished Stage 1, Pattern=00000000
2023-08-07 00:27:54 - Starting Stage 0, Pattern=FFFFFFFF
2023-08-07 00:27:56 - Finished Stage 0, Pattern=FFFFFFFF
2023-08-07 00:27:56 - Sleep start time: 4198626
2023-08-07 00:27:56 - Sleep time: 300000
2023-08-07 00:27:56 - Test 10 - Sleeping (299 seconds remaining)
2023-08-07 00:28:03 - Current CPU temperature: 61C
2023-08-07 00:28:26 - Slept for 30 seconds
2023-08-07 00:28:56 - Slept for 60 seconds
2023-08-07 00:29:03 - Current CPU temperature: 57C
2023-08-07 00:29:27 - Slept for 90 seconds
2023-08-07 00:29:57 - Slept for 121 seconds
2023-08-07 00:30:04 - Current CPU temperature: 58C
2023-08-07 00:30:27 - Slept for 151 seconds
2023-08-07 00:30:58 - Slept for 181 seconds
2023-08-07 00:31:04 - Current CPU temperature: 58C
2023-08-07 00:31:28 - Slept for 212 seconds
2023-08-07 00:31:58 - Slept for 242 seconds
2023-08-07 00:32:04 - Current CPU temperature: 58C
2023-08-07 00:32:28 - Slept for 272 seconds
2023-08-07 00:32:56 - Starting Stage 1, Pattern=FFFFFFFF
2023-08-07 00:32:59 - Finished Stage 1, Pattern=FFFFFFFF
2023-08-07 00:32:59 - MtSupportRunAllTests - Test execution time: 611.170s (Test 10 cumulative error count: 0, buffer full count: 0)
2023-08-07 00:32:59 - Running test #13 (Test 13 [Hammer test])
2023-08-07 00:32:59 - MtSupportRunAllTests - Setting random seed to 0x4AFBE82D
2023-08-07 00:32:59 - MtSupportRunAllTests - Start time: 4502207 ms
2023-08-07 00:32:59 - MtSupportRunAllTests - Enabling memory cache for test
2023-08-07 00:32:59 - MtSupportRunAllTests - Enabling memory cache complete
2023-08-07 00:32:59 - Start double-sided hammer test (0x0 - 0x10000000000, Step size: 0x1000000)
2023-08-07 00:32:59 - Using random pattern
2023-08-07 00:32:59 - # of segments to hammer: 15 (SegSize=2048MB, SkipSize=0MB)
2023-08-07 00:33:04 - Current CPU temperature: 74C
2023-08-07 00:33:49 - RunHammerTest - Running hammer test on 2 CPUs (573MB each) [0xB021000 - 0x52B99000]
2023-08-07 00:34:04 - Current CPU temperature: 75C
2023-08-07 00:35:00 - RunHammerTest - Running hammer test on 4 CPUs (512MB each) [0x100000000 - 0x180000000]
2023-08-07 00:35:04 - Current CPU temperature: 62C
2023-08-07 00:35:39 - RunHammerTest - Running hammer test on 4 CPUs (512MB each) [0x180000000 - 0x200000000]
2023-08-07 00:36:04 - Current CPU temperature: 73C
2023-08-07 00:36:18 - RunHammerTest - Running hammer test on 4 CPUs (512MB each) [0x200000000 - 0x280000000]
2023-08-07 00:36:56 - RunHammerTest - Running hammer test on 4 CPUs (512MB each) [0x280000000 - 0x300000000]
2023-08-07 00:37:04 - Current CPU temperature: 67C
2023-08-07 00:37:35 - RunHammerTest - Running hammer test on 4 CPUs (512MB each) [0x300000000 - 0x380000000]
2023-08-07 00:38:04 - Current CPU temperature: 71C
2023-08-07 00:38:14 - RunHammerTest - Running hammer test on 4 CPUs (512MB each) [0x380000000 - 0x400000000]
2023-08-07 00:38:52 - RunHammerTest - Running hammer test on 4 CPUs (512MB each) [0x400000000 - 0x480000000]
2023-08-07 00:39:04 - Current CPU temperature: 74C
2023-08-07 00:39:31 - RunHammerTest - Running hammer test on 4 CPUs (512MB each) [0x480000000 - 0x500000000]
2023-08-07 00:40:04 - Current CPU temperature: 71C
2023-08-07 00:40:10 - RunHammerTest - Running hammer test on 4 CPUs (512MB each) [0x500000000 - 0x580000000]
2023-08-07 00:40:48 - RunHammerTest - Running hammer test on 4 CPUs (512MB each) [0x580000000 - 0x600000000]
2023-08-07 00:41:04 - Current CPU temperature: 74C
2023-08-07 00:41:27 - RunHammerTest - Running hammer test on 4 CPUs (512MB each) [0x600000000 - 0x680000000]
2023-08-07 00:42:04 - Current CPU temperature: 70C
2023-08-07 00:42:06 - RunHammerTest - Running hammer test on 4 CPUs (512MB each) [0x680000000 - 0x700000000]
2023-08-07 00:42:45 - RunHammerTest - Running hammer test on 4 CPUs (512MB each) [0x700000000 - 0x780000000]
2023-08-07 00:43:04 - Current CPU temperature: 73C
2023-08-07 00:43:23 - RunHammerTest - Running hammer test on 4 CPUs (512MB each) [0x780000000 - 0x800000000]
2023-08-07 00:44:02 - RunHammerTest - Running hammer test on 2 CPUs (704MB each) [0x800000000 - 0x858000000]
2023-08-07 00:44:04 - Current CPU temperature: 64C
2023-08-07 00:44:27 - MtSupportRunAllTests - Test execution time: 687.743s (Test 13 cumulative error count: 0, buffer full count: 0)
2023-08-07 00:44:27 - Finished pass #2 (of 4) (Cumulative error count: 9, buffer full count: 0)
2023-08-07 00:44:27 - Starting pass #3 (of 4)
2023-08-07 00:44:27 - Running test #0 (Test 0 [Address test, walking ones, 1 CPU])
2023-08-07 00:44:27 - MtSupportRunAllTests - Setting random seed to 0xA644EA0F
2023-08-07 00:44:27 - MtSupportRunAllTests - Start time: 5190062 ms
2023-08-07 00:44:27 - MtSupportRunAllTests - Enabling memory cache for test
2023-08-07 00:44:27 - MtSupportRunAllTests - Enabling memory cache complete
2023-08-07 00:44:27 - Start memory range test (0x0 - 0x10000000000)
2023-08-07 00:44:28 - MtSupportRunAllTests - Test execution time: 0.803s (Test 0 cumulative error count: 0, buffer full count: 0)
2023-08-07 00:44:28 - Running test #1 (Test 1 [Address test, own address, 1 CPU])
2023-08-07 00:44:28 - MtSupportRunAllTests - Setting random seed to 0x974333F3
2023-08-07 00:44:28 - MtSupportRunAllTests - Start time: 5190962 ms
2023-08-07 00:44:28 - MtSupportRunAllTests - Enabling memory cache for test
2023-08-07 00:44:28 - MtSupportRunAllTests - Enabling memory cache complete
2023-08-07 00:44:28 - Start memory range test (0x0 - 0x10000000000)
2023-08-07 00:44:32 - MtSupportRunAllTests - Test execution time: 3.529s (Test 1 cumulative error count: 0, buffer full count: 0)
2023-08-07 00:44:32 - Running test #2 (Test 2 [Address test, own address])
2023-08-07 00:44:32 - MtSupportRunAllTests - Setting random seed to 0x5E9E0DA8
2023-08-07 00:44:32 - MtSupportRunAllTests - Start time: 5194575 ms
2023-08-07 00:44:32 - MtSupportRunAllTests - Enabling memory cache for test
2023-08-07 00:44:32 - MtSupportRunAllTests - Enabling memory cache complete
2023-08-07 00:44:32 - Start memory range test (0x0 - 0x10000000000)
2023-08-07 00:44:35 - MtSupportRunAllTests - Test execution time: 3.374s (Test 2 cumulative error count: 0, buffer full count: 0)
2023-08-07 00:44:35 - Running test #3 (Test 3 [Moving inversions, ones & zeroes])
2023-08-07 00:44:35 - MtSupportRunAllTests - Setting random seed to 0xFCD139D4
2023-08-07 00:44:35 - MtSupportRunAllTests - Start time: 5198035 ms
2023-08-07 00:44:35 - MtSupportRunAllTests - Enabling memory cache for test
2023-08-07 00:44:35 - MtSupportRunAllTests - Enabling memory cache complete
2023-08-07 00:44:35 - Start memory range test (0x0 - 0x10000000000)
2023-08-07 00:45:04 - Current CPU temperature: 68C
2023-08-07 00:45:09 - MtSupportRunAllTests - Test execution time: 33.905s (Test 3 cumulative error count: 0, buffer full count: 0)
2023-08-07 00:45:09 - Running test #4 (Test 4 [Moving inversions, 8-bit pattern])
2023-08-07 00:45:09 - MtSupportRunAllTests - Setting random seed to 0x88C7C16A
2023-08-07 00:45:09 - MtSupportRunAllTests - Start time: 5232023 ms
2023-08-07 00:45:09 - MtSupportRunAllTests - Enabling memory cache for test
2023-08-07 00:45:09 - MtSupportRunAllTests - Enabling memory cache complete
2023-08-07 00:45:09 - Start memory range test (0x0 - 0x10000000000)
2023-08-07 00:46:04 - Current CPU temperature: 69C
2023-08-07 00:47:04 - Current CPU temperature: 69C
2023-08-07 00:47:36 - MtSupportRunAllTests - Test execution time: 147.200s (Test 4 cumulative error count: 0, buffer full count: 0)
2023-08-07 00:47:36 - Running test #5 (Test 5 [Moving inversions, random pattern])
2023-08-07 00:47:36 - MtSupportRunAllTests - Setting random seed to 0x8DEA6153
2023-08-07 00:47:36 - MtSupportRunAllTests - Start time: 5379298 ms
2023-08-07 00:47:36 - MtSupportRunAllTests - Enabling memory cache for test
2023-08-07 00:47:36 - MtSupportRunAllTests - Enabling memory cache complete
2023-08-07 00:47:36 - Start memory range test (0x0 - 0x10000000000)
2023-08-07 00:48:05 - Current CPU temperature: 70C
2023-08-07 00:49:05 - Current CPU temperature: 70C
2023-08-07 00:50:05 - Current CPU temperature: 69C
2023-08-07 00:50:53 - MtSupportRunAllTests - Test execution time: 196.290s (Test 5 cumulative error count: 0, buffer full count: 0)
2023-08-07 00:50:53 - Running test #6 (Test 6 [Block move, 64-byte blocks])
2023-08-07 00:50:53 - MtSupportRunAllTests - Setting random seed to 0xE9FBEEC6
2023-08-07 00:50:53 - MtSupportRunAllTests - Start time: 5575665 ms
2023-08-07 00:50:53 - MtSupportRunAllTests - Enabling memory cache for test
2023-08-07 00:50:53 - MtSupportRunAllTests - Enabling memory cache complete
2023-08-07 00:50:53 - Start memory range test (0x0 - 0x10000000000)
2023-08-07 00:51:05 - Current CPU temperature: 59C
2023-08-07 00:52:05 - Current CPU temperature: 58C
2023-08-07 00:53:05 - Current CPU temperature: 59C
2023-08-07 00:54:05 - Current CPU temperature: 59C
2023-08-07 00:55:05 - Current CPU temperature: 59C
2023-08-07 00:56:05 - Current CPU temperature: 59C
2023-08-07 00:56:25 - MtSupportRunAllTests - Test execution time: 332.464s (Test 6 cumulative error count: 0, buffer full count: 0)
2023-08-07 00:56:25 - Running test #7 (Test 7 [Moving inversions, 32-bit pattern])
2023-08-07 00:56:25 - MtSupportRunAllTests - Setting random seed to 0xB56CAB7F
2023-08-07 00:56:25 - MtSupportRunAllTests - Start time: 5908229 ms
2023-08-07 00:56:25 - MtSupportRunAllTests - Enabling memory cache for test
2023-08-07 00:56:25 - MtSupportRunAllTests - Enabling memory cache complete
2023-08-07 00:56:25 - Start memory range test (0x0 - 0x10000000000)
2023-08-07 00:57:05 - Current CPU temperature: 73C
2023-08-07 00:58:05 - Current CPU temperature: 73C
2023-08-07 00:59:06 - Current CPU temperature: 75C
2023-08-07 01:00:06 - Current CPU temperature: 74C
2023-08-07 01:01:06 - Current CPU temperature: 74C
2023-08-07 01:02:06 - Current CPU temperature: 73C
2023-08-07 01:03:06 - Current CPU temperature: 73C
2023-08-07 01:04:06 - Current CPU temperature: 73C
2023-08-07 01:05:06 - Current CPU temperature: 73C
2023-08-07 01:06:06 - Current CPU temperature: 76C
2023-08-07 01:06:12 - MtSupportRunAllTests - Test execution time: 586.418s (Test 7 cumulative error count: 0, buffer full count: 0)
2023-08-07 01:06:12 - Running test #8 (Test 8 [Random number sequence])
2023-08-07 01:06:12 - MtSupportRunAllTests - Setting random seed to 0x113CC112
2023-08-07 01:06:12 - MtSupportRunAllTests - Start time: 6494728 ms
2023-08-07 01:06:12 - MtSupportRunAllTests - Enabling memory cache for test
2023-08-07 01:06:12 - MtSupportRunAllTests - Enabling memory cache complete
2023-08-07 01:06:12 - Start memory range test (0x0 - 0x10000000000)
2023-08-07 01:06:30 - [MEM ERROR - Data] Test: 8, CPU: 10, Address: 1E748214C, Expected: 630B4764, Actual: 230B4764
2023-08-07 01:06:30 - [MEM ERROR - Data] Test: 8, CPU: 3, Address: 1C88EC58C, Expected: C6FC5366, Actual: 86FC5366
2023-08-07 01:06:34 - [MEM ERROR - Data] Test: 8, CPU: 8, Address: 21E3FAB0C, Expected: AF2D9D63, Actual: EF2D9D63
2023-08-07 01:06:37 - [MEM ERROR - Data] Test: 8, CPU: 9, Address: 263D03F8C, Expected: C9FC0880, Actual: 89FC0880
2023-08-07 01:06:44 - [MEM ERROR - Data] Test: 8, CPU: 2, Address: 2C4E191CC, Expected: 131660E8, Actual: 531660E8
2023-08-07 01:06:58 - [MEM ERROR - Data] Test: 8, CPU: 4, Address: 3CFE7A34C, Expected: C6545C49, Actual: 86545C49
2023-08-07 01:07:07 - Current CPU temperature: 95C
2023-08-07 01:07:08 - [MEM ERROR - Data] Test: 8, CPU: 12, Address: 4ADB4C14C, Expected: 466DE5DD, Actual: 066DE5DD
2023-08-07 01:07:15 - [MEM ERROR - Data] Test: 8, CPU: 0, Address: 53CD5DD0C, Expected: C73C792E, Actual: 873C792E
2023-08-07 01:07:22 - [MEM ERROR - Data] Test: 8, CPU: 1, Address: 58030A94C, Expected: 9A203B54, Actual: DA203B54
2023-08-07 01:07:53 - [MEM ERROR - Data] Test: 8, CPU: 8, Address: 7DEBE3DCC, Expected: 5447B738, Actual: 1447B738
2023-08-07 01:07:58 - MtSupportRunAllTests - Test execution time: 106.279s (Test 8 cumulative error count: 19, buffer full count: 0)
2023-08-07 01:07:58 - Running test #9 (Test 9 [Modulo 20, ones & zeros])
2023-08-07 01:07:58 - MtSupportRunAllTests - Setting random seed to 0x4CBC5DE1
2023-08-07 01:07:58 - MtSupportRunAllTests - Start time: 6601090 ms
2023-08-07 01:07:58 - MtSupportRunAllTests - Enabling memory cache for test
2023-08-07 01:07:58 - MtSupportRunAllTests - Enabling memory cache complete
2023-08-07 01:07:58 - Start memory range test (0x0 - 0x10000000000)
2023-08-07 01:08:07 - Current CPU temperature: 78C
2023-08-07 01:09:07 - Current CPU temperature: 74C
2023-08-07 01:10:07 - Current CPU temperature: 75C
2023-08-07 01:11:07 - Current CPU temperature: 75C
2023-08-07 01:12:07 - Current CPU temperature: 74C
2023-08-07 01:13:07 - Current CPU temperature: 75C
2023-08-07 01:14:07 - Current CPU temperature: 75C
2023-08-07 01:15:07 - Current CPU temperature: 74C
2023-08-07 01:16:07 - Current CPU temperature: 74C
2023-08-07 01:16:53 - MtSupportRunAllTests - Test execution time: 534.422s (Test 9 cumulative error count: 0, buffer full count: 0)
2023-08-07 01:16:53 - Running test #10 (Test 10 [Bit fade test, 2 patterns, 1 CPU])
2023-08-07 01:16:53 - MtSupportRunAllTests - Setting random seed to 0x490A7A0D
2023-08-07 01:16:53 - MtSupportRunAllTests - Start time: 7135609 ms
2023-08-07 01:16:53 - MtSupportRunAllTests - Enabling memory cache for test
2023-08-07 01:16:53 - MtSupportRunAllTests - Enabling memory cache complete
2023-08-07 01:16:53 - Start bit fade test (0x0 - 0x10000000000)
2023-08-07 01:16:53 - Starting Stage 0, Pattern=00000000
2023-08-07 01:16:55 - Finished Stage 0, Pattern=00000000
2023-08-07 01:16:55 - Sleep start time: 7137705
2023-08-07 01:16:55 - Sleep time: 300000
2023-08-07 01:16:55 - Test 10 - Sleeping (299 seconds remaining)
2023-08-07 01:17:07 - Current CPU temperature: 57C
2023-08-07 01:17:25 - Slept for 30 seconds
2023-08-07 01:17:55 - Slept for 60 seconds
2023-08-07 01:18:07 - Current CPU temperature: 56C
2023-08-07 01:18:26 - Slept for 90 seconds
2023-08-07 01:18:56 - Slept for 121 seconds
2023-08-07 01:19:07 - Current CPU temperature: 57C
2023-08-07 01:19:26 - Slept for 151 seconds
2023-08-07 01:19:57 - Slept for 181 seconds
2023-08-07 01:20:07 - Current CPU temperature: 57C
2023-08-07 01:20:27 - Slept for 212 seconds
2023-08-07 01:20:57 - Slept for 242 seconds
2023-08-07 01:21:08 - Current CPU temperature: 57C
2023-08-07 01:21:28 - Slept for 272 seconds
2023-08-07 01:21:55 - Starting Stage 1, Pattern=00000000
2023-08-07 01:21:58 - Finished Stage 1, Pattern=00000000
2023-08-07 01:21:58 - Starting Stage 0, Pattern=FFFFFFFF
2023-08-07 01:22:00 - Finished Stage 0, Pattern=FFFFFFFF
2023-08-07 01:22:00 - Sleep start time: 7443301
2023-08-07 01:22:00 - Sleep time: 300000
2023-08-07 01:22:00 - Test 10 - Sleeping (299 seconds remaining)
2023-08-07 01:22:08 - Current CPU temperature: 61C
2023-08-07 01:22:31 - Slept for 30 seconds
2023-08-07 01:23:01 - Slept for 60 seconds
2023-08-07 01:23:08 - Current CPU temperature: 57C
2023-08-07 01:23:31 - Slept for 90 seconds
2023-08-07 01:24:02 - Slept for 121 seconds
2023-08-07 01:24:08 - Current CPU temperature: 57C
2023-08-07 01:24:32 - Slept for 151 seconds
2023-08-07 01:25:02 - Slept for 181 seconds
2023-08-07 01:25:08 - Current CPU temperature: 57C
2023-08-07 01:25:33 - Slept for 212 seconds
2023-08-07 01:26:03 - Slept for 242 seconds
2023-08-07 01:26:08 - Current CPU temperature: 57C
2023-08-07 01:26:33 - Slept for 272 seconds
2023-08-07 01:27:01 - Starting Stage 1, Pattern=FFFFFFFF
2023-08-07 01:27:04 - Finished Stage 1, Pattern=FFFFFFFF
2023-08-07 01:27:04 - MtSupportRunAllTests - Test execution time: 611.192s (Test 10 cumulative error count: 0, buffer full count: 0)
2023-08-07 01:27:04 - Running test #13 (Test 13 [Hammer test])
2023-08-07 01:27:04 - MtSupportRunAllTests - Setting random seed to 0x915C37CA
2023-08-07 01:27:04 - MtSupportRunAllTests - Start time: 7746882 ms
2023-08-07 01:27:04 - MtSupportRunAllTests - Enabling memory cache for test
2023-08-07 01:27:04 - MtSupportRunAllTests - Enabling memory cache complete
2023-08-07 01:27:04 - Start double-sided hammer test (0x0 - 0x10000000000, Step size: 0x1000000)
2023-08-07 01:27:04 - Using random pattern
2023-08-07 01:27:04 - # of segments to hammer: 15 (SegSize=2048MB, SkipSize=0MB)
2023-08-07 01:27:08 - Current CPU temperature: 74C
2023-08-07 01:27:53 - RunHammerTest - Running hammer test on 2 CPUs (573MB each) [0xB021000 - 0x52B99000]
2023-08-07 01:28:08 - Current CPU temperature: 75C
2023-08-07 01:29:05 - RunHammerTest - Running hammer test on 4 CPUs (512MB each) [0x100000000 - 0x180000000]
2023-08-07 01:29:08 - Current CPU temperature: 61C
2023-08-07 01:29:43 - RunHammerTest - Running hammer test on 4 CPUs (512MB each) [0x180000000 - 0x200000000]
2023-08-07 01:30:08 - Current CPU temperature: 73C
2023-08-07 01:30:22 - RunHammerTest - Running hammer test on 4 CPUs (512MB each) [0x200000000 - 0x280000000]
2023-08-07 01:31:00 - RunHammerTest - Running hammer test on 4 CPUs (512MB each) [0x280000000 - 0x300000000]
2023-08-07 01:31:08 - Current CPU temperature: 69C
2023-08-07 01:31:39 - RunHammerTest - Running hammer test on 4 CPUs (512MB each) [0x300000000 - 0x380000000]
2023-08-07 01:32:08 - Current CPU temperature: 71C
2023-08-07 01:32:18 - RunHammerTest - Running hammer test on 4 CPUs (512MB each) [0x380000000 - 0x400000000]
2023-08-07 01:32:56 - RunHammerTest - Running hammer test on 4 CPUs (512MB each) [0x400000000 - 0x480000000]
2023-08-07 01:33:08 - Current CPU temperature: 73C
2023-08-07 01:33:35 - RunHammerTest - Running hammer test on 4 CPUs (512MB each) [0x480000000 - 0x500000000]
2023-08-07 01:34:08 - Current CPU temperature: 71C
2023-08-07 01:34:13 - RunHammerTest - Running hammer test on 4 CPUs (512MB each) [0x500000000 - 0x580000000]
2023-08-07 01:34:52 - RunHammerTest - Running hammer test on 4 CPUs (512MB each) [0x580000000 - 0x600000000]
2023-08-07 01:35:08 - Current CPU temperature: 73C
2023-08-07 01:35:30 - RunHammerTest - Running hammer test on 4 CPUs (512MB each) [0x600000000 - 0x680000000]
2023-08-07 01:36:08 - Current CPU temperature: 70C
2023-08-07 01:36:09 - RunHammerTest - Running hammer test on 4 CPUs (512MB each) [0x680000000 - 0x700000000]
2023-08-07 01:36:47 - RunHammerTest - Running hammer test on 4 CPUs (512MB each) [0x700000000 - 0x780000000]
2023-08-07 01:37:08 - Current CPU temperature: 73C
2023-08-07 01:37:26 - RunHammerTest - Running hammer test on 4 CPUs (512MB each) [0x780000000 - 0x800000000]
2023-08-07 01:38:04 - RunHammerTest - Running hammer test on 2 CPUs (704MB each) [0x800000000 - 0x858000000]
2023-08-07 01:38:09 - Current CPU temperature: 59C
2023-08-07 01:38:29 - MtSupportRunAllTests - Test execution time: 685.344s (Test 13 cumulative error count: 0, buffer full count: 0)
2023-08-07 01:38:29 - Finished pass #3 (of 4) (Cumulative error count: 19, buffer full count: 0)
2023-08-07 01:38:29 - Starting pass #4 (of 4)
2023-08-07 01:38:29 - Running test #0 (Test 0 [Address test, walking ones, 1 CPU])
2023-08-07 01:38:29 - MtSupportRunAllTests - Setting random seed to 0x6917F82E
2023-08-07 01:38:29 - MtSupportRunAllTests - Start time: 8432333 ms
2023-08-07 01:38:30 - MtSupportRunAllTests - Enabling memory cache for test
2023-08-07 01:38:30 - MtSupportRunAllTests - Enabling memory cache complete
2023-08-07 01:38:30 - Start memory range test (0x0 - 0x10000000000)
2023-08-07 01:38:30 - MtSupportRunAllTests - Test execution time: 0.806s (Test 0 cumulative error count: 0, buffer full count: 0)
2023-08-07 01:38:30 - Running test #1 (Test 1 [Address test, own address, 1 CPU])
2023-08-07 01:38:30 - MtSupportRunAllTests - Setting random seed to 0x56C09743
2023-08-07 01:38:30 - MtSupportRunAllTests - Start time: 8433221 ms
2023-08-07 01:38:34 - MtSupportRunAllTests - Test execution time: 3.531s (Test 1 cumulative error count: 0, buffer full count: 0)
2023-08-07 01:38:34 - Running test #2 (Test 2 [Address test, own address])
2023-08-07 01:38:34 - MtSupportRunAllTests - Setting random seed to 0x1E15C1DA
2023-08-07 01:38:34 - MtSupportRunAllTests - Start time: 8436834 ms
2023-08-07 01:38:34 - MtSupportRunAllTests - Enabling memory cache for test
2023-08-07 01:38:34 - MtSupportRunAllTests - Enabling memory cache complete
2023-08-07 01:38:34 - Start memory range test (0x0 - 0x10000000000)
2023-08-07 01:38:37 - MtSupportRunAllTests - Test execution time: 3.349s (Test 2 cumulative error count: 0, buffer full count: 0)
2023-08-07 01:38:37 - Running test #3 (Test 3 [Moving inversions, ones & zeroes])
2023-08-07 01:38:37 - MtSupportRunAllTests - Setting random seed to 0xB515AF52
2023-08-07 01:38:37 - MtSupportRunAllTests - Start time: 8440267 ms
2023-08-07 01:38:37 - MtSupportRunAllTests - Enabling memory cache for test
2023-08-07 01:38:37 - MtSupportRunAllTests - Enabling memory cache complete
2023-08-07 01:38:37 - Start memory range test (0x0 - 0x10000000000)
2023-08-07 01:39:09 - Current CPU temperature: 68C
2023-08-07 01:39:11 - MtSupportRunAllTests - Test execution time: 33.911s (Test 3 cumulative error count: 0, buffer full count: 0)
2023-08-07 01:39:11 - Running test #4 (Test 4 [Moving inversions, 8-bit pattern])
2023-08-07 01:39:11 - MtSupportRunAllTests - Setting random seed to 0x458B332C
2023-08-07 01:39:11 - MtSupportRunAllTests - Start time: 8474274 ms
2023-08-07 01:39:11 - MtSupportRunAllTests - Enabling memory cache for test
2023-08-07 01:39:11 - MtSupportRunAllTests - Enabling memory cache complete
2023-08-07 01:39:11 - Start memory range test (0x0 - 0x10000000000)
2023-08-07 01:40:09 - Current CPU temperature: 69C
2023-08-07 01:41:09 - Current CPU temperature: 70C
2023-08-07 01:41:39 - MtSupportRunAllTests - Test execution time: 147.177s (Test 4 cumulative error count: 0, buffer full count: 0)
2023-08-07 01:41:39 - Running test #5 (Test 5 [Moving inversions, random pattern])
2023-08-07 01:41:39 - MtSupportRunAllTests - Setting random seed to 0x47284928
2023-08-07 01:41:39 - MtSupportRunAllTests - Start time: 8621536 ms
2023-08-07 01:41:39 - MtSupportRunAllTests - Enabling memory cache for test
2023-08-07 01:41:39 - MtSupportRunAllTests - Enabling memory cache complete
2023-08-07 01:41:39 - Start memory range test (0x0 - 0x10000000000)
2023-08-07 01:42:09 - Current CPU temperature: 69C
2023-08-07 01:43:09 - Current CPU temperature: 69C
2023-08-07 01:44:09 - Current CPU temperature: 70C
2023-08-07 01:44:55 - MtSupportRunAllTests - Test execution time: 196.281s (Test 5 cumulative error count: 0, buffer full count: 0)
2023-08-07 01:44:55 - Running test #6 (Test 6 [Block move, 64-byte blocks])
2023-08-07 01:44:55 - MtSupportRunAllTests - Setting random seed to 0xA33544C8
2023-08-07 01:44:55 - MtSupportRunAllTests - Start time: 8817902 ms
2023-08-07 01:44:55 - MtSupportRunAllTests - Enabling memory cache for test
2023-08-07 01:44:55 - MtSupportRunAllTests - Enabling memory cache complete
2023-08-07 01:44:55 - Start memory range test (0x0 - 0x10000000000)
2023-08-07 01:45:09 - Current CPU temperature: 59C
2023-08-07 01:46:09 - Current CPU temperature: 58C
2023-08-07 01:47:09 - Current CPU temperature: 58C
2023-08-07 01:48:09 - Current CPU temperature: 58C
2023-08-07 01:49:10 - Current CPU temperature: 59C
2023-08-07 01:50:10 - Current CPU temperature: 59C
2023-08-07 01:50:28 - MtSupportRunAllTests - Test execution time: 332.459s (Test 6 cumulative error count: 0, buffer full count: 0)
2023-08-07 01:50:28 - Running test #7 (Test 7 [Moving inversions, 32-bit pattern])
2023-08-07 01:50:28 - MtSupportRunAllTests - Setting random seed to 0x69184AE9
2023-08-07 01:50:28 - MtSupportRunAllTests - Start time: 9150446 ms
2023-08-07 01:50:28 - MtSupportRunAllTests - Enabling memory cache for test
2023-08-07 01:50:28 - MtSupportRunAllTests - Enabling memory cache complete
2023-08-07 01:50:28 - Start memory range test (0x0 - 0x10000000000)
2023-08-07 01:51:10 - Current CPU temperature: 73C
2023-08-07 01:52:10 - Current CPU temperature: 76C
2023-08-07 01:53:10 - Current CPU temperature: 74C
2023-08-07 01:54:10 - Current CPU temperature: 73C
2023-08-07 01:55:10 - Current CPU temperature: 73C
2023-08-07 01:56:10 - Current CPU temperature: 73C
2023-08-07 01:57:11 - Current CPU temperature: 73C
2023-08-07 01:58:11 - Current CPU temperature: 73C
2023-08-07 01:59:11 - Current CPU temperature: 75C
2023-08-07 02:00:11 - Current CPU temperature: 75C
2023-08-07 02:00:14 - MtSupportRunAllTests - Test execution time: 586.264s (Test 7 cumulative error count: 0, buffer full count: 0)
2023-08-07 02:00:14 - Running test #8 (Test 8 [Random number sequence])
2023-08-07 02:00:14 - MtSupportRunAllTests - Setting random seed to 0x9D3B9CD8
2023-08-07 02:00:14 - MtSupportRunAllTests - Start time: 9736798 ms
2023-08-07 02:00:14 - MtSupportRunAllTests - Enabling memory cache for test
2023-08-07 02:00:14 - MtSupportRunAllTests - Enabling memory cache complete
2023-08-07 02:00:14 - Start memory range test (0x0 - 0x10000000000)
2023-08-07 02:00:30 - [MEM ERROR - Data] Test: 8, CPU: 0, Address: 1FCDFD54C, Expected: 6B1AB91C, Actual: 2B1AB91C
2023-08-07 02:01:11 - Current CPU temperature: 95C
2023-08-07 02:02:00 - MtSupportRunAllTests - Test execution time: 106.044s (Test 8 cumulative error count: 20, buffer full count: 0)
2023-08-07 02:02:00 - Running test #9 (Test 9 [Modulo 20, ones & zeros])
2023-08-07 02:02:00 - MtSupportRunAllTests - Setting random seed to 0x9D409B38
2023-08-07 02:02:00 - MtSupportRunAllTests - Start time: 9842934 ms
2023-08-07 02:02:00 - MtSupportRunAllTests - Enabling memory cache for test
2023-08-07 02:02:00 - MtSupportRunAllTests - Enabling memory cache complete
2023-08-07 02:02:00 - Start memory range test (0x0 - 0x10000000000)
2023-08-07 02:02:11 - Current CPU temperature: 76C
2023-08-07 02:03:11 - Current CPU temperature: 74C
2023-08-07 02:04:11 - Current CPU temperature: 74C
2023-08-07 02:05:11 - Current CPU temperature: 75C
2023-08-07 02:06:11 - Current CPU temperature: 74C
2023-08-07 02:07:12 - Current CPU temperature: 75C
2023-08-07 02:08:12 - Current CPU temperature: 75C
2023-08-07 02:09:12 - Current CPU temperature: 76C
2023-08-07 02:10:12 - Current CPU temperature: 75C
2023-08-07 02:10:55 - MtSupportRunAllTests - Test execution time: 534.616s (Test 9 cumulative error count: 0, buffer full count: 0)
2023-08-07 02:10:55 - Running test #10 (Test 10 [Bit fade test, 2 patterns, 1 CPU])
2023-08-07 02:10:55 - MtSupportRunAllTests - Setting random seed to 0xCBD7A951
2023-08-07 02:10:55 - MtSupportRunAllTests - Start time: 10377628 ms
2023-08-07 02:10:55 - MtSupportRunAllTests - Enabling memory cache for test
2023-08-07 02:10:55 - MtSupportRunAllTests - Enabling memory cache complete
2023-08-07 02:10:55 - Start bit fade test (0x0 - 0x10000000000)
2023-08-07 02:10:55 - Starting Stage 0, Pattern=00000000
2023-08-07 02:10:57 - Finished Stage 0, Pattern=00000000
2023-08-07 02:10:57 - Sleep start time: 10379695
2023-08-07 02:10:57 - Sleep time: 300000
2023-08-07 02:10:57 - Test 10 - Sleeping (299 seconds remaining)
2023-08-07 02:11:12 - Current CPU temperature: 56C
2023-08-07 02:11:27 - Slept for 30 seconds
2023-08-07 02:11:58 - Slept for 60 seconds
2023-08-07 02:12:12 - Current CPU temperature: 56C
2023-08-07 02:12:28 - Slept for 90 seconds
2023-08-07 02:12:58 - Slept for 121 seconds
2023-08-07 02:13:12 - Current CPU temperature: 57C
2023-08-07 02:13:28 - Slept for 151 seconds
2023-08-07 02:13:59 - Slept for 181 seconds
2023-08-07 02:14:12 - Current CPU temperature: 57C
2023-08-07 02:14:29 - Slept for 212 seconds
2023-08-07 02:14:59 - Slept for 242 seconds
2023-08-07 02:15:12 - Current CPU temperature: 58C
2023-08-07 02:15:30 - Slept for 272 seconds
2023-08-07 02:15:57 - Starting Stage 1, Pattern=00000000
2023-08-07 02:16:00 - Finished Stage 1, Pattern=00000000
2023-08-07 02:16:00 - Starting Stage 0, Pattern=FFFFFFFF
2023-08-07 02:16:02 - Finished Stage 0, Pattern=FFFFFFFF
2023-08-07 02:16:02 - Sleep start time: 10685275
2023-08-07 02:16:02 - Sleep time: 300000
2023-08-07 02:16:03 - Test 10 - Sleeping (299 seconds remaining)
2023-08-07 02:16:12 - Current CPU temperature: 60C
2023-08-07 02:16:33 - Slept for 30 seconds
2023-08-07 02:17:03 - Slept for 60 seconds
2023-08-07 02:17:12 - Current CPU temperature: 57C
2023-08-07 02:17:33 - Slept for 90 seconds
2023-08-07 02:18:04 - Slept for 121 seconds
2023-08-07 02:18:12 - Current CPU temperature: 57C
2023-08-07 02:18:34 - Slept for 151 seconds
2023-08-07 02:19:04 - Slept for 181 seconds
2023-08-07 02:19:13 - Current CPU temperature: 57C
2023-08-07 02:19:35 - Slept for 212 seconds
2023-08-07 02:20:05 - Slept for 242 seconds
2023-08-07 02:20:13 - Current CPU temperature: 57C
2023-08-07 02:20:35 - Slept for 272 seconds
2023-08-07 02:21:03 - Starting Stage 1, Pattern=FFFFFFFF
2023-08-07 02:21:06 - Finished Stage 1, Pattern=FFFFFFFF
2023-08-07 02:21:06 - MtSupportRunAllTests - Test execution time: 611.156s (Test 10 cumulative error count: 0, buffer full count: 0)
2023-08-07 02:21:06 - Running test #13 (Test 13 [Hammer test])
2023-08-07 02:21:06 - MtSupportRunAllTests - Setting random seed to 0x071E4F2F
2023-08-07 02:21:06 - MtSupportRunAllTests - Start time: 10988867 ms
2023-08-07 02:21:06 - MtSupportRunAllTests - Enabling memory cache for test
2023-08-07 02:21:06 - MtSupportRunAllTests - Enabling memory cache complete
2023-08-07 02:21:06 - Start double-sided hammer test (0x0 - 0x10000000000, Step size: 0x1000000)
2023-08-07 02:21:06 - Using random pattern
2023-08-07 02:21:06 - # of segments to hammer: 15 (SegSize=2048MB, SkipSize=0MB)
2023-08-07 02:21:13 - Current CPU temperature: 74C
2023-08-07 02:21:55 - RunHammerTest - Running hammer test on 2 CPUs (573MB each) [0xB021000 - 0x52B99000]
2023-08-07 02:22:13 - Current CPU temperature: 75C
2023-08-07 02:23:07 - RunHammerTest - Running hammer test on 4 CPUs (512MB each) [0x100000000 - 0x180000000]
2023-08-07 02:23:13 - Current CPU temperature: 59C
2023-08-07 02:23:46 - RunHammerTest - Running hammer test on 4 CPUs (512MB each) [0x180000000 - 0x200000000]
2023-08-07 02:24:13 - Current CPU temperature: 72C
2023-08-07 02:24:24 - RunHammerTest - Running hammer test on 4 CPUs (512MB each) [0x200000000 - 0x280000000]
2023-08-07 02:25:03 - RunHammerTest - Running hammer test on 4 CPUs (512MB each) [0x280000000 - 0x300000000]
2023-08-07 02:25:13 - Current CPU temperature: 74C
2023-08-07 02:25:42 - RunHammerTest - Running hammer test on 4 CPUs (512MB each) [0x300000000 - 0x380000000]
2023-08-07 02:26:13 - Current CPU temperature: 71C
2023-08-07 02:26:20 - RunHammerTest - Running hammer test on 4 CPUs (512MB each) [0x380000000 - 0x400000000]
2023-08-07 02:26:59 - RunHammerTest - Running hammer test on 4 CPUs (512MB each) [0x400000000 - 0x480000000]
2023-08-07 02:27:13 - Current CPU temperature: 74C
2023-08-07 02:27:38 - RunHammerTest - Running hammer test on 4 CPUs (512MB each) [0x480000000 - 0x500000000]
2023-08-07 02:28:13 - Current CPU temperature: 70C
2023-08-07 02:28:17 - RunHammerTest - Running hammer test on 4 CPUs (512MB each) [0x500000000 - 0x580000000]
2023-08-07 02:28:55 - RunHammerTest - Running hammer test on 4 CPUs (512MB each) [0x580000000 - 0x600000000]
2023-08-07 02:29:13 - Current CPU temperature: 74C
2023-08-07 02:29:34 - RunHammerTest - Running hammer test on 4 CPUs (512MB each) [0x600000000 - 0x680000000]
2023-08-07 02:30:13 - RunHammerTest - Running hammer test on 4 CPUs (512MB each) [0x680000000 - 0x700000000]
2023-08-07 02:30:13 - Current CPU temperature: 68C
2023-08-07 02:30:51 - RunHammerTest - Running hammer test on 4 CPUs (512MB each) [0x700000000 - 0x780000000]
2023-08-07 02:31:13 - Current CPU temperature: 73C
2023-08-07 02:31:30 - RunHammerTest - Running hammer test on 4 CPUs (512MB each) [0x780000000 - 0x800000000]
2023-08-07 02:32:09 - RunHammerTest - Running hammer test on 2 CPUs (704MB each) [0x800000000 - 0x858000000]
2023-08-07 02:32:14 - Current CPU temperature: 59C
2023-08-07 02:32:34 - MtSupportRunAllTests - Test execution time: 687.744s (Test 13 cumulative error count: 0, buffer full count: 0)
2023-08-07 02:32:34 - Finished pass #4 (of 4) (Cumulative error count: 20, buffer full count: 0)
2023-08-07 02:32:34 - Cleanup - Unlocking all memory ranges...
2023-08-07 02:32:34 - All memory ranges successfully unlocked
2023-08-07 02:32:36 - Test result: FAIL (Errors: 20)
2023-08-07 02:33:04 - Display test result summary
2023-08-07 02:33:34 - Enabling graphics mode
2023-08-07 02:33:34 - Get screen size
2023-08-07 02:33:34 - Current screen size: 1024 x 768
2023-08-07 02:33:34 - poll_timings_ryzen - [MC0] DramConfiguration=80050960
2023-08-07 02:33:34 - poll_timings_ryzen - [MC0] DebugMisc=0B0008F8
2023-08-07 02:33:34 - poll_timings_ryzen - [MC1] DramConfiguration=80050960
2023-08-07 02:33:34 - poll_timings_ryzen - [MC1] DebugMisc=0B0008F8
