Aleph jimini # smartctl -a /dev/sda
smartctl 5.40 2010-10-16 r3189 [i686-pc-linux-gnu] (local build)
Copyright (C) 2002-10 by Bruce Allen,
smartmontools
=== START OF INFORMATION SECTION ===
Model Family: Fujitsu MHV series
Device Model: FUJITSU MHV2120BH
Serial Number: NWAPT6926JGB
Firmware Version: 00000029
User Capacity: 120.034.123.776 bytes
Device is: In smartctl database [for details use: -P show]
ATA Version is: 7
ATA Standard is: ATA/ATAPI-7 T13 1532D revision 4a
Local Time is: Fri Aug 19 11:23:37 2011 CEST
SMART support is: Available - device has SMART capability.
SMART support is: Enabled
=== START OF READ SMART DATA SECTION ===
SMART overall-health self-assessment test result: PASSED
General SMART Values:
Offline data collection status: (0x84) Offline data collection activity
was suspended by an interrupting command from host.
Auto Offline Data Collection: Enabled.
Self-test execution status: ( 0) The previous self-test routine completed
without error or no self-test has ever
been run.
Total time to complete Offline
data collection: ( 702) seconds.
capabilities: (0x7b) SMART execute Offline immediate.
Auto Offline data collection on/off support.
Suspend Offline collection upon new
command.
Offline surface scan supported.
Self-test supported.
Conveyance Self-test supported.
Selective Self-test supported.
SMART capabilities: (0x0003) Saves SMART data before entering
power-saving mode.
Supports SMART auto save timer.
Error logging capability: (0x01) Error logging supported.
General Purpose Logging supported.
Short self-test routine
recommended polling time: ( 2) minutes.
Extended self-test routine
recommended polling time: ( 82) minutes.
Conveyance self-test routine
SCT capabilities: (0x003d) SCT Status supported.
SCT Error Recovery Control supported.
SCT Feature Control supported.
SCT Data Table supported.
SMART Attributes Data Structure revision number: 16
Vendor Specific SMART Attributes with Thresholds:
ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE
1 Raw_Read_Error_Rate 0x000f 100 100 046 Pre-fail Always - 133532
2 Throughput_Performance 0x0005 100 100 030 Pre-fail Offline - 31784960
3 Spin_Up_Time 0x0003 100 100 025 Pre-fail Always - 1
4 Start_Stop_Count 0x0032 099 099 000 Old_age Always - 2412
5 Reallocated_Sector_Ct 0x0033 100 100 024 Pre-fail Always - 0 (2000, 0)
7 Seek_Error_Rate 0x000f 100 100 047 Pre-fail Always - 2437
8 Seek_Time_Performance 0x0005 100 100 019 Pre-fail Offline - 0
9 Power_On_Seconds 0x0032 063 063 000 Old_age Always - 18766h+47m+57s
10 Spin_Retry_Count 0x0013 100 100 020 Pre-fail Always - 0
12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 2277
192 Power-Off_Retract_Count 0x0032 099 099 000 Old_age Always - 260
193 Load_Cycle_Count 0x0032 091 091 000 Old_age Always - 195248
194 Temperature_Celsius 0x0022 100 100 000 Old_age Always - 37 (Min/Max 7/58)
195 Hardware_ECC_Recovered 0x001a 100 100 000 Old_age Always - 7805
196 Reallocated_Event_Count 0x0032 100 100 000 Old_age Always - 0 (0, 6592)
197 Current_Pending_Sector 0x0012 100 100 000 Old_age Always - 0
198 Offline_Uncorrectable 0x0010 100 100 000 Old_age Offline - 0
199 UDMA_CRC_Error_Count 0x003e 200 200 000 Old_age Always - 0
200 Multi_Zone_Error_Rate 0x000f 100 100 060 Pre-fail Always - 24537
203 Run_Out_Cancel 0x0002 100 100 000 Old_age Always - 429509441668
240 Head_Flying_Hours 0x003e 200 200 000 Old_age Always - 0
SMART Error Log Version: 1
No Errors Logged
SMART Self-test log structure revision number 1
No self-tests have been logged. [To run self-tests, use: smartctl -t]
SMART Selective self-test log data structure revision number 1
SPAN MIN_LBA MAX_LBA CURRENT_TEST_STATUS
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
Selective self-test flags (0x0):
After scanning selected spans, do NOT read-scan remainder of disk.
If Selective self-test is pending on power-up, resume after 0 minute delay.
