DKK007
PCGH-Community-Veteran(in)
Kann jemand etwas mit dieser Fehlermeldung anfangen:
Ich weiß nicht, warum die das nicht hinbekommen bei Java mal verständliche Fehlermeldungen zu liefern.
Exception in thread "JavaFX Application Thread" java.lang.RuntimeException: java.lang.reflect.InvocationTargetException at javafx.fxml.FXMLLoader$MethodHandler.invoke(FXMLLoader.java:1774)
at javafx.fxml.FXMLLoader$ControllerMethodEventHandler.handle(FXMLLoader.java:1657)
at com.sun.javafx.event.CompositeEventHandler.dispatchBubblingEvent(CompositeEventHandler.java:86)
at com.sun.javafx.event.EventHandlerManager.dispatchBubblingEvent(EventHandlerManager.java:238)
at com.sun.javafx.event.EventHandlerManager.dispatchBubblingEvent(EventHandlerManager.java:191)
at com.sun.javafx.event.CompositeEventDispatcher.dispatchBubblingEvent(CompositeEventDispatcher.java:59)
at com.sun.javafx.event.BasicEventDispatcher.dispatchEvent(BasicEventDispatcher.java:58)
at com.sun.javafx.event.EventDispatchChainImpl.dispatchEvent(EventDispatchChainImpl.java:114)
at com.sun.javafx.event.BasicEventDispatcher.dispatchEvent(BasicEventDispatcher.java:56)
at com.sun.javafx.event.EventUtil.fireEventImpl(EventUtil.java:74)
at com.sun.javafx.event.EventUtil.fireEvent(EventUtil.java:54)
at javafx.event.Event.fireEvent(Event.java:198)
at javafx.scene.Scene$ClickGenerator.postProcess(Scene.java:3470)
at javafx.scene.Scene$ClickGenerator.access$8100(Scene.java:3398)
at javafx.scene.Scene$MouseHandler.process(Scene.java:3766)
at javafx.scene.Scene$MouseHandler.access$1500(Scene.java:3485)
at javafx.scene.Scene.impl_processMouseEvent(Scene.java:1762)
at javafx.scene.Scene$ScenePeerListener.mouseEvent(Scene.java:2494)
at com.sun.javafx.tk.quantum.GlassViewEventHandler$MouseEventNotification.run(GlassViewEventHandler.java:352)
at com.sun.javafx.tk.quantum.GlassViewEventHandler$MouseEventNotification.run(GlassViewEventHandler.java:275)
at java.security.AccessController.doPrivileged(Native Method)
at com.sun.javafx.tk.quantum.GlassViewEventHandler.lambda$handleMouseEvent$300(GlassViewEventHandler.java:388)
at com.sun.javafx.tk.quantum.QuantumToolkit.runWithoutRenderLock(QuantumToolkit.java:389)
at com.sun.javafx.tk.quantum.GlassViewEventHandler.handleMouseEvent(GlassViewEventHandler.java:387)
at com.sun.glass.ui.View.handleMouseEvent(View.java:555)
at com.sun.glass.ui.View.notifyMouse(View.java:937)
at com.sun.glass.ui.gtk.GtkApplication._runLoop(Native Method)
at com.sun.glass.ui.gtk.GtkApplication.lambda$null$450(GtkApplication.java:139)
at java.lang.Thread.run(Thread.java:748)
Caused by: java.lang.reflect.InvocationTargetException
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.lang.reflect.Method.invoke(Method.java:498)
at sun.reflect.misc.Trampoline.invoke(MethodUtil.java:71)
at sun.reflect.GeneratedMethodAccessor1.invoke(Unknown Source)
at sun.reflect.misc.MethodUtil.invoke(MethodUtil.java:275)
at javafx.fxml.FXMLLoader$MethodHandler.invoke(FXMLLoader.java:1771)
... 31 more
Caused by: java.lang.NoClassDefFoundError: org/apache/commons/lang3/StringUtils
at org.neo4j.kernel.configuration.Settings$21.apply(Settings.java:849)
at org.neo4j.kernel.configuration.Settings$21.apply(Settings.java:840)
at org.neo4j.kernel.configuration.Settings$DefaultSetting.apply(Settings.java:1290)
at org.neo4j.kernel.configuration.Settings$DefaultSetting.apply(Settings.java:1205)
at org.neo4j.graphdb.config.Setting.validate(Setting.java:80)
at org.neo4j.kernel.configuration.IndividualSettingsValidator.lambda$validate$1(IndividualSettingsValidator.java:62)
at java.util.stream.ReferencePipeline$3$1.accept(ReferencePipeline.java:193)
at java.util.ArrayList$ArrayListSpliterator.forEachRemaining(ArrayList.java:1374)
at java.util.stream.AbstractPipeline.copyInto(AbstractPipeline.java:481)
at java.util.stream.AbstractPipeline.wrapAndCopyInto(AbstractPipeline.java:471)
at java.util.stream.ReduceOps$ReduceOp.evaluateSequential(ReduceOps.java:708)
at java.util.stream.AbstractPipeline.evaluate(AbstractPipeline.java:234)
at java.util.stream.ReferencePipeline.collect(ReferencePipeline.java:499)
at org.neo4j.kernel.configuration.IndividualSettingsValidator.validate(IndividualSettingsValidator.java:70)
at org.neo4j.kernel.configuration.Config.replaceSettings(Config.java:403)
at org.neo4j.kernel.configuration.Config.<init>(Config.java:227)
at org.neo4j.kernel.configuration.Config.<init>(Config.java:201)
at org.neo4j.kernel.configuration.Config.embeddedDefaults(Config.java:149)
at org.neo4j.kernel.configuration.Config.embeddedDefaults(Config.java:129)
at org.neo4j.kernel.configuration.Config.embeddedDefaults(Config.java:105)
at org.neo4j.graphdb.factory.GraphDatabaseBuilder.newGraphDatabase(GraphDatabaseBuilder.java:193)
at org.neo4j.graphdb.factory.GraphDatabaseFactory.newEmbeddedDatabase(GraphDatabaseFactory.java:70)
at application.DBService.init(DBService.java:38)
at application.FXMLController.button1Clicked(FXMLController.java:82)
... 41 more
Caused by: java.lang.ClassNotFoundException: org.apache.commons.lang3.StringUtils
at java.net.URLClassLoader.findClass(URLClassLoader.java:381)
at java.lang.ClassLoader.loadClass(ClassLoader.java:424)
at sun.misc.Launcher$AppClassLoader.loadClass(Launcher.java:335)
at java.lang.ClassLoader.loadClass(ClassLoader.java:357)
... 65 more
... 31 more
... 41 more
... 65 more
