Ada’s Optical Flow Accelerator analyzes two sequential in-game frames and calculates an optical flow field. The optical flow field captures the direction and speed at which pixels are moving from frame 1 to frame 2. The Optical Flow Accelerator is able to capture pixel-level information such as particles, reflections, shadows, and lighting, which are not included in game engine motion vector calculations. In the motorcycle example below, the motion flow of the motorcyclist accurately represents that the shadow stays in roughly the same place on the screen with respect to their bike.
https://images.nvidia.com/aem-dam/S...ia-dlss-3-motion-optical-flow-accelerator.jpg
Whereas the Optical Flow Accelerator accurately tracks pixel level effects such as reflections, DLSS 3 also uses game engine motion vectors to precisely track the movement of geometry in the scene. In the example below, game motion vectors accurately track the movement of the road moving past the motorcyclist, but not their shadow. Generating frames using engine motion vectors alone would result in visual anomalies like stuttering on the shadow.
https://www.nvidia.com/content/dam/...ations/nvidia-dlss-3-without-optical-flow.jpg
For each pixel, the DLSS Frame Generation AI network decides how to use information from the game motion vectors, the optical flow field, and the sequential game frames to create intermediate frames. By using both engine motion vectors and optical flow to track motion, the DLSS Frame Generation network is able to accurately reconstruct both geometry and effects, as seen in the picture below.
https://images.nvidia.com/aem-dam/S...dia-dlss-3-motion-optical-flow-estimation.jpg
With DLSS 3 enabled, AI is reconstructing three-fourths of the first frame with DLSS Super Resolution, and reconstructing the entire second frame using DLSS Frame Generation. In total, DLSS 3 reconstructs seven-eighths of the total displayed pixels, increasing performance significantly!
https://images.nvidia.com/aem-dam/S...vations/nvidia-dlss-3-reconstructs-pixels.png
DLSS 3 also incorporates
NVIDIA Reflex, which synchronizes the GPU and CPU, ensuring optimum responsiveness and low system latency. Lower system latency makes game controls more responsive, and ensures on-screen actions occur almost instantaneously once you click your mouse or other control input. When compared to native, DLSS 3 can reduce latency by up to 2X.
