[Sammelthread] DayZ - Arma II Modifikation
Auf welchem Server zockt ihr so?
Hab mich gestern mal hier angemeldet.
Server sind zwar in den USA, aber die Admins schalten einen binnen 60 Mins frei und dann heißt es cheaterfrei zocken.
Man sieht regelmäßig wie Leute vom Server gekickt werden, die nicht registriert sind oder sich nicht an die Regeln halten. Die Admins sind sehr aktiv. Hier mal die goldenen Regeln: :ugly:
0. Respect your fellow Players, Administrators, and Moderators.
1. NO offensive language is tolerated either in game or on the forums. This includes but is not limited to: racism, homophobia, sexism and discrimination.
2. NO VOIP in side, this is enforced heavily. There is a thread that shows you how to bind VOIP to direct chat only.
3. Don’t abuse exploits. Use common sense to figure it out. If you are unsure about something being an exploit, ask a moderator or admin before doing it.
4. NO excessive trash talking. Competitive banter is allowed but if the staff feels you are crossing the line you will be warned and if need be, kicked or banned.
5. If one of your friends is kicked or banned, help him appeal on the forums but absolutely do not harass the moderator about it over side. You can always appeal the ban on the forums, complaining in side chat will do nothing but hurt his chances.
6. Do NOT pick up hacked gear, or accept free loot from hackers. If it’s suspicious, report it or don’t loot it – if you accidentally pick it up, you may have to appeal to us on the forums if you are banned.
7. Confirmed cases of combat logging will result in a 24 hour ban, and a permanent ban if you do it again.
8. Do NOT accuse people of hacking in side chat, these forums are the place to make a cheat report rather than in-game chat.
9. Do NOT glitch tents to prevent others from raiding them. This includes but is not limited to: placing them under water, placing them inside rocks, placing them inside houses. If you are caught doing this you will be punished.
10. Do NOT abuse players who stream on the BMRF servers. Do not ‘stream snipe’ them, or try to grief their events in any way. Be respectful of people who stream.
11. Do NOT threaten to hack the server. It’s pointless and will probably get you banned.
12. If you break side chat rules too much – you will be temp banned or even permanently banned. Kicks may serve as a warning, text may serve as a warning.
13. Both our Administrators AND our Moderators reserve the right to interpret the Server Rules in their own manner, you may file a complaint – but do so only on the forums, NOT in sidechat.
14. You are expected to read the rules. They are found through the link on the homepage or on the forum navigation bar. Not having read them is not an excuse.
15. If you’re in control of a multiple Air Vehicles, you’re not allowed to store all of them on an unclimbable surface. May result in loss of your air vehicle, kick or temporary ban.
16. All rules are open to change without notice.
Außerdem schieben sie offensichtlichen Bugs einen Riegel vor - momentan machen wohl die Zelte Probleme...
Läuft vorbildlich zivilisiert ab dort -das gefällt! :daumen:
P.S. Serverhopping ist auch nicht drin. Es wurde eine Wartezeit eingebaut (glaub 10 Minuten waren es), sodass Ghosting verhindert wird! Eine gute und konsequente Idee!
hmm, ich hab heute mal alles geupdated (beta patch und 1.7.5.1), aber der findet kaum server (keine filter). un die 3 4 die er findet heissen immer irgendwas mit private. dann war ich ma auf einem druff, wars wieder laggy wie hölle und um mich rum lagen 2 flugzeugträger :ugly: also auch schnell wieder runter. fehlt mir noch irgendwas oder?
Mods aus aktiviert? Vom Beta-Launcher gestartet?
Ansonsten benutz den DayZ Commander
Hat jmd. von euch auch so komisches Texturflackern mit ner AMD Graka? Hab das nur wenn ich die Glättung für Bäume und Grass aktivieren will.
Joa hab ich auch allerdings eher selten :D
Uiii ich hab hier grad Mountain Dew neben mir stehen :D Also im RL nicht in DayZ :D
Das Zeug schmeckt irgendwie... anders. Nicht so Süß wie erwartet und der Geschmack ist auch nicht so kräftig sondern eher mild :D Gefällt mir
is immernoch meine alte installation usw. also alles aktiviert und die selbe verknüpfung bla. ich kam ja auch auf nen server druff (mit flugzeugträgern auf der map wie streussel aufm kuchen xD), aber mehr wie 10 oder so hat er halt ned gefunden :/
Welche map war das denn? Im DayzCommander siehst du ja welche server prozentual gesehen mit welcher version am häufigsten laufen.
Ich hab jetzt schon ein paar tage überlebt, find aber grad ums verrecken kein zelt. Vorgestern eins so gut zwischen 3 tannen versteckt, dass selbst ich net mehr dran kam...
stink normal chernarus. kA ob ich ohne irgendwelche zusatz downloads auf andre maps druff komm, daher probier ich nur chernarus. also das mit den flugzeugträgern war definitiv nich koscher - daher bin ich da auch postwendend wieder runter ^^ bin bisher immer übern ingame browser rein.
hallo leute, spiele auch dayz. habe mir vor kurzem nen neuen rechner zusammengebaut i5-3570k und Gigabyte HD 7970 Ghz Edition mit 3 GB
Arma zwingt jedoch auf Atoc 7 und ultra Einstellungen selbst diese Hardware in die Knie und hab dann im Gras nur noch 20 fps. AUßerdem hat meine neue Graka ein Problem mit Atoc.
und zwar dieses hier: https://dev-heaven.net/issues/17144
Hat jemand von euch auch diese Raster/Kästchen Grafikbugs? So wie ich bisher gehesen habe gibts dafür noch keine Lösung, also weiterhin mit Atoc 0 und den besch.... Bäumen aus Arma 2 spielen, oder die Bugs so hinnehmen?? ;-((
Ja, ATOC zieht massig an der Leistung, ich spiele auf AA very high, ATOC max., SMAA very high, aber das Problem ist mir so noch nicht aufgefallen. Muss ich nachher mal schauen, wenn ich daheim bin.
mit oder ohne Vsync??
Vsync off is bei mir no go, dann spiel ich lieber mit diesen Kästchen und 25 fps oder Atoc auf 0
