[Sammelthread] AsRock X58 Extreme
jupph
Specs:
CPU:
- Intel® Socket 1366 Core™ i7 Processor Extreme Edition inkl. Gulftown 6-CoreCPU
- Dynamic Speed Technology
- System Bus up to 6400 MT/s; Intel® QuickPath Interconnect
- Advanced V8 Power Phase Design
- Supports Hyper-Threading Technology
- Supports Untied Overclocking Technology
- Supports EM64T CPU
Chipset:
- Northbridge: Intel® X58
- Southbridge: Intel® ICH10R
Ram:
- Triple Channel DDR3 memory technology
- 6 x DDR3 DIMM slots
- Supports DDR3 2000(OC)/1866(OC)/1600(OC)/1333(OC)/1066 non-ECC, un-buffered memory
- Supports DDR3 ECC, un-buffered memory with Intel® Workstation 1S Xeon® processors 3500 series
- Max. capacity of system memory: 24GB
- Supports Intel® Extreme Memory Profile (XMP)
Bios:
- 8Mb AMI BIOS
- AMI Legal BIOS
- Supports "Plug and Play"
- ACPI 1.1 Compliance Wake Up Events
- Supports jumperfree
- SMBIOS 2.3.1 Support
- CPU, DRAM, NB, SB, VTT Voltage Multi-adjustment
- Supports I. O. T. (Intelligent Overclocking Technology)
- Supports Smart BIOS
Audio:
- 7.1 CH HD Audio with Content Protection
- DAC with 110dB dynamic range (ALC890 Audio Codec)
LAN:
- PCIE x1 Gigabit LAN 10/100/1000 Mb/s
- Realtek RTL8111DL
- Supports Wake-On-LAN
Expensionslots:
- 3 x PCI Express 2.0 x16 slots (blue @ x16 mode, orange @ x4 mode) (Double-wide slot spacing between each PCI-E slot)
- 2 x PCI Express x1 slots
- 2 x PCI slots
- Supports ATI™ CrossFireX™, 3-Way CrossFireX™ and Quad CrossFireX™
- Supports NVIDIA® SLI™ and Quad SLI™
Connectors:
- 6 x SATAII 3.0 Gb/s connectors, support RAID (RAID 0, RAID 1, RAID 10, RAID 5 and Intel® Matrix Storage), NCQ, AHCI and Hot Plug functions
- 1 x ATA133 IDE connector (supports 2 x IDE devices)
- 1 x Floppy connector
- 1 x IR header
- 1 x COM port header
- 1 x HDMI_SPDIF header
- 1 x IEEE 1394 header
- 1 x TPM header
- CPU/Chassis/NB/Power FAN connector
- 24 pin ATX power connector
- 8 pin 12V power connector
- CD in header
- Front panel audio connector
- 2 x USB 2.0 headers (support 4 USB 2.0 ports)
I/O Panel:
- 1 x PS/2 Mouse Port
- 1 x PS/2 Keyboard Port
- 1 x Coaxial SPDIF Out Port
- 1 x Optical SPDIF Out Port
- 7 x Ready-to-Use USB 2.0 Ports
- 1 x Powered eSATAII/USB Connector
- 1 x RJ-45 LAN Port with LED (ACT/LINK LED and SPEED LED)
- 1 x IEEE 1394 Port
- 1 x Clear CMOS Switch
- HD Audio Jack: Side Speaker / Rear Speaker / Central / Bass / Line in / Front Speaker / Microphone
Overview
  • Supports all 1366 CPU's inkl. Gulftown 6-Core CPU
  • System Bus up to 6400 MT/s; Intel® QuickPath Interconnect
  • Triple Channel DDR3 2000(OC) with 6 DIMM slots
  • 2 x PCI Express 2.0 x 16 slots (Double-wide slot spacing between each PCI-E slot)
  • 1 x PCI Express 2.0 x 8 slot
  • 1 x Powered eSATAII/USB Connector
  • NVIDIA® Quad SLI™ and SLI™
  • ATI™ CrossFireX™, 3-Way CrossFireX™ and Quad CrossFireX™
  • 7.1 CH, ALC890 Audio Codec
  • Smart Switch Design
  • Dr. Debug
  • TPM support
Software/Tools:
  • ASRock Instant Boot
  • Instant Flash
  • Smart BIOS
  • ASRock OC Tuner
  • Intelligent Energy Saver
Da es noch keinen Sammelthread für das Board gibt, will ich ihm nun einen widmen.
Grade da AsRock immernoch eher den Ruf von mehr Schlecht als Recht hat,
würden mich Langzeiterfahrungen von anderen Usern interessieren.
Mein Board läuft seit einem halben Jahr ohne Probleme mit folgenden Einstellungen:
CPU: Core i7 920 @ 3,613 GHz (21x172), 1,152v
Kühlung: Prolimatech Megahalems
RAM: G.Skill RipJaws @ 1720MHz
GPU: Sparkle GTX 480
Gehäuse: CoolerMaster HAF 932
Netzteil: Tagan Piperock 800W
Die Overclockingeinstellungen erinnern mich sehr stark an mein altes Asus-Board
und sind demnach sehr umfangreich.
Bisher gab es keinerlei Probleme und ich bin selbst überrascht wie "sauber"
das Board von der Asus-Tochter bis jetzt läuft.
*Update 27.07.2010 - Bios-Bilder hinzugefügt*
Ich will dir nicht zunahe treten, aber das kann man nach den Forum-internen Üblichkeiten kaum Sammelthread nennen.
Habe ein Bild des Boards und Bios-Screens im Startpost eingefügt.
Beim Boardlayout finde ich genial das man SLI auch mit GraKa's die 3 Slotkühler haben, betreiben kann.
Hier noch ein Bild des "Asrock-Overclocking-Tuners" mit allen vier Reitern.
Damit ist das Übertakten unter Windows problemlos möglich.
hallo
ich habe heute ein biosupdate gemacht auf das aktuellste was ich finden konnte 2.5
nun ist mein turbo weg
aber dafür rennt er auf 3,8ghz mit weniger vcore und bisher stabil was vorher nicht der fall war da gings nur bis 3,6ghz +turbo =3783mhz
kennt das problem jemand von euch ?
Ich habe auch vor einiger Zeit aufs 2.5er geupdated. Vorher hatte ich den Multi immer auf 21. Nach dem Update ging er nur noch bis 20.
Ich musste unter CPU-Settings (im zweiten Menüpunkt) den Turbomodus wieder aktivieren,
neu starten(!) und konnte dann den Multi wieder auf 21 setzen.
oh sorry. hab noch mal geschaut. Der Turbo-Modus wird mittels SpeedStep an-&ausgeschaltet.
Also:
BIOS: Advanced -> CPU Configuration -> "Intel(R) SpeedStep(tm) tech" auf enabled setzen.
neu starten und dann müsste der Multi von 21 wieder wählbar sein.
(bzw auf auto ist der TurboModus aktiviert)
Falls es schon auf enabled steht, dann einfach mal disabled wählen, neustarten, wieder enabled wählen und nochmal neustarten.
Was macht denn das Board so an Max-Bclk? Hab nur ein P55 Extreme von Asrock. Gegenüber Gigabyte sind die schon ein stück schlechter in der Spanungsversorung.
Also just for fun bin ich mal bis zu stabilen 213 gekommen.
Die liefen testweise 4 Stunden unter Videokodierung stabil.
Allerdings kann es vllt auch noch mehr.
Weiter wollte ich mit der Standardkühlung und ohne Grund nicht gehen.
Hi,
der Thread ist zwar schon ein paar Monate alt, aber da ich das Asrock X58 Extreme habe, bin ich hier wohl richtig.
Ich habe mir letztens 12 GB RAM gegönnt, aber das Board erkennt nur 8 GB. Zuerst hatte ich 12 GB Kingston HyperX 1600. Da war das gleiche Problem und ich habe dann nach der PDF-Tabelle für das Board geguckt (Memory QVL .. Direktlink von Asrock.com), welcher Ram am besten passt.
Also G.Skill (auch 1600er) bestellt und es wurden wieder nur 8 GB erkannt. Everest Ultimate erkennt sogar alle sechs Riegel.
Habe auch schon ziemlich alle Einstellungen im Bios probiert, was Spannungen und Taktraten angeht. Bei extremen Werten erkennt das Board sogar nur 4 GB.
Das System läuft aber stabil und ich hatte ansonsten noch keine Probleme. Betreibe SLI mit zwei GTX260 und einen i7-920 notOC; 850Watt Cougar 80+ Netzteil.
Durch googeln konnte ich einen Thread auf Hardwareluxx.de finden mit HAARGENAU dem gleichen Problem, aber bei im ist das System zusätzlich noch instabil:
Das Problem sieht so aus:
- Von 3 bzw. 6 Speicherriegeln werden nur 2 bzw. 4 richtig erkannt. (Bänke A und B, bei C steht Empty im BIOS).
- Austauschen der Riegel hat nix gebracht, sie laufen alle auf A/B, aber keiner auf C.
- Beim Starten erzählt das Board was von Triple-Channel wenn 3 bzw. 6 Riegel drin stecken. Bei nur 2 bzw. 4 Riegeln steht an der Stelle Dual-Channel. Die Anzeige der Speicherriegel im BIOS ist allerdings jeweils identisch (C leer).
- BIOS-Update hat nix gebracht (Version 1.5 vom 13.04.2010) --- Habe ich auch gemacht auf Ver 2.80
- Speicher als DDR3 1333 oder 1066 statt 1600 (Auto) laufen zu lassen hat auch nix gebracht
- Im Windows (7) werden nur jeweils 4 bzw. 8 GB angezeigt, allerdings zeigt CPU-Z bei den SPD-Settings alle 3 bzw. 6 Module an! (und hat da auch 6 bzw. 12 GB stehen als Summe)
- Board-Settings waren alle auf Default, nix übertaktet, der Speicher hat sich per XMP auf 1.60V eingestellt --- wie bei mir
- Windows läuft prinzipiell, allerdings stürzt es bei Belastung relativ schnell ab. --- noch keinen Absturz, auch bei Belastung
- Auch diverse Programme stürzen ab (auch mit nur 2 Riegeln installiert): Prime95 sofort beim Start des Blend Tests (SmallFFT läuft aber), Firefox nach ein paar Seiten browsen, SIW immer beim Laden oder spätestens beim Zugriff auf die Sensors-Seite. Manche Programme laufen offenbar problemlos (z.B. Disk-Benchmarks) --- kein einziges Problem bei mir mit keinem Proggi
- Die CPU/Board-Temperaturen sehen soweit gut aus. Die beiden Chips auf dem Board werden relativ warm, aber ich habe einen Lüfter drüber.
- Netzteil ist ein CoolerMaster SilentPro M500, was vorher mit einem P5Q-E problemlos lief
- Außerdem ist noch eine XFX HD5770 Grafikkarte auf dem Board und natürlich die CPU (Gulftown i7 980X)
- Speicher ist der hier: G.Skill RipJaws DIMM Kit 4GB PC3-12800U CL7-8-7-24 (DDR3-1600) (F3-12800CL7D-4GBRM)
- Die 7-Segment-Anzeige auf dem Board zeigt den Code AA an wenn es gebootet ist (unabhängig von der Anzahl der Speichermodule). Dieser Error-Code ist im Handbuch aber nicht mit aufgelistet. --- Das muss ich noch nachgucken, was bei mir steht
Quelle: HardwareLuxx.de Forum
Weiter in diesem Thread steht, dass es an den CPU-Pins auf dem Mainboard liegen könnte, die verbogen sind. Da ich mir gerade einen neuen CPU-Kühler gekauft habe, werde ich mir die Pins in den nächsten Tagen anschauen.
Betreibt einer von euch das Board mit 12 GB? Oder hat auch ähnliche Probleme?
Gruss LD
Hi! Ich betreibe das Board auch mit einem 920'er und 12GB Ram von G.skill (Ripjaws-Serie).
Bei einem von circa 5 neustarts erkennt er nur 8GB Ram (obwohl sich dann auch per CPU-Z alle 6 Rambänke
korrekt auslesen lassen).
Dann hilft aber ein Reset und ich habe die vollen 12GB. Kann dir gern mal meine BIOS-Einstellungen posten, wenn du magst.
Moin!
Mein Speicher ist baugleich. Gleiche Timings nur anderer Kühlkörper.
Komisch das auf der Alternate-Seite jemand das Tag "Cold start Bug" vergeben hat. :confused:
Hast du schon das neueste BIOS drauf? Hier zu finden: klick
Bios-Bilder im Anhang
Hi,
vielen Dank für deine Bilder!!! Ein Bios-Update war das erste, was ich gemacht habe.
Leider hat es bei mir nicht geklappt. Es wurden durchgehend 8 GiB erkannt, obwohl ich noch ein bisschen mit den Werten rumgespielt habe, nachdem ich deine Werte genauso übernommen hatte.
Morgen oder Samstag sollte mein CPU-Kühler kommen. Dann guck ich mal nach den Pins. Glaube aber weniger, dass bei mir ein Pin verbogen ist, wie bei dem auf Hardwareluxx.de, da mein System total stabil läuft und bei meinem Verweislink zu Hardwareluxx.de hatte derjenige zu seinem Speicherprob auch ein unstabiles System.
Die Garantie läuft noch bis Anfang 2012, zum Glück. Werde berichten, wie es weitergeht.
Thx nochmal, Jupph!
Habe auch das Board und ebenfalls 12 Gb!
Wurde bis jetzt IMMER voll erkannt.
Ram ist von TeamGorup.
Was mich jedoch wundert ist, wie heiss die Northbridge wird.
Im übertakteten Einstellungen zeigen verschiendene Tools Wert von über 120°C und tatsächlich fühlt sich der NB-Kühlkörper höllisch heiss an so das ich einen kleinen
Lüfter dran montiert habe. Das selbe fiel mir dann auch bei SB auf.
Achja eins noch:
Meldet bei euch "DR Debug" oder wie das heisst auch immer "AA" als Code?
Anfangs kann ich mich immer an eine "99" erinnern. Seit geraumer Zeit wird jedoch immer nur noch dieses "AA" direkt vor dem Start von Win. angezeigt und bleibt auch dann die ganze Zeit über bei dem Wert!
Hi,
gebracht hat mein Kühlerwechsel leider nichts.
Habe immer noch 8 GiB und beim Booten zeigt er mir "Triple-Channel". Kein Pin war verbogen. Hatte sogar eine Lupe mit Licht. Die Riegel vertauschen und alle neu reingemachen hatte auch nix gebracht.
Immer 8 GiB. Denke mal, dass es doch defekt ist.
Boah, das Mainboard zu tauschen ist stressig. Werde noch ein bisschen warten. Wenn ich aber dann 12 GiB erkennen sollte, melde ich mich wieder.
Cu
Weiss hier jemand ob dieses Board auch den I970 Gulftown 6 Core akzeptiert?
Auf der Verpackung ist nur der 980x angedeutet.
