Eine neue Version des RightMark CPU Clock Utilities ist erschienen. Die Version 2.30 hat folgendes Changelog.
Changes to this version include (in reverse chronological order):
- New official EULA added to the installation package (in English and Russian languages).
- Improved design of the main CPU P-states table editor.
- Minor UI fix of the Advanced CPU settings page, Intel Core 2 CPU families.
- RMClock Updater: Fixed update installation procedure to handle updating of all files of an update package.
- Brand new UI design of the main CPU P-states table editor.
- Fixed battery tray icon context menu availability at program startup.
- RMClock PRO: Added new event type: calendar (one time only, daily, weekly).
- Added monitoring graph grid color selection.
- Improved drawing of the monitoring graphs with custom graph background.
- Changed default text color of CPU frequency, CPU temperature and Battery tray icons.
- Improved drawing of CPU frequency and CPU temperature tray icons: no transparency color restriction.
- Improved efficiency of P-states transitions logic with official AMD K8 PST schemes.
- Modified "CpuTempOffset" registry tweak format to allow per-core CPU temperature offsets.
- Fixed applying of Intel EIST enable setting at startup.
- Fixed custom power plan not being created correctly on Windows Vista.
- Fixed per-profile OSPM settings applying on Windows Vista.
- Added desktop/mobile Intel Core2 CPU type selection.
- RMClock PRO: Fixed "OS power scheme changes" event handling on Windows Vista.
- RMClock PRO: Added new event type: enter into system standby.
- Improved handling of incompatible registry settings (prevents sudden loss of the module licenses).
- Added new AMD K8 NPT CPU default P-states tables.
- Added support for new Intel CPUs (Pentium Dual Core, Celeron 4xx, new Core 2 revisions).
- Added support for new Intel southbridges (ICH8M and ICH9 families).
- Added process/thread realtime priority setting (as a registry tweak).
- Added advanced logging options to the Settings page.
- Unlocked "Hard C4E" option for Intel Core 2 CPUs.
- Fixed incorrect determination of certain Intel Core 2 CPUs as "mobile" ones.
- Fixed "Apply changes?" confirmation dialog problem on main window hiding/restoring.
- Added "check-after-apply" for the advanced CPU settings at startup.
- Added option to enable/disable battery devices auto-detection on insertion/removal.
- Added settings to force battery life time and charge/discharge rate estimation.
- Implemented per-profile manage OSPM setting on Windows 2000/XP/Vista.
- Added full-featured support for OSPM setting management on Windows Vista.
- Disabled OSPM settings tab when OSPM management is disabled.
- Changed OSPM settings format and appearance on Windows 2000/XP.
- Fixed "Disable OS CPU power management" setting on Windows 2000/XP.
- Improved AMD K8 CPU core temperature reading routine.
- Implemented "interactive" Apply button behavior in all property pages.
- Fixed AC power/battery icon resources loading when localization DLLs are used.
- Added handling of "TaskbarCreated" message on Windows Vista.
- RMClock PRO: Added new event type: resume from standby.
- RMClock PRO: Added new event type: power status change.
- RMClock PRO: Added new event type: OS power scheme changes.
- RMClock PRO: Fixed inactivation of currently active actions on disabling with a check box.
- Added Celsius/Farenheit temperature display setting.
- Added option to skip CPUID check (as a registry tweak).
- Added showing/hiding of individual Monitoring graphs.
- Fixed Advanced CPU settings (AMD K8, Transmeta) context menu positions.
- Changed copyright of all modules to match official company name.
- Moved combo boxes items to the resource strings (aids in localization).
