CORSAIR_Marcus
Patch für die iCUE Version 4.19.191
Ihr könnt die aktuelle Version von iCUE hier downloaden.
Software Enhancements
- The ASUS Integration now has a lighting effect assigned by default
- Duplicate devices on the Home Page will no longer have numbers in their naming
- Graph scaling has been improved when adjusting the window size
- The home screen now has additional tooltips on hover
- Hover on the search bar will now display the correct text
- Resolved an issue with Action – Launch Application improperly defaulting to the first app
- Resolved an issue with the opacity slider for Scenes
- Resolved an issue with Key Assignments when switching between 2 different keys
- Macro Action – Action Repeat will no longer require users to input a higher value first
HID Product Enhancements
- SABRE PRO WIRELESS On-the-fly DPI now saves properly, if adjusted, before launching iCUE
- Improved the performance of the K65 MIINI RGB’s Mouse Speed through the FN key combination
- Resolved an issue with K55 RGB improperly showing duplicate tabs when changing the layout
- Resolved an issue with VIRTUOSO XT Lighting Effects on macOS M1 platforms
- Improved some minor issues related to NEXUS Macro Assignments
- G-Key Remap for NEXUS no longer defaults to the A key
DIY Product Enhancements
- DRAM lighting playback should no longer stops playing dynamically when configuring lighting effects
- LT100 tower numbering will now properly start with Tower 1 instead of Tower 2
- Resolved some text spacing issues with LT100’s Setup Wizard
- Resolved a scrolling text issue with ELITE LCD’s Fade Fill effect
- ELITE LCD image has been updated to show Liquid Temp instead of CPU Temp for the hardware screen lighting device image to match what is on the device
