Outdated Release Notes for iCUE 5.17.104
CORSAIR_Marcus
Hallo zusammen!
Hier könnt ihr die aktuellen Release Notes von iCUE einsehen, inkl. einem Link zum download.
iCUE 5.17.104 Issues Resolved
Known Issue:
We are aware of reports related to the Gigabyte Plugin not properly detecting motherboards in iCUE and we are investigating this issue with Gigabyte.
Software Enhancements
  • Resolved an issue that caused Cooling and Alert tabs to be missing on NVIDIA RTX devices
  • Due to the changes implemented in iCUE’s backend support, users will need to update their Stream Deck plugin – updates for the plugin will also resolve various issues including action assignments and iCUE LINK device detection
  • Resolved an issue with Govee that prevented right-clicking to change the name in the Device Settings tab
  • Removed aspect ratio selection for Murals to improve the Murals setup experience
  • Resolved an issue that prevented any “Press Dial” features from triggering on press
  • Resolved issues that caused the download progress bar to disappear while updating new modules
  • Resolved an issue that may prevent notifications from appearing after clicking on an info button
  • Deleting the Govee plugin will no longer cause issues with the Device Settings tab
DIY Product Enhancements
  • We have expanded the customization of our LCD screens for Hydro Coolers by allowing our users to overlay sensor data over any custom background
  • Resolved an issue with 5000T RGB that caused lighting effects selected on a 4-pin channel to also play on the 3-pin channel
  • HydroX cooling presets are now available in Device Memory Mode
  • Resolved an issue that prevented preset fan curves from saving in iCUE after a software restart
  • Resolved an issue that prevented the “Set LCD Frame Rate” slider from appearing properly
  • Arc lighting effect now properly plays on SP120 PRO and SP120 ELITE series fans
  • Resolved an issue with all cooling devices that prevented drag and drop from the cooling library
  • Resolved an issue that caused software-enabled lighting effects to appear under Device Memory Mode
  • Users will no longer be able to accidentally quit iCUE during any Setup Wizard process
  • Resolved an issue with COMMANDER CORE not importing and exporting profiles properly
HID Product Enhancements
  • Assignment buttons will no longer be disabled when unplugging a separate HID device
  • Resolved an issue that caused problems with key assignments after a firmware update
  • iCUE will no longer crash after changing lift height in Device Memory Mode
  • Resolved an issue that prevented K95 RGB PLATINUM from displaying indicators if the brightness was set to 0%
  • Resolved an issue with switching DPI stages on wireless mice after completing a new pairing process
  • Resolved an issue with K70 MAX when using tournament mode with Device Memory Mode
  • Resolved an issue with VIRTUOXO XT that caused mic boom LED issues when leaving the connectivity range of the receiver
